root/radiance/ray/src/rt/p_func.c
Wed Jan 17 17:35:35 2024 UTC (18 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.12: +2 -3 lines
Diff to previous 2.12
perf(rvu, rpict, rtrace, rcontrib): Better rendering of spectral primitives in RGB mode
Sun Jan 7 18:04:16 2024 UTC (18 months, 3 weeks ago) by greg
Changes since 2.11: +3 -4 lines
fix(rpict,rtrace,rcontrib,rvu): fixed sampling for "specfunc" primitive
Wed Dec 13 23:26:16 2023 UTC (19 months, 3 weeks ago) by greg
feat(rpict,rvu,rtrace,rcontrib): Added "specdata" and "specpict" pattern primitives
Fri Nov 17 20:02:07 2023 UTC (20 months, 2 weeks ago) by greg
Wed Nov 15 18:02:53 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.8: +66 -7 lines
Tue Jul 8 18:25:00 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.6: +12 -8 lines
Wed Mar 5 16:16:53 2003 UTC (22 years, 5 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.3: +57 -5 lines
Wed Jan 12 16:46:50 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.2: +4 -2 lines
Mon Nov 25 09:50:57 1991 UTC (33 years, 8 months ago) by greg
Changes since 2.1: +15 -23 lines
Tue Nov 12 17:08:40 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.2
Thu Aug 8 11:29:58 1991 UTC (34 years ago) by greg
Changes since 1.1: +2 -4 lines
Diff to previous 1.1
added contexts to function files
Thu Feb 2 10:41:34 1989 UTC (36 years, 6 months ago) by greg
