1 |
/* Copyright (c) 1996 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for persistent rtrace and rpict processes. |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#ifdef F_SETLKW |
14 |
#include "paths.h" |
15 |
#include <signal.h> |
16 |
#include <sys/types.h> |
17 |
#include <sys/select.h> |
18 |
#include <sys/stat.h> |
19 |
/* select call compatibility stuff */ |
20 |
#ifndef FD_SETSIZE |
21 |
#include <sys/param.h> |
22 |
#define FD_SETSIZE NOFILE /* maximum # select file descriptors */ |
23 |
#endif |
24 |
#ifndef FD_SET |
25 |
#ifndef NFDBITS |
26 |
#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */ |
27 |
#endif |
28 |
#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS))) |
29 |
#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS))) |
30 |
#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS))) |
31 |
#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p))) |
32 |
#endif |
33 |
34 |
#ifndef TIMELIM |
35 |
#define TIMELIM (8*3600) /* time limit for holding pattern */ |
36 |
#endif |
37 |
38 |
extern char *strcpy(), *index(); |
39 |
40 |
extern int headismine; /* boolean true if header belongs to me */ |
41 |
42 |
extern char *progname; /* global program name */ |
43 |
44 |
extern char *errfile; /* global error file name */ |
45 |
46 |
static char *persistfname = NULL; /* persist file name */ |
47 |
static int persistfd = -1; /* persist file descriptor */ |
48 |
49 |
static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; |
50 |
51 |
52 |
pfdetach() /* release persist (and header) resources */ |
53 |
54 |
if (persistfd >= 0) |
55 |
close(persistfd); |
56 |
persistfd = -1; |
57 |
persistfname = NULL; |
58 |
inpname[0] = '\0'; |
59 |
outpname[0] = '\0'; |
60 |
errname[0] = '\0'; |
61 |
headismine = 0; |
62 |
63 |
64 |
65 |
pfclean() /* clean up persist files */ |
66 |
67 |
68 |
close(persistfd); |
69 |
if (persistfname != NULL) |
70 |
unlink(persistfname); |
71 |
if (inpname[0]) |
72 |
unlink(inpname); |
73 |
if (outpname[0]) |
74 |
unlink(outpname); |
75 |
if (errname[0]) |
76 |
unlink(errname); |
77 |
78 |
79 |
80 |
pflock(lf) /* place or release exclusive lock on file */ |
81 |
int lf; |
82 |
83 |
struct flock fls; |
84 |
85 |
fls.l_type = lf ? F_WRLCK : F_UNLCK; |
86 |
fls.l_whence = 0; |
87 |
fls.l_start = 0L; |
88 |
fls.l_len = 0L; |
89 |
if (fcntl(persistfd, F_SETLKW, &fls) < 0) |
90 |
error(SYSTEM, "cannot (un)lock persist file"); |
91 |
92 |
93 |
94 |
persistfile(pfn) /* open persist file and lock it */ |
95 |
char *pfn; |
96 |
97 |
persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); |
98 |
if (persistfd >= 0) { |
99 |
persistfname = pfn; |
100 |
pflock(1); |
101 |
return; |
102 |
103 |
/* file exists -- switch to i/o process */ |
104 |
persistfd = open(pfn, O_RDWR); |
105 |
if (persistfd < 0) { |
106 |
sprintf(errmsg, "cannot open persist file \"%s\"", pfn); |
107 |
error(SYSTEM, errmsg); |
108 |
109 |
pflock(1); |
110 |
io_process(); /* never returns */ |
111 |
112 |
113 |
114 |
static int got_io; |
115 |
116 |
static int sig_io() { got_io++; } |
117 |
118 |
static int sig_alrm() { quit(0); } |
119 |
120 |
121 |
pfhold() /* holding pattern for idle rendering process */ |
122 |
123 |
int (*oldalrm)(); |
124 |
char buf[512]; |
125 |
register int n; |
126 |
/* close input and output descriptors */ |
127 |
close(fileno(stdin)); |
128 |
close(fileno(stdout)); |
129 |
if (errfile == NULL) |
130 |
close(fileno(stderr)); |
131 |
/* create named pipes for input and output */ |
132 |
if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) |
133 |
goto createrr; |
134 |
if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) |
135 |
goto createrr; |
136 |
if (errfile == NULL && |
137 |
mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0) |
138 |
goto createrr; |
139 |
sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), |
140 |
inpname, outpname, errname); |
141 |
n = strlen(buf); |
142 |
if (write(persistfd, buf, n) < n) |
143 |
error(SYSTEM, "error writing persist file"); |
144 |
lseek(persistfd, 0L, 0); |
145 |
/* wait TIMELIM for someone to signal us */ |
146 |
got_io = 0; |
147 |
signal(SIGIO, sig_io); |
148 |
oldalrm = (int (*)())signal(SIGALRM, sig_alrm); |
149 |
alarm(TIMELIM); |
150 |
pflock(0); /* unlock persist file for attach */ |
151 |
while (!got_io) |
152 |
pause(); /* wait for attach */ |
153 |
alarm(0); /* turn off alarm */ |
154 |
signal(SIGALRM, oldalrm); |
155 |
signal(SIGIO, SIG_DFL); |
156 |
pflock(1); /* grab persist file back */ |
157 |
/* someone wants us; reopen stdin and stdout */ |
158 |
if (freopen(inpname, "r", stdin) == NULL) |
159 |
goto openerr; |
160 |
if (freopen(outpname, "w", stdout) == NULL) |
161 |
goto openerr; |
162 |
if (errname[0]) { |
163 |
if (freopen(errname, "w", stderr) == NULL) |
164 |
goto openerr; |
165 |
unlink(errname); |
166 |
167 |
168 |
unlink(inpname); |
169 |
170 |
unlink(outpname); |
171 |
172 |
return; |
173 |
createrr: |
174 |
error(SYSTEM, "cannot create named pipes in pfhold"); |
175 |
openerr: |
176 |
error(SYSTEM, "cannot open named pipes in pfhold"); |
177 |
178 |
179 |
180 |
io_process() /* just act as go-between for actual process */ |
181 |
182 |
register char *cp; |
183 |
register int nr, n; |
184 |
char buf[BUFSIZ], *pfin, *pfout, *pferr; |
185 |
int pid, nfds; |
186 |
int fdin, fdout, fderr = -1; |
187 |
fd_set readfds, writefds, excepfds; |
188 |
/* load persist file */ |
189 |
n = 40; |
190 |
while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) { |
191 |
if (!n--) |
192 |
error(USER, "unattended persist file?"); |
193 |
pflock(0); |
194 |
sleep(15); /* wait until ready */ |
195 |
pflock(1); |
196 |
197 |
if (nr < 0) |
198 |
error(SYSTEM, "error reading persist file"); |
199 |
ftruncate(persistfd, 0L); /* truncate persist file */ |
200 |
pfdetach(); /* close & release persist file */ |
201 |
buf[nr] = '\0'; /* parse what we got */ |
202 |
if ((cp = index(buf, ' ')) == NULL) |
203 |
goto formerr; |
204 |
*cp++ = '\0'; |
205 |
if ((pid = atoi(cp)) <= 0) |
206 |
goto formerr; |
207 |
if ((cp = index(cp, '\n')) == NULL) |
208 |
goto formerr; |
209 |
pfin = ++cp; |
210 |
211 |
goto formerr; |
212 |
*cp++ = '\0'; |
213 |
pfout = cp; |
214 |
215 |
goto formerr; |
216 |
*cp++ = '\0'; |
217 |
pferr = cp; |
218 |
219 |
goto formerr; |
220 |
*cp++ = '\0'; |
221 |
if (cp-buf != nr) |
222 |
goto formerr; |
223 |
if (strcmp(buf, progname)) { |
224 |
sprintf(errmsg, "persist file for %s, not %s", buf, progname); |
225 |
error(USER, errmsg); |
226 |
227 |
/* wake up rendering process */ |
228 |
if (kill(pid, SIGIO) < 0) |
229 |
error(SYSTEM, "cannot signal rendering process in io_process"); |
230 |
/* open named pipes, in order */ |
231 |
if ((fdin = open(pfin, O_WRONLY)) < 0) |
232 |
error(SYSTEM, "cannot open input pipe in io_process"); |
233 |
if ((fdout = open(pfout, O_RDONLY)) < 0) |
234 |
error(SYSTEM, "cannot open output pipe in io_process"); |
235 |
if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0) |
236 |
error(SYSTEM, "cannot open error pipe in io_process"); |
237 |
for ( ; ; ) { /* loop on select call */ |
238 |
FD_ZERO(&readfds); |
239 |
FD_ZERO(&writefds); |
240 |
FD_ZERO(&excepfds); |
241 |
nfds = 0; |
242 |
if (fdin >= 0) { |
243 |
FD_SET(fdin, &writefds); |
244 |
FD_SET(fdin, &excepfds); |
245 |
nfds = fdin+1; |
246 |
247 |
if (fdout >= 0) { |
248 |
FD_SET(fdout, &readfds); |
249 |
FD_SET(fdout, &excepfds); |
250 |
nfds = fdout+1; |
251 |
252 |
if (fderr >= 0) { |
253 |
FD_SET(fderr, &readfds); |
254 |
FD_SET(fderr, &excepfds); |
255 |
nfds = fderr+1; |
256 |
257 |
if (nfds == 0) |
258 |
break; /* all done, exit */ |
259 |
if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0) |
260 |
error(SYSTEM, "error in select call in io_process"); |
261 |
/* renderer stderr */ |
262 |
if (fderr >= 0 && (FD_ISSET(fderr, &readfds) || |
263 |
FD_ISSET(fderr, &excepfds))) { |
264 |
nr = read(fderr, cp=buf, sizeof(buf)); |
265 |
if (nr < 0) |
266 |
goto readerr; |
267 |
if (nr == 0) { |
268 |
close(fderr); |
269 |
/* close(2); don't close stderr! */ |
270 |
fderr = -1; |
271 |
} else |
272 |
do { /* write it all */ |
273 |
if ((n = write(2, cp, nr)) <= 0) |
274 |
goto writerr; |
275 |
cp += n; |
276 |
} while ((nr -= n) > 0); |
277 |
278 |
/* renderer stdout */ |
279 |
if (fdout >= 0 && (FD_ISSET(fdout, &readfds) || |
280 |
FD_ISSET(fdout, &excepfds))) { |
281 |
nr = read(fdout, cp=buf, sizeof(buf)); |
282 |
if (nr < 0) |
283 |
goto readerr; |
284 |
if (nr == 0) { /* EOF */ |
285 |
close(fdout); |
286 |
close(1); |
287 |
fdout = -1; |
288 |
} else |
289 |
290 |
if ((n = write(1, cp, nr)) <= 0) |
291 |
goto writerr; |
292 |
cp += n; |
293 |
294 |
295 |
/* renderer stdin */ |
296 |
if (fdin >= 0 && (FD_ISSET(fdin, &writefds) || |
297 |
FD_ISSET(fdin, &excepfds))) { |
298 |
nr = read(0, buf, 512); /* use minimal buffer */ |
299 |
if (nr < 0) |
300 |
goto readerr; |
301 |
if (nr == 0) { |
302 |
close(0); |
303 |
close(fdin); |
304 |
fdin = -1; |
305 |
} else if (write(fdin, buf, nr) < nr) |
306 |
goto writerr; /* what else to do? */ |
307 |
308 |
309 |
_exit(0); /* we ought to return renderer error status! */ |
310 |
formerr: |
311 |
error(USER, "format error in persist file"); |
312 |
readerr: |
313 |
error(SYSTEM, "read error in io_process"); |
314 |
writerr: |
315 |
error(SYSTEM, "write error in io_process"); |
316 |
317 |
318 |
#else |
319 |
320 |
pfclean() {} |
321 |
322 |
#endif |
