root/radiance/ray/src/rt/persist.c
Revision: 2.18
Committed: Mon Jul 22 18:09:26 1996 UTC (27 years, 10 months ago) by greg
avoided close of standard error in io_process()
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for persistent rtrace and rpict processes.
9 */
10
11 #include "standard.h"
12
13 #ifdef F_SETLKW
14 #include "paths.h"
15 #include <signal.h>
16 #include <sys/types.h>
17 #include <sys/stat.h>
18 /* select call compatibility stuff */
19 #ifndef FD_SETSIZE
20 #include <sys/param.h>
21 #define FD_SETSIZE NOFILE /* maximum # select file descriptors */
22 #endif
23 #ifndef FD_SET
24 #ifndef NFDBITS
25 #define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */
26 #endif
27 #define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS)))
28 #define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS)))
29 #define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS)))
30 #define FD_ZERO(p) bzero((char *)(p), sizeof(*(p)))
31 #endif
32
33 #ifndef TIMELIM
34 #define TIMELIM (8*3600) /* time limit for holding pattern */
35 #endif
36
37 extern char *strcpy(), *index();
38
39 extern int headismine; /* boolean true if header belongs to me */
40
41 extern char *progname; /* global program name */
42
43 extern char *errfile; /* global error file name */
44
45 static char *persistfname = NULL; /* persist file name */
46 static int persistfd = -1; /* persist file descriptor */
47
48 static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1];
49
50
51 pfdetach() /* release persist (and header) resources */
52 {
53 if (persistfd >= 0)
54 close(persistfd);
55 persistfd = -1;
56 persistfname = NULL;
57 inpname[0] = '\0';
58 outpname[0] = '\0';
59 errname[0] = '\0';
60 headismine = 0;
61 }
62
63
64 pfclean() /* clean up persist files */
65 {
66 if (persistfd >= 0)
67 close(persistfd);
68 if (persistfname != NULL)
69 unlink(persistfname);
70 if (inpname[0])
71 unlink(inpname);
72 if (outpname[0])
73 unlink(outpname);
74 if (errname[0])
75 unlink(errname);
76 }
77
78
79 pflock(lf) /* place or release exclusive lock on file */
80 int lf;
81 {
82 struct flock fls;
83
84 fls.l_type = lf ? F_WRLCK : F_UNLCK;
85 fls.l_whence = 0;
86 fls.l_start = 0L;
87 fls.l_len = 0L;
88 if (fcntl(persistfd, F_SETLKW, &fls) < 0)
89 error(SYSTEM, "cannot (un)lock persist file");
90 }
91
92
93 persistfile(pfn) /* open persist file and lock it */
94 char *pfn;
95 {
96 persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644);
97 if (persistfd >= 0) {
98 persistfname = pfn;
99 pflock(1);
100 return;
101 }
102 /* file exists -- switch to i/o process */
103 persistfd = open(pfn, O_RDWR);
104 if (persistfd < 0) {
105 sprintf(errmsg, "cannot open persist file \"%s\"", pfn);
106 error(SYSTEM, errmsg);
107 }
108 pflock(1);
109 io_process(); /* never returns */
110 }
111
112
113 static int got_io;
114
115 static int sig_io() { got_io++; }
116
117 static int sig_alrm() { quit(0); }
118
119
120 pfhold() /* holding pattern for idle rendering process */
121 {
122 int (*oldalrm)();
123 char buf[512];
124 register int n;
125 /* close input and output descriptors */
126 close(fileno(stdin));
127 close(fileno(stdout));
128 if (errfile == NULL)
129 close(fileno(stderr));
130 /* create named pipes for input and output */
131 if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
132 goto createrr;
133 if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
134 goto createrr;
135 if (errfile == NULL &&
136 mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
137 goto createrr;
138 sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(),
139 inpname, outpname, errname);
140 n = strlen(buf);
141 if (write(persistfd, buf, n) < n)
142 error(SYSTEM, "error writing persist file");
143 lseek(persistfd, 0L, 0);
144 /* wait TIMELIM for someone to signal us */
145 got_io = 0;
146 signal(SIGIO, sig_io);
147 oldalrm = (int (*)())signal(SIGALRM, sig_alrm);
148 alarm(TIMELIM);
149 pflock(0); /* unlock persist file for attach */
150 while (!got_io)
151 pause(); /* wait for attach */
152 alarm(0); /* turn off alarm */
153 signal(SIGALRM, oldalrm);
154 signal(SIGIO, SIG_DFL);
155 pflock(1); /* grab persist file back */
156 /* someone wants us; reopen stdin and stdout */
157 if (freopen(inpname, "r", stdin) == NULL)
158 goto openerr;
159 if (freopen(outpname, "w", stdout) == NULL)
160 goto openerr;
161 if (errname[0]) {
162 if (freopen(errname, "w", stderr) == NULL)
163 goto openerr;
164 unlink(errname);
165 errname[0] = '\0';
166 }
167 unlink(inpname);
168 inpname[0] = '\0';
169 unlink(outpname);
170 outpname[0] = '\0';
171 return;
172 createrr:
173 error(SYSTEM, "cannot create named pipes in pfhold");
174 openerr:
175 error(SYSTEM, "cannot open named pipes in pfhold");
176 }
177
178
179 io_process() /* just act as go-between for actual process */
180 {
181 register char *cp;
182 register int nr, n;
183 char buf[BUFSIZ], *pfin, *pfout, *pferr;
184 int pid, nfds;
185 int fdin, fdout, fderr = -1;
186 fd_set readfds, writefds, excepfds;
187 /* load persist file */
188 n = 40;
189 while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) {
190 if (!n--)
191 error(USER, "unattended persist file?");
192 pflock(0);
193 sleep(15); /* wait until ready */
194 pflock(1);
195 }
196 if (nr < 0)
197 error(SYSTEM, "error reading persist file");
198 ftruncate(persistfd, 0L); /* truncate persist file */
199 pfdetach(); /* close & release persist file */
200 buf[nr] = '\0'; /* parse what we got */
201 if ((cp = index(buf, ' ')) == NULL)
202 goto formerr;
203 *cp++ = '\0';
204 if ((pid = atoi(cp)) <= 0)
205 goto formerr;
206 if ((cp = index(cp, '\n')) == NULL)
207 goto formerr;
208 pfin = ++cp;
209 if ((cp = index(cp, '\n')) == NULL)
210 goto formerr;
211 *cp++ = '\0';
212 pfout = cp;
213 if ((cp = index(cp, '\n')) == NULL)
214 goto formerr;
215 *cp++ = '\0';
216 pferr = cp;
217 if ((cp = index(cp, '\n')) == NULL)
218 goto formerr;
219 *cp++ = '\0';
220 if (cp-buf != nr)
221 goto formerr;
222 if (strcmp(buf, progname)) {
223 sprintf(errmsg, "persist file for %s, not %s", buf, progname);
224 error(USER, errmsg);
225 }
226 /* wake up rendering process */
227 if (kill(pid, SIGIO) < 0)
228 error(SYSTEM, "cannot signal rendering process in io_process");
229 /* open named pipes, in order */
230 if ((fdin = open(pfin, O_WRONLY)) < 0)
231 error(SYSTEM, "cannot open input pipe in io_process");
232 if ((fdout = open(pfout, O_RDONLY)) < 0)
233 error(SYSTEM, "cannot open output pipe in io_process");
234 if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0)
235 error(SYSTEM, "cannot open error pipe in io_process");
236 for ( ; ; ) { /* loop on select call */
237 FD_ZERO(&readfds);
238 FD_ZERO(&writefds);
239 FD_ZERO(&excepfds);
240 nfds = 0;
241 if (fdin >= 0) {
242 FD_SET(fdin, &writefds);
243 FD_SET(fdin, &excepfds);
244 nfds = fdin+1;
245 }
246 if (fdout >= 0) {
247 FD_SET(fdout, &readfds);
248 FD_SET(fdout, &excepfds);
249 nfds = fdout+1;
250 }
251 if (fderr >= 0) {
252 FD_SET(fderr, &readfds);
253 FD_SET(fderr, &excepfds);
254 nfds = fderr+1;
255 }
256 if (nfds == 0)
257 break; /* all done, exit */
258 if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0)
259 error(SYSTEM, "error in select call in io_process");
260 /* renderer stderr */
261 if (fderr >= 0 && (FD_ISSET(fderr, &readfds) ||
262 FD_ISSET(fderr, &excepfds))) {
263 nr = read(fderr, cp=buf, sizeof(buf));
264 if (nr < 0)
265 goto readerr;
266 if (nr == 0) {
267 close(fderr);
268 /* close(2); don't close stderr! */
269 fderr = -1;
270 } else
271 do { /* write it all */
272 if ((n = write(2, cp, nr)) <= 0)
273 goto writerr;
274 cp += n;
275 } while ((nr -= n) > 0);
276 }
277 /* renderer stdout */
278 if (fdout >= 0 && (FD_ISSET(fdout, &readfds) ||
279 FD_ISSET(fdout, &excepfds))) {
280 nr = read(fdout, cp=buf, sizeof(buf));
281 if (nr < 0)
282 goto readerr;
283 if (nr == 0) { /* EOF */
284 close(fdout);
285 close(1);
286 fdout = -1;
287 } else
288 do { /* write it all */
289 if ((n = write(1, cp, nr)) <= 0)
290 goto writerr;
291 cp += n;
292 } while ((nr -= n) > 0);
293 }
294 /* renderer stdin */
295 if (fdin >= 0 && (FD_ISSET(fdin, &writefds) ||
296 FD_ISSET(fdin, &excepfds))) {
297 nr = read(0, buf, 512); /* use minimal buffer */
298 if (nr < 0)
299 goto readerr;
300 if (nr == 0) {
301 close(0);
302 close(fdin);
303 fdin = -1;
304 } else if (write(fdin, buf, nr) < nr)
305 goto writerr; /* what else to do? */
306 }
307 }
308 _exit(0); /* we ought to return renderer error status! */
309 formerr:
310 error(USER, "format error in persist file");
311 readerr:
312 error(SYSTEM, "read error in io_process");
313 writerr:
314 error(SYSTEM, "write error in io_process");
315 }
316
317 #else
318
319 pfclean() {}
320
321 #endif
