--- ray/src/rt/persist.c 1996/07/06 22:30:05 2.14 +++ ray/src/rt/persist.c 1996/07/22 18:09:26 2.18 @@ -11,11 +11,24 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #ifdef F_SETLKW - #include "paths.h" #include #include #include + /* select call compatibility stuff */ +#ifndef FD_SETSIZE +#include +#define FD_SETSIZE NOFILE /* maximum # select file descriptors */ +#endif +#ifndef FD_SET +#ifndef NFDBITS +#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */ +#endif +#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS))) +#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS))) +#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS))) +#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p))) +#endif #ifndef TIMELIM #define TIMELIM (8*3600) /* time limit for holding pattern */ @@ -83,8 +96,6 @@ char *pfn; persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { persistfname = pfn; - /* put something there for faulty lock daemons */ - write(persistfd, "Initializing...\n", 16); pflock(1); return; } @@ -114,6 +125,8 @@ pfhold() /* holding pattern for idle rendering proces /* close input and output descriptors */ close(fileno(stdin)); close(fileno(stdout)); + if (errfile == NULL) + close(fileno(stderr)); /* create named pipes for input and output */ if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) goto createrr; @@ -124,25 +137,22 @@ pfhold() /* holding pattern for idle rendering proces goto createrr; sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), inpname, outpname, errname); - if (lseek(persistfd, 0L, 0) < 0) - error(SYSTEM, "seek error on persist file"); n = strlen(buf); if (write(persistfd, buf, n) < n) error(SYSTEM, "error writing persist file"); - ftruncate(persistfd, (long)n); - fsync(persistfd); /* shouldn't be necessary, but.... */ + lseek(persistfd, 0L, 0); /* wait TIMELIM for someone to signal us */ got_io = 0; signal(SIGIO, sig_io); oldalrm = (int (*)())signal(SIGALRM, sig_alrm); alarm(TIMELIM); - pflock(0); + pflock(0); /* unlock persist file for attach */ while (!got_io) - pause(); - alarm(0); + pause(); /* wait for attach */ + alarm(0); /* turn off alarm */ signal(SIGALRM, oldalrm); signal(SIGIO, SIG_DFL); - pflock(1); + pflock(1); /* grab persist file back */ /* someone wants us; reopen stdin and stdout */ if (freopen(inpname, "r", stdin) == NULL) goto openerr; @@ -166,19 +176,28 @@ openerr: } -io_process() /* just act as conduits to and from actual process */ +io_process() /* just act as go-between for actual process */ { register char *cp; register int nr, n; - char buf[512], *pfin, *pfout, *pferr; - int pid, pid2 = -1; - /* load and close persist file */ - errno = 0; - nr = read(persistfd, buf, sizeof(buf)-1); - pfdetach(); - if (nr <= 0) + char buf[BUFSIZ], *pfin, *pfout, *pferr; + int pid, nfds; + int fdin, fdout, fderr = -1; + fd_set readfds, writefds, excepfds; + /* load persist file */ + n = 40; + while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) { + if (!n--) + error(USER, "unattended persist file?"); + pflock(0); + sleep(15); /* wait until ready */ + pflock(1); + } + if (nr < 0) error(SYSTEM, "error reading persist file"); - buf[nr] = '\0'; + ftruncate(persistfd, 0L); /* truncate persist file */ + pfdetach(); /* close & release persist file */ + buf[nr] = '\0'; /* parse what we got */ if ((cp = index(buf, ' ')) == NULL) goto formerr; *cp++ = '\0'; @@ -204,56 +223,95 @@ io_process() /* just act as conduits to and from actu sprintf(errmsg, "persist file for %s, not %s", buf, progname); error(USER, errmsg); } - /* wake up rendering process */ + /* wake up rendering process */ if (kill(pid, SIGIO) < 0) error(SYSTEM, "cannot signal rendering process in io_process"); - pid = fork(); /* fork i/o process */ - if (pid < 0) - goto forkerr; - /* connect to appropriate pipe */ - if (pid) { /* parent passes renderer output */ - close(0); - if (pferr[0]) { - pid2 = fork(); /* fork another for stderr */ - if (pid2 < 0) - goto forkerr; + /* open named pipes, in order */ + if ((fdin = open(pfin, O_WRONLY)) < 0) + error(SYSTEM, "cannot open input pipe in io_process"); + if ((fdout = open(pfout, O_RDONLY)) < 0) + error(SYSTEM, "cannot open output pipe in io_process"); + if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0) + error(SYSTEM, "cannot open error pipe in io_process"); + for ( ; ; ) { /* loop on select call */ + FD_ZERO(&readfds); + FD_ZERO(&writefds); + FD_ZERO(&excepfds); + nfds = 0; + if (fdin >= 0) { + FD_SET(fdin, &writefds); + FD_SET(fdin, &excepfds); + nfds = fdin+1; } - if (pid2) { /* parent is still stdout */ - if (open(pfout, O_RDONLY) != 0) - error(SYSTEM, - "cannot open output pipe in io_process"); - } else { /* second child is stderr */ - if (open(pferr, O_RDONLY) != 0) - error(SYSTEM, - "cannot open error pipe in io_process"); - dup2(2, 1); /* attach stdout to stderr */ + if (fdout >= 0) { + FD_SET(fdout, &readfds); + FD_SET(fdout, &excepfds); + nfds = fdout+1; } - } else { /* child passes renderer input */ - close(1); - if (open(pfin, O_WRONLY) != 1) - error(SYSTEM, "cannot open input pipe in io_process"); + if (fderr >= 0) { + FD_SET(fderr, &readfds); + FD_SET(fderr, &excepfds); + nfds = fderr+1; + } + if (nfds == 0) + break; /* all done, exit */ + if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0) + error(SYSTEM, "error in select call in io_process"); + /* renderer stderr */ + if (fderr >= 0 && (FD_ISSET(fderr, &readfds) || + FD_ISSET(fderr, &excepfds))) { + nr = read(fderr, cp=buf, sizeof(buf)); + if (nr < 0) + goto readerr; + if (nr == 0) { + close(fderr); + /* close(2); don't close stderr! */ + fderr = -1; + } else + do { /* write it all */ + if ((n = write(2, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); + } + /* renderer stdout */ + if (fdout >= 0 && (FD_ISSET(fdout, &readfds) || + FD_ISSET(fdout, &excepfds))) { + nr = read(fdout, cp=buf, sizeof(buf)); + if (nr < 0) + goto readerr; + if (nr == 0) { /* EOF */ + close(fdout); + close(1); + fdout = -1; + } else + do { /* write it all */ + if ((n = write(1, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); + } + /* renderer stdin */ + if (fdin >= 0 && (FD_ISSET(fdin, &writefds) || + FD_ISSET(fdin, &excepfds))) { + nr = read(0, buf, 512); /* use minimal buffer */ + if (nr < 0) + goto readerr; + if (nr == 0) { + close(0); + close(fdin); + fdin = -1; + } else if (write(fdin, buf, nr) < nr) + goto writerr; /* what else to do? */ + } } - /* pass input to output */ - /* read as much as we can, write all of it */ - while ((nr = read(0, cp=buf, sizeof(buf))) > 0) - do { - if ((n = write(1, cp, nr)) <= 0) - error(SYSTEM, "write error in io_process"); - cp += n; - } while ((nr -= n) > 0); - if (nr < 0) - error(SYSTEM, "read error in io_process"); - close(0); /* close input */ - close(1); /* close output */ - if (pid) /* parent waits for stdin child */ - wait(0); - if (pid2 > 0) /* wait for stderr child also */ - wait(0); - _exit(0); /* all done, exit (not quit!) */ + _exit(0); /* we ought to return renderer error status! */ formerr: error(USER, "format error in persist file"); -forkerr: - error(SYSTEM, "fork failed in io_process"); +readerr: + error(SYSTEM, "read error in io_process"); +writerr: + error(SYSTEM, "write error in io_process"); } #else
