--- ray/src/rt/persist.c 2003/10/20 16:01:55 2.32 +++ ray/src/rt/persist.c 2004/03/30 16:13:01 2.34 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: persist.c,v 2.32 2003/10/20 16:01:55 greg Exp $"; +static const char RCSid[] = "$Id: persist.c,v 2.34 2004/03/30 16:13:01 schorsch Exp $"; #endif /* * Routines for persistent rtrace and rpict processes. @@ -13,10 +13,11 @@ static const char RCSid[] = "$Id: persist.c,v 2.32 200 #include #include +#include "platform.h" #include "rtprocess.h" /* getpid() */ #include "standard.h" -#include "platform.h" #include "random.h" +#include "ray.h" #ifdef F_SETLKW #include "paths.h" @@ -26,22 +27,20 @@ static const char RCSid[] = "$Id: persist.c,v 2.32 200 #define TIMELIM (8*3600) /* time limit for holding pattern */ #endif -extern void io_process(); - extern int headismine; /* boolean true if header belongs to me */ - extern char *progname; /* global program name */ - extern char *errfile; /* global error file name */ - static char *persistfname = NULL; /* persist file name */ static int persistfd = -1; /* persist file descriptor */ - static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1]; +typedef void (sighandler_t)(int); +static sighandler_t sig_io; +static sighandler_t sig_alrm; -void -pfdetach() /* release persist (and header) resources */ + +extern void +pfdetach(void) /* release persist (and header) resources */ { if (persistfd >= 0) close(persistfd); @@ -54,8 +53,8 @@ pfdetach() /* release persist (and header) resources } -void -pfclean() /* clean up persist files */ +extern void +pfclean(void) /* clean up persist files */ { if (persistfd >= 0) close(persistfd); @@ -70,9 +69,10 @@ pfclean() /* clean up persist files */ } -void -pflock(lf) /* place or release exclusive lock on file */ -int lf; +extern void +pflock( /* place or release exclusive lock on file */ + int lf +) { struct flock fls; @@ -85,9 +85,10 @@ int lf; } -void -persistfile(pfn) /* open persist file and lock it */ -char *pfn; +extern void +persistfile( /* open persist file and lock it */ + char *pfn +) { persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644); if (persistfd >= 0) { @@ -108,15 +109,15 @@ char *pfn; static int got_io; -static void sig_io() { got_io++; } +static void sig_io(int i) { got_io++; } -static void sig_alrm() { quit(0); } +static void sig_alrm(int i) { quit(0); } -void -pfhold() /* holding pattern for idle rendering process */ +extern void +pfhold(void) /* holding pattern for idle rendering process */ { - void (*oldalrm)(); + sighandler_t *oldalrm; char buf[512]; register int n; /* close input and output descriptors */ @@ -141,7 +142,7 @@ pfhold() /* holding pattern for idle rendering proces /* wait TIMELIM for someone to signal us */ got_io = 0; signal(SIGIO, sig_io); - oldalrm = (void (*)())signal(SIGALRM, sig_alrm); + oldalrm = signal(SIGALRM, sig_alrm); alarm(TIMELIM); pflock(0); /* unlock persist file for attach */ while (!got_io) @@ -184,8 +185,8 @@ openerr: } -void -io_process() /* just act as go-between for actual process */ +extern void +io_process(void) /* just act as go-between for actual process */ { register char *cp; register int nr, n; @@ -334,7 +335,7 @@ io_process() /* just act as go-between for actual pro } while ((nr -= n) > 0); } } - wait(0); /* wait for feeder process */ + wait(0); /* wait for feeder process */ /* XXX platform */ _exit(status); formerr: error(USER, "format error in persist file"); @@ -346,6 +347,6 @@ writerr: #else -void pfclean() {} +extern void pfclean(void) {} #endif
