--- ray/src/rt/persist.c 1996/01/23 15:51:38 2.12 +++ ray/src/rt/persist.c 1996/07/06 23:19:57 2.15 @@ -1,4 +1,4 @@ -/* Copyright (c) 1995 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -27,10 +27,12 @@ extern int headismine; /* boolean true if header belon extern char *progname; /* global program name */ +extern char *errfile; /* global error file name */ + static char *persistfname = NULL; /* persist file name */ static int persistfd = -1; /* persist file descriptor */ -static char inpname[TEMPLEN+1], outpname[TEMPLEN+1]; +static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; pfdetach() /* release persist (and header) resources */ @@ -41,6 +43,7 @@ pfdetach() /* release persist (and header) resources persistfname = NULL; inpname[0] = '\0'; outpname[0] = '\0'; + errname[0] = '\0'; headismine = 0; } @@ -55,6 +58,8 @@ pfclean() /* clean up persist files */ unlink(inpname); if (outpname[0]) unlink(outpname); + if (errname[0]) + unlink(errname); } @@ -75,7 +80,7 @@ int lf; persistfile(pfn) /* open persist file and lock it */ char *pfn; { - persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0666); + persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { persistfname = pfn; pflock(1); @@ -92,11 +97,16 @@ char *pfn; } -int sig_noop() {} +static int got_io; +static int sig_io() { got_io++; } +static int sig_alrm() { quit(0); } + + pfhold() /* holding pattern for idle rendering process */ { + int (*oldalrm)(); char buf[512]; register int n; /* close input and output descriptors */ @@ -107,25 +117,39 @@ pfhold() /* holding pattern for idle rendering proces goto createrr; if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) goto createrr; - sprintf(buf, "%s %d\n%s\n%s\n", progname, getpid(), inpname, outpname); - if (lseek(persistfd, 0L, 0) < 0 || ftruncate(persistfd, 0L) < 0) - error(SYSTEM, "seek/truncate error on persist file"); + if (errfile == NULL && + mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + goto createrr; + sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), + inpname, outpname, errname); n = strlen(buf); if (write(persistfd, buf, n) < n) error(SYSTEM, "error writing persist file"); /* wait TIMELIM for someone to signal us */ - signal(SIGIO, sig_noop); + got_io = 0; + signal(SIGIO, sig_io); + oldalrm = (int (*)())signal(SIGALRM, sig_alrm); alarm(TIMELIM); - pflock(0); - pause(); - alarm(0); + pflock(0); /* unlock persist file for attach */ + while (!got_io) + pause(); /* wait for attach */ + pflock(1); /* grab persist file right back! */ + alarm(0); /* turn off alarm */ + signal(SIGALRM, oldalrm); signal(SIGIO, SIG_DFL); - pflock(1); + if (lseek(persistfd, 0L, 0) < 0 || ftruncate(persistfd, 0L) < 0) + error(SYSTEM, "seek/truncate error on persist file"); /* someone wants us; reopen stdin and stdout */ if (freopen(inpname, "r", stdin) == NULL) goto openerr; if (freopen(outpname, "w", stdout) == NULL) goto openerr; + if (errname[0]) { + if (freopen(errname, "w", stderr) == NULL) + goto openerr; + unlink(errname); + errname[0] = '\0'; + } unlink(inpname); inpname[0] = '\0'; unlink(outpname); @@ -142,13 +166,17 @@ io_process() /* just act as conduits to and from actu { register char *cp; register int nr, n; - char buf[512], *pfin, *pfout; - int pid; - /* load and close persist file */ - nr = read(persistfd, buf, sizeof(buf)-1); - pfdetach(); + char buf[512], *pfin, *pfout, *pferr; + int pid, pid2 = -1; + /* load persist file */ + while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) { + pflock(0); + sleep(15); /* wait until ready */ + pflock(1); + } + pfdetach(); /* close persist file */ if (nr < 0) - error(SYSTEM, "cannot read persist file"); + error(SYSTEM, "error reading persist file"); buf[nr] = '\0'; if ((cp = index(buf, ' ')) == NULL) goto formerr; @@ -165,6 +193,10 @@ io_process() /* just act as conduits to and from actu if ((cp = index(cp, '\n')) == NULL) goto formerr; *cp++ = '\0'; + pferr = cp; + if ((cp = index(cp, '\n')) == NULL) + goto formerr; + *cp++ = '\0'; if (cp-buf != nr) goto formerr; if (strcmp(buf, progname)) { @@ -176,36 +208,51 @@ io_process() /* just act as conduits to and from actu error(SYSTEM, "cannot signal rendering process in io_process"); pid = fork(); /* fork i/o process */ if (pid < 0) - error(SYSTEM, "fork failed in io_process"); + goto forkerr; /* connect to appropriate pipe */ if (pid) { /* parent passes renderer output */ close(0); - if (open(pfout, O_RDONLY) != 0) - error(SYSTEM, "cannot open input pipe in io_process"); + if (pferr[0]) { + pid2 = fork(); /* fork another for stderr */ + if (pid2 < 0) + goto forkerr; + } + if (pid2) { /* parent is still stdout */ + if (open(pfout, O_RDONLY) != 0) + error(SYSTEM, + "cannot open output pipe in io_process"); + } else { /* second child is stderr */ + if (open(pferr, O_RDONLY) != 0) + error(SYSTEM, + "cannot open error pipe in io_process"); + dup2(2, 1); /* attach stdout to stderr */ + } } else { /* child passes renderer input */ close(1); if (open(pfin, O_WRONLY) != 1) - error(SYSTEM, "cannot open output pipe in io_process"); + error(SYSTEM, "cannot open input pipe in io_process"); } /* pass input to output */ /* read as much as we can, write all of it */ while ((nr = read(0, cp=buf, sizeof(buf))) > 0) do { if ((n = write(1, cp, nr)) <= 0) - goto writerr; + error(SYSTEM, "write error in io_process"); cp += n; } while ((nr -= n) > 0); if (nr < 0) error(SYSTEM, "read error in io_process"); close(0); /* close input */ close(1); /* close output */ - if (pid) /* parent waits for child */ + if (pid) /* parent waits for stdin child */ wait(0); - exit(0); /* all done, exit (not quit!) */ + if (pid2 > 0) /* wait for stderr child also */ + wait(0); + _exit(0); /* all done, exit (not quit!) */ formerr: error(USER, "format error in persist file"); -writerr: - error(SYSTEM, "write error in io_process"); +forkerr: + error(SYSTEM, "fork failed in io_process"); } #else
