--- ray/src/rt/persist.c 1996/07/08 19:46:21 2.16 +++ ray/src/rt/persist.c 2010/12/15 17:24:29 2.42 @@ -1,54 +1,51 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: persist.c,v 2.42 2010/12/15 17:24:29 greg Exp $"; #endif - /* * Routines for persistent rtrace and rpict processes. + * + * External symbols declared in ray.h */ -#include "standard.h" +#include "copyright.h" -#ifdef F_SETLKW -#include "paths.h" +#include #include -#include #include - /* select call compatibility stuff */ -#ifndef FD_SETSIZE -#include -#define FD_SETSIZE NOFILE /* maximum # select file descriptors */ +#include + +#include "platform.h" +#ifndef NON_POSIX /* XXX need abstraction for process management */ + #include #endif -#ifndef FD_SET -#ifndef NFDBITS -#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */ -#endif -#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS))) -#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS))) -#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS))) -#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p))) -#endif +#include "rtprocess.h" /* getpid() */ +#include "standard.h" +#include "random.h" +#include "ray.h" + +#ifdef F_SETLKW +#include "paths.h" +#include "selcall.h" + #ifndef TIMELIM #define TIMELIM (8*3600) /* time limit for holding pattern */ #endif -extern char *strcpy(), *index(); - extern int headismine; /* boolean true if header belongs to me */ - extern char *progname; /* global program name */ - extern char *errfile; /* global error file name */ - static char *persistfname = NULL; /* persist file name */ static int persistfd = -1; /* persist file descriptor */ - static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; +typedef void (rsighandler_t)(int); +static rsighandler_t sig_io; +static rsighandler_t sig_alrm; -pfdetach() /* release persist (and header) resources */ + +extern void +pfdetach(void) /* release persist (and header) resources */ { if (persistfd >= 0) close(persistfd); @@ -61,7 +58,8 @@ pfdetach() /* release persist (and header) resources } -pfclean() /* clean up persist files */ +extern void +pfclean(void) /* clean up persist files */ { if (persistfd >= 0) close(persistfd); @@ -76,8 +74,10 @@ pfclean() /* clean up persist files */ } -pflock(lf) /* place or release exclusive lock on file */ -int lf; +extern void +pflock( /* place or release exclusive lock on file */ + int lf +) { struct flock fls; @@ -90,8 +90,10 @@ int lf; } -persistfile(pfn) /* open persist file and lock it */ -char *pfn; +extern void +persistfile( /* open persist file and lock it */ + char *pfn +) { persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { @@ -112,56 +114,61 @@ char *pfn; static int got_io; -static int sig_io() { got_io++; } +static void sig_io(int i) { got_io++; } -static int sig_alrm() { quit(0); } +static void sig_alrm(int i) { quit(0); } -pfhold() /* holding pattern for idle rendering process */ +extern void +pfhold(void) /* holding pattern for idle rendering process */ { - int (*oldalrm)(); + rsighandler_t *oldalrm; char buf[512]; register int n; /* close input and output descriptors */ - close(fileno(stdin)); - close(fileno(stdout)); + close(0); + close(1); if (errfile == NULL) - close(fileno(stderr)); + close(2); /* create named pipes for input and output */ - if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + if (mkfifo(mktemp(strcpy(inpname,TEMPLATE)), 0600) < 0) goto createrr; - if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + if (mkfifo(mktemp(strcpy(outpname,TEMPLATE)), 0600) < 0) goto createrr; if (errfile == NULL && - mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + mkfifo(mktemp(strcpy(errname,TEMPLATE)), 0600) < 0) goto createrr; sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), inpname, outpname, errname); n = strlen(buf); if (write(persistfd, buf, n) < n) error(SYSTEM, "error writing persist file"); + lseek(persistfd, (off_t)0, SEEK_SET); /* wait TIMELIM for someone to signal us */ got_io = 0; signal(SIGIO, sig_io); - oldalrm = (int (*)())signal(SIGALRM, sig_alrm); + oldalrm = signal(SIGALRM, sig_alrm); alarm(TIMELIM); pflock(0); /* unlock persist file for attach */ while (!got_io) pause(); /* wait for attach */ - pflock(1); /* grab persist file right back! */ alarm(0); /* turn off alarm */ signal(SIGALRM, oldalrm); signal(SIGIO, SIG_DFL); - if (lseek(persistfd, 0L, 0) < 0 || ftruncate(persistfd, 0L) < 0) - error(SYSTEM, "seek/truncate error on persist file"); + pflock(1); /* grab persist file back */ /* someone wants us; reopen stdin and stdout */ - if (freopen(inpname, "r", stdin) == NULL) - goto openerr; - if (freopen(outpname, "w", stdout) == NULL) - goto openerr; + close(0); + if (open(inpname, O_RDONLY) != 0) + error(INTERNAL, "unexpected stdin file number"); + clearerr(stdin); + close(1); + if (open(outpname, O_WRONLY) != 1) + error(INTERNAL, "unexpected stdout file number"); + sleep(3); /* give them a chance to open their pipes */ if (errname[0]) { - if (freopen(errname, "w", stderr) == NULL) - goto openerr; + close(2); + if (open(errname, O_WRONLY) != 2) + error(INTERNAL, "unexpected stderr file number"); unlink(errname); errname[0] = '\0'; } @@ -172,46 +179,52 @@ pfhold() /* holding pattern for idle rendering proces return; createrr: error(SYSTEM, "cannot create named pipes in pfhold"); -openerr: - error(SYSTEM, "cannot open named pipes in pfhold"); } -io_process() /* just act as go-between for actual process */ +extern void +io_process(void) /* just act as go-between for actual process */ { register char *cp; register int nr, n; char buf[BUFSIZ], *pfin, *pfout, *pferr; int pid, nfds; - int fdin, fdout, fderr = -1; - fd_set readfds, writefds, excepfds; + int fdout, fderr = -1; + int status = 0; + fd_set readfds, excepfds; /* load persist file */ + n = 40; while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) { + if (!n--) + error(USER, "unattended persist file?"); pflock(0); - sleep(15); /* wait until ready */ + sleep(3+(3*getpid()+random())%13); /* wait until ready */ pflock(1); } - pfdetach(); /* close persist file */ if (nr < 0) error(SYSTEM, "error reading persist file"); - buf[nr] = '\0'; - if ((cp = index(buf, ' ')) == NULL) +#ifndef _WIN32 /* XXX we need a replacement for that one */ + ftruncate(persistfd, (off_t)0L); /* truncate persist file */ +#endif + pfdetach(); /* close & release persist file */ + buf[nr] = '\0'; /* parse what we got */ + if ((cp = strchr(buf, ' ')) == NULL) goto formerr; *cp++ = '\0'; if ((pid = atoi(cp)) <= 0) goto formerr; - if ((cp = index(cp, '\n')) == NULL) + if ((cp = strchr(cp, '\n')) == NULL) goto formerr; pfin = ++cp; - if ((cp = index(cp, '\n')) == NULL) + if ((cp = strchr(cp, '\n')) == NULL) goto formerr; *cp++ = '\0'; pfout = cp; - if ((cp = index(cp, '\n')) == NULL) + if ((cp = strchr(cp, '\n')) == NULL) goto formerr; *cp++ = '\0'; pferr = cp; - if ((cp = index(cp, '\n')) == NULL) + if ((cp = strchr(cp, '\n')) == NULL) goto formerr; *cp++ = '\0'; if (cp-buf != nr) @@ -223,23 +236,37 @@ io_process() /* just act as go-between for actual pro /* wake up rendering process */ if (kill(pid, SIGIO) < 0) error(SYSTEM, "cannot signal rendering process in io_process"); - /* open named pipes, in order */ - if ((fdin = open(pfin, O_WRONLY)) < 0) - error(SYSTEM, "cannot open input pipe in io_process"); + /* fork child feeder process */ + pid = fork(); + if (pid < 0) + error(SYSTEM, "fork failed in io_process"); + if (pid == 0) { /* feeder loop */ + int fdin; + close(1); /* open input pipe */ + if ((fdin = open(pfin, O_WRONLY)) < 0) + error(SYSTEM, "cannot open feed pipe in io_process"); + /* renderer stdin */ + while ((nr = read(0, cp=buf, sizeof(buf))) > 0) { + do { + if ((n = write(fdin, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); + } + if (nr < 0) + goto readerr; + _exit(0); + } + close(0); + /* open output pipes, in order */ if ((fdout = open(pfout, O_RDONLY)) < 0) error(SYSTEM, "cannot open output pipe in io_process"); if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0) error(SYSTEM, "cannot open error pipe in io_process"); - for ( ; ; ) { /* loop on select call */ + for ( ; ; ) { /* eater loop */ FD_ZERO(&readfds); - FD_ZERO(&writefds); FD_ZERO(&excepfds); nfds = 0; - if (fdin >= 0) { - FD_SET(fdin, &writefds); - FD_SET(fdin, &excepfds); - nfds = fdin+1; - } if (fdout >= 0) { FD_SET(fdout, &readfds); FD_SET(fdout, &excepfds); @@ -252,7 +279,7 @@ io_process() /* just act as go-between for actual pro } if (nfds == 0) break; /* all done, exit */ - if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0) + if (select(nfds, &readfds, NULL, &excepfds, NULL) < 0) error(SYSTEM, "error in select call in io_process"); /* renderer stderr */ if (fderr >= 0 && (FD_ISSET(fderr, &readfds) || @@ -262,14 +289,30 @@ io_process() /* just act as go-between for actual pro goto readerr; if (nr == 0) { close(fderr); - close(2); + /* close(2); don't close stderr! */ fderr = -1; - } else - do { /* write it all */ + } else { + cp[nr] = '\0'; /* deduce status if we can */ + n = strlen(progname); + if (!strncmp(cp, progname, n) && + cp[n++] == ':' && + cp[n++] == ' ') { + register struct erract *ep; + for (ep = erract; ep < erract+NERRS; + ep++) + if (ep->pre[0] && + !strncmp(cp+n, ep->pre, + strlen(ep->pre))) { + status = ep->ec; + break; + } + } + do { /* write message */ if ((n = write(2, cp, nr)) <= 0) goto writerr; cp += n; } while ((nr -= n) > 0); + } } /* renderer stdout */ if (fdout >= 0 && (FD_ISSET(fdout, &readfds) || @@ -288,21 +331,10 @@ io_process() /* just act as go-between for actual pro cp += n; } while ((nr -= n) > 0); } - /* renderer stdin */ - if (fdin >= 0 && (FD_ISSET(fdin, &writefds) || - FD_ISSET(fdin, &excepfds))) { - nr = read(0, buf, 512); /* use minimal buffer */ - if (nr < 0) - goto readerr; - if (nr == 0) { - close(0); - close(fdin); - fdin = -1; - } else if (write(fdin, buf, nr) < nr) - goto writerr; /* what else to do? */ - } } - _exit(0); /* we ought to return renderer error status! */ + kill(pid, SIGTERM); /* no more process to feed, so... */ + waitpid(pid, 0, 0); /* wait for feeder process */ + _exit(status); formerr: error(USER, "format error in persist file"); readerr: @@ -313,6 +345,6 @@ writerr: #else -pfclean() {} +extern void pfclean(void) {} #endif
