root/radiance/ray/src/rt/persist.c
Wed Dec 15 17:24:29 2010 UTC (14 years, 8 months ago) by greg
Changes since 2.41: +5 -5 lines
Diff to previous 2.41
Name change to avoid conflict under Cygwin
Thu May 1 15:50:28 2008 UTC (17 years, 3 months ago) by greg
Changes since 2.40: +1 -9 lines
Diff to previous 2.40
Minor warning fixes
Sun Apr 27 17:22:49 2008 UTC (17 years, 3 months ago) by schorsch
Changes since 2.39: +3 -2 lines
Diff to previous 2.39
Mon Apr 21 07:31:30 2008 UTC (17 years, 3 months ago) by schorsch
Changes since 2.38: +4 -2 lines
Diff to previous 2.38
Scons update for mingw.
Wed Jun 7 17:52:04 2006 UTC (19 years, 2 months ago) by schorsch
Changes since 2.37: +3 -1 lines
Diff to previous 2.37
Fri Jan 21 00:52:59 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.36: +4 -4 lines
Diff to previous 2.36
Sun Sep 19 07:24:37 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.35: +2 -1 lines
Diff to previous 2.35
Added explicit kill of feeder process to prevent deadlock (paranoia?)
Fri Sep 17 21:43:50 2004 UTC (20 years, 11 months ago) by greg
Diff to previous 2.34
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.33: +28 -27 lines
Diff to previous 2.33
Wed Oct 22 02:06:35 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.32
Mon Oct 20 16:01:55 2003 UTC (21 years, 9 months ago) by greg
Changes since 2.31: +3 -2 lines
Diff to previous 2.31
Sat Aug 30 09:03:31 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.30: +1 -5 lines
Diff to previous 2.30
Eliminated obsolete "freebsd" dependency.
Mon Jul 14 20:02:30 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.29: +3 -4 lines
Diff to previous 2.29
Mon Jun 30 14:59:12 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.28: +13 -8 lines
Diff to previous 2.28
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.27
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.26: +1 -56 lines
Diff to previous 2.26
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.25: +92 -17 lines
Diff to previous 2.25
Sat Jan 3 20:07:31 1998 UTC (27 years, 7 months ago) by gregl
Changes since 2.24: +2 -1 lines
Diff to previous 2.24
Mon Nov 24 15:13:33 1997 UTC (27 years, 8 months ago) by gregl
Changes since 2.23: +4 -3 lines
Diff to previous 2.23
fixed error introduced in last change
Tue Nov 11 20:29:25 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.22: +19 -2 lines
Diff to previous 2.22
added code to deduce exit status from last stderr message
Fri Nov 7 12:12:53 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.21: +28 -26 lines
Diff to previous 2.21
went back to separate feeder process, because select() was hanging us
Tue Oct 28 14:00:02 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.20: +1 -18 lines
Diff to previous 2.20
created selcall.h include file for select(2) compatibility
Thu Oct 16 13:49:22 1997 UTC (27 years, 10 months ago) by gregl
Changes since 2.19: +2 -0 lines
Diff to previous 2.19
added ifdef for INCL_SEL_H since not every system has it
Thu Sep 18 16:13:28 1997 UTC (27 years, 11 months ago) by gregl
Changes since 2.18: +1 -0 lines
Diff to previous 2.18
added include of sys/select.h for AIX machines
Mon Jul 22 18:09:26 1996 UTC (29 years ago) by greg
Diff to previous 2.17
avoided close of standard error in io_process()
Fri Jul 19 10:16:00 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.16: +8 -5 lines
Diff to previous 2.16
final(?) fix to process synchronization problems
Mon Jul 8 19:46:21 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.15: +103 -47 lines
Diff to previous 2.15
changed io_process() to use select() and a single process
Sat Jul 6 23:19:57 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.14: +14 -15 lines
Diff to previous 2.14
finally fixed synchronization problem caused by break in lock during fork
Sat Jul 6 22:30:05 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.13: +55 -17 lines
Diff to previous 2.13
added piping of stderr to persist functions
Thu Jul 4 09:54:59 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.12: +16 -6 lines
Diff to previous 2.12
made it so alarm signal causes quiet termination in persist mode
fixed minor synchronization problem by adding sleep() call.  (I hope!)
Tue Jan 23 15:51:38 1996 UTC (29 years, 6 months ago) by greg
Changes since 2.11: +16 -8 lines
added program name to beginning of persist file for safety reasons
Mon Nov 8 09:35:32 1993 UTC (31 years, 9 months ago) by greg
minor fix
Fri May 28 13:37:39 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.9: +3 -3 lines
fixed potential bug in persist file function
Thu Apr 1 08:55:37 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.8: +7 -19 lines
made io_process write all its output before getting more input
Wed Mar 3 09:07:52 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.7: +4 -0 lines
added ghost call to pfclean()
Wed Feb 10 11:02:20 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.6: +23 -8 lines
potential bug fix in io_process()
Fri Jan 29 12:02:29 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.5: +5 -0 lines
made parallel operations conditional on F_SETLKW
Mon Jan 25 19:17:36 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.4: +0 -1 lines
moved reinitialization code for persist function
Fri Jan 22 09:51:23 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.3: +0 -1 lines
bug fixes and improvements on stdio flushing
Thu Jan 21 17:01:24 1993 UTC (32 years, 6 months ago) by greg
added code to reset ray counters and clock on persistent restart
Thu Jan 21 10:09:04 1993 UTC (32 years, 7 months ago) by greg
Changes since 2.1: +11 -4 lines
changed signals so ALRM always causes exit, CONT now used by rpict
Wed Jan 20 15:19:00 1993 UTC (32 years, 7 months ago) by greg
