root/radiance/ray/src/rt/pmap.c
Revision: 2.13
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 11 months ago) by rschregle
Changes since 2.12: +170 -102 lines
Updated photon map code for Windows; no multproc or ooC for now
2 static const char RCSid[] = "$Id: pmap.c,v 2.12 2016/09/26 20:19:30 greg Exp $";
4
5
6 /*
7 ======================================================================
8 Photon map main module
9
10 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11 (c) Fraunhofer Institute for Solar Energy Systems,
12 (c) Lucerne University of Applied Sciences and Arts,
13 supported by the Swiss National Science Foundation (SNSF, #147053)
14 ======================================================================
15
16 $Id: pmap.c,v 2.12 2016/09/26 20:19:30 greg Exp $
17 */
18
19
20 #include "pmap.h"
21 #include "pmapmat.h"
22 #include "pmapsrc.h"
23 #include "pmaprand.h"
24 #include "pmapio.h"
25 #include "pmapbias.h"
26 #include "pmapdiag.h"
27 #include "otypes.h"
28 #include <time.h>
29 #if NIX
30 #include <sys/stat.h>
31 #include <sys/mman.h>
32 #include <sys/wait.h>
33 #endif
34
35
36 void savePmaps (const PhotonMap **pmaps, int argc, char **argv)
37 {
38 unsigned t;
39
40 for (t = 0; t < NUM_PMAP_TYPES; t++) {
41 if (pmaps [t])
42 savePhotonMap(pmaps [t], pmaps [t] -> fileName, argc, argv);
43 }
44 }
45
46
47
48 static int photonParticipate (RAY *ray)
49 /* Trace photon through participating medium. Returns 1 if passed through,
50 or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */
51 {
52 int i;
53 RREAL cosTheta, cosPhi, du, dv;
54 const float cext = colorAvg(ray -> cext),
55 albedo = colorAvg(ray -> albedo);
56 FVECT u, v;
57 COLOR cvext;
58
59 /* Mean free distance until interaction with medium */
60 ray -> rmax = -log(pmapRandom(mediumState)) / cext;
61
62 while (!localhit(ray, &thescene)) {
63 setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]),
64 exp(-ray -> rmax * ray -> cext [1]),
65 exp(-ray -> rmax * ray -> cext [2]));
66
67 /* Modify ray color and normalise */
68 multcolor(ray -> rcol, cvext);
69 colorNorm(ray -> rcol);
70 VCOPY(ray -> rorg, ray -> rop);
71
72 if (albedo > FTINY && ray -> rlvl > 0)
73 /* Add to volume photon map */
74 newPhoton(volumePmap, ray);
75
76 /* Absorbed? */
77 if (pmapRandom(rouletteState) > albedo)
78 return 0;
79
80 /* Colour bleeding without attenuation (?) */
81 multcolor(ray -> rcol, ray -> albedo);
82 scalecolor(ray -> rcol, 1 / albedo);
83
84 /* Scatter photon */
85 cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1
86 : 1 / (2 * ray -> gecc) *
87 (1 + ray -> gecc * ray -> gecc -
88 (1 - ray -> gecc * ray -> gecc) /
89 (1 - ray -> gecc + 2 * ray -> gecc *
90 pmapRandom(scatterState)));
91
92 cosPhi = cos(2 * PI * pmapRandom(scatterState));
93 du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */
94 du *= cosPhi;
95 dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */
96
97 /* Get axes u & v perpendicular to photon direction */
98 i = 0;
99 do {
100 v [0] = v [1] = v [2] = 0;
101 v [i++] = 1;
102 fcross(u, v, ray -> rdir);
103 } while (normalize(u) < FTINY);
104 fcross(v, ray -> rdir, u);
105
106 for (i = 0; i < 3; i++)
107 ray -> rdir [i] = du * u [i] + dv * v [i] +
108 cosTheta * ray -> rdir [i];
109 ray -> rlvl++;
110 ray -> rmax = -log(pmapRandom(mediumState)) / cext;
111 }
112
113 setcolor(cvext, exp(-ray -> rot * ray -> cext [0]),
114 exp(-ray -> rot * ray -> cext [1]),
115 exp(-ray -> rot * ray -> cext [2]));
116
117 /* Modify ray color and normalise */
118 multcolor(ray -> rcol, cvext);
119 colorNorm(ray -> rcol);
120
121 /* Passed through medium */
122 return 1;
123 }
124
125
126
127 void tracePhoton (RAY *ray)
128 /* Follow photon as it bounces around... */
129 {
130 long mod;
131 OBJREC *mat, *port = NULL;
132
133 if (!ray -> parent) {
134 /* !!! PHOTON PORT REJECTION SAMPLING HACK: get photon port for
135 * !!! primary ray from ray -> ro, then reset the latter to NULL so
136 * !!! as not to interfere with localhit() */
137 port = ray -> ro;
138 ray -> ro = NULL;
139 }
140
141 if (ray -> rlvl > photonMaxBounce) {
142 #ifdef PMAP_RUNAWAY_WARN
143 error(WARNING, "runaway photon!");
144 #endif
145 return;
146 }
147
148 if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray))
149 return;
150
151 if (localhit(ray, &thescene)) {
152 mod = ray -> ro -> omod;
153
154 if (port && ray -> ro != port) {
155 /* !!! PHOTON PORT REJECTION SAMPLING HACK !!!
156 * Terminate photon if emitted from port without intersecting it;
157 * this can happen when the port's partitions extend beyond its
158 * actual geometry, e.g. with polygons. Since the total flux
159 * relayed by the port is based on the (in this case) larger
160 * partition area, it is overestimated; terminating these photons
161 * constitutes rejection sampling and thereby compensates any bias
162 * incurred by the overestimated flux. */
163 #ifdef PMAP_PORTREJECT_WARN
164 sprintf(errmsg, "photon outside port %s", ray -> ro -> oname);
165 error(WARNING, errmsg);
166 #endif
167 return;
168 }
169
170 if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) {
171 /* Transfer ray if modifier is VOID or clipped within antimatta */
172 RAY tray;
173 photonRay(ray, &tray, PMAP_XFER, NULL);
174 tracePhoton(&tray);
175 }
176 else {
177 /* Scatter for modifier material */
178 mat = objptr(mod);
179 photonScatter [mat -> otype] (mat, ray);
180 }
181 }
182 }
183
184
185
186 static void preComputeGlobal (PhotonMap *pmap)
187 /* Precompute irradiance from global photons for final gathering for
188 a random subset of finalGather * pmap -> numPhotons photons, and builds
189 the photon map, discarding the original photons. */
190 /* !!! NOTE: PRECOMPUTATION WITH OOC CURRENTLY WITHOUT CACHE !!! */
191 {
192 unsigned long i, numPreComp;
193 unsigned j;
194 PhotonIdx pIdx;
195 Photon photon;
196 RAY ray;
197 PhotonMap nuPmap;
198
199 repComplete = numPreComp = finalGather * pmap -> numPhotons;
200
201 if (verbose) {
202 sprintf(errmsg,
203 "\nPrecomputing irradiance for %ld global photons\n",
204 numPreComp);
205 eputs(errmsg);
206 #if NIX
207 fflush(stderr);
208 #endif
209 }
210
211 /* Copy photon map for precomputed photons */
212 memcpy(&nuPmap, pmap, sizeof(PhotonMap));
213
214 /* Zero counters, init new heap and extents */
215 nuPmap.numPhotons = 0;
216 initPhotonHeap(&nuPmap);
217
218 for (j = 0; j < 3; j++) {
219 nuPmap.minPos [j] = FHUGE;
220 nuPmap.maxPos [j] = -FHUGE;
221 }
222
223 /* Record start time, baby */
224 repStartTime = time(NULL);
225 #ifdef SIGCONT
226 signal(SIGCONT, pmapPreCompReport);
227 #endif
228 repProgress = 0;
229
230 photonRay(NULL, &ray, PRIMARY, NULL);
231 ray.ro = NULL;
232
233 for (i = 0; i < numPreComp; i++) {
234 /* Get random photon from stratified distribution in source heap to
235 * avoid duplicates and clustering */
236 pIdx = firstPhoton(pmap) +
237 (unsigned long)((i + pmapRandom(pmap -> randState)) /
238 finalGather);
239 getPhoton(pmap, pIdx, &photon);
240
241 /* Init dummy photon ray with intersection at photon position */
242 VCOPY(ray.rop, photon.pos);
243 for (j = 0; j < 3; j++)
244 ray.ron [j] = photon.norm [j] / 127.0;
245
246 /* Get density estimate at photon position */
247 photonDensity(pmap, &ray, ray.rcol);
248
249 /* Append photon to new heap from ray */
250 newPhoton(&nuPmap, &ray);
251
252 /* Update progress */
253 repProgress++;
254
255 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
256 pmapPreCompReport();
257 #ifdef SIGCONT
258 else signal(SIGCONT, pmapPreCompReport);
259 #endif
260 }
261
262 /* Flush heap */
263 flushPhotonHeap(&nuPmap);
264
265 #ifdef SIGCONT
266 signal(SIGCONT, SIG_DFL);
267 #endif
268
269 /* Trash original pmap, replace with precomputed one */
270 deletePhotons(pmap);
271 memcpy(pmap, &nuPmap, sizeof(PhotonMap));
272
273 if (verbose) {
274 eputs("\nRebuilding precomputed photon map\n");
275 #if NIX
276 fflush(stderr);
277 #endif
278 }
279
280 /* Rebuild underlying data structure, destroying heap */
281 buildPhotonMap(pmap, NULL, NULL, 1);
282 }
283
284
285
286 typedef struct {
287 unsigned long numPhotons [NUM_PMAP_TYPES],
288 numEmitted, numComplete;
289 } PhotonCnt;
290
291
292
293 void distribPhotons (PhotonMap **pmaps, unsigned numProc)
294 {
295 EmissionMap emap;
296 char errmsg2 [128], shmFname [PMAP_TMPFNLEN];
297 unsigned t, srcIdx, proc;
298 double totalFlux = 0;
299 int shmFile, stat, pid;
300 PhotonMap *pm;
301 PhotonCnt *photonCnt;
302
303 for (t = 0; t < NUM_PMAP_TYPES && !pmaps [t]; t++);
304
305 if (t >= NUM_PMAP_TYPES)
306 error(USER, "no photon maps defined in distribPhotons");
307
308 if (!nsources)
309 error(USER, "no light sources in distribPhotons");
310
311 /* ===================================================================
312 * INITIALISATION - Set up emission and scattering funcs
313 * =================================================================== */
314 emap.samples = NULL;
315 emap.maxPartitions = MAXSPART;
316 emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
317 if (!emap.partitions)
318 error(INTERNAL, "can't allocate source partitions in distribPhotons");
319
320 /* Initialise all defined photon maps */
321 for (t = 0; t < NUM_PMAP_TYPES; t++)
322 if (pmaps [t]) {
323 initPhotonMap(pmaps [t], t);
324 /* Open photon heapfile */
325 initPhotonHeap(pmaps [t]);
326 /* Per-subprocess target count */
327 pmaps [t] -> distribTarget /= numProc;
328
329 if (!pmaps [t] -> distribTarget)
330 error(INTERNAL, "no photons to distribute in distribPhotons");
331 }
332
333 initPhotonEmissionFuncs();
334 initPhotonScatterFuncs();
335
336 /* Get photon ports if specified */
337 if (ambincl == 1)
338 getPhotonPorts();
339
340 /* Get photon sensor modifiers */
341 getPhotonSensors(photonSensorList);
342
343 #if NIX
344 /* Set up shared mem for photon counters (zeroed by ftruncate) */
345 strcpy(shmFname, PMAP_TMPFNAME);
346 shmFile = mkstemp(shmFname);
347
348 if (shmFile < 0 || ftruncate(shmFile, sizeof(*photonCnt)) < 0)
349 error(SYSTEM, "failed shared mem init in distribPhotons");
350
351 photonCnt = mmap(NULL, sizeof(*photonCnt), PROT_READ | PROT_WRITE,
352 MAP_SHARED, shmFile, 0);
353
354 if (photonCnt == MAP_FAILED)
355 error(SYSTEM, "failed mapping shared memory in distribPhotons");
356 #else
357 /* Allocate photon counters statically on Windoze */
358 if (!(photonCnt = malloc(sizeof(PhotonCnt))))
359 error(SYSTEM, "failed trivial malloc in distribPhotons");
360 photonCnt -> numEmitted = photonCnt -> numComplete = 0;
361 #endif /* NIX */
362
363 if (verbose) {
364 sprintf(errmsg, "\nIntegrating flux from %d sources", nsources);
365
366 if (photonPorts) {
367 sprintf(errmsg2, " via %d ports", numPhotonPorts);
368 strcat(errmsg, errmsg2);
369 }
370
371 strcat(errmsg, "\n");
372 eputs(errmsg);
373 }
374
375 /* ===================================================================
376 * FLUX INTEGRATION - Get total photon flux from light sources
377 * =================================================================== */
378 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
379 unsigned portCnt = 0;
380 emap.src = source + srcIdx;
381
382 do { /* Need at least one iteration if no ports! */
383 emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
384 : NULL;
385 photonPartition [emap.src -> so -> otype] (&emap);
386
387 if (verbose) {
388 sprintf(errmsg, "\tIntegrating flux from source %s ",
389 source [srcIdx].so -> oname);
390
391 if (emap.port) {
392 sprintf(errmsg2, "via port %s ",
393 photonPorts [portCnt].so -> oname);
394 strcat(errmsg, errmsg2);
395 }
396
397 sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions);
398 strcat(errmsg, errmsg2);
399 eputs(errmsg);
400 #if NIX
401 fflush(stderr);
402 #endif
403 }
404
405 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
406 emap.partitionCnt++) {
407 initPhotonEmission(&emap, pdfSamples);
408 totalFlux += colorAvg(emap.partFlux);
409 }
410
411 portCnt++;
412 } while (portCnt < numPhotonPorts);
413 }
414
415 if (totalFlux < FTINY)
416 error(USER, "zero flux from light sources");
417
418 /* Record start time for progress reports */
419 repStartTime = time(NULL);
420
421 if (verbose) {
422 sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc);
423 eputs(errmsg);
424 }
425
426 /* MAIN LOOP */
427 for (proc = 0; proc < numProc; proc++) {
428 #if NIX
429 if (!(pid = fork())) {
430 /* SUBPROCESS ENTERS HERE; open and mmapped files inherited */
431 #else
432 if (1) {
433 /* No subprocess under Windoze */
434 #endif
435 /* Local photon counters for this subprocess */
436 unsigned passCnt = 0, prePassCnt = 0;
437 unsigned long lastNumPhotons [NUM_PMAP_TYPES];
438 unsigned long localNumEmitted = 0; /* Num photons emitted by this
439 subprocess alone */
440
441 /* Seed RNGs from PID for decorellated photon distribution */
442 pmapSeed(randSeed + proc, partState);
443 pmapSeed(randSeed + (proc + 1) % numProc, emitState);
444 pmapSeed(randSeed + (proc + 2) % numProc, cntState);
445 pmapSeed(randSeed + (proc + 3) % numProc, mediumState);
446 pmapSeed(randSeed + (proc + 4) % numProc, scatterState);
447 pmapSeed(randSeed + (proc + 5) % numProc, rouletteState);
448
449 for (t = 0; t < NUM_PMAP_TYPES; t++)
450 lastNumPhotons [t] = 0;
451
452 /* =============================================================
453 * 2-PASS PHOTON DISTRIBUTION
454 * Pass 1 (pre): emit fraction of target photon count
455 * Pass 2 (main): based on outcome of pass 1, estimate remaining
456 * number of photons to emit to approximate target
457 * count
458 * ============================================================= */
459 do {
460 double numEmit;
461
462 if (!passCnt) {
463 /* INIT PASS 1 */
464 /* Skip if no photons contributed after sufficient
465 * iterations; make it clear to user which photon maps are
466 * missing so (s)he can check geometry and materials */
467 if (++prePassCnt > maxPreDistrib) {
468 sprintf(errmsg, "proc %d: too many prepasses", proc);
469
470 for (t = 0; t < NUM_PMAP_TYPES; t++)
471 if (pmaps [t] && !pmaps [t] -> numPhotons) {
472 sprintf(errmsg2, ", no %s photons stored",
473 pmapName [t]);
474 strcat(errmsg, errmsg2);
475 }
476
477 error(USER, errmsg);
478 break;
479 }
480
481 /* Num to emit is fraction of minimum target count */
482 numEmit = FHUGE;
483
484 for (t = 0; t < NUM_PMAP_TYPES; t++)
485 if (pmaps [t])
486 numEmit = min(pmaps [t] -> distribTarget, numEmit);
487
488 numEmit *= preDistrib;
489 }
490 else {
491 /* INIT PASS 2 */
492 /* Based on the outcome of the predistribution we can now
493 * estimate how many more photons we have to emit for each
494 * photon map to meet its respective target count. This
495 * value is clamped to 0 in case the target has already been
496 * exceeded in the pass 1. */
497 double maxDistribRatio = 0;
498
499 /* Set the distribution ratio for each map; this indicates
500 * how many photons of each respective type are stored per
501 * emitted photon, and is used as probability for storing a
502 * photon by newPhoton(). Since this biases the photon
503 * density, newPhoton() promotes the flux of stored photons
504 * to compensate. */
505 for (t = 0; t < NUM_PMAP_TYPES; t++)
506 if ((pm = pmaps [t])) {
507 pm -> distribRatio = (double)pm -> distribTarget /
508 pm -> numPhotons - 1;
509
510 /* Check if photon map "overflowed", i.e. exceeded its
511 * target count in the prepass; correcting the photon
512 * flux via the distribution ratio is no longer
513 * possible, as no more photons of this type will be
514 * stored, so notify the user rather than deliver
515 * incorrect results. In future we should handle this
516 * more intelligently by using the photonFlux in each
517 * photon map to individually correct the flux after
518 * distribution. */
519 if (pm -> distribRatio <= FTINY) {
520 sprintf(errmsg, "%s photon map overflow in "
521 "prepass, reduce -apD", pmapName [t]);
522 error(INTERNAL, errmsg);
523 }
524
525 maxDistribRatio = max(pm -> distribRatio,
526 maxDistribRatio);
527 }
528
529 /* Normalise distribution ratios and calculate number of
530 * photons to emit in main pass */
531 for (t = 0; t < NUM_PMAP_TYPES; t++)
532 if ((pm = pmaps [t]))
533 pm -> distribRatio /= maxDistribRatio;
534
535 if ((numEmit = localNumEmitted * maxDistribRatio) < FTINY)
536 /* No photons left to distribute in main pass */
537 break;
538 }
539
540 /* Update shared completion counter for progreport by parent */
541 photonCnt -> numComplete += numEmit;
542
543 /* PHOTON DISTRIBUTION LOOP */
544 for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
545 unsigned portCnt = 0;
546 emap.src = source + srcIdx;
547
548 do { /* Need at least one iteration if no ports! */
549 emap.port = emap.src -> sflags & SDISTANT
550 ? photonPorts + portCnt : NULL;
551 photonPartition [emap.src -> so -> otype] (&emap);
552
553 if (verbose && !proc) {
554 /* Output from subproc 0 only to avoid race condition
555 * on console I/O */
556 if (!passCnt)
557 sprintf(errmsg, "\tPREPASS %d on source %s ",
558 prePassCnt, source [srcIdx].so -> oname);
559 else
560 sprintf(errmsg, "\tMAIN PASS on source %s ",
561 source [srcIdx].so -> oname);
562
563 if (emap.port) {
564 sprintf(errmsg2, "via port %s ",
565 photonPorts [portCnt].so -> oname);
566 strcat(errmsg, errmsg2);
567 }
568
569 sprintf(errmsg2, "(%lu partitions)\n",
570 emap.numPartitions);
571 strcat(errmsg, errmsg2);
572 eputs(errmsg);
573 #if NIX
574 fflush(stderr);
575 #endif
576 }
577
578 for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
579 emap.partitionCnt++) {
580 double partNumEmit;
581 unsigned long partEmitCnt;
582
583 /* Get photon origin within current source partishunn
584 * and build emission map */
585 photonOrigin [emap.src -> so -> otype] (&emap);
586 initPhotonEmission(&emap, pdfSamples);
587
588 /* Number of photons to emit from ziss partishunn --
589 * proportional to flux; photon ray weight and scalar
590 * flux are uniform (latter only varying in RGB). */
591 partNumEmit = numEmit * colorAvg(emap.partFlux) /
592 totalFlux;
593 partEmitCnt = (unsigned long)partNumEmit;
594
595 /* Probabilistically account for fractional photons */
596 if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
597 partEmitCnt++;
598
599 /* Update local and shared (global) emission counter */
600 photonCnt -> numEmitted += partEmitCnt;
601 localNumEmitted += partEmitCnt;
602
603 /* Integer counter avoids FP rounding errors during
604 * iteration */
605 while (partEmitCnt--) {
606 RAY photonRay;
607
608 /* Emit photon based on PDF and trace through scene
609 * until absorbed/leaked */
610 emitPhoton(&emap, &photonRay);
611 #if 1
612 if (emap.port)
613 /* !!! PHOTON PORT REJECTION SAMPLING HACK: set
614 * !!! photon port as fake hit object for
615 * !!! primary ray to check for intersection in
616 * !!! tracePhoton() */
617 photonRay.ro = emap.port -> so;
618 #endif
619 tracePhoton(&photonRay);
620 }
621
622 /* Update shared global photon count for each pmap */
623 for (t = 0; t < NUM_PMAP_TYPES; t++)
624 if (pmaps [t]) {
625 photonCnt -> numPhotons [t] +=
626 pmaps [t] -> numPhotons - lastNumPhotons [t];
627 lastNumPhotons [t] = pmaps [t] -> numPhotons;
628 }
629 #if !NIX
630 /* Synchronous progress report on Windoze */
631 if (!proc && photonRepTime > 0 &&
632 time(NULL) >= repLastTime + photonRepTime) {
633 repEmitted = repProgress = photonCnt -> numEmitted;
634 repComplete = photonCnt -> numComplete;
635 pmapDistribReport();
636 }
637 #endif
638 }
639
640 portCnt++;
641 } while (portCnt < numPhotonPorts);
642 }
643
644 for (t = 0; t < NUM_PMAP_TYPES; t++)
645 if (pmaps [t] && !pmaps [t] -> numPhotons) {
646 /* Double preDistrib in case a photon map is empty and
647 * redo pass 1 --> possibility of infinite loop for
648 * pathological scenes (e.g. absorbing materials) */
649 preDistrib *= 2;
650 break;
651 }
652
653 if (t >= NUM_PMAP_TYPES)
654 /* No empty photon maps found; now do pass 2 */
655 passCnt++;
656 } while (passCnt < 2);
657
658 /* Flush heap buffa for every pmap one final time;
659 * avoids potential data corruption! */
660 for (t = 0; t < NUM_PMAP_TYPES; t++)
661 if (pmaps [t]) {
662 flushPhotonHeap(pmaps [t]);
663 /* Heap file closed automatically on exit
664 fclose(pmaps [t] -> heap); */
665 #ifdef DEBUG_PMAP
666 sprintf(errmsg, "Proc %d: total %ld photons\n", proc,
667 pmaps [t] -> numPhotons);
668 eputs(errmsg);
669 #endif
670 }
671 #if NIX
672 /* Terminate subprocess */
673 exit(0);
674 #endif
675 }
676 else if (pid < 0)
677 error(SYSTEM, "failed to fork subprocess in distribPhotons");
678 }
679
680 #if NIX
681 /* PARENT PROCESS CONTINUES HERE */
682 #ifdef SIGCONT
683 /* Enable progress report signal handler */
684 signal(SIGCONT, pmapDistribReport);
685 #endif
686 /* Wait for subprocesses complete while reporting progress */
687 proc = numProc;
688 while (proc) {
689 while (waitpid(-1, &stat, WNOHANG) > 0) {
690 /* Subprocess exited; check status */
691 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
692 error(USER, "failed photon distribution");
693
694 --proc;
695 }
696
697 /* Nod off for a bit and update progress */
698 sleep(1);
699
700 /* Asynchronous progress report from shared subprocess counters */
701 repEmitted = repProgress = photonCnt -> numEmitted;
702 repComplete = photonCnt -> numComplete;
703
704 repProgress = repComplete = 0;
705 for (t = 0; t < NUM_PMAP_TYPES; t++)
706 if ((pm = pmaps [t])) {
707 /* Get global photon count from shmem updated by subprocs */
708 repProgress += pm -> numPhotons = photonCnt -> numPhotons [t];
709 repComplete += pm -> distribTarget;
710 }
711 repComplete *= numProc;
712
713 if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
714 pmapDistribReport();
715 #ifdef SIGCONT
716 else signal(SIGCONT, pmapDistribReport);
717 #endif
718 }
719 #endif /* NIX */
720
721 /* ===================================================================
722 * POST-DISTRIBUTION - Set photon flux and build data struct for photon
723 * storage, etc.
724 * =================================================================== */
725 #ifdef SIGCONT
726 /* Reset signal handler */
727 signal(SIGCONT, SIG_DFL);
728 #endif
729 free(emap.samples);
730
731 /* Set photon flux */
732 totalFlux /= photonCnt -> numEmitted;
733 #if NIX
734 /* Photon counters no longer needed, unmap shared memory */
735 munmap(photonCnt, sizeof(*photonCnt));
736 close(shmFile);
737 unlink(shmFname);
738 #else
739 free(photonCnt);
740 #endif
741 if (verbose)
742 eputs("\n");
743
744 for (t = 0; t < NUM_PMAP_TYPES; t++)
745 if (pmaps [t]) {
746 if (verbose) {
747 sprintf(errmsg, "Building %s photon map\n", pmapName [t]);
748 eputs(errmsg);
749 #if NIX
750 fflush(stderr);
751 #endif
752 }
753
754 /* Build underlying data structure; heap is destroyed */
755 buildPhotonMap(pmaps [t], &totalFlux, NULL, numProc);
756 }
757
758 /* Precompute photon irradiance if necessary */
759 if (preCompPmap) {
760 if (verbose)
761 eputs("\n");
762 preComputeGlobal(preCompPmap);
763 }
764
765 if (verbose)
766 eputs("\n");
767 }
