1 |
2 |
3 |
Photon map main module |
4 |
5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
6 |
(c) Fraunhofer Institute for Solar Energy Systems, |
7 |
Lucerne University of Applied Sciences & Arts |
8 |
9 |
10 |
$Id: pmap.c,v 2.2 2015/04/21 19:16:51 greg Exp $ |
11 |
12 |
13 |
14 |
15 |
#include "pmap.h" |
16 |
#include "pmapmat.h" |
17 |
#include "pmapsrc.h" |
18 |
#include "pmaprand.h" |
19 |
#include "pmapio.h" |
20 |
#include "pmapbias.h" |
21 |
#include "pmapdiag.h" |
22 |
#include "otypes.h" |
23 |
#include <time.h> |
24 |
#include <sys/stat.h> |
25 |
26 |
27 |
28 |
extern char *octname; |
29 |
30 |
static char PmapRevision [] = "$Revision: 2.2 $"; |
31 |
32 |
33 |
34 |
/* Photon map lookup functions per type */ |
35 |
void (*pmapLookup [NUM_PMAP_TYPES])(PhotonMap*, RAY*, COLOR) = { |
36 |
photonDensity, photonPreCompDensity, photonDensity, volumePhotonDensity, |
37 |
photonDensity, NULL |
38 |
39 |
40 |
41 |
42 |
void colorNorm (COLOR c) |
43 |
/* Normalise colour channels to average of 1 */ |
44 |
45 |
const float avg = colorAvg(c); |
46 |
47 |
if (!avg) |
48 |
return; |
49 |
50 |
c [0] /= avg; |
51 |
c [1] /= avg; |
52 |
c [2] /= avg; |
53 |
54 |
55 |
56 |
57 |
void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *parm) |
58 |
59 |
unsigned t; |
60 |
struct stat octstat, pmstat; |
61 |
PhotonMap *pm; |
62 |
PhotonMapType type; |
63 |
64 |
for (t = 0; t < NUM_PMAP_TYPES; t++) |
65 |
if (setPmapParam(&pm, parm + t)) { |
66 |
/* Check if photon map newer than octree */ |
67 |
if (!stat(pm -> fileName, &pmstat) && !stat(octname, &octstat) && |
68 |
octstat.st_mtime > pmstat.st_mtime) { |
69 |
sprintf(errmsg, "photon map in file %s may be stale", |
70 |
pm -> fileName); |
71 |
error(USER, errmsg); |
72 |
73 |
74 |
/* Load photon map from file and get its type */ |
75 |
if ((type = loadPhotonMap(pm, pm -> fileName)) == PMAP_TYPE_NONE) |
76 |
error(USER, "failed loading photon map"); |
77 |
78 |
/* Assign to appropriate photon map type (deleting previously |
79 |
* loaded photon map of same type if necessary) */ |
80 |
if (pmaps [type]) { |
81 |
deletePhotons(pmaps [type]); |
82 |
free(pmaps [type]); |
83 |
84 |
pmaps [type] = pm; |
85 |
86 |
/* Check for invalid density estimate bandwidth */ |
87 |
if (pm -> maxGather > pm -> heapSize) { |
88 |
error(WARNING, "adjusting density estimate bandwidth"); |
89 |
pm -> minGather = pm -> maxGather = pm -> heapSize; |
90 |
91 |
92 |
93 |
94 |
95 |
96 |
void savePmaps (const PhotonMap **pmaps, int argc, char **argv) |
97 |
98 |
unsigned t; |
99 |
100 |
for (t = 0; t < NUM_PMAP_TYPES; t++) { |
101 |
if (pmaps [t]) |
102 |
savePhotonMap(pmaps [t], pmaps [t] -> fileName, t, argc, argv); |
103 |
104 |
105 |
106 |
107 |
108 |
void cleanUpPmaps (PhotonMap **pmaps) |
109 |
110 |
unsigned t; |
111 |
112 |
113 |
if (pmaps [t]) { |
114 |
deletePhotons(pmaps [t]); |
115 |
free(pmaps [t]); |
116 |
117 |
118 |
119 |
120 |
121 |
122 |
static int photonParticipate (RAY *ray) |
123 |
/* Trace photon through participating medium. Returns 1 if passed through, |
124 |
or 0 if absorbed and $*%&ed. Analogon to rayparticipate(). */ |
125 |
126 |
int i; |
127 |
RREAL cosTheta, cosPhi, du, dv; |
128 |
const float cext = colorAvg(ray -> cext), |
129 |
albedo = colorAvg(ray -> albedo); |
130 |
FVECT u, v; |
131 |
COLOR cvext; |
132 |
133 |
/* Mean free distance until interaction with medium */ |
134 |
ray -> rmax = -log(pmapRandom(mediumState)) / cext; |
135 |
136 |
while (!localhit(ray, &thescene)) { |
137 |
setcolor(cvext, exp(-ray -> rmax * ray -> cext [0]), |
138 |
exp(-ray -> rmax * ray -> cext [1]), |
139 |
exp(-ray -> rmax * ray -> cext [2])); |
140 |
141 |
/* Modify ray color and normalise */ |
142 |
multcolor(ray -> rcol, cvext); |
143 |
colorNorm(ray -> rcol); |
144 |
VCOPY(ray -> rorg, ray -> rop); |
145 |
146 |
if (albedo > FTINY) |
147 |
/* Add to volume photon map */ |
148 |
if (ray -> rlvl > 0) addPhoton(volumePmap, ray); |
149 |
150 |
/* Absorbed? */ |
151 |
if (pmapRandom(rouletteState) > albedo) return 0; |
152 |
153 |
/* Colour bleeding without attenuation (?) */ |
154 |
multcolor(ray -> rcol, ray -> albedo); |
155 |
scalecolor(ray -> rcol, 1 / albedo); |
156 |
157 |
/* Scatter photon */ |
158 |
cosTheta = ray -> gecc <= FTINY ? 2 * pmapRandom(scatterState) - 1 |
159 |
: 1 / (2 * ray -> gecc) * |
160 |
(1 + ray -> gecc * ray -> gecc - |
161 |
(1 - ray -> gecc * ray -> gecc) / |
162 |
(1 - ray -> gecc + 2 * ray -> gecc * |
163 |
pmapRandom(scatterState))); |
164 |
165 |
cosPhi = cos(2 * PI * pmapRandom(scatterState)); |
166 |
du = dv = sqrt(1 - cosTheta * cosTheta); /* sin(theta) */ |
167 |
du *= cosPhi; |
168 |
dv *= sqrt(1 - cosPhi * cosPhi); /* sin(phi) */ |
169 |
170 |
/* Get axes u & v perpendicular to photon direction */ |
171 |
i = 0; |
172 |
do { |
173 |
v [0] = v [1] = v [2] = 0; |
174 |
v [i++] = 1; |
175 |
fcross(u, v, ray -> rdir); |
176 |
} while (normalize(u) < FTINY); |
177 |
fcross(v, ray -> rdir, u); |
178 |
179 |
for (i = 0; i < 3; i++) |
180 |
ray -> rdir [i] = du * u [i] + dv * v [i] + |
181 |
cosTheta * ray -> rdir [i]; |
182 |
ray -> rlvl++; |
183 |
184 |
185 |
186 |
setcolor(cvext, exp(-ray -> rot * ray -> cext [0]), |
187 |
exp(-ray -> rot * ray -> cext [1]), |
188 |
exp(-ray -> rot * ray -> cext [2])); |
189 |
190 |
191 |
192 |
193 |
194 |
/* Passed through medium */ |
195 |
return 1; |
196 |
197 |
198 |
199 |
200 |
void tracePhoton (RAY *ray) |
201 |
/* Follow photon as it bounces around... */ |
202 |
203 |
long mod; |
204 |
OBJREC* mat; |
205 |
206 |
if (ray -> rlvl > photonMaxBounce) { |
207 |
error(WARNING, "runaway photon!"); |
208 |
return; |
209 |
210 |
211 |
if (colorAvg(ray -> cext) > FTINY && !photonParticipate(ray)) |
212 |
return; |
213 |
214 |
if (localhit(ray, &thescene)) { |
215 |
mod = ray -> ro -> omod; |
216 |
217 |
if ((ray -> clipset && inset(ray -> clipset, mod)) || mod == OVOID) { |
218 |
/* Transfer ray if modifier is VOID or clipped within antimatta */ |
219 |
RAY tray; |
220 |
photonRay(ray, &tray, PMAP_XFER, NULL); |
221 |
tracePhoton(&tray); |
222 |
223 |
else { |
224 |
/* Scatter for modifier material */ |
225 |
mat = objptr(mod); |
226 |
photonScatter [mat -> otype] (mat, ray); |
227 |
228 |
229 |
230 |
231 |
232 |
233 |
static void preComputeGlobal (PhotonMap *pmap) |
234 |
/* Precompute irradiance from global photons for final gathering using |
235 |
the first finalGather * pmap -> heapSize photons in the heap. Returns |
236 |
new heap with precomputed photons. */ |
237 |
238 |
unsigned long i, nuHeapSize; |
239 |
unsigned j; |
240 |
Photon *nuHeap, *p; |
241 |
COLOR irrad; |
242 |
RAY ray; |
243 |
float nuMinPos [3], nuMaxPos [3]; |
244 |
245 |
repComplete = nuHeapSize = finalGather * pmap -> heapSize; |
246 |
247 |
if (photonRepTime) { |
248 |
sprintf(errmsg, |
249 |
"Precomputing irradiance for %ld global photons...\n", |
250 |
nuHeapSize); |
251 |
eputs(errmsg); |
252 |
fflush(stderr); |
253 |
254 |
255 |
p = nuHeap = (Photon*)malloc(nuHeapSize * sizeof(Photon)); |
256 |
if (!nuHeap) |
257 |
error(USER, "can't allocate photon heap"); |
258 |
259 |
for (j = 0; j <= 2; j++) { |
260 |
nuMinPos [j] = FHUGE; |
261 |
nuMaxPos [j] = -FHUGE; |
262 |
263 |
264 |
/* Record start time, baby */ |
265 |
repStartTime = time(NULL); |
266 |
#ifdef SIGCONT |
267 |
signal(SIGCONT, pmapPreCompReport); |
268 |
#endif |
269 |
repProgress = 0; |
270 |
memcpy(nuHeap, pmap -> heap, nuHeapSize * sizeof(Photon)); |
271 |
272 |
for (i = 0, p = nuHeap; i < nuHeapSize; i++, p++) { |
273 |
ray.ro = NULL; |
274 |
VCOPY(ray.rop, p -> pos); |
275 |
276 |
/* Update min and max positions & set ray normal */ |
277 |
for (j = 0; j < 3; j++) { |
278 |
if (p -> pos [j] < nuMinPos [j]) nuMinPos [j] = p -> pos [j]; |
279 |
if (p -> pos [j] > nuMaxPos [j]) nuMaxPos [j] = p -> pos [j]; |
280 |
ray.ron [j] = p -> norm [j] / 127.0; |
281 |
282 |
283 |
photonDensity(pmap, &ray, irrad); |
284 |
setPhotonFlux(p, irrad); |
285 |
repProgress++; |
286 |
287 |
if (photonRepTime > 0 && time(NULL) >= repLastTime + photonRepTime) |
288 |
pmapPreCompReport(); |
289 |
#ifdef SIGCONT |
290 |
else signal(SIGCONT, pmapPreCompReport); |
291 |
#endif |
292 |
293 |
294 |
#ifdef SIGCONT |
295 |
signal(SIGCONT, SIG_DFL); |
296 |
#endif |
297 |
298 |
/* Replace & rebuild heap */ |
299 |
free(pmap -> heap); |
300 |
pmap -> heap = nuHeap; |
301 |
pmap -> heapSize = pmap -> heapEnd = nuHeapSize; |
302 |
VCOPY(pmap -> minPos, nuMinPos); |
303 |
VCOPY(pmap -> maxPos, nuMaxPos); |
304 |
305 |
306 |
eputs("Rebuilding global photon heap...\n"); |
307 |
fflush(stderr); |
308 |
309 |
310 |
balancePhotons(pmap, NULL); |
311 |
312 |
313 |
314 |
315 |
void distribPhotons (PhotonMap **pmaps) |
316 |
317 |
EmissionMap emap; |
318 |
char errmsg2 [128]; |
319 |
unsigned t, srcIdx, passCnt = 0, prePassCnt = 0; |
320 |
double totalFlux = 0; |
321 |
PhotonMap *pm; |
322 |
323 |
for (t = 0; t < NUM_PMAP_TYPES && !photonMaps [t]; t++); |
324 |
if (t >= NUM_PMAP_TYPES) |
325 |
error(USER, "no photon maps defined"); |
326 |
327 |
if (!nsources) |
328 |
error(USER, "no light sources"); |
329 |
330 |
331 |
* INITIALISATION - Set up emission and scattering funcs |
332 |
333 |
emap.samples = NULL; |
334 |
emap.maxPartitions = MAXSPART; |
335 |
emap.partitions = (unsigned char*)malloc(emap.maxPartitions >> 1); |
336 |
if (!emap.partitions) |
337 |
error(INTERNAL, "can't allocate source partitions"); |
338 |
339 |
/* Initialise all defined photon maps */ |
340 |
341 |
initPhotonMap(photonMaps [t], t); |
342 |
343 |
initPhotonEmissionFuncs(); |
344 |
initPhotonScatterFuncs(); |
345 |
346 |
/* Get photon ports if specified */ |
347 |
if (ambincl == 1) |
348 |
getPhotonPorts(); |
349 |
350 |
/* Get photon sensor modifiers */ |
351 |
getPhotonSensors(photonSensorList); |
352 |
353 |
/* Seed RNGs for photon distribution */ |
354 |
pmapSeed(randSeed, partState); |
355 |
pmapSeed(randSeed, emitState); |
356 |
pmapSeed(randSeed, cntState); |
357 |
pmapSeed(randSeed, mediumState); |
358 |
pmapSeed(randSeed, scatterState); |
359 |
pmapSeed(randSeed, rouletteState); |
360 |
361 |
if (photonRepTime) |
362 |
eputs("\n"); |
363 |
364 |
365 |
* FLUX INTEGRATION - Get total photon flux from light sources |
366 |
367 |
for (srcIdx = 0; srcIdx < nsources; srcIdx++) { |
368 |
unsigned portCnt = 0; |
369 |
emap.src = source + srcIdx; |
370 |
371 |
do { |
372 |
emap.port = emap.src -> sflags & SDISTANT ? photonPorts + portCnt |
373 |
: NULL; |
374 |
photonPartition [emap.src -> so -> otype] (&emap); |
375 |
376 |
377 |
sprintf(errmsg, "Integrating flux from source %s ", |
378 |
source [srcIdx].so -> oname); |
379 |
380 |
if (emap.port) { |
381 |
sprintf(errmsg2, "via port %s ", |
382 |
photonPorts [portCnt].so -> oname); |
383 |
strcat(errmsg, errmsg2); |
384 |
385 |
386 |
sprintf(errmsg2, "(%lu partitions)...\n", emap.numPartitions); |
387 |
388 |
eputs(errmsg); |
389 |
fflush(stderr); |
390 |
391 |
392 |
for (emap.partitionCnt = 0; emap.partitionCnt < emap.numPartitions; |
393 |
emap.partitionCnt++) { |
394 |
initPhotonEmission(&emap, pdfSamples); |
395 |
totalFlux += colorAvg(emap.partFlux); |
396 |
397 |
398 |
portCnt++; |
399 |
} while (portCnt < numPhotonPorts); |
400 |
401 |
402 |
if (totalFlux < FTINY) |
403 |
error(USER, "zero flux from light sources"); |
404 |
405 |
/* Record start time and enable progress report signal handler */ |
406 |
407 |
#ifdef SIGCONT |
408 |
signal(SIGCONT, pmapDistribReport); |
409 |
#endif |
410 |
repProgress = prePassCnt = 0; |
411 |
412 |
413 |
eputs("\n"); |
414 |
415 |
416 |
* 2-PASS PHOTON DISTRIBUTION |
417 |
* Pass 1 (pre): emit fraction of target photon count |
418 |
* Pass 2 (main): based on outcome of pass 1, estimate remaining number |
419 |
* of photons to emit to approximate target count |
420 |
421 |
do { |
422 |
double numEmit; |
423 |
424 |
if (!passCnt) { |
425 |
/* INIT PASS 1 */ |
426 |
/* Skip if no photons contributed after sufficient iterations; make |
427 |
* it clear to user which photon maps are missing so (s)he can |
428 |
* check the scene geometry and materials */ |
429 |
if (++prePassCnt > maxPreDistrib) { |
430 |
sprintf(errmsg, "too many prepasses"); |
431 |
432 |
433 |
if (photonMaps [t] && !photonMaps [t] -> heapEnd) { |
434 |
sprintf(errmsg2, ", no %s photons stored", pmapName [t]); |
435 |
436 |
437 |
438 |
439 |
break; |
440 |
441 |
442 |
/* Num to emit is fraction of minimum target count */ |
443 |
numEmit = FHUGE; |
444 |
445 |
446 |
if (photonMaps [t]) |
447 |
numEmit = min(photonMaps [t] -> distribTarget, numEmit); |
448 |
449 |
numEmit *= preDistrib; |
450 |
451 |
452 |
else { |
453 |
/* INIT PASS 2 */ |
454 |
/* Based on the outcome of the predistribution we can now estimate |
455 |
* how many more photons we have to emit for each photon map to |
456 |
* meet its respective target count. This value is clamped to 0 in |
457 |
* case the target has already been exceeded in the pass 1. Note |
458 |
* repProgress is the number of photons emitted thus far, while |
459 |
* heapEnd is the number of photons stored in each photon map. */ |
460 |
double maxDistribRatio = 0; |
461 |
462 |
/* Set the distribution ratio for each map; this indicates how many |
463 |
* photons of each respective type are stored per emitted photon, |
464 |
* and is used as probability for storing a photon by addPhoton(). |
465 |
* Since this biases the photon density, addPhoton() promotes the |
466 |
* flux of stored photons to compensate. */ |
467 |
468 |
if ((pm = photonMaps [t])) { |
469 |
pm -> distribRatio = (double)pm -> distribTarget / |
470 |
pm -> heapEnd - 1; |
471 |
472 |
/* Check if photon map "overflowed", i.e. exceeded its target |
473 |
* count in the prepass; correcting the photon flux via the |
474 |
* distribution ratio is no longer possible, as no more |
475 |
* photons of this type will be stored, so notify the user |
476 |
* rather than deliver incorrect results. |
477 |
* In future we should handle this more intelligently by |
478 |
* using the photonFlux in each photon map to individually |
479 |
* correct the flux after distribution. */ |
480 |
if (pm -> distribRatio <= FTINY) { |
481 |
sprintf(errmsg, |
482 |
"%s photon map overflow in prepass, reduce -apD", |
483 |
pmapName [t]); |
484 |
error(INTERNAL, errmsg); |
485 |
486 |
487 |
maxDistribRatio = max(pm -> distribRatio, maxDistribRatio); |
488 |
489 |
490 |
/* Normalise distribution ratios and calculate number of photons to |
491 |
* emit in main pass */ |
492 |
493 |
if ((pm = photonMaps [t])) |
494 |
pm -> distribRatio /= maxDistribRatio; |
495 |
496 |
if ((numEmit = repProgress * maxDistribRatio) < FTINY) |
497 |
/* No photons left to distribute in main pass */ |
498 |
break; |
499 |
500 |
501 |
/* Set completion count for progress report */ |
502 |
repComplete = numEmit + repProgress; |
503 |
504 |
/* PHOTON DISTRIBUTION LOOP */ |
505 |
506 |
507 |
508 |
509 |
do { |
510 |
511 |
: NULL; |
512 |
513 |
514 |
515 |
if (!passCnt) |
516 |
sprintf(errmsg, "PREPASS %d on source %s ", |
517 |
prePassCnt, source [srcIdx].so -> oname); |
518 |
else |
519 |
sprintf(errmsg, "MAIN PASS on source %s ", |
520 |
521 |
522 |
if (emap.port) { |
523 |
524 |
525 |
526 |
527 |
528 |
529 |
530 |
eputs(errmsg); |
531 |
fflush(stderr); |
532 |
533 |
534 |
535 |
536 |
double partNumEmit; |
537 |
unsigned long partEmitCnt; |
538 |
539 |
/* Get photon origin within current source partishunn and |
540 |
* build emission map */ |
541 |
photonOrigin [emap.src -> so -> otype] (&emap); |
542 |
543 |
544 |
/* Number of photons to emit from ziss partishunn -- |
545 |
* proportional to flux; photon ray weight and scalar flux |
546 |
* are uniform (the latter only varying in RGB). */ |
547 |
partNumEmit = numEmit * colorAvg(emap.partFlux) / totalFlux; |
548 |
partEmitCnt = (unsigned long)partNumEmit; |
549 |
550 |
/* Probabilistically account for fractional photons */ |
551 |
if (pmapRandom(cntState) < partNumEmit - partEmitCnt) |
552 |
partEmitCnt++; |
553 |
554 |
/* Integer counter avoids FP rounding errors */ |
555 |
while (partEmitCnt--) { |
556 |
RAY photonRay; |
557 |
558 |
/* Emit photon based on PDF and trace through scene until |
559 |
* absorbed/leaked */ |
560 |
emitPhoton(&emap, &photonRay); |
561 |
tracePhoton(&photonRay); |
562 |
563 |
/* Record progress */ |
564 |
repProgress++; |
565 |
566 |
if (photonRepTime > 0 && |
567 |
568 |
pmapDistribReport(); |
569 |
#ifdef SIGCONT |
570 |
else signal(SIGCONT, pmapDistribReport); |
571 |
#endif |
572 |
573 |
574 |
575 |
portCnt++; |
576 |
577 |
578 |
579 |
580 |
581 |
/* Double preDistrib in case a photon map is empty and redo |
582 |
* pass 1 --> possibility of infinite loop for pathological |
583 |
* scenes (e.g. absorbing materials) */ |
584 |
preDistrib *= 2; |
585 |
break; |
586 |
587 |
588 |
if (t >= NUM_PMAP_TYPES) { |
589 |
/* No empty photon maps found; now do pass 2 */ |
590 |
passCnt++; |
591 |
592 |
eputs("\n"); |
593 |
594 |
} while (passCnt < 2); |
595 |
596 |
597 |
* POST-DISTRIBUTION - Set photon flux and build kd-tree, etc. |
598 |
599 |
#ifdef SIGCONT |
600 |
601 |
#endif |
602 |
free(emap.samples); |
603 |
604 |
/* Set photon flux (repProgress is total num emitted) */ |
605 |
totalFlux /= repProgress; |
606 |
607 |
608 |
if (photonMaps [t]) { |
609 |
610 |
sprintf(errmsg, "\nBuilding %s photon map...\n", pmapName [t]); |
611 |
eputs(errmsg); |
612 |
fflush(stderr); |
613 |
614 |
615 |
balancePhotons(photonMaps [t], &totalFlux); |
616 |
617 |
618 |
/* Precompute photon irradiance if necessary */ |
619 |
if (preCompPmap) |
620 |
preComputeGlobal(preCompPmap); |
621 |
622 |
623 |
624 |
625 |
void photonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad) |
626 |
/* Photon density estimate. Returns irradiance at ray -> rop. */ |
627 |
628 |
unsigned i; |
629 |
PhotonSQNode *sq; |
630 |
float r; |
631 |
COLOR flux; |
632 |
633 |
setcolor(irrad, 0, 0, 0); |
634 |
635 |
if (!pmap -> maxGather) |
636 |
return; |
637 |
638 |
/* Ignore sources */ |
639 |
if (ray -> ro) |
640 |
if (islight(objptr(ray -> ro -> omod) -> otype)) |
641 |
return; |
642 |
643 |
pmap -> squeueEnd = 0; |
644 |
findPhotons(pmap, ray); |
645 |
646 |
/* Need at least 2 photons */ |
647 |
if (pmap -> squeueEnd < 2) { |
648 |
#ifdef PMAP_NONEFOUND |
649 |
sprintf(errmsg, "no photons found on %s at (%.3f, %.3f, %.3f)", |
650 |
ray -> ro ? ray -> ro -> oname : "<null>", |
651 |
ray -> rop [0], ray -> rop [1], ray -> rop [2]); |
652 |
error(WARNING, errmsg); |
653 |
#endif |
654 |
655 |
return; |
656 |
657 |
658 |
if (pmap -> minGather == pmap -> maxGather) { |
659 |
/* No bias compensation. Just do a plain vanilla estimate */ |
660 |
sq = pmap -> squeue + 1; |
661 |
662 |
/* Average radius between furthest two photons to improve accuracy */ |
663 |
r = max(sq -> dist, (sq + 1) -> dist); |
664 |
r = 0.25 * (pmap -> maxDist + r + 2 * sqrt(pmap -> maxDist * r)); |
665 |
666 |
/* Skip the extra photon */ |
667 |
for (i = 1 ; i < pmap -> squeueEnd; i++, sq++) { |
668 |
getPhotonFlux(sq -> photon, flux); |
669 |
#ifdef PMAP_EPANECHNIKOV |
670 |
/* Apply Epanechnikov kernel to photon flux (dists are squared) */ |
671 |
scalecolor(flux, 2 * (1 - sq -> dist / r)); |
672 |
#endif |
673 |
addcolor(irrad, flux); |
674 |
675 |
676 |
/* Divide by search area PI * r^2, 1 / PI required as ambient |
677 |
normalisation factor */ |
678 |
scalecolor(irrad, 1 / (PI * PI * r)); |
679 |
680 |
return; |
681 |
682 |
else |
683 |
/* Apply bias compensation to density estimate */ |
684 |
biasComp(pmap, irrad); |
685 |
686 |
687 |
688 |
689 |
void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad) |
690 |
/* Returns precomputed photon density estimate at ray -> rop. */ |
691 |
692 |
Photon *p; |
693 |
694 |
695 |
696 |
697 |
if (r -> ro && islight(objptr(r -> ro -> omod) -> otype)) |
698 |
return; |
699 |
700 |
if ((p = find1Photon(preCompPmap, r))) |
701 |
getPhotonFlux(p, irrad); |
702 |
703 |
704 |
705 |
706 |
void volumePhotonDensity (PhotonMap *pmap, RAY *ray, COLOR irrad) |
707 |
/* Photon volume density estimate. Returns irradiance at ray -> rop. */ |
708 |
709 |
unsigned i; |
710 |
PhotonSQNode *sq; |
711 |
float gecc2, r, ph; |
712 |
COLOR flux; |
713 |
714 |
715 |
716 |
717 |
return; |
718 |
719 |
720 |
721 |
722 |
723 |
if (pmap -> squeueEnd < 2) |
724 |
return; |
725 |
726 |
727 |
728 |
gecc2 = ray -> gecc * ray -> gecc; |
729 |
730 |
731 |
732 |
733 |
734 |
735 |
736 |
737 |
/* Compute phase function for inscattering from photon */ |
738 |
if (gecc2 <= FTINY) |
739 |
ph = 1; |
740 |
else { |
741 |
ph = DOT(ray -> rdir, sq -> photon -> norm) / 127; |
742 |
ph = 1 + gecc2 - 2 * ray -> gecc * ph; |
743 |
ph = (1 - gecc2) / (ph * sqrt(ph)); |
744 |
745 |
746 |
747 |
scalecolor(flux, ph); |
748 |
749 |
750 |
751 |
/* Divide by search volume 4 / 3 * PI * r^3 and phase function |
752 |
normalization factor 1 / (4 * PI) */ |
753 |
scalecolor(irrad, 3 / (16 * PI * PI * r * sqrt(r))); |
754 |
755 |
return; |
756 |
757 |
758 |
else |
759 |
760 |
volumeBiasComp(pmap, ray, irrad); |
761 |
