root/radiance/ray/src/rt/pmap.c
Fri Feb 19 02:10:35 2021 UTC (3 years, 3 months ago) by rschregle
CVS Tags: HEAD, rad5R4
Changes since 2.17: +15 -6 lines
Diff to previous 2.17 , to selected 2.6
Modified photon port rejection sampling in tracePhoton() to better handle
faceted photon ports by testing for identical material
Tue Dec 18 22:14:04 2018 UTC (5 years, 5 months ago) by rschregle
Changes since 2.16: +16 -14 lines
Diff to previous 2.16 , to selected 2.6
Fixed skewed volume photon scattering for gecc < 1 due to buggy sin(phi) in photonParticipate()
Wed Nov 21 19:33:30 2018 UTC (5 years, 6 months ago) by rschregle
Changes since 2.15: +24 -14 lines
Fixed potential infinite loop in photonParticipate() if photon leaves scene
Thu Jun 7 19:26:04 2018 UTC (6 years ago) by rschregle
Changes since 2.14: +20 -3 lines
Added photon distrib PID output to attach debugger
Tue Mar 20 19:55:33 2018 UTC (6 years, 2 months ago) by rschregle
Changes since 2.13: +4 -5 lines
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Mon Aug 14 21:12:10 2017 UTC (6 years, 9 months ago) by rschregle
Changes since 2.12: +170 -102 lines
Updated photon map code for Windows; no multproc or ooC for now
Mon Sep 26 20:19:30 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.11: +2 -230 lines
Pulled pmap routines needed during rendering from pmap.c into pmutil.c
Tue May 17 17:39:47 2016 UTC (8 years ago) by rschregle
Changes since 2.10: +471 -311 lines
Tue Sep 1 16:27:52 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.9: +2 -3 lines
Tue Aug 18 18:45:55 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.8: +5 -2 lines
Tue May 26 12:07:31 2015 UTC (9 years ago) by rschregle
Changes since 2.7: +12 -12 lines
distribPhotons() now gets its list of photon maps as parameter
Fri May 22 14:09:01 2015 UTC (9 years ago) by greg
Removed redundant photon map type parameter
Thu May 21 13:54:59 2015 UTC (9 years ago) by greg
Added calls to findmaterial() and simplified photon map shadow check
Fri May 8 13:20:23 2015 UTC (9 years, 1 month ago) by rschregle
Changes since 2.4: +5 -3 lines
Thu Apr 23 20:02:04 2015 UTC (9 years, 1 month ago) by rschregle
Changes since 2.3: +6 -4 lines
Check for stale photon map skipped if octree name not initialised
Wed Apr 22 20:28:16 2015 UTC (9 years, 1 month ago) by rschregle
Changes since 2.2: +18 -10 lines
Disabled use of SIGCONT if undefined (e.g. on WIN32), removed extra space in
rpict reports after biascomp stats
Tue Apr 21 19:16:51 2015 UTC (9 years, 1 month ago) by greg
Changes since 2.1: +3 -4 lines
Fixes for Windows and photon map
Tue Feb 24 19:39:26 2015 UTC (9 years, 3 months ago) by greg
Diff to selected 2.6
