| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmap.c,v 2.14 2018/03/20 19:55:33 rschregle Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
| 8 |
Photon map main module
| 9 |
| 10 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 11 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 12 |
(c) Lucerne University of Applied Sciences and Arts,
| 13 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
| 19 |
| 20 |
#include "pmap.h"
| 21 |
#include "pmapmat.h"
| 22 |
#include "pmapsrc.h"
| 23 |
#include "pmaprand.h"
| 24 |
#include "pmapio.h"
| 25 |
#include "pmapbias.h"
| 26 |
#include "pmapdiag.h"
| 27 |
#include "otypes.h"
| 28 |
#include <time.h>
| 29 |
#if NIX
| 30 |
#include <sys/stat.h>
| 31 |
#include <sys/mman.h>
| 32 |
#include <sys/wait.h>
| 33 |
#endif
| 34 |
| 35 |
| 36 |
void savePmaps (const PhotonMap **pmaps, int argc, char **argv)
| 37 |
| 38 |
unsigned t;
| 39 |
| 40 |
for (t = 0; t < NUM_PMAP_TYPES; t++) {
| 41 |
if (pmaps [t])
| 42 |
savePhotonMap(pmaps [t], pmaps [t] -> fileName, argc, argv);
| 43 |
| 44 |
| 45 |
| 46 |
| 47 |
| 48 |
static int photonParticipate (RAY *ray)
| 49 |
/* Trace photon through participating medium. Returns 1 if passed through,
| 50 |
or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */
| 51 |
| 52 |
int i;
| 53 |
RREAL cosTheta, cosPhi, du, dv;
| 54 |
const float cext = colorAvg(ray -> cext),
| 55 |
albedo = colorAvg(ray -> albedo);
| 56 |
FVECT u, v;
| 57 |
COLOR cvext;
| 58 |
| 59 |
/* Mean free distance until interaction with medium */
| 60 |
ray -> rmax = -log(pmapRandom(mediumState)) / cext;
| 61 |
| 62 |
while (!localhit(ray, &thescene)) {
| 63 |
setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]),
| 64 |
exp(-ray -> rmax * ray -> cext [1]),
| 65 |
exp(-ray -> rmax * ray -> cext [2]));
| 66 |
| 67 |
/* Modify ray color and normalise */
| 68 |
multcolor(ray -> rcol, cvext);
| 69 |
colorNorm(ray -> rcol);
| 70 |
VCOPY(ray -> rorg, ray -> rop);
| 71 |
| 72 |
#if 0
| 73 |
if (albedo > FTINY && ray -> rlvl > 0)
| 74 |
#else
| 75 |
/* Store volume photons unconditionally in mist to also account for
| 76 |
direct inscattering from sources */
| 77 |
if (albedo > FTINY)
| 78 |
#endif
| 79 |
/* Add to volume photon map */
| 80 |
newPhoton(volumePmap, ray);
| 81 |
| 82 |
/* Absorbed? */
| 83 |
if (pmapRandom(rouletteState) > albedo)
| 84 |
return 0;
| 85 |
| 86 |
/* Colour bleeding without attenuation (?) */
| 87 |
multcolor(ray -> rcol, ray -> albedo);
| 88 |
scalecolor(ray -> rcol, 1 / albedo);
| 89 |
| 90 |
/* Scatter photon */
| 91 |
cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1
| 92 |
: 1 / (2 * ray -> gecc) *
| 93 |
(1 + ray -> gecc * ray -> gecc -
| 94 |
(1 - ray -> gecc * ray -> gecc) /
| 95 |
(1 - ray -> gecc + 2 * ray -> gecc *
| 96 |
pmapRandom(scatterState)));
| 97 |
| 98 |
cosPhi = cos(2 * PI * pmapRandom(scatterState));
| 99 |
du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */
| 100 |
du *= cosPhi;
| 101 |
dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */
| 102 |
| 103 |
/* Get axes u & v perpendicular to photon direction */
| 104 |
i = 0;
| 105 |
do {
| 106 |
v [0] = v [1] = v [2] = 0;
| 107 |
v [i++] = 1;
| 108 |
fcross(u, v, ray -> rdir);
| 109 |
} while (normalize(u) < FTINY);
| 110 |
fcross(v, ray -> rdir, u);
| 111 |
| 112 |
for (i = 0; i < 3; i++)
| 113 |
ray -> rdir [i] = du * u [i] + dv * v [i] +
| 114 |
cosTheta * ray -> rdir [i];
| 115 |
ray -> rlvl++;
| 116 |
| 117 |
| 118 |
| 119 |
setcolor(cvext, exp(-ray -> rot * ray -> cext [0]),
| 120 |
exp(-ray -> rot * ray -> cext [1]),
| 121 |
exp(-ray -> rot * ray -> cext [2]));
| 122 |
| 123 |
| 124 |
| 125 |
| 126 |
| 127 |
/* Passed through medium */
| 128 |
return 1;
| 129 |
| 130 |
| 131 |
| 132 |
| 133 |
void tracePhoton (RAY *ray)
| 134 |
/* Follow photon as it bounces around... */
| 135 |
| 136 |
long mod;
| 137 |
OBJREC *mat, *port = NULL;
| 138 |
| 139 |
if (!ray -> parent) {
| 140 |
/* !!! PHOTON PORT REJECTION SAMPLING HACK: get photon port for
| 141 |
* !!! primary ray from ray -> ro, then reset the latter to NULL so
| 142 |
* !!! as not to interfere with localhit() */
| 143 |
port = ray -> ro;
| 144 |
ray -> ro = NULL;
| 145 |
| 146 |
| 147 |
if (ray -> rlvl > photonMaxBounce) {
| 148 |
#ifdef PMAP_RUNAWAY_WARN
| 149 |
error(WARNING, "runaway photon!");
| 150 |
#endif
| 151 |
return;
| 152 |
| 153 |
| 154 |
if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray))
| 155 |
return;
| 156 |
| 157 |
if (localhit(ray, &thescene)) {
| 158 |
mod = ray -> ro -> omod;
| 159 |
| 160 |
if (port && ray -> ro != port) {
| 161 |
/* !!! PHOTON PORT REJECTION SAMPLING HACK !!!
| 162 |
* Terminate photon if emitted from port without intersecting it;
| 163 |
* this can happen when the port's partitions extend beyond its
| 164 |
* actual geometry, e.g. with polygons. Since the total flux
| 165 |
* relayed by the port is based on the (in this case) larger
| 166 |
* partition area, it is overestimated; terminating these photons
| 167 |
* constitutes rejection sampling and thereby compensates any bias
| 168 |
* incurred by the overestimated flux. */
| 169 |
#ifdef PMAP_PORTREJECT_WARN
| 170 |
sprintf(errmsg, "photon outside port %s", ray -> ro -> oname);
| 171 |
error(WARNING, errmsg);
| 172 |
#endif
| 173 |
return;
| 174 |
| 175 |
| 176 |
if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) {
| 177 |
/* Transfer ray if modifier is VOID or clipped within antimatta */
| 178 |
RAY tray;
| 179 |
photonRay(ray, &tray, PMAP_XFER, NULL);
| 180 |
tracePhoton(&tray);
| 181 |
| 182 |
else {
| 183 |
/* Scatter for modifier material */
| 184 |
mat = objptr(mod);
| 185 |
photonScatter [mat -> otype] (mat, ray);
| 186 |
| 187 |
| 188 |
| 189 |
| 190 |
| 191 |
| 192 |
static void preComputeGlobal (PhotonMap *pmap)
| 193 |
/* Precompute irradiance from global photons for final gathering for
| 194 |
a random subset of finalGather * pmap -> numPhotons photons, and builds
| 195 |
the photon map, discarding the original photons. */
| 196 |
/* !!! NOTE: PRECOMPUTATION WITH OOC CURRENTLY WITHOUT CACHE !!! */
| 197 |
| 198 |
unsigned long i, numPreComp;
| 199 |
unsigned j;
| 200 |
PhotonIdx pIdx;
| 201 |
Photon photon;
| 202 |
RAY ray;
| 203 |
PhotonMap nuPmap;
| 204 |
| 205 |
repComplete = numPreComp = finalGather * pmap -> numPhotons;
| 206 |
| 207 |
if (verbose) {
| 208 |
sprintf(errmsg,
| 209 |
"\nPrecomputing irradiance for %ld global photons\n",
| 210 |
numPreComp);
| 211 |
eputs(errmsg);
| 212 |
#if NIX
| 213 |
fflush(stderr);
| 214 |
#endif
| 215 |
| 216 |
| 217 |
/* Copy photon map for precomputed photons */
| 218 |
memcpy(&nuPmap, pmap, sizeof(PhotonMap));
| 219 |
| 220 |
/* Zero counters, init new heap and extents */
| 221 |
nuPmap.numPhotons = 0;
| 222 |
initPhotonHeap(&nuPmap);
| 223 |
| 224 |
for (j = 0; j < 3; j++) {
| 225 |
nuPmap.minPos [j] = FHUGE;
| 226 |
nuPmap.maxPos [j] = -FHUGE;
| 227 |
| 228 |
| 229 |
/* Record start time, baby */
| 230 |
repStartTime = time(NULL);
| 231 |
#ifdef SIGCONT
| 232 |
signal(SIGCONT, pmapPreCompReport);
| 233 |
#endif
| 234 |
repProgress = 0;
| 235 |
| 236 |
photonRay(NULL, &ray, PRIMARY, NULL);
| 237 |
ray.ro = NULL;
| 238 |
| 239 |
for (i = 0; i < numPreComp; i++) {
| 240 |
/* Get random photon from stratified distribution in source heap to
| 241 |
* avoid duplicates and clustering */
| 242 |
pIdx = firstPhoton(pmap) +
| 243 |
(unsigned long)((i + pmapRandom(pmap -> randState)) /
| 244 |
finalGather);
| 245 |
getPhoton(pmap, pIdx, &photon);
| 246 |
| 247 |
/* Init dummy photon ray with intersection at photon position */
| 248 |
VCOPY(ray.rop, photon.pos);
| 249 |
| 250 |
ray.ron [j] = photon.norm [j] / 127.0;
| 251 |
| 252 |
/* Get density estimate at photon position */
| 253 |
photonDensity(pmap, &ray, ray.rcol);
| 254 |
| 255 |
/* Append photon to new heap from ray */
| 256 |
newPhoton(&nuPmap, &ray);
| 257 |
| 258 |
/* Update progress */
| 259 |
repProgress++;
| 260 |
| 261 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
| 262 |
pmapPreCompReport();
| 263 |
#ifdef SIGCONT
| 264 |
else signal(SIGCONT, pmapPreCompReport);
| 265 |
#endif
| 266 |
| 267 |
| 268 |
/* Flush heap */
| 269 |
flushPhotonHeap(&nuPmap);
| 270 |
| 271 |
#ifdef SIGCONT
| 272 |
signal(SIGCONT, SIG_DFL);
| 273 |
#endif
| 274 |
| 275 |
/* Trash original pmap, replace with precomputed one */
| 276 |
deletePhotons(pmap);
| 277 |
memcpy(pmap, &nuPmap, sizeof(PhotonMap));
| 278 |
| 279 |
if (verbose) {
| 280 |
eputs("\nRebuilding precomputed photon map\n");
| 281 |
#if NIX
| 282 |
fflush(stderr);
| 283 |
#endif
| 284 |
| 285 |
| 286 |
/* Rebuild underlying data structure, destroying heap */
| 287 |
buildPhotonMap(pmap, NULL, NULL, 1);
| 288 |
| 289 |
| 290 |
| 291 |
| 292 |
typedef struct {
| 293 |
unsigned long numPhotons [NUM_PMAP_TYPES],
| 294 |
numEmitted, numComplete;
| 295 |
} PhotonCnt;
| 296 |
| 297 |
| 298 |
| 299 |
void distribPhotons (PhotonMap **pmaps, unsigned numProc)
| 300 |
| 301 |
EmissionMap emap;
| 302 |
char errmsg2 [128], shmFname [PMAP_TMPFNLEN];
| 303 |
unsigned t, srcIdx, proc;
| 304 |
double totalFlux = 0;
| 305 |
int shmFile, stat, pid;
| 306 |
PhotonMap *pm;
| 307 |
PhotonCnt *photonCnt;
| 308 |
| 309 |
for (t = 0; t < NUM_PMAP_TYPES && !pmaps [t]; t++);
| 310 |
| 311 |
if (t >= NUM_PMAP_TYPES)
| 312 |
error(USER, "no photon maps defined in distribPhotons");
| 313 |
| 314 |
if (!nsources)
| 315 |
error(USER, "no light sources in distribPhotons");
| 316 |
| 317 |
| 318 |
* INITIALISATION - Set up emission and scattering funcs
| 319 |
| 320 |
emap.samples = NULL;
| 321 |
emap.maxPartitions = MAXSPART;
| 322 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
| 323 |
if (!emap.partitions)
| 324 |
error(INTERNAL, "can't allocate source partitions in distribPhotons");
| 325 |
| 326 |
/* Initialise all defined photon maps */
| 327 |
| 328 |
if (pmaps [t]) {
| 329 |
initPhotonMap(pmaps [t], t);
| 330 |
/* Open photon heapfile */
| 331 |
initPhotonHeap(pmaps [t]);
| 332 |
/* Per-subprocess target count */
| 333 |
pmaps [t] -> distribTarget /= numProc;
| 334 |
| 335 |
if (!pmaps [t] -> distribTarget)
| 336 |
error(INTERNAL, "no photons to distribute in distribPhotons");
| 337 |
| 338 |
| 339 |
initPhotonEmissionFuncs();
| 340 |
initPhotonScatterFuncs();
| 341 |
| 342 |
/* Get photon ports from modifier list */
| 343 |
getPhotonPorts(photonPortList);
| 344 |
| 345 |
/* Get photon sensor modifiers */
| 346 |
getPhotonSensors(photonSensorList);
| 347 |
| 348 |
#if NIX
| 349 |
/* Set up shared mem for photon counters (zeroed by ftruncate) */
| 350 |
strcpy(shmFname, PMAP_TMPFNAME);
| 351 |
shmFile = mkstemp(shmFname);
| 352 |
| 353 |
if (shmFile < 0 || ftruncate(shmFile, sizeof(*photonCnt)) < 0)
| 354 |
error(SYSTEM, "failed shared mem init in distribPhotons");
| 355 |
| 356 |
photonCnt = mmap(NULL, sizeof(*photonCnt), PROT_READ | PROT_WRITE,
| 357 |
MAP_SHARED, shmFile, 0);
| 358 |
| 359 |
if (photonCnt == MAP_FAILED)
| 360 |
error(SYSTEM, "failed mapping shared memory in distribPhotons");
| 361 |
#else
| 362 |
/* Allocate photon counters statically on Windoze */
| 363 |
if (!(photonCnt = malloc(sizeof(PhotonCnt))))
| 364 |
error(SYSTEM, "failed trivial malloc in distribPhotons");
| 365 |
photonCnt -> numEmitted = photonCnt -> numComplete = 0;
| 366 |
#endif /* NIX */
| 367 |
| 368 |
if (verbose) {
| 369 |
sprintf(errmsg, "\nIntegrating flux from %d sources", nsources);
| 370 |
| 371 |
if (photonPorts) {
| 372 |
sprintf(errmsg2, " via %d ports", numPhotonPorts);
| 373 |
strcat(errmsg, errmsg2);
| 374 |
| 375 |
| 376 |
strcat(errmsg, "\n");
| 377 |
eputs(errmsg);
| 378 |
| 379 |
| 380 |
| 381 |
* FLUX INTEGRATION - Get total photon flux from light sources
| 382 |
| 383 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
| 384 |
unsigned portCnt = 0;
| 385 |
emap.src = source + srcIdx;
| 386 |
| 387 |
do { /* Need at least one iteration if no ports! */
| 388 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
| 389 |
: NULL;
| 390 |
photonPartition [emap.src -> so -> otype] (&emap);
| 391 |
| 392 |
if (verbose) {
| 393 |
sprintf(errmsg, "\tIntegrating flux from source %s ",
| 394 |
source [srcIdx].so -> oname);
| 395 |
| 396 |
if (emap.port) {
| 397 |
sprintf(errmsg2, "via port %s ",
| 398 |
photonPorts [portCnt].so -> oname);
| 399 |
| 400 |
| 401 |
| 402 |
sprintf(errmsg2, "(%lu partitions)\n", emap.numPartitions);
| 403 |
| 404 |
eputs(errmsg);
| 405 |
#if NIX
| 406 |
fflush(stderr);
| 407 |
#endif
| 408 |
| 409 |
| 410 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
| 411 |
emap.partitionCnt++) {
| 412 |
initPhotonEmission(&emap, pdfSamples);
| 413 |
totalFlux += colorAvg(emap.partFlux);
| 414 |
| 415 |
| 416 |
portCnt++;
| 417 |
} while (portCnt < numPhotonPorts);
| 418 |
| 419 |
| 420 |
if (totalFlux < FTINY)
| 421 |
error(USER, "zero flux from light sources");
| 422 |
| 423 |
/* Record start time for progress reports */
| 424 |
| 425 |
| 426 |
if (verbose) {
| 427 |
sprintf(errmsg, "\nPhoton distribution @ %d procs\n", numProc);
| 428 |
eputs(errmsg);
| 429 |
| 430 |
| 431 |
/* MAIN LOOP */
| 432 |
for (proc = 0; proc < numProc; proc++) {
| 433 |
#if NIX
| 434 |
if (!(pid = fork())) {
| 435 |
/* SUBPROCESS ENTERS HERE; open and mmapped files inherited */
| 436 |
#else
| 437 |
if (1) {
| 438 |
/* No subprocess under Windoze */
| 439 |
#endif
| 440 |
/* Local photon counters for this subprocess */
| 441 |
unsigned passCnt = 0, prePassCnt = 0;
| 442 |
unsigned long lastNumPhotons [NUM_PMAP_TYPES];
| 443 |
unsigned long localNumEmitted = 0; /* Num photons emitted by this
| 444 |
subprocess alone */
| 445 |
| 446 |
/* Seed RNGs from PID for decorellated photon distribution */
| 447 |
pmapSeed(randSeed + proc, partState);
| 448 |
pmapSeed(randSeed + (proc + 1) % numProc, emitState);
| 449 |
pmapSeed(randSeed + (proc + 2) % numProc, cntState);
| 450 |
pmapSeed(randSeed + (proc + 3) % numProc, mediumState);
| 451 |
pmapSeed(randSeed + (proc + 4) % numProc, scatterState);
| 452 |
pmapSeed(randSeed + (proc + 5) % numProc, rouletteState);
| 453 |
| 454 |
#ifdef DEBUG_PMAP
| 455 |
/* Output child process PID after random delay to prevent corrupted
| 456 |
* console output due to race condition */
| 457 |
usleep(1e6 * pmapRandom(rouletteState));
| 458 |
fprintf(stderr, "Proc %d: PID = %d "
| 459 |
"(waiting 10 sec to attach debugger...)\n",
| 460 |
proc, getpid());
| 461 |
/* Allow time for debugger to attach to child process */
| 462 |
sleep(10);
| 463 |
#endif
| 464 |
| 465 |
| 466 |
lastNumPhotons [t] = 0;
| 467 |
| 468 |
| 469 |
* 2-PASS PHOTON DISTRIBUTION
| 470 |
* Pass 1 (pre): emit fraction of target photon count
| 471 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining
| 472 |
* number of photons to emit to approximate target
| 473 |
* count
| 474 |
| 475 |
do {
| 476 |
double numEmit;
| 477 |
| 478 |
if (!passCnt) {
| 479 |
/* INIT PASS 1 */
| 480 |
/* Skip if no photons contributed after sufficient
| 481 |
* iterations; make it clear to user which photon maps are
| 482 |
* missing so (s)he can check geometry and materials */
| 483 |
if (++prePassCnt > maxPreDistrib) {
| 484 |
sprintf(errmsg, "proc %d: too many prepasses", proc);
| 485 |
| 486 |
| 487 |
if (pmaps [t] && !pmaps [t] -> numPhotons) {
| 488 |
sprintf(errmsg2, ", no %s photons stored",
| 489 |
pmapName [t]);
| 490 |
| 491 |
| 492 |
| 493 |
error(USER, errmsg);
| 494 |
break;
| 495 |
| 496 |
| 497 |
/* Num to emit is fraction of minimum target count */
| 498 |
numEmit = FHUGE;
| 499 |
| 500 |
| 501 |
if (pmaps [t])
| 502 |
numEmit = min(pmaps [t] -> distribTarget, numEmit);
| 503 |
| 504 |
numEmit *= preDistrib;
| 505 |
| 506 |
else {
| 507 |
/* INIT PASS 2 */
| 508 |
/* Based on the outcome of the predistribution we can now
| 509 |
* estimate how many more photons we have to emit for each
| 510 |
* photon map to meet its respective target count. This
| 511 |
* value is clamped to 0 in case the target has already been
| 512 |
* exceeded in the pass 1. */
| 513 |
double maxDistribRatio = 0;
| 514 |
| 515 |
/* Set the distribution ratio for each map; this indicates
| 516 |
* how many photons of each respective type are stored per
| 517 |
* emitted photon, and is used as probability for storing a
| 518 |
* photon by newPhoton(). Since this biases the photon
| 519 |
* density, newPhoton() promotes the flux of stored photons
| 520 |
* to compensate. */
| 521 |
| 522 |
if ((pm = pmaps [t])) {
| 523 |
pm -> distribRatio = (double)pm -> distribTarget /
| 524 |
pm -> numPhotons - 1;
| 525 |
| 526 |
/* Check if photon map "overflowed", i.e. exceeded its
| 527 |
* target count in the prepass; correcting the photon
| 528 |
* flux via the distribution ratio is no longer
| 529 |
* possible, as no more photons of this type will be
| 530 |
* stored, so notify the user rather than deliver
| 531 |
* incorrect results. In future we should handle this
| 532 |
* more intelligently by using the photonFlux in each
| 533 |
* photon map to individually correct the flux after
| 534 |
* distribution. */
| 535 |
if (pm -> distribRatio <= FTINY) {
| 536 |
sprintf(errmsg, "%s photon map overflow in "
| 537 |
"prepass, reduce -apD", pmapName [t]);
| 538 |
error(INTERNAL, errmsg);
| 539 |
| 540 |
| 541 |
maxDistribRatio = max(pm -> distribRatio,
| 542 |
maxDistribRatio);
| 543 |
| 544 |
| 545 |
/* Normalise distribution ratios and calculate number of
| 546 |
* photons to emit in main pass */
| 547 |
| 548 |
| 549 |
pm -> distribRatio /= maxDistribRatio;
| 550 |
| 551 |
if ((numEmit = localNumEmitted * maxDistribRatio) < FTINY)
| 552 |
/* No photons left to distribute in main pass */
| 553 |
break;
| 554 |
| 555 |
| 556 |
/* Update shared completion counter for progreport by parent */
| 557 |
photonCnt -> numComplete += numEmit;
| 558 |
| 559 |
/* PHOTON DISTRIBUTION LOOP */
| 560 |
| 561 |
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
? photonPorts + portCnt : NULL;
| 567 |
| 568 |
| 569 |
if (verbose && !proc) {
| 570 |
/* Output from subproc 0 only to avoid race condition
| 571 |
* on console I/O */
| 572 |
if (!passCnt)
| 573 |
sprintf(errmsg, "\tPREPASS %d on source %s ",
| 574 |
prePassCnt, source [srcIdx].so -> oname);
| 575 |
else
| 576 |
sprintf(errmsg, "\tMAIN PASS on source %s ",
| 577 |
| 578 |
| 579 |
if (emap.port) {
| 580 |
| 581 |
| 582 |
| 583 |
| 584 |
| 585 |
| 586 |
| 587 |
| 588 |
eputs(errmsg);
| 589 |
#if NIX
| 590 |
fflush(stderr);
| 591 |
#endif
| 592 |
| 593 |
| 594 |
| 595 |
| 596 |
double partNumEmit;
| 597 |
unsigned long partEmitCnt;
| 598 |
| 599 |
/* Get photon origin within current source partishunn
| 600 |
* and build emission map */
| 601 |
photonOrigin [emap.src -> so -> otype] (&emap);
| 602 |
| 603 |
| 604 |
/* Number of photons to emit from ziss partishunn --
| 605 |
* proportional to flux; photon ray weight and scalar
| 606 |
* flux are uniform (latter only varying in RGB). */
| 607 |
partNumEmit = numEmit * colorAvg(emap.partFlux) /
| 608 |
totalFlux;
| 609 |
partEmitCnt = (unsigned long)partNumEmit;
| 610 |
| 611 |
/* Probabilistically account for fractional photons */
| 612 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
| 613 |
partEmitCnt++;
| 614 |
| 615 |
/* Update local and shared (global) emission counter */
| 616 |
photonCnt -> numEmitted += partEmitCnt;
| 617 |
localNumEmitted += partEmitCnt;
| 618 |
| 619 |
/* Integer counter avoids FP rounding errors during
| 620 |
* iteration */
| 621 |
while (partEmitCnt--) {
| 622 |
RAY photonRay;
| 623 |
| 624 |
/* Emit photon based on PDF and trace through scene
| 625 |
* until absorbed/leaked */
| 626 |
emitPhoton(&emap, &photonRay);
| 627 |
#if 1
| 628 |
if (emap.port)
| 629 |
/* !!! PHOTON PORT REJECTION SAMPLING HACK: set
| 630 |
* !!! photon port as fake hit object for
| 631 |
* !!! primary ray to check for intersection in
| 632 |
* !!! tracePhoton() */
| 633 |
photonRay.ro = emap.port -> so;
| 634 |
#endif
| 635 |
tracePhoton(&photonRay);
| 636 |
| 637 |
| 638 |
/* Update shared global photon count for each pmap */
| 639 |
| 640 |
if (pmaps [t]) {
| 641 |
photonCnt -> numPhotons [t] +=
| 642 |
pmaps [t] -> numPhotons - lastNumPhotons [t];
| 643 |
lastNumPhotons [t] = pmaps [t] -> numPhotons;
| 644 |
| 645 |
#if !NIX
| 646 |
/* Synchronous progress report on Windoze */
| 647 |
if (!proc && photonRepTime > 0 &&
| 648 |
time(NULL) >= repLastTime + photonRepTime) {
| 649 |
repEmitted = repProgress = photonCnt -> numEmitted;
| 650 |
repComplete = photonCnt -> numComplete;
| 651 |
pmapDistribReport();
| 652 |
| 653 |
#endif
| 654 |
| 655 |
| 656 |
portCnt++;
| 657 |
| 658 |
| 659 |
| 660 |
| 661 |
| 662 |
/* Double preDistrib in case a photon map is empty and
| 663 |
* redo pass 1 --> possibility of infinite loop for
| 664 |
* pathological scenes (e.g. absorbing materials) */
| 665 |
preDistrib *= 2;
| 666 |
break;
| 667 |
| 668 |
| 669 |
| 670 |
/* No empty photon maps found; now do pass 2 */
| 671 |
passCnt++;
| 672 |
} while (passCnt < 2);
| 673 |
| 674 |
/* Flush heap buffa for every pmap one final time;
| 675 |
* avoids potential data corruption! */
| 676 |
| 677 |
if (pmaps [t]) {
| 678 |
flushPhotonHeap(pmaps [t]);
| 679 |
/* Heap file closed automatically on exit
| 680 |
fclose(pmaps [t] -> heap); */
| 681 |
#ifdef DEBUG_PMAP
| 682 |
sprintf(errmsg, "Proc %d: total %ld photons\n", proc,
| 683 |
pmaps [t] -> numPhotons);
| 684 |
eputs(errmsg);
| 685 |
#endif
| 686 |
| 687 |
#if NIX
| 688 |
/* Terminate subprocess */
| 689 |
exit(0);
| 690 |
#endif
| 691 |
| 692 |
else if (pid < 0)
| 693 |
error(SYSTEM, "failed to fork subprocess in distribPhotons");
| 694 |
| 695 |
| 696 |
#if NIX
| 697 |
/* PARENT PROCESS CONTINUES HERE */
| 698 |
#ifdef SIGCONT
| 699 |
/* Enable progress report signal handler */
| 700 |
signal(SIGCONT, pmapDistribReport);
| 701 |
#endif
| 702 |
/* Wait for subprocesses complete while reporting progress */
| 703 |
proc = numProc;
| 704 |
while (proc) {
| 705 |
while (waitpid(-1, &stat, WNOHANG) > 0) {
| 706 |
/* Subprocess exited; check status */
| 707 |
if (!WIFEXITED(stat) || WEXITSTATUS(stat))
| 708 |
error(USER, "failed photon distribution");
| 709 |
| 710 |
--proc;
| 711 |
| 712 |
| 713 |
/* Nod off for a bit and update progress */
| 714 |
sleep(1);
| 715 |
| 716 |
/* Asynchronous progress report from shared subprocess counters */
| 717 |
| 718 |
| 719 |
| 720 |
repProgress = repComplete = 0;
| 721 |
| 722 |
| 723 |
/* Get global photon count from shmem updated by subprocs */
| 724 |
repProgress += pm -> numPhotons = photonCnt -> numPhotons [t];
| 725 |
repComplete += pm -> distribTarget;
| 726 |
| 727 |
repComplete *= numProc;
| 728 |
| 729 |
| 730 |
| 731 |
#ifdef SIGCONT
| 732 |
else signal(SIGCONT, pmapDistribReport);
| 733 |
#endif
| 734 |
| 735 |
#endif /* NIX */
| 736 |
| 737 |
| 738 |
* POST-DISTRIBUTION - Set photon flux and build data struct for photon
| 739 |
* storage, etc.
| 740 |
| 741 |
#ifdef SIGCONT
| 742 |
/* Reset signal handler */
| 743 |
| 744 |
#endif
| 745 |
free(emap.samples);
| 746 |
| 747 |
/* Set photon flux */
| 748 |
totalFlux /= photonCnt -> numEmitted;
| 749 |
#if NIX
| 750 |
/* Photon counters no longer needed, unmap shared memory */
| 751 |
munmap(photonCnt, sizeof(*photonCnt));
| 752 |
close(shmFile);
| 753 |
unlink(shmFname);
| 754 |
#else
| 755 |
free(photonCnt);
| 756 |
#endif
| 757 |
if (verbose)
| 758 |
eputs("\n");
| 759 |
| 760 |
| 761 |
if (pmaps [t]) {
| 762 |
if (verbose) {
| 763 |
sprintf(errmsg, "Building %s photon map\n", pmapName [t]);
| 764 |
eputs(errmsg);
| 765 |
#if NIX
| 766 |
fflush(stderr);
| 767 |
#endif
| 768 |
| 769 |
| 770 |
/* Build underlying data structure; heap is destroyed */
| 771 |
buildPhotonMap(pmaps [t], &totalFlux, NULL, numProc);
| 772 |
| 773 |
| 774 |
/* Precompute photon irradiance if necessary */
| 775 |
if (preCompPmap) {
| 776 |
if (verbose)
| 777 |
eputs("\n");
| 778 |
preComputeGlobal(preCompPmap);
| 779 |
| 780 |
| 781 |
if (verbose)
| 782 |
eputs("\n");
| 783 |
