--- ray/src/rt/persist.c 1996/07/06 22:30:05 2.14 +++ ray/src/rt/persist.c 2003/06/26 00:58:10 2.28 @@ -1,28 +1,33 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: persist.c,v 2.28 2003/06/26 00:58:10 schorsch Exp $"; #endif - /* * Routines for persistent rtrace and rpict processes. + * + * External symbols declared in ray.h */ +#include "copyright.h" + #include "standard.h" +#include "random.h" #ifdef F_SETLKW - #include "paths.h" +#include "selcall.h" #include -#include #include #ifndef TIMELIM #define TIMELIM (8*3600) /* time limit for holding pattern */ #endif -extern char *strcpy(), *index(); +#ifndef freebsd +#define mkfifo(fn,md) mknod(fn, S_IFIFO|(md), 0) +#endif +extern void io_process(); + extern int headismine; /* boolean true if header belongs to me */ extern char *progname; /* global program name */ @@ -35,6 +40,7 @@ static int persistfd = -1; /* persist file descriptor static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; +void pfdetach() /* release persist (and header) resources */ { if (persistfd >= 0) @@ -48,6 +54,7 @@ pfdetach() /* release persist (and header) resources } +void pfclean() /* clean up persist files */ { if (persistfd >= 0) @@ -63,6 +70,7 @@ pfclean() /* clean up persist files */ } +void pflock(lf) /* place or release exclusive lock on file */ int lf; { @@ -83,8 +91,6 @@ char *pfn; persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { persistfname = pfn; - /* put something there for faulty lock daemons */ - write(persistfd, "Initializing...\n", 16); pflock(1); return; } @@ -101,56 +107,67 @@ char *pfn; static int got_io; -static int sig_io() { got_io++; } +static void sig_io() { got_io++; } -static int sig_alrm() { quit(0); } +static void sig_alrm() { quit(0); } +void pfhold() /* holding pattern for idle rendering process */ { - int (*oldalrm)(); + void (*oldalrm)(); char buf[512]; register int n; /* close input and output descriptors */ close(fileno(stdin)); close(fileno(stdout)); + if (errfile == NULL) + close(fileno(stderr)); /* create named pipes for input and output */ - if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + if (mkfifo(mktemp(strcpy(inpname,TEMPLATE)), 0600) < 0) goto createrr; - if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + if (mkfifo(mktemp(strcpy(outpname,TEMPLATE)), 0600) < 0) goto createrr; if (errfile == NULL && - mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0) + mkfifo(mktemp(strcpy(errname,TEMPLATE)), 0600) < 0) goto createrr; sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(), inpname, outpname, errname); - if (lseek(persistfd, 0L, 0) < 0) - error(SYSTEM, "seek error on persist file"); n = strlen(buf); if (write(persistfd, buf, n) < n) error(SYSTEM, "error writing persist file"); - ftruncate(persistfd, (long)n); - fsync(persistfd); /* shouldn't be necessary, but.... */ + lseek(persistfd, (off_t)0L, 0); /* wait TIMELIM for someone to signal us */ got_io = 0; signal(SIGIO, sig_io); - oldalrm = (int (*)())signal(SIGALRM, sig_alrm); + oldalrm = (void (*)())signal(SIGALRM, sig_alrm); alarm(TIMELIM); - pflock(0); + pflock(0); /* unlock persist file for attach */ while (!got_io) - pause(); - alarm(0); + pause(); /* wait for attach */ + alarm(0); /* turn off alarm */ signal(SIGALRM, oldalrm); signal(SIGIO, SIG_DFL); - pflock(1); + pflock(1); /* grab persist file back */ /* someone wants us; reopen stdin and stdout */ + /* if (freopen(inpname, "r", stdin) == NULL) goto openerr; if (freopen(outpname, "w", stdout) == NULL) goto openerr; + */ + close(0); + if (open(inpname, O_RDONLY) != 0) + error(INTERNAL, "unexpected stdin file number"); + clearerr(stdin); + close(1); + if (open(outpname, O_WRONLY) != 1) + error(INTERNAL, "unexpected stdout file number"); + sleep(3); /* give them a chance to open their pipes */ if (errname[0]) { - if (freopen(errname, "w", stderr) == NULL) - goto openerr; + close(2); + if (open(errname, O_WRONLY) != 2) + error(INTERNAL, "unexpected stderr file number"); unlink(errname); errname[0] = '\0'; } @@ -166,19 +183,32 @@ openerr: } -io_process() /* just act as conduits to and from actual process */ +void +io_process() /* just act as go-between for actual process */ { register char *cp; register int nr, n; - char buf[512], *pfin, *pfout, *pferr; - int pid, pid2 = -1; - /* load and close persist file */ - errno = 0; - nr = read(persistfd, buf, sizeof(buf)-1); - pfdetach(); - if (nr <= 0) + char buf[BUFSIZ], *pfin, *pfout, *pferr; + int pid, nfds; + int fdout, fderr = -1; + int status = 0; + fd_set readfds, excepfds; + /* load persist file */ + n = 40; + while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) { + if (!n--) + error(USER, "unattended persist file?"); + pflock(0); + sleep(3+(3*getpid()+random())%13); /* wait until ready */ + pflock(1); + } + if (nr < 0) error(SYSTEM, "error reading persist file"); - buf[nr] = '\0'; +#ifndef _WIN32 /* XXX we need a replacement for that one */ + ftruncate(persistfd, (off_t)0L); /* truncate persist file */ +#endif + pfdetach(); /* close & release persist file */ + buf[nr] = '\0'; /* parse what we got */ if ((cp = index(buf, ' ')) == NULL) goto formerr; *cp++ = '\0'; @@ -204,60 +234,117 @@ io_process() /* just act as conduits to and from actu sprintf(errmsg, "persist file for %s, not %s", buf, progname); error(USER, errmsg); } - /* wake up rendering process */ + /* wake up rendering process */ if (kill(pid, SIGIO) < 0) error(SYSTEM, "cannot signal rendering process in io_process"); - pid = fork(); /* fork i/o process */ + /* fork child feeder process */ + pid = fork(); if (pid < 0) - goto forkerr; - /* connect to appropriate pipe */ - if (pid) { /* parent passes renderer output */ - close(0); - if (pferr[0]) { - pid2 = fork(); /* fork another for stderr */ - if (pid2 < 0) - goto forkerr; + error(SYSTEM, "fork failed in io_process"); + if (pid == 0) { /* feeder loop */ + int fdin; + close(1); /* open input pipe */ + if ((fdin = open(pfin, O_WRONLY)) < 0) + error(SYSTEM, "cannot open feed pipe in io_process"); + /* renderer stdin */ + while ((nr = read(0, cp=buf, sizeof(buf))) > 0) { + do { + if ((n = write(fdin, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); } - if (pid2) { /* parent is still stdout */ - if (open(pfout, O_RDONLY) != 0) - error(SYSTEM, - "cannot open output pipe in io_process"); - } else { /* second child is stderr */ - if (open(pferr, O_RDONLY) != 0) - error(SYSTEM, - "cannot open error pipe in io_process"); - dup2(2, 1); /* attach stdout to stderr */ + if (nr < 0) + goto readerr; + _exit(0); + } + close(0); + /* open output pipes, in order */ + if ((fdout = open(pfout, O_RDONLY)) < 0) + error(SYSTEM, "cannot open output pipe in io_process"); + if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0) + error(SYSTEM, "cannot open error pipe in io_process"); + for ( ; ; ) { /* eater loop */ + FD_ZERO(&readfds); + FD_ZERO(&excepfds); + nfds = 0; + if (fdout >= 0) { + FD_SET(fdout, &readfds); + FD_SET(fdout, &excepfds); + nfds = fdout+1; } - } else { /* child passes renderer input */ - close(1); - if (open(pfin, O_WRONLY) != 1) - error(SYSTEM, "cannot open input pipe in io_process"); + if (fderr >= 0) { + FD_SET(fderr, &readfds); + FD_SET(fderr, &excepfds); + nfds = fderr+1; + } + if (nfds == 0) + break; /* all done, exit */ + if (select(nfds, &readfds, NULL, &excepfds, NULL) < 0) + error(SYSTEM, "error in select call in io_process"); + /* renderer stderr */ + if (fderr >= 0 && (FD_ISSET(fderr, &readfds) || + FD_ISSET(fderr, &excepfds))) { + nr = read(fderr, cp=buf, sizeof(buf)); + if (nr < 0) + goto readerr; + if (nr == 0) { + close(fderr); + /* close(2); don't close stderr! */ + fderr = -1; + } else { + cp[nr] = '\0'; /* deduce status if we can */ + n = strlen(progname); + if (!strncmp(cp, progname, n) && + cp[n++] == ':' && + cp[n++] == ' ') { + register struct erract *ep; + for (ep = erract; ep < erract+NERRS; + ep++) + if (ep->pre[0] && + !strncmp(cp+n, ep->pre, + strlen(ep->pre))) { + status = ep->ec; + break; + } + } + do { /* write message */ + if ((n = write(2, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); + } + } + /* renderer stdout */ + if (fdout >= 0 && (FD_ISSET(fdout, &readfds) || + FD_ISSET(fdout, &excepfds))) { + nr = read(fdout, cp=buf, sizeof(buf)); + if (nr < 0) + goto readerr; + if (nr == 0) { /* EOF */ + close(fdout); + close(1); + fdout = -1; + } else + do { /* write it all */ + if ((n = write(1, cp, nr)) <= 0) + goto writerr; + cp += n; + } while ((nr -= n) > 0); + } } - /* pass input to output */ - /* read as much as we can, write all of it */ - while ((nr = read(0, cp=buf, sizeof(buf))) > 0) - do { - if ((n = write(1, cp, nr)) <= 0) - error(SYSTEM, "write error in io_process"); - cp += n; - } while ((nr -= n) > 0); - if (nr < 0) - error(SYSTEM, "read error in io_process"); - close(0); /* close input */ - close(1); /* close output */ - if (pid) /* parent waits for stdin child */ - wait(0); - if (pid2 > 0) /* wait for stderr child also */ - wait(0); - _exit(0); /* all done, exit (not quit!) */ + wait(0); /* wait for feeder process */ + _exit(status); formerr: error(USER, "format error in persist file"); -forkerr: - error(SYSTEM, "fork failed in io_process"); +readerr: + error(SYSTEM, "read error in io_process"); +writerr: + error(SYSTEM, "write error in io_process"); } #else -pfclean() {} +void pfclean() {} #endif
