--- ray/src/rt/persist.c 2003/02/22 02:07:29 2.26
+++ ray/src/rt/persist.c 2008/04/27 17:22:49 2.40
@@ -1,5 +1,5 @@
#ifndef lint
-static const char RCSid[] = "$Id: persist.c,v 2.26 2003/02/22 02:07:29 greg Exp $";
+static const char RCSid[] = "$Id: persist.c,v 2.40 2008/04/27 17:22:49 schorsch Exp $";
#endif
* Routines for persistent rtrace and rpict processes.
@@ -7,96 +7,45 @@ static const char RCSid[] = "$Id: persist.c,v 2.26 200
* External symbols declared in ray.h
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
+#include
+#include
+#include
+#include
+#include "platform.h"
+#ifndef NON_POSIX /* XXX need abstraction for process management */
+ #include
+#endif
+#include "rtprocess.h" /* getpid() */
#include "standard.h"
#include "random.h"
+#include "ray.h"
#ifdef F_SETLKW
#include "paths.h"
#include "selcall.h"
-#include
-#include
#ifndef TIMELIM
#define TIMELIM (8*3600) /* time limit for holding pattern */
#endif
-#ifndef freebsd
-#define mkfifo(fn,md) mknod(fn, S_IFIFO|(md), 0)
-#endif
-extern void io_process();
extern int headismine; /* boolean true if header belongs to me */
extern char *progname; /* global program name */
extern char *errfile; /* global error file name */
static char *persistfname = NULL; /* persist file name */
static int persistfd = -1; /* persist file descriptor */
static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1];
+typedef void (sighandler_t)(int);
+static sighandler_t sig_io;
+static sighandler_t sig_alrm;
-void
-pfdetach() /* release persist (and header) resources */
+extern void
+pfdetach(void) /* release persist (and header) resources */
if (persistfd >= 0)
close(persistfd);
@@ -109,8 +58,8 @@ pfdetach() /* release persist (and header) resources
-void
-pfclean() /* clean up persist files */
+extern void
+pfclean(void) /* clean up persist files */
if (persistfd >= 0)
close(persistfd);
@@ -125,9 +74,10 @@ pfclean() /* clean up persist files */
-void
-pflock(lf) /* place or release exclusive lock on file */
-int lf;
+extern void
+pflock( /* place or release exclusive lock on file */
+ int lf
struct flock fls;
@@ -140,8 +90,10 @@ int lf;
-persistfile(pfn) /* open persist file and lock it */
-char *pfn;
+extern void
+persistfile( /* open persist file and lock it */
+ char *pfn
persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644);
if (persistfd >= 0) {
@@ -162,22 +114,22 @@ char *pfn;
static int got_io;
-static void sig_io() { got_io++; }
+static void sig_io(int i) { got_io++; }
-static void sig_alrm() { quit(0); }
+static void sig_alrm(int i) { quit(0); }
-void
-pfhold() /* holding pattern for idle rendering process */
+extern void
+pfhold(void) /* holding pattern for idle rendering process */
- void (*oldalrm)();
+ sighandler_t *oldalrm;
char buf[512];
register int n;
/* close input and output descriptors */
- close(fileno(stdin));
- close(fileno(stdout));
+ close(0);
+ close(1);
if (errfile == NULL)
- close(fileno(stderr));
+ close(2);
/* create named pipes for input and output */
if (mkfifo(mktemp(strcpy(inpname,TEMPLATE)), 0600) < 0)
goto createrr;
@@ -191,11 +143,11 @@ pfhold() /* holding pattern for idle rendering proces
n = strlen(buf);
if (write(persistfd, buf, n) < n)
error(SYSTEM, "error writing persist file");
- lseek(persistfd, (off_t)0L, 0);
+ lseek(persistfd, (off_t)0, SEEK_SET);
/* wait TIMELIM for someone to signal us */
got_io = 0;
signal(SIGIO, sig_io);
- oldalrm = (void (*)())signal(SIGALRM, sig_alrm);
+ oldalrm = signal(SIGALRM, sig_alrm);
alarm(TIMELIM);
pflock(0); /* unlock persist file for attach */
while (!got_io)
@@ -238,8 +190,8 @@ openerr:
-void
-io_process() /* just act as go-between for actual process */
+extern void
+io_process(void) /* just act as go-between for actual process */
register char *cp;
register int nr, n;
@@ -259,26 +211,28 @@ io_process() /* just act as go-between for actual pro
if (nr < 0)
error(SYSTEM, "error reading persist file");
+#ifndef _WIN32 /* XXX we need a replacement for that one */
ftruncate(persistfd, (off_t)0L); /* truncate persist file */
+#endif
pfdetach(); /* close & release persist file */
buf[nr] = '\0'; /* parse what we got */
- if ((cp = index(buf, ' ')) == NULL)
+ if ((cp = strchr(buf, ' ')) == NULL)
goto formerr;
*cp++ = '\0';
if ((pid = atoi(cp)) <= 0)
goto formerr;
- if ((cp = index(cp, '\n')) == NULL)
+ if ((cp = strchr(cp, '\n')) == NULL)
goto formerr;
pfin = ++cp;
goto formerr;
*cp++ = '\0';
pfout = cp;
goto formerr;
*cp++ = '\0';
pferr = cp;
goto formerr;
*cp++ = '\0';
if (cp-buf != nr)
@@ -386,7 +340,8 @@ io_process() /* just act as go-between for actual pro
} while ((nr -= n) > 0);
- wait(0); /* wait for feeder process */
+ kill(pid, SIGTERM); /* no more process to feed, so... */
+ waitpid(pid, 0, 0); /* wait for feeder process */
_exit(status);
formerr:
error(USER, "format error in persist file");
@@ -398,6 +353,6 @@ writerr:
#else
-void pfclean() {}
+extern void pfclean(void) {}
#endif
