1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pmap.c,v 4.33.1.10 2016/05/11 12:50:54 taschreg Exp taschreg $"; |
3 |
#endif |
4 |
5 |
6 |
7 |
Photon map main module |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Fraunhofer Institute for Solar Energy Systems, |
11 |
(c) Lucerne University of Applied Sciences and Arts, |
12 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
13 |
14 |
15 |
$Id: pmap.c,v 4.33.1.10 2016/05/11 12:50:54 taschreg Exp taschreg $ |
16 |
17 |
18 |
19 |
20 |
#include "pmap.h" |
21 |
#include "pmapmat.h" |
22 |
#include "pmapsrc.h" |
23 |
#include "pmaprand.h" |
24 |
#include "pmapio.h" |
25 |
#include "pmapbias.h" |
26 |
#include "pmapdiag.h" |
27 |
#include "otypes.h" |
28 |
#include <time.h> |
29 |
#include <sys/stat.h> |
30 |
#include <sys/mman.h> |
31 |
#include <sys/wait.h> |
32 |
33 |
#define PMAP_REV "$Revision: 4.33.1.10 $" |
34 |
35 |
36 |
extern char *octname; |
37 |
38 |
39 |
40 |
/* Photon map lookup functions per type */ |
41 |
void (*pmapLookup [NUM_PMAP_TYPES])(PhotonMap*, RAY*, COLOR) = { |
42 |
photonDensity, photonPreCompDensity, photonDensity, volumePhotonDensity, |
43 |
photonDensity, NULL |
44 |
45 |
46 |
47 |
48 |
void colorNorm (COLOR c) |
49 |
/* Normalise colour channels to average of 1 */ |
50 |
51 |
const float avg = colorAvg(c); |
52 |
53 |
if (!avg) |
54 |
return; |
55 |
56 |
c [0] /= avg; |
57 |
c [1] /= avg; |
58 |
c [2] /= avg; |
59 |
60 |
61 |
62 |
63 |
void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *parm) |
64 |
65 |
unsigned t; |
66 |
struct stat octstat, pmstat; |
67 |
PhotonMap *pm; |
68 |
PhotonMapType type; |
69 |
70 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
71 |
if (setPmapParam(&pm, parm + t)) { |
72 |
/* Check if photon map newer than octree */ |
73 |
if (pm -> fileName && octname && |
74 |
!stat(pm -> fileName, &pmstat) && !stat(octname, &octstat) && |
75 |
octstat.st_mtime > pmstat.st_mtime) { |
76 |
sprintf(errmsg, "photon map in file %s may be stale", |
77 |
pm -> fileName); |
78 |
error(USER, errmsg); |
79 |
80 |
81 |
/* Load photon map from file and get its type */ |
82 |
if ((type = loadPhotonMap(pm, pm -> fileName)) == PMAP_TYPE_NONE) |
83 |
error(USER, "failed loading photon map"); |
84 |
85 |
/* Assign to appropriate photon map type (deleting previously |
86 |
* loaded photon map of same type if necessary) */ |
87 |
if (pmaps [type]) { |
88 |
deletePhotons(pmaps [type]); |
89 |
free(pmaps [type]); |
90 |
91 |
pmaps [type] = pm; |
92 |
93 |
/* Check for invalid density estimate bandwidth */ |
94 |
if (pm -> maxGather > pm -> numPhotons) { |
95 |
error(WARNING, "adjusting density estimate bandwidth"); |
96 |
pm -> minGather = pm -> maxGather = pm -> numPhotons; |
97 |
98 |
99 |
100 |
101 |
102 |
103 |
void savePmaps (const PhotonMap **pmaps, int argc, char **argv) |
104 |
105 |
unsigned t; |
106 |
107 |
for (t = 0; t < NUM_PMAP_TYPES; t++) { |
108 |
if (pmaps [t]) |
109 |
savePhotonMap(pmaps [t], pmaps [t] -> fileName, argc, argv); |
110 |
111 |
112 |
113 |
114 |
115 |
void cleanUpPmaps (PhotonMap **pmaps) |
116 |
117 |
unsigned t; |
118 |
119 |
120 |
if (pmaps [t]) { |
121 |
deletePhotons(pmaps [t]); |
122 |
free(pmaps [t]); |
123 |
124 |
125 |
126 |
127 |
128 |
129 |
static int photonParticipate (RAY *ray) |
130 |
/* Trace photon through participating medium. Returns 1 if passed through, |
131 |
or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */ |
132 |
133 |
int i; |
134 |
RREAL cosTheta, cosPhi, du, dv; |
135 |
const float cext = colorAvg(ray -> cext), |
136 |
albedo = colorAvg(ray -> albedo); |
137 |
FVECT u, v; |
138 |
COLOR cvext; |
139 |
140 |
/* Mean free distance until interaction with medium */ |
141 |
ray -> rmax = -log(pmapRandom(mediumState)) / cext; |
142 |
143 |
while (!localhit(ray, &thescene)) { |
144 |
setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]), |
145 |
exp(-ray -> rmax * ray -> cext [1]), |
146 |
exp(-ray -> rmax * ray -> cext [2])); |
147 |
148 |
/* Modify ray color and normalise */ |
149 |
multcolor(ray -> rcol, cvext); |
150 |
colorNorm(ray -> rcol); |
151 |
VCOPY(ray -> rorg, ray -> rop); |
152 |
153 |
if (albedo > FTINY && ray -> rlvl > 0) |
154 |
/* Add to volume photon map */ |
155 |
newPhoton(volumePmap, ray); |
156 |
157 |
/* Absorbed? */ |
158 |
if (pmapRandom(rouletteState) > albedo) |
159 |
return 0; |
160 |
161 |
/* Colour bleeding without attenuation (?) */ |
162 |
multcolor(ray -> rcol, ray -> albedo); |
163 |
scalecolor(ray -> rcol, 1 / albedo); |
164 |
165 |
/* Scatter photon */ |
166 |
cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1 |
167 |
: 1 / (2 * ray -> gecc) * |
168 |
(1 + ray -> gecc * ray -> gecc - |
169 |
(1 - ray -> gecc * ray -> gecc) / |
170 |
(1 - ray -> gecc + 2 * ray -> gecc * |
171 |
pmapRandom(scatterState))); |
172 |
173 |
cosPhi = cos(2 * PI * pmapRandom(scatterState)); |
174 |
du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */ |
175 |
du *= cosPhi; |
176 |
dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */ |
177 |
178 |
/* Get axes u & v perpendicular to photon direction */ |
179 |
i = 0; |
180 |
do { |
181 |
v [0] = v [1] = v [2] = 0; |
182 |
v [i++] = 1; |
183 |
fcross(u, v, ray -> rdir); |
184 |
} while (normalize(u) < FTINY); |
185 |
fcross(v, ray -> rdir, u); |
186 |
187 |
for (i = 0; i < 3; i++) |
188 |
ray -> rdir [i] = du * u [i] + dv * v [i] + |
189 |
cosTheta * ray -> rdir [i]; |
190 |
ray -> rlvl++; |
191 |
192 |
193 |
194 |
setcolor(cvext, exp(-ray -> rot * ray -> cext [0]), |
195 |
exp(-ray -> rot * ray -> cext [1]), |
196 |
exp(-ray -> rot * ray -> cext [2])); |
197 |
198 |
199 |
200 |
201 |
202 |
/* Passed through medium */ |
203 |
return 1; |
204 |
205 |
206 |
207 |
208 |
void tracePhoton (RAY *ray) |
209 |
/* Follow photon as it bounces around... */ |
210 |
211 |
long mod; |
212 |
OBJREC* mat; |
213 |
214 |
if (ray -> rlvl > photonMaxBounce) { |
215 |
#ifdef PMAP_RUNAWAY_WARN |
216 |
error(WARNING, "runaway photon!"); |
217 |
#endif |
218 |
return; |
219 |
220 |
221 |
if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray)) |
222 |
return; |
223 |
224 |
if (localhit(ray, &thescene)) { |
225 |
mod = ray -> ro -> omod; |
226 |
227 |
if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) { |
228 |
/* Transfer ray if modifier is VOID or clipped within antimatta */ |
229 |
RAY tray; |
230 |
photonRay(ray, &tray, PMAP_XFER, NULL); |
231 |
tracePhoton(&tray); |
232 |
233 |
else { |
234 |
/* Scatter for modifier material */ |
235 |
mat = objptr(mod); |
236 |
photonScatter [mat -> otype] (mat, ray); |
237 |
238 |
239 |
240 |
241 |
242 |
243 |
static void preComputeGlobal (PhotonMap *pmap) |
244 |
/* Precompute irradiance from global photons for final gathering for |
245 |
a random subset of finalGather * pmap -> numPhotons photons, and builds |
246 |
the photon map, discarding the original photons. */ |
247 |
/* !!! NOTE: PRECOMPUTATION WITH OOC CURRENTLY WITHOUT CACHE !!! */ |
248 |
249 |
unsigned long i, numPreComp; |
250 |
unsigned j; |
251 |
PhotonIdx pIdx; |
252 |
Photon photon; |
253 |
RAY ray; |
254 |
PhotonMap nuPmap; |
255 |
256 |
repComplete = numPreComp = finalGather * pmap -> numPhotons; |
257 |
258 |
if (photonRepTime) { |
259 |
sprintf(errmsg, "Precomputing irradiance for %ld global photons...\n", |
260 |
numPreComp); |
261 |
eputs(errmsg); |
262 |
fflush(stderr); |
263 |
264 |
265 |
/* Copy photon map for precomputed photons */ |
266 |
memcpy(&nuPmap, pmap, sizeof(PhotonMap)); |
267 |
268 |
/* Zero counters, init new heap and extents */ |
269 |
nuPmap.numPhotons = 0; |
270 |
initPhotonHeap(&nuPmap); |
271 |
272 |
for (j = 0; j < 3; j++) { |
273 |
nuPmap.minPos [j] = FHUGE; |
274 |
nuPmap.maxPos [j] = -FHUGE; |
275 |
276 |
277 |
/* Record start time, baby */ |
278 |
repStartTime = time(NULL); |
279 |
#ifdef SIGCONT |
280 |
signal(SIGCONT, pmapPreCompReport); |
281 |
#endif |
282 |
repProgress = 0; |
283 |
284 |
photonRay(NULL, &ray, PRIMARY, NULL); |
285 |
ray.ro = NULL; |
286 |
287 |
for (i = 0; i < numPreComp; i++) { |
288 |
/* Get random photon from stratified distribution in source heap to |
289 |
* avoid duplicates and clutering */ |
290 |
pIdx = firstPhoton(pmap) + |
291 |
(unsigned long)((i + pmapRandom(pmap -> randState)) / |
292 |
finalGather); |
293 |
getPhoton(pmap, pIdx, &photon); |
294 |
295 |
/* Init dummy photon ray with intersection at photon position */ |
296 |
VCOPY(ray.rop, photon.pos); |
297 |
for (j = 0; j < 3; j++) |
298 |
ray.ron [j] = photon.norm [j] / 127.0; |
299 |
300 |
/* Get density estimate at photon position */ |
301 |
photonDensity(pmap, &ray, ray.rcol); |
302 |
303 |
/* Append photon to new heap from ray */ |
304 |
newPhoton(&nuPmap, &ray); |
305 |
306 |
/* Update progress */ |
307 |
repProgress++; |
308 |
309 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime) |
310 |
pmapPreCompReport(); |
311 |
#ifdef SIGCONT |
312 |
else signal(SIGCONT, pmapPreCompReport); |
313 |
#endif |
314 |
315 |
316 |
/* Flush heap */ |
317 |
flushPhotonHeap(&nuPmap); |
318 |
319 |
#ifdef SIGCONT |
320 |
signal(SIGCONT, SIG_DFL); |
321 |
#endif |
322 |
323 |
/* Trash original pmap, replace with precomputed one */ |
324 |
deletePhotons(pmap); |
325 |
memcpy(pmap, &nuPmap, sizeof(PhotonMap)); |
326 |
327 |
328 |
eputs("Rebuilding precomputed photon map...\n"); |
329 |
fflush(stderr); |
330 |
331 |
332 |
/* Rebuild underlying data structure, destroying heap */ |
333 |
buildPhotonMap(pmap, NULL, NULL, 1); |
334 |
335 |
336 |
337 |
338 |
typedef struct { |
339 |
unsigned long numPhotons [NUM_PMAP_TYPES], |
340 |
numEmitted, numComplete; |
341 |
} PhotonCnt; |
342 |
343 |
344 |
345 |
void distribPhotons (PhotonMap **pmaps, unsigned numProc) |
346 |
347 |
EmissionMap emap; |
348 |
char errmsg2 [128], shmFname [255]; |
349 |
unsigned t, srcIdx, proc; |
350 |
double totalFlux = 0; |
351 |
int shmFile, stat, pid; |
352 |
PhotonMap *pm; |
353 |
PhotonCnt *photonCnt; |
354 |
355 |
for (t = 0; t < NUM_PMAP_TYPES && !pmaps [t]; t++); |
356 |
357 |
if (t >= NUM_PMAP_TYPES) |
358 |
error(USER, "no photon maps defined in distribPhotons"); |
359 |
360 |
if (!nsources) |
361 |
error(USER, "no light sources in distribPhotons"); |
362 |
363 |
364 |
* INITIALISATION - Set up emission and scattering funcs |
365 |
366 |
emap.samples = NULL; |
367 |
emap.maxPartitions = MAXSPART; |
368 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1); |
369 |
if (!emap.partitions) |
370 |
error(INTERNAL, "can't allocate source partitions in distribPhotons"); |
371 |
372 |
/* Initialise all defined photon maps */ |
373 |
374 |
if (pmaps [t]) { |
375 |
initPhotonMap(pmaps [t], t); |
376 |
/* Open photon heapfile */ |
377 |
initPhotonHeap(pmaps [t]); |
378 |
/* Per-subprocess target count */ |
379 |
pmaps [t] -> distribTarget /= numProc; |
380 |
381 |
382 |
initPhotonEmissionFuncs(); |
383 |
initPhotonScatterFuncs(); |
384 |
385 |
/* Get photon ports if specified */ |
386 |
if (ambincl == 1) |
387 |
getPhotonPorts(); |
388 |
389 |
/* Get photon sensor modifiers */ |
390 |
getPhotonSensors(photonSensorList); |
391 |
392 |
/* Set up shared mem for photon counters (zeroed by ftruncate) */ |
393 |
#if 0 |
394 |
snprintf(shmFname, 255, PMAP_SHMFNAME, getpid()); |
395 |
shmFile = shm_open(shmFname, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR); |
396 |
#else |
397 |
strcpy(shmFname, PMAP_SHMFNAME); |
398 |
shmFile = mkstemp(shmFname); |
399 |
#endif |
400 |
401 |
if (shmFile < 0) |
402 |
error(SYSTEM, "failed opening shared memory file in distribPhotons"); |
403 |
404 |
if (ftruncate(shmFile, sizeof(*photonCnt)) < 0) |
405 |
error(SYSTEM, "failed setting shared memory size in distribPhotons"); |
406 |
407 |
photonCnt = mmap(NULL, sizeof(*photonCnt), PROT_READ | PROT_WRITE, |
408 |
MAP_SHARED, shmFile, 0); |
409 |
410 |
if (photonCnt == MAP_FAILED) |
411 |
error(SYSTEM, "failed mapping shared memory in distribPhotons"); |
412 |
413 |
if (photonRepTime) |
414 |
eputs("\n"); |
415 |
416 |
417 |
* FLUX INTEGRATION - Get total photon flux from light sources |
418 |
419 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) { |
420 |
unsigned portCnt = 0; |
421 |
emap.src = source + srcIdx; |
422 |
423 |
do { /* Need at least one iteration if no ports! */ |
424 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt |
425 |
: NULL; |
426 |
photonPartition [emap.src -> so -> otype] (&emap); |
427 |
428 |
429 |
sprintf(errmsg, "Integrating flux from source %s ", |
430 |
source [srcIdx].so -> oname); |
431 |
432 |
if (emap.port) { |
433 |
sprintf(errmsg2, "via port %s ", |
434 |
photonPorts [portCnt].so -> oname); |
435 |
strcat(errmsg, errmsg2); |
436 |
437 |
438 |
sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions); |
439 |
440 |
eputs(errmsg); |
441 |
fflush(stderr); |
442 |
443 |
444 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions; |
445 |
emap.partitionCnt++) { |
446 |
initPhotonEmission(&emap, pdfSamples); |
447 |
totalFlux += colorAvg(emap.partFlux); |
448 |
449 |
450 |
portCnt++; |
451 |
} while (portCnt < numPhotonPorts); |
452 |
453 |
454 |
if (totalFlux < FTINY) |
455 |
error(USER, "zero flux from light sources"); |
456 |
457 |
/* MAIN LOOP */ |
458 |
for (proc = 0; proc < numProc; proc++) { |
459 |
if (!(pid = fork())) { |
460 |
/* SUBPROCESS ENTERS HERE. |
461 |
All opened and memory mapped files are inherited */ |
462 |
unsigned passCnt = 0, prePassCnt = 0; |
463 |
unsigned long lastNumPhotons [NUM_PMAP_TYPES]; |
464 |
unsigned long localNumEmitted = 0; /* Num photons emitted by this |
465 |
subprocess alone */ |
466 |
467 |
/* Seed RNGs from PID for decorellated photon distribution */ |
468 |
pmapSeed(randSeed + proc, partState); |
469 |
pmapSeed(randSeed + proc, emitState); |
470 |
pmapSeed(randSeed + proc, cntState); |
471 |
pmapSeed(randSeed + proc, mediumState); |
472 |
pmapSeed(randSeed + proc, scatterState); |
473 |
pmapSeed(randSeed + proc, rouletteState); |
474 |
475 |
476 |
lastNumPhotons [t] = 0; |
477 |
478 |
479 |
* 2-PASS PHOTON DISTRIBUTION |
480 |
* Pass 1 (pre): emit fraction of target photon count |
481 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining |
482 |
* number of photons to emit to approximate target |
483 |
* count |
484 |
485 |
do { |
486 |
double numEmit; |
487 |
488 |
if (!passCnt) { |
489 |
/* INIT PASS 1 */ |
490 |
/* Skip if no photons contributed after sufficient |
491 |
* iterations; make it clear to user which photon maps are |
492 |
* missing so (s)he can check geometry and materials */ |
493 |
if (++prePassCnt > maxPreDistrib) { |
494 |
sprintf(errmsg, |
495 |
"proc %d, source %s: too many prepasses", |
496 |
proc, source [srcIdx].so -> oname); |
497 |
498 |
499 |
if (pmaps [t] && !pmaps [t] -> numPhotons) { |
500 |
sprintf(errmsg2, ", no %s photons stored", |
501 |
pmapName [t]); |
502 |
503 |
504 |
505 |
506 |
break; |
507 |
508 |
509 |
/* Num to emit is fraction of minimum target count */ |
510 |
numEmit = FHUGE; |
511 |
512 |
513 |
if (pmaps [t]) |
514 |
numEmit = min(pmaps [t] -> distribTarget, numEmit); |
515 |
516 |
numEmit *= preDistrib; |
517 |
518 |
else { |
519 |
/* INIT PASS 2 */ |
520 |
/* Based on the outcome of the predistribution we can now |
521 |
* estimate how many more photons we have to emit for each |
522 |
* photon map to meet its respective target count. This |
523 |
* value is clamped to 0 in case the target has already been |
524 |
* exceeded in the pass 1. */ |
525 |
double maxDistribRatio = 0; |
526 |
527 |
/* Set the distribution ratio for each map; this indicates |
528 |
* how many photons of each respective type are stored per |
529 |
* emitted photon, and is used as probability for storing a |
530 |
* photon by newPhoton(). Since this biases the photon |
531 |
* density, newPhoton() promotes the flux of stored photons |
532 |
* to compensate. */ |
533 |
534 |
if ((pm = pmaps [t])) { |
535 |
pm -> distribRatio = (double)pm -> distribTarget / |
536 |
pm -> numPhotons - 1; |
537 |
538 |
/* Check if photon map "overflowed", i.e. exceeded its |
539 |
* target count in the prepass; correcting the photon |
540 |
* flux via the distribution ratio is no longer |
541 |
* possible, as no more photons of this type will be |
542 |
* stored, so notify the user rather than deliver |
543 |
* incorrect results. In future we should handle this |
544 |
* more intelligently by using the photonFlux in each |
545 |
* photon map to individually correct the flux after |
546 |
* distribution. */ |
547 |
if (pm -> distribRatio <= FTINY) { |
548 |
sprintf(errmsg, "%s photon map overflow in " |
549 |
"prepass, reduce -apD", pmapName [t]); |
550 |
error(INTERNAL, errmsg); |
551 |
552 |
553 |
maxDistribRatio = max(pm -> distribRatio, |
554 |
maxDistribRatio); |
555 |
556 |
557 |
/* Normalise distribution ratios and calculate number of |
558 |
* photons to emit in main pass */ |
559 |
560 |
if ((pm = pmaps [t])) |
561 |
pm -> distribRatio /= maxDistribRatio; |
562 |
563 |
if ((numEmit = localNumEmitted * maxDistribRatio) < FTINY) |
564 |
/* No photons left to distribute in main pass */ |
565 |
break; |
566 |
567 |
568 |
/* Update shared completion counter for prog.report by parent */ |
569 |
photonCnt -> numComplete += numEmit; |
570 |
571 |
/* PHOTON DISTRIBUTION LOOP */ |
572 |
573 |
574 |
575 |
576 |
577 |
emap.port = emap.src -> sflags & SDISTANT |
578 |
? photonPorts + portCnt : NULL; |
579 |
580 |
581 |
if (photonRepTime && !proc) { |
582 |
if (!passCnt) |
583 |
sprintf(errmsg, "PREPASS %d on source %s ", |
584 |
prePassCnt, source [srcIdx].so -> oname); |
585 |
else |
586 |
sprintf(errmsg, "MAIN PASS on source %s ", |
587 |
588 |
589 |
if (emap.port) { |
590 |
591 |
592 |
593 |
594 |
595 |
sprintf(errmsg2, "(%lu partitions)\n", |
596 |
597 |
598 |
eputs(errmsg); |
599 |
fflush(stderr); |
600 |
601 |
602 |
603 |
604 |
double partNumEmit; |
605 |
unsigned long partEmitCnt; |
606 |
607 |
/* Get photon origin within current source partishunn |
608 |
* and build emission map */ |
609 |
photonOrigin [emap.src -> so -> otype] (&emap); |
610 |
611 |
612 |
/* Number of photons to emit from ziss partishunn -- |
613 |
* proportional to flux; photon ray weight and scalar |
614 |
* flux are uniform (the latter only varying in RGB). |
615 |
616 |
partNumEmit = numEmit * colorAvg(emap.partFlux) / |
617 |
totalFlux; |
618 |
partEmitCnt = (unsigned long)partNumEmit; |
619 |
620 |
/* Probabilistically account for fractional photons */ |
621 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt) |
622 |
partEmitCnt++; |
623 |
624 |
/* Update local and shared (global) emission counter */ |
625 |
photonCnt -> numEmitted += partEmitCnt; |
626 |
localNumEmitted += partEmitCnt; |
627 |
628 |
/* Integer counter avoids FP rounding errors during |
629 |
* iteration */ |
630 |
while (partEmitCnt--) { |
631 |
RAY photonRay; |
632 |
633 |
/* Emit photon based on PDF and trace through scene |
634 |
* until absorbed/leaked */ |
635 |
emitPhoton(&emap, &photonRay); |
636 |
tracePhoton(&photonRay); |
637 |
638 |
639 |
/* Update shared global photon count for each pmap */ |
640 |
641 |
if (pmaps [t]) { |
642 |
photonCnt -> numPhotons [t] += |
643 |
pmaps [t] -> numPhotons - lastNumPhotons [t]; |
644 |
lastNumPhotons [t] = pmaps [t] -> numPhotons; |
645 |
646 |
647 |
648 |
portCnt++; |
649 |
650 |
651 |
652 |
653 |
654 |
/* Double preDistrib in case a photon map is empty and |
655 |
* redo pass 1 --> possibility of infinite loop for |
656 |
* pathological scenes (e.g. absorbing materials) */ |
657 |
preDistrib *= 2; |
658 |
break; |
659 |
660 |
661 |
if (t >= NUM_PMAP_TYPES) { |
662 |
/* No empty photon maps found; now do pass 2 */ |
663 |
passCnt++; |
664 |
#if 0 |
665 |
666 |
eputs("\n"); |
667 |
#endif |
668 |
669 |
} while (passCnt < 2); |
670 |
671 |
/* Unmap shared photon counters */ |
672 |
#if 0 |
673 |
munmap(photonCnt, sizeof(*photonCnt)); |
674 |
close(shmFile); |
675 |
#endif |
676 |
677 |
/* Flush heap buffa for every pmap one final time; this is required |
678 |
* to prevent data corruption! */ |
679 |
680 |
if (pmaps [t]) { |
681 |
#if 0 |
682 |
eputs("Final flush\n"); |
683 |
#endif |
684 |
flushPhotonHeap(pmaps [t]); |
685 |
fclose(pmaps [t] -> heap); |
686 |
#ifdef DEBUG_PMAP |
687 |
sprintf(errmsg, "Proc %d: total %ld photons\n", getpid(), |
688 |
pmaps [t] -> numPhotons); |
689 |
eputs(errmsg); |
690 |
#endif |
691 |
692 |
693 |
exit(0); |
694 |
695 |
else if (pid < 0) |
696 |
error(SYSTEM, "failed to fork subprocess in distribPhotons"); |
697 |
698 |
699 |
/* PARENT PROCESS CONTINUES HERE */ |
700 |
/* Record start time and enable progress report signal handler */ |
701 |
702 |
#ifdef SIGCONT |
703 |
signal(SIGCONT, pmapDistribReport); |
704 |
#endif |
705 |
706 |
707 |
eputs("\n"); |
708 |
709 |
/* Wait for subprocesses to complete while reporting progress */ |
710 |
proc = numProc; |
711 |
while (proc) { |
712 |
while (waitpid(-1, &stat, WNOHANG) > 0) { |
713 |
/* Subprocess exited; check status */ |
714 |
if (!WIFEXITED(stat) || WEXITSTATUS(stat)) |
715 |
error(USER, "failed photon distribution"); |
716 |
717 |
--proc; |
718 |
719 |
720 |
/* Nod off for a bit and update progress */ |
721 |
sleep(1); |
722 |
/* Update progress report from shared subprocess counters */ |
723 |
repEmitted = repProgress = photonCnt -> numEmitted; |
724 |
repComplete = photonCnt -> numComplete; |
725 |
726 |
727 |
728 |
#if 0 |
729 |
/* Get photon count from heapfile size for progress update */ |
730 |
fseek(pm -> heap, 0, SEEK_END); |
731 |
pm -> numPhotons = ftell(pm -> heap) / sizeof(Photon); */ |
732 |
#else |
733 |
/* Get global photon count from shmem updated by subprocs */ |
734 |
pm -> numPhotons = photonCnt -> numPhotons [t]; |
735 |
#endif |
736 |
737 |
738 |
739 |
pmapDistribReport(); |
740 |
#ifdef SIGCONT |
741 |
else signal(SIGCONT, pmapDistribReport); |
742 |
#endif |
743 |
744 |
745 |
746 |
* POST-DISTRIBUTION - Set photon flux and build data struct for photon |
747 |
* storage, etc. |
748 |
749 |
#ifdef SIGCONT |
750 |
751 |
#endif |
752 |
free(emap.samples); |
753 |
754 |
/* Set photon flux (repProgress is total num emitted) */ |
755 |
totalFlux /= photonCnt -> numEmitted; |
756 |
757 |
/* Photon counters no longer needed, unmap shared memory */ |
758 |
759 |
close(shmFile); |
760 |
#if 0 |
761 |
shm_unlink(shmFname); |
762 |
#else |
763 |
unlink(shmFname); |
764 |
#endif |
765 |
766 |
767 |
if (pmaps [t]) { |
768 |
769 |
sprintf(errmsg, "\nBuilding %s photon map...\n", pmapName [t]); |
770 |
eputs(errmsg); |
771 |
fflush(stderr); |
772 |
773 |
774 |
/* Build underlying data structure; heap is destroyed */ |
775 |
buildPhotonMap(pmaps [t], &totalFlux, NULL, numProc); |
776 |
777 |
778 |
/* Precompute photon irradiance if necessary */ |
779 |
if (preCompPmap) |
780 |
preComputeGlobal(preCompPmap); |
781 |
782 |
783 |
784 |
785 |
void photonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad) |
786 |
/* Photon density estimate. Returns irradiance at ray -> rop. */ |
787 |
788 |
unsigned i; |
789 |
float r; |
790 |
COLOR flux; |
791 |
Photon *photon; |
792 |
const PhotonSearchQueueNode *sqn; |
793 |
794 |
setcolor(irrad, 0, 0, 0); |
795 |
796 |
if (!pmap -> maxGather) |
797 |
return; |
798 |
799 |
/* Ignore sources */ |
800 |
if (ray -> ro && islight(objptr(ray -> ro -> omod) -> otype)) |
801 |
return; |
802 |
803 |
findPhotons(pmap, ray); |
804 |
805 |
/* Need at least 2 photons */ |
806 |
if (pmap -> squeue.tail < 2) { |
807 |
#ifdef PMAP_NONEFOUND |
808 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
809 |
ray -> ro ? ray -> ro -> oname : "<null>", |
810 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
811 |
error(WARNING, errmsg); |
812 |
#endif |
813 |
814 |
return; |
815 |
816 |
817 |
if (pmap -> minGather == pmap -> maxGather) { |
818 |
/* No bias compensation. Just do a plain vanilla estimate */ |
819 |
sqn = pmap -> squeue.node + 1; |
820 |
821 |
/* Average radius between furthest two photons to improve accuracy */ |
822 |
r = max(sqn -> dist2, (sqn + 1) -> dist2); |
823 |
r = 0.25 * (pmap -> maxDist2 + r + 2 * sqrt(pmap -> maxDist2 * r)); |
824 |
825 |
/* Skip the extra photon */ |
826 |
for (i = 1 ; i < pmap -> squeue.tail; i++, sqn++) { |
827 |
photon = getNearestPhoton(&pmap -> squeue, sqn -> idx); |
828 |
getPhotonFlux(photon, flux); |
829 |
#ifdef PMAP_EPANECHNIKOV |
830 |
/* Apply Epanechnikov kernel to photon flux based on photon dist */ |
831 |
scalecolor(flux, 2 * (1 - sqn -> dist2 / r)); |
832 |
#endif |
833 |
addcolor(irrad, flux); |
834 |
835 |
836 |
/* Divide by search area PI * r^2, 1 / PI required as ambient |
837 |
normalisation factor */ |
838 |
scalecolor(irrad, 1 / (PI * PI * r)); |
839 |
840 |
return; |
841 |
842 |
else |
843 |
/* Apply bias compensation to density estimate */ |
844 |
biasComp(pmap, irrad); |
845 |
846 |
847 |
848 |
849 |
void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad) |
850 |
/* Returns precomputed photon density estimate at ray -> rop. */ |
851 |
852 |
Photon p; |
853 |
854 |
855 |
856 |
857 |
if (r -> ro && islight(objptr(r -> ro -> omod) -> otype)) |
858 |
return; |
859 |
860 |
find1Photon(preCompPmap, r, &p); |
861 |
getPhotonFlux(&p, irrad); |
862 |
863 |
864 |
865 |
866 |
void volumePhotonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad) |
867 |
/* Photon volume density estimate. Returns irradiance at ray -> rop. */ |
868 |
869 |
unsigned i; |
870 |
float r, gecc2, ph; |
871 |
COLOR flux; |
872 |
Photon *photon; |
873 |
874 |
875 |
876 |
877 |
878 |
return; |
879 |
880 |
881 |
882 |
883 |
if (pmap -> squeue.tail < 2) |
884 |
return; |
885 |
886 |
#if 0 |
887 |
/* Volume biascomp disabled (probably redundant) */ |
888 |
if (pmap -> minGather == pmap -> maxGather) |
889 |
#endif |
890 |
891 |
892 |
gecc2 = ray -> gecc * ray -> gecc; |
893 |
894 |
895 |
896 |
897 |
898 |
899 |
900 |
for (i = 1; i < pmap -> squeue.tail; i++, sqn++) { |
901 |
902 |
903 |
/* Compute phase function for inscattering from photon */ |
904 |
if (gecc2 <= FTINY) |
905 |
ph = 1; |
906 |
else { |
907 |
ph = DOT(ray -> rdir, photon -> norm) / 127; |
908 |
ph = 1 + gecc2 - 2 * ray -> gecc * ph; |
909 |
ph = (1 - gecc2) / (ph * sqrt(ph)); |
910 |
911 |
912 |
913 |
scalecolor(flux, ph); |
914 |
915 |
916 |
917 |
/* Divide by search volume 4 / 3 * PI * r^3 and phase function |
918 |
normalization factor 1 / (4 * PI) */ |
919 |
scalecolor(irrad, 3 / (16 * PI * PI * r * sqrt(r))); |
920 |
return; |
921 |
922 |
#if 0 |
923 |
else |
924 |
925 |
volumeBiasComp(pmap, ray, irrad); |
926 |
#endif |
927 |
