--- ray/src/rt/persist.c 2010/12/15 17:24:29 2.42 +++ ray/src/rt/persist.c 2013/11/08 18:08:07 2.43 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: persist.c,v 2.42 2010/12/15 17:24:29 greg Exp $"; +static const char RCSid[] = "$Id: persist.c,v 2.43 2013/11/08 18:08:07 greg Exp $"; #endif /* * Routines for persistent rtrace and rpict processes. @@ -44,7 +44,7 @@ static rsighandler_t sig_io; static rsighandler_t sig_alrm; -extern void +void pfdetach(void) /* release persist (and header) resources */ { if (persistfd >= 0) @@ -58,7 +58,7 @@ pfdetach(void) /* release persist (and header) resour } -extern void +void pfclean(void) /* clean up persist files */ { if (persistfd >= 0) @@ -74,7 +74,7 @@ pfclean(void) /* clean up persist files */ } -extern void +void pflock( /* place or release exclusive lock on file */ int lf ) @@ -90,7 +90,7 @@ pflock( /* place or release exclusive lock on file */ } -extern void +void persistfile( /* open persist file and lock it */ char *pfn ) @@ -119,12 +119,12 @@ static void sig_io(int i) { got_io++; } static void sig_alrm(int i) { quit(0); } -extern void +void pfhold(void) /* holding pattern for idle rendering process */ { rsighandler_t *oldalrm; char buf[512]; - register int n; + int n; /* close input and output descriptors */ close(0); close(1); @@ -182,11 +182,11 @@ createrr: } -extern void +void io_process(void) /* just act as go-between for actual process */ { - register char *cp; - register int nr, n; + char *cp; + int nr, n; char buf[BUFSIZ], *pfin, *pfout, *pferr; int pid, nfds; int fdout, fderr = -1; @@ -297,7 +297,7 @@ io_process(void) /* just act as go-between for actual if (!strncmp(cp, progname, n) && cp[n++] == ':' && cp[n++] == ' ') { - register struct erract *ep; + struct erract *ep; for (ep = erract; ep < erract+NERRS; ep++) if (ep->pre[0] && @@ -345,6 +345,6 @@ writerr: #else -extern void pfclean(void) {} +void pfclean(void) {} #endif
