| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pmap.c,v 2.9 2015/08/18 18:45:55 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
Photon map main module
| 7 |
| 8 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 9 |
(c) Fraunhofer Institute for Solar Energy Systems,
| 10 |
(c) Lucerne University of Applied Sciences and Arts,
| 11 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 12 |
| 13 |
| 14 |
| 15 |
| 16 |
| 17 |
| 18 |
#include "pmap.h"
| 19 |
#include "pmapmat.h"
| 20 |
#include "pmapsrc.h"
| 21 |
#include "pmaprand.h"
| 22 |
#include "pmapio.h"
| 23 |
#include "pmapbias.h"
| 24 |
#include "pmapdiag.h"
| 25 |
#include "otypes.h"
| 26 |
#include <time.h>
| 27 |
#include <sys/stat.h>
| 28 |
| 29 |
| 30 |
| 31 |
extern char *octname;
| 32 |
| 33 |
static char PmapRevision [] = "$Revision: 2.9 $";
| 34 |
| 35 |
| 36 |
| 37 |
/* Photon map lookup functions per type */
| 38 |
void (*pmapLookup [NUM_PMAP_TYPES])(PhotonMap*, RAY*, COLOR) = {
| 39 |
photonDensity, photonPreCompDensity, photonDensity, volumePhotonDensity,
| 40 |
photonDensity, NULL
| 41 |
| 42 |
| 43 |
| 44 |
| 45 |
void colorNorm (COLOR c)
| 46 |
/* Normalise colour channels to average of 1 */
| 47 |
| 48 |
const float avg = colorAvg(c);
| 49 |
| 50 |
if (!avg)
| 51 |
return;
| 52 |
| 53 |
c [0] /= avg;
| 54 |
c [1] /= avg;
| 55 |
c [2] /= avg;
| 56 |
| 57 |
| 58 |
| 59 |
| 60 |
void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *parm)
| 61 |
| 62 |
unsigned t;
| 63 |
struct stat octstat, pmstat;
| 64 |
PhotonMap *pm;
| 65 |
PhotonMapType type;
| 66 |
| 67 |
for (t = 0; t < NUM_PMAP_TYPES; t++)
| 68 |
if (setPmapParam(&pm, parm + t)) {
| 69 |
/* Check if photon map newer than octree */
| 70 |
if (pm -> fileName && octname &&
| 71 |
!stat(pm -> fileName, &pmstat) && !stat(octname, &octstat) &&
| 72 |
octstat.st_mtime > pmstat.st_mtime) {
| 73 |
sprintf(errmsg, "photon map in file %s may be stale",
| 74 |
pm -> fileName);
| 75 |
error(USER, errmsg);
| 76 |
| 77 |
| 78 |
/* Load photon map from file and get its type */
| 79 |
if ((type = loadPhotonMap(pm, pm -> fileName)) == PMAP_TYPE_NONE)
| 80 |
error(USER, "failed loading photon map");
| 81 |
| 82 |
/* Assign to appropriate photon map type (deleting previously
| 83 |
* loaded photon map of same type if necessary) */
| 84 |
if (pmaps [type]) {
| 85 |
deletePhotons(pmaps [type]);
| 86 |
free(pmaps [type]);
| 87 |
| 88 |
pmaps [type] = pm;
| 89 |
| 90 |
/* Check for invalid density estimate bandwidth */
| 91 |
if (pm -> maxGather > pm -> heapSize) {
| 92 |
error(WARNING, "adjusting density estimate bandwidth");
| 93 |
pm -> minGather = pm -> maxGather = pm -> heapSize;
| 94 |
| 95 |
| 96 |
| 97 |
| 98 |
| 99 |
| 100 |
void savePmaps (const PhotonMap **pmaps, int argc, char **argv)
| 101 |
| 102 |
unsigned t;
| 103 |
| 104 |
for (t = 0; t < NUM_PMAP_TYPES; t++) {
| 105 |
if (pmaps [t])
| 106 |
savePhotonMap(pmaps [t], pmaps [t] -> fileName, argc, argv);
| 107 |
| 108 |
| 109 |
| 110 |
| 111 |
| 112 |
void cleanUpPmaps (PhotonMap **pmaps)
| 113 |
| 114 |
unsigned t;
| 115 |
| 116 |
| 117 |
if (pmaps [t]) {
| 118 |
deletePhotons(pmaps [t]);
| 119 |
free(pmaps [t]);
| 120 |
| 121 |
| 122 |
| 123 |
| 124 |
| 125 |
| 126 |
static int photonParticipate (RAY *ray)
| 127 |
/* Trace photon through participating medium. Returns 1 if passed through,
| 128 |
or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */
| 129 |
| 130 |
int i;
| 131 |
RREAL cosTheta, cosPhi, du, dv;
| 132 |
const float cext = colorAvg(ray -> cext),
| 133 |
albedo = colorAvg(ray -> albedo);
| 134 |
FVECT u, v;
| 135 |
COLOR cvext;
| 136 |
| 137 |
/* Mean free distance until interaction with medium */
| 138 |
ray -> rmax = -log(pmapRandom(mediumState)) / cext;
| 139 |
| 140 |
while (!localhit(ray, &thescene)) {
| 141 |
setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]),
| 142 |
exp(-ray -> rmax * ray -> cext [1]),
| 143 |
exp(-ray -> rmax * ray -> cext [2]));
| 144 |
| 145 |
/* Modify ray color and normalise */
| 146 |
multcolor(ray -> rcol, cvext);
| 147 |
colorNorm(ray -> rcol);
| 148 |
VCOPY(ray -> rorg, ray -> rop);
| 149 |
| 150 |
if (albedo > FTINY)
| 151 |
/* Add to volume photon map */
| 152 |
if (ray -> rlvl > 0) addPhoton(volumePmap, ray);
| 153 |
| 154 |
/* Absorbed? */
| 155 |
if (pmapRandom(rouletteState) > albedo) return 0;
| 156 |
| 157 |
/* Colour bleeding without attenuation (?) */
| 158 |
multcolor(ray -> rcol, ray -> albedo);
| 159 |
scalecolor(ray -> rcol, 1 / albedo);
| 160 |
| 161 |
/* Scatter photon */
| 162 |
cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1
| 163 |
: 1 / (2 * ray -> gecc) *
| 164 |
(1 + ray -> gecc * ray -> gecc -
| 165 |
(1 - ray -> gecc * ray -> gecc) /
| 166 |
(1 - ray -> gecc + 2 * ray -> gecc *
| 167 |
pmapRandom(scatterState)));
| 168 |
| 169 |
cosPhi = cos(2 * PI * pmapRandom(scatterState));
| 170 |
du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */
| 171 |
du *= cosPhi;
| 172 |
dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */
| 173 |
| 174 |
/* Get axes u & v perpendicular to photon direction */
| 175 |
i = 0;
| 176 |
do {
| 177 |
v [0] = v [1] = v [2] = 0;
| 178 |
v [i++] = 1;
| 179 |
fcross(u, v, ray -> rdir);
| 180 |
} while (normalize(u) < FTINY);
| 181 |
fcross(v, ray -> rdir, u);
| 182 |
| 183 |
for (i = 0; i < 3; i++)
| 184 |
ray -> rdir [i] = du * u [i] + dv * v [i] +
| 185 |
cosTheta * ray -> rdir [i];
| 186 |
ray -> rlvl++;
| 187 |
| 188 |
| 189 |
| 190 |
setcolor(cvext, exp(-ray -> rot * ray -> cext [0]),
| 191 |
exp(-ray -> rot * ray -> cext [1]),
| 192 |
exp(-ray -> rot * ray -> cext [2]));
| 193 |
| 194 |
| 195 |
| 196 |
| 197 |
| 198 |
/* Passed through medium */
| 199 |
return 1;
| 200 |
| 201 |
| 202 |
| 203 |
| 204 |
void tracePhoton (RAY *ray)
| 205 |
/* Follow photon as it bounces around... */
| 206 |
| 207 |
long mod;
| 208 |
OBJREC* mat;
| 209 |
| 210 |
if (ray -> rlvl > photonMaxBounce) {
| 211 |
#ifdef PMAP_RUNAWAY_WARN
| 212 |
error(WARNING, "runaway photon!");
| 213 |
#endif
| 214 |
return;
| 215 |
| 216 |
| 217 |
if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray))
| 218 |
return;
| 219 |
| 220 |
if (localhit(ray, &thescene)) {
| 221 |
mod = ray -> ro -> omod;
| 222 |
| 223 |
if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) {
| 224 |
/* Transfer ray if modifier is VOID or clipped within antimatta */
| 225 |
RAY tray;
| 226 |
photonRay(ray, &tray, PMAP_XFER, NULL);
| 227 |
tracePhoton(&tray);
| 228 |
| 229 |
else {
| 230 |
/* Scatter for modifier material */
| 231 |
mat = objptr(mod);
| 232 |
photonScatter [mat -> otype] (mat, ray);
| 233 |
| 234 |
| 235 |
| 236 |
| 237 |
| 238 |
| 239 |
static void preComputeGlobal (PhotonMap *pmap)
| 240 |
/* Precompute irradiance from global photons for final gathering using
| 241 |
the first finalGather * pmap -> heapSize photons in the heap. Returns
| 242 |
new heap with precomputed photons. */
| 243 |
| 244 |
unsigned long i, nuHeapSize;
| 245 |
unsigned j;
| 246 |
Photon *nuHeap, *p;
| 247 |
COLOR irrad;
| 248 |
RAY ray;
| 249 |
float nuMinPos [3], nuMaxPos [3];
| 250 |
| 251 |
repComplete = nuHeapSize = finalGather * pmap -> heapSize;
| 252 |
| 253 |
if (photonRepTime) {
| 254 |
sprintf(errmsg,
| 255 |
"Precomputing irradiance for %ld global photons...\n",
| 256 |
nuHeapSize);
| 257 |
eputs(errmsg);
| 258 |
fflush(stderr);
| 259 |
| 260 |
| 261 |
p = nuHeap = (Photon*)malloc(nuHeapSize * sizeof(Photon));
| 262 |
if (!nuHeap)
| 263 |
error(USER, "can't allocate photon heap");
| 264 |
| 265 |
for (j = 0; j <= 2; j++) {
| 266 |
nuMinPos [j] = FHUGE;
| 267 |
nuMaxPos [j] = -FHUGE;
| 268 |
| 269 |
| 270 |
/* Record start time, baby */
| 271 |
repStartTime = time(NULL);
| 272 |
#ifdef SIGCONT
| 273 |
signal(SIGCONT, pmapPreCompReport);
| 274 |
#endif
| 275 |
repProgress = 0;
| 276 |
memcpy(nuHeap, pmap -> heap, nuHeapSize * sizeof(Photon));
| 277 |
| 278 |
for (i = 0, p = nuHeap; i < nuHeapSize; i++, p++) {
| 279 |
ray.ro = NULL;
| 280 |
VCOPY(ray.rop, p -> pos);
| 281 |
| 282 |
/* Update min and max positions & set ray normal */
| 283 |
for (j = 0; j < 3; j++) {
| 284 |
if (p -> pos [j] < nuMinPos [j]) nuMinPos [j] = p -> pos [j];
| 285 |
if (p -> pos [j] > nuMaxPos [j]) nuMaxPos [j] = p -> pos [j];
| 286 |
ray.ron [j] = p -> norm [j] / 127.0;
| 287 |
| 288 |
| 289 |
photonDensity(pmap, &ray, irrad);
| 290 |
setPhotonFlux(p, irrad);
| 291 |
repProgress++;
| 292 |
| 293 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime)
| 294 |
pmapPreCompReport();
| 295 |
#ifdef SIGCONT
| 296 |
else signal(SIGCONT, pmapPreCompReport);
| 297 |
#endif
| 298 |
| 299 |
| 300 |
#ifdef SIGCONT
| 301 |
signal(SIGCONT, SIG_DFL);
| 302 |
#endif
| 303 |
| 304 |
/* Replace & rebuild heap */
| 305 |
free(pmap -> heap);
| 306 |
pmap -> heap = nuHeap;
| 307 |
pmap -> heapSize = pmap -> heapEnd = nuHeapSize;
| 308 |
VCOPY(pmap -> minPos, nuMinPos);
| 309 |
VCOPY(pmap -> maxPos, nuMaxPos);
| 310 |
| 311 |
| 312 |
eputs("Rebuilding global photon heap...\n");
| 313 |
fflush(stderr);
| 314 |
| 315 |
| 316 |
balancePhotons(pmap, NULL);
| 317 |
| 318 |
| 319 |
| 320 |
| 321 |
void distribPhotons (PhotonMap **pmaps)
| 322 |
| 323 |
EmissionMap emap;
| 324 |
char errmsg2 [128];
| 325 |
unsigned t, srcIdx, passCnt = 0, prePassCnt = 0;
| 326 |
double totalFlux = 0;
| 327 |
PhotonMap *pm;
| 328 |
| 329 |
for (t = 0; t < NUM_PMAP_TYPES && !pmaps [t]; t++);
| 330 |
if (t >= NUM_PMAP_TYPES)
| 331 |
error(USER, "no photon maps defined");
| 332 |
| 333 |
if (!nsources)
| 334 |
error(USER, "no light sources");
| 335 |
| 336 |
| 337 |
* INITIALISATION - Set up emission and scattering funcs
| 338 |
| 339 |
emap.samples = NULL;
| 340 |
emap.maxPartitions = MAXSPART;
| 341 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1);
| 342 |
if (!emap.partitions)
| 343 |
error(INTERNAL, "can't allocate source partitions");
| 344 |
| 345 |
/* Initialise all defined photon maps */
| 346 |
| 347 |
initPhotonMap(pmaps [t], t);
| 348 |
| 349 |
initPhotonEmissionFuncs();
| 350 |
initPhotonScatterFuncs();
| 351 |
| 352 |
/* Get photon ports if specified */
| 353 |
if (ambincl == 1)
| 354 |
getPhotonPorts();
| 355 |
| 356 |
/* Get photon sensor modifiers */
| 357 |
getPhotonSensors(photonSensorList);
| 358 |
| 359 |
/* Seed RNGs for photon distribution */
| 360 |
pmapSeed(randSeed, partState);
| 361 |
pmapSeed(randSeed, emitState);
| 362 |
pmapSeed(randSeed, cntState);
| 363 |
pmapSeed(randSeed, mediumState);
| 364 |
pmapSeed(randSeed, scatterState);
| 365 |
pmapSeed(randSeed, rouletteState);
| 366 |
| 367 |
if (photonRepTime)
| 368 |
eputs("\n");
| 369 |
| 370 |
| 371 |
* FLUX INTEGRATION - Get total photon flux from light sources
| 372 |
| 373 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) {
| 374 |
unsigned portCnt = 0;
| 375 |
emap.src = source + srcIdx;
| 376 |
| 377 |
do {
| 378 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt
| 379 |
: NULL;
| 380 |
photonPartition [emap.src -> so -> otype] (&emap);
| 381 |
| 382 |
| 383 |
sprintf(errmsg, "Integrating flux from source %s ",
| 384 |
source [srcIdx].so -> oname);
| 385 |
| 386 |
if (emap.port) {
| 387 |
sprintf(errmsg2, "via port %s ",
| 388 |
photonPorts [portCnt].so -> oname);
| 389 |
strcat(errmsg, errmsg2);
| 390 |
| 391 |
| 392 |
sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions);
| 393 |
| 394 |
eputs(errmsg);
| 395 |
fflush(stderr);
| 396 |
| 397 |
| 398 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions;
| 399 |
emap.partitionCnt++) {
| 400 |
initPhotonEmission(&emap, pdfSamples);
| 401 |
totalFlux += colorAvg(emap.partFlux);
| 402 |
| 403 |
| 404 |
portCnt++;
| 405 |
} while (portCnt < numPhotonPorts);
| 406 |
| 407 |
| 408 |
if (totalFlux < FTINY)
| 409 |
error(USER, "zero flux from light sources");
| 410 |
| 411 |
/* Record start time and enable progress report signal handler */
| 412 |
| 413 |
#ifdef SIGCONT
| 414 |
signal(SIGCONT, pmapDistribReport);
| 415 |
#endif
| 416 |
repProgress = prePassCnt = 0;
| 417 |
| 418 |
if (photonRepTime)
| 419 |
eputs("\n");
| 420 |
| 421 |
| 422 |
* 2-PASS PHOTON DISTRIBUTION
| 423 |
* Pass 1 (pre): emit fraction of target photon count
| 424 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining number
| 425 |
* of photons to emit to approximate target count
| 426 |
| 427 |
do {
| 428 |
double numEmit;
| 429 |
| 430 |
if (!passCnt) {
| 431 |
/* INIT PASS 1 */
| 432 |
/* Skip if no photons contributed after sufficient iterations; make
| 433 |
* it clear to user which photon maps are missing so (s)he can
| 434 |
* check the scene geometry and materials */
| 435 |
if (++prePassCnt > maxPreDistrib) {
| 436 |
sprintf(errmsg, "too many prepasses");
| 437 |
| 438 |
| 439 |
if (pmaps [t] && !pmaps [t] -> heapEnd) {
| 440 |
sprintf(errmsg2, ", no %s photons stored", pmapName [t]);
| 441 |
| 442 |
| 443 |
| 444 |
| 445 |
break;
| 446 |
| 447 |
| 448 |
/* Num to emit is fraction of minimum target count */
| 449 |
numEmit = FHUGE;
| 450 |
| 451 |
| 452 |
if (pmaps [t])
| 453 |
numEmit = min(pmaps [t] -> distribTarget, numEmit);
| 454 |
| 455 |
numEmit *= preDistrib;
| 456 |
| 457 |
| 458 |
else {
| 459 |
/* INIT PASS 2 */
| 460 |
/* Based on the outcome of the predistribution we can now estimate
| 461 |
* how many more photons we have to emit for each photon map to
| 462 |
* meet its respective target count. This value is clamped to 0 in
| 463 |
* case the target has already been exceeded in the pass 1. Note
| 464 |
* repProgress is the number of photons emitted thus far, while
| 465 |
* heapEnd is the number of photons stored in each photon map. */
| 466 |
double maxDistribRatio = 0;
| 467 |
| 468 |
/* Set the distribution ratio for each map; this indicates how many
| 469 |
* photons of each respective type are stored per emitted photon,
| 470 |
* and is used as probability for storing a photon by addPhoton().
| 471 |
* Since this biases the photon density, addPhoton() promotes the
| 472 |
* flux of stored photons to compensate. */
| 473 |
| 474 |
if ((pm = pmaps [t])) {
| 475 |
pm -> distribRatio = (double)pm -> distribTarget /
| 476 |
pm -> heapEnd - 1;
| 477 |
| 478 |
/* Check if photon map "overflowed", i.e. exceeded its target
| 479 |
* count in the prepass; correcting the photon flux via the
| 480 |
* distribution ratio is no longer possible, as no more
| 481 |
* photons of this type will be stored, so notify the user
| 482 |
* rather than deliver incorrect results.
| 483 |
* In future we should handle this more intelligently by
| 484 |
* using the photonFlux in each photon map to individually
| 485 |
* correct the flux after distribution. */
| 486 |
if (pm -> distribRatio <= FTINY) {
| 487 |
sprintf(errmsg,
| 488 |
"%s photon map overflow in prepass, reduce -apD",
| 489 |
pmapName [t]);
| 490 |
error(INTERNAL, errmsg);
| 491 |
| 492 |
| 493 |
maxDistribRatio = max(pm -> distribRatio, maxDistribRatio);
| 494 |
| 495 |
| 496 |
/* Normalise distribution ratios and calculate number of photons to
| 497 |
* emit in main pass */
| 498 |
| 499 |
| 500 |
pm -> distribRatio /= maxDistribRatio;
| 501 |
| 502 |
if ((numEmit = repProgress * maxDistribRatio) < FTINY)
| 503 |
/* No photons left to distribute in main pass */
| 504 |
break;
| 505 |
| 506 |
| 507 |
/* Set completion count for progress report */
| 508 |
repComplete = numEmit + repProgress;
| 509 |
| 510 |
/* PHOTON DISTRIBUTION LOOP */
| 511 |
| 512 |
| 513 |
| 514 |
| 515 |
do {
| 516 |
| 517 |
: NULL;
| 518 |
| 519 |
| 520 |
| 521 |
if (!passCnt)
| 522 |
sprintf(errmsg, "PREPASS %d on source %s ",
| 523 |
prePassCnt, source [srcIdx].so -> oname);
| 524 |
else
| 525 |
sprintf(errmsg, "MAIN PASS on source %s ",
| 526 |
| 527 |
| 528 |
if (emap.port) {
| 529 |
| 530 |
| 531 |
| 532 |
| 533 |
| 534 |
| 535 |
| 536 |
eputs(errmsg);
| 537 |
fflush(stderr);
| 538 |
| 539 |
| 540 |
| 541 |
| 542 |
double partNumEmit;
| 543 |
unsigned long partEmitCnt;
| 544 |
| 545 |
/* Get photon origin within current source partishunn and
| 546 |
* build emission map */
| 547 |
photonOrigin [emap.src -> so -> otype] (&emap);
| 548 |
| 549 |
| 550 |
/* Number of photons to emit from ziss partishunn --
| 551 |
* proportional to flux; photon ray weight and scalar flux
| 552 |
* are uniform (the latter only varying in RGB). */
| 553 |
partNumEmit = numEmit * colorAvg(emap.partFlux) / totalFlux;
| 554 |
partEmitCnt = (unsigned long)partNumEmit;
| 555 |
| 556 |
/* Probabilistically account for fractional photons */
| 557 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt)
| 558 |
partEmitCnt++;
| 559 |
| 560 |
/* Integer counter avoids FP rounding errors */
| 561 |
while (partEmitCnt--) {
| 562 |
RAY photonRay;
| 563 |
| 564 |
/* Emit photon based on PDF and trace through scene until
| 565 |
* absorbed/leaked */
| 566 |
emitPhoton(&emap, &photonRay);
| 567 |
tracePhoton(&photonRay);
| 568 |
| 569 |
/* Record progress */
| 570 |
repProgress++;
| 571 |
| 572 |
| 573 |
| 574 |
pmapDistribReport();
| 575 |
#ifdef SIGCONT
| 576 |
else signal(SIGCONT, pmapDistribReport);
| 577 |
#endif
| 578 |
| 579 |
| 580 |
| 581 |
portCnt++;
| 582 |
| 583 |
| 584 |
| 585 |
| 586 |
| 587 |
/* Double preDistrib in case a photon map is empty and redo
| 588 |
* pass 1 --> possibility of infinite loop for pathological
| 589 |
* scenes (e.g. absorbing materials) */
| 590 |
preDistrib *= 2;
| 591 |
break;
| 592 |
| 593 |
| 594 |
if (t >= NUM_PMAP_TYPES) {
| 595 |
/* No empty photon maps found; now do pass 2 */
| 596 |
passCnt++;
| 597 |
if (photonRepTime)
| 598 |
eputs("\n");
| 599 |
| 600 |
} while (passCnt < 2);
| 601 |
| 602 |
| 603 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc.
| 604 |
| 605 |
#ifdef SIGCONT
| 606 |
| 607 |
#endif
| 608 |
free(emap.samples);
| 609 |
| 610 |
/* Set photon flux (repProgress is total num emitted) */
| 611 |
totalFlux /= repProgress;
| 612 |
| 613 |
| 614 |
if (pmaps [t]) {
| 615 |
| 616 |
sprintf(errmsg, "\nBuilding %s photon map...\n", pmapName [t]);
| 617 |
eputs(errmsg);
| 618 |
fflush(stderr);
| 619 |
| 620 |
| 621 |
balancePhotons(pmaps [t], &totalFlux);
| 622 |
| 623 |
| 624 |
/* Precompute photon irradiance if necessary */
| 625 |
if (preCompPmap)
| 626 |
preComputeGlobal(preCompPmap);
| 627 |
| 628 |
| 629 |
| 630 |
| 631 |
void photonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
| 632 |
/* Photon density estimate. Returns irradiance at ray -> rop. */
| 633 |
| 634 |
unsigned i;
| 635 |
PhotonSQNode *sq;
| 636 |
float r;
| 637 |
COLOR flux;
| 638 |
| 639 |
setcolor(irrad, 0, 0, 0);
| 640 |
| 641 |
if (!pmap -> maxGather)
| 642 |
return;
| 643 |
| 644 |
/* Ignore sources */
| 645 |
if (ray -> ro)
| 646 |
if (islight(objptr(ray -> ro -> omod) -> otype))
| 647 |
return;
| 648 |
| 649 |
pmap -> squeueEnd = 0;
| 650 |
findPhotons(pmap, ray);
| 651 |
| 652 |
/* Need at least 2 photons */
| 653 |
if (pmap -> squeueEnd < 2) {
| 654 |
#ifdef PMAP_NONEFOUND
| 655 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)",
| 656 |
ray -> ro ? ray -> ro -> oname : "<null>",
| 657 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]);
| 658 |
error(WARNING, errmsg);
| 659 |
#endif
| 660 |
| 661 |
return;
| 662 |
| 663 |
| 664 |
if (pmap -> minGather == pmap -> maxGather) {
| 665 |
/* No bias compensation. Just do a plain vanilla estimate */
| 666 |
sq = pmap -> squeue + 1;
| 667 |
| 668 |
/* Average radius between furthest two photons to improve accuracy */
| 669 |
r = max(sq -> dist, (sq + 1) -> dist);
| 670 |
r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r));
| 671 |
| 672 |
/* Skip the extra photon */
| 673 |
for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) {
| 674 |
getPhotonFlux(sq -> photon, flux);
| 675 |
#ifdef PMAP_EPANECHNIKOV
| 676 |
/* Apply Epanechnikov kernel to photon flux (dists are squared) */
| 677 |
scalecolor(flux, 2 * (1 - sq -> dist / r));
| 678 |
#endif
| 679 |
addcolor(irrad, flux);
| 680 |
| 681 |
| 682 |
/* Divide by search area PI * r^2, 1 / PI required as ambient
| 683 |
normalisation factor */
| 684 |
scalecolor(irrad, 1 / (PI * PI * r));
| 685 |
| 686 |
return;
| 687 |
| 688 |
else
| 689 |
/* Apply bias compensation to density estimate */
| 690 |
biasComp(pmap, irrad);
| 691 |
| 692 |
| 693 |
| 694 |
| 695 |
void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad)
| 696 |
/* Returns precomputed photon density estimate at ray -> rop. */
| 697 |
| 698 |
Photon *p;
| 699 |
| 700 |
| 701 |
| 702 |
| 703 |
if (r -> ro && islight(objptr(r -> ro -> omod) -> otype))
| 704 |
return;
| 705 |
| 706 |
if ((p = find1Photon(preCompPmap, r)))
| 707 |
getPhotonFlux(p, irrad);
| 708 |
| 709 |
| 710 |
| 711 |
| 712 |
void volumePhotonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad)
| 713 |
/* Photon volume density estimate. Returns irradiance at ray -> rop. */
| 714 |
| 715 |
unsigned i;
| 716 |
PhotonSQNode *sq;
| 717 |
float gecc2, r, ph;
| 718 |
COLOR flux;
| 719 |
| 720 |
| 721 |
| 722 |
| 723 |
return;
| 724 |
| 725 |
| 726 |
| 727 |
| 728 |
| 729 |
| 730 |
return;
| 731 |
| 732 |
| 733 |
| 734 |
gecc2 = ray -> gecc * ray -> gecc;
| 735 |
| 736 |
| 737 |
| 738 |
| 739 |
| 740 |
| 741 |
| 742 |
| 743 |
/* Compute phase function for inscattering from photon */
| 744 |
if (gecc2 <= FTINY)
| 745 |
ph = 1;
| 746 |
else {
| 747 |
ph = DOT(ray -> rdir, sq -> photon -> norm) / 127;
| 748 |
ph = 1 + gecc2 - 2 * ray -> gecc * ph;
| 749 |
ph = (1 - gecc2) / (ph * sqrt(ph));
| 750 |
| 751 |
| 752 |
| 753 |
scalecolor(flux, ph);
| 754 |
| 755 |
| 756 |
| 757 |
/* Divide by search volume 4 / 3 * PI * r^3 and phase function
| 758 |
normalization factor 1 / (4 * PI) */
| 759 |
scalecolor(irrad, 3 / (16 * PI * PI * r * sqrt(r)));
| 760 |
| 761 |
return;
| 762 |
| 763 |
| 764 |
else
| 765 |
| 766 |
volumeBiasComp(pmap, ray, irrad);
| 767 |
