--- ray/src/rt/persist.c 1993/01/22 09:51:23 2.4 +++ ray/src/rt/persist.c 1996/07/06 22:30:05 2.14 @@ -1,4 +1,4 @@ -/* Copyright (c) 1993 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -9,6 +9,9 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include "standard.h" + +#ifdef F_SETLKW + #include "paths.h" #include #include @@ -22,10 +25,14 @@ extern char *strcpy(), *index(); extern int headismine; /* boolean true if header belongs to me */ +extern char *progname; /* global program name */ + +extern char *errfile; /* global error file name */ + static char *persistfname = NULL; /* persist file name */ static int persistfd = -1; /* persist file descriptor */ -static char inpname[TEMPLEN+1], outpname[TEMPLEN+1]; +static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; pfdetach() /* release persist (and header) resources */ @@ -36,6 +43,7 @@ pfdetach() /* release persist (and header) resources persistfname = NULL; inpname[0] = '\0'; outpname[0] = '\0'; + errname[0] = '\0'; headismine = 0; } @@ -50,6 +58,8 @@ pfclean() /* clean up persist files */ unlink(inpname); if (outpname[0]) unlink(outpname); + if (errname[0]) + unlink(errname); } @@ -70,9 +80,11 @@ int lf; persistfile(pfn) /* open persist file and lock it */ char *pfn; { - persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0666); + persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { persistfname = pfn; + /* put something there for faulty lock daemons */ + write(persistfd, "Initializing...\n", 16); pflock(1); return; } @@ -87,33 +99,48 @@ char *pfn; } -int sig_noop() {} +static int got_io; +static int sig_io() { got_io++; } +static int sig_alrm() { quit(0); } + + pfhold() /* holding pattern for idle rendering process */ { - char buf[128]; + int (*oldalrm)(); + char buf[512]; register int n; /* close input and output descriptors */ close(fileno(stdin)); close(fileno(stdout)); /* create named pipes for input and output */ - if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600) < 0) + if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) goto createrr; - if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600) < 0) + if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) goto createrr; - sprintf(buf, "%d\n%s\n%s\n", getpid(), inpname, outpname); + if (errfile == NULL && + mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + goto createrr; + sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), + inpname, outpname, errname); if (lseek(persistfd, 0L, 0) < 0) - error(SYSTEM, "seek error on persist file in pfhold"); + error(SYSTEM, "seek error on persist file"); n = strlen(buf); if (write(persistfd, buf, n) < n) - error(SYSTEM, "error writing persist file in pfhold"); + error(SYSTEM, "error writing persist file"); + ftruncate(persistfd, (long)n); + fsync(persistfd); /* shouldn't be necessary, but.... */ /* wait TIMELIM for someone to signal us */ - signal(SIGIO, sig_noop); + got_io = 0; + signal(SIGIO, sig_io); + oldalrm = (int (*)())signal(SIGALRM, sig_alrm); alarm(TIMELIM); pflock(0); - pause(); + while (!got_io) + pause(); alarm(0); + signal(SIGALRM, oldalrm); signal(SIGIO, SIG_DFL); pflock(1); /* someone wants us; reopen stdin and stdout */ @@ -121,11 +148,16 @@ pfhold() /* holding pattern for idle rendering proces goto openerr; if (freopen(outpname, "w", stdout) == NULL) goto openerr; + if (errname[0]) { + if (freopen(errname, "w", stderr) == NULL) + goto openerr; + unlink(errname); + errname[0] = '\0'; + } unlink(inpname); inpname[0] = '\0'; unlink(outpname); outpname[0] = '\0'; - clean_slate(); /* reset time and ray counters */ return; createrr: error(SYSTEM, "cannot create named pipes in pfhold"); @@ -138,59 +170,94 @@ io_process() /* just act as conduits to and from actu { register char *cp; register int nr, n; - char buf[4096], *pfin, *pfout; - int pid; + char buf[512], *pfin, *pfout, *pferr; + int pid, pid2 = -1; /* load and close persist file */ - nr = read(persistfd, buf, sizeof(buf)); + errno = 0; + nr = read(persistfd, buf, sizeof(buf)-1); pfdetach(); - if (nr < 0) - error(SYSTEM, "cannot read persist file"); + if (nr <= 0) + error(SYSTEM, "error reading persist file"); buf[nr] = '\0'; - if ((cp = index(buf, '\n')) == NULL) + if ((cp = index(buf, ' ')) == NULL) goto formerr; *cp++ = '\0'; - if ((pid = atoi(buf)) <= 0) + if ((pid = atoi(cp)) <= 0) goto formerr; - pfin = cp; if ((cp = index(cp, '\n')) == NULL) goto formerr; + pfin = ++cp; + if ((cp = index(cp, '\n')) == NULL) + goto formerr; *cp++ = '\0'; pfout = cp; if ((cp = index(cp, '\n')) == NULL) goto formerr; *cp++ = '\0'; + pferr = cp; + if ((cp = index(cp, '\n')) == NULL) + goto formerr; + *cp++ = '\0'; if (cp-buf != nr) goto formerr; + if (strcmp(buf, progname)) { + sprintf(errmsg, "persist file for %s, not %s", buf, progname); + error(USER, errmsg); + } /* wake up rendering process */ if (kill(pid, SIGIO) < 0) error(SYSTEM, "cannot signal rendering process in io_process"); pid = fork(); /* fork i/o process */ if (pid < 0) - error(SYSTEM, "fork failed in io_process"); + goto forkerr; /* connect to appropriate pipe */ if (pid) { /* parent passes renderer output */ - if (freopen(pfout, "r", stdin) == NULL) - error(SYSTEM, "cannot open input pipe in io_process"); + close(0); + if (pferr[0]) { + pid2 = fork(); /* fork another for stderr */ + if (pid2 < 0) + goto forkerr; + } + if (pid2) { /* parent is still stdout */ + if (open(pfout, O_RDONLY) != 0) + error(SYSTEM, + "cannot open output pipe in io_process"); + } else { /* second child is stderr */ + if (open(pferr, O_RDONLY) != 0) + error(SYSTEM, + "cannot open error pipe in io_process"); + dup2(2, 1); /* attach stdout to stderr */ + } } else { /* child passes renderer input */ - if (freopen(pfin, "w", stdout) == NULL) + close(1); + if (open(pfin, O_WRONLY) != 1) error(SYSTEM, "cannot open input pipe in io_process"); } /* pass input to output */ - cp = buf; n = sizeof(buf); - while ((nr = read(fileno(stdin), cp, n)) > 0) { - nr += cp-buf; - if ((n = write(fileno(stdout), buf, nr)) <= 0) - error(SYSTEM, "write error in io_process"); - cp = buf; - while (n < nr) - *cp++ = buf[n++]; - n = sizeof(buf) - (cp-buf); - } - fclose(stdin); - fclose(stdout); - if (pid) /* parent waits for child */ + /* read as much as we can, write all of it */ + while ((nr = read(0, cp=buf, sizeof(buf))) > 0) + do { + if ((n = write(1, cp, nr)) <= 0) + error(SYSTEM, "write error in io_process"); + cp += n; + } while ((nr -= n) > 0); + if (nr < 0) + error(SYSTEM, "read error in io_process"); + close(0); /* close input */ + close(1); /* close output */ + if (pid) /* parent waits for stdin child */ wait(0); - exit(0); /* all done, exit (not quit!) */ + if (pid2 > 0) /* wait for stderr child also */ + wait(0); + _exit(0); /* all done, exit (not quit!) */ formerr: error(USER, "format error in persist file"); +forkerr: + error(SYSTEM, "fork failed in io_process"); } + +#else + +pfclean() {} + +#endif
