root/radiance/ray/src/rt/p_func.c
Revision: 2.8
Committed: Tue Jul 8 18:25:00 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3
2 static const char RCSid[] = "$Id: p_func.c,v 2.7 2004/03/30 16:13:01 schorsch Exp $";
5 * p_func.c - routine for procedural patterns.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "func.h"
12 #include "rtotypes.h"
13
14 /*
15 * A procedural pattern can either be a brightness or a
16 * color function. A brightness function is given as:
17 *
18 * modifier brightfunc name
19 * 2+ bvarname filename xf
20 * 0
21 * n A1 A2 ..
22 *
23 * A color function is given as:
24 *
25 * modifier colorfunc name
26 * 4+ rvarname gvarname bvarname filename xf
27 * 0
28 * n A1 A2 ..
29 *
30 * Filename is the name of the file where the variable definitions
31 * can be found. The list of real arguments can be accessed by
32 * definitions in the file. The xf is a transformation
33 * to get from the original coordinates to the current coordinates.
34 */
35
36
37 int
38 p_bfunc( /* compute brightness pattern */
39 OBJREC *m,
40 RAY *r
41 )
42 {
43 double bval;
44 MFUNC *mf;
45
46 if (m->oargs.nsargs < 2)
47 objerror(m, USER, "bad # arguments");
48 mf = getfunc(m, 1, 0x1, 0);
49 setfunc(m, r);
50 errno = 0;
51 bval = evalue(mf->ep[0]);
52 if (errno == EDOM || errno == ERANGE) {
53 objerror(m, WARNING, "compute error");
54 return(0);
55 }
56 scalecolor(r->pcol, bval);
57 return(0);
58 }
59
60
61 int
62 p_cfunc( /* compute color pattern */
63 OBJREC *m,
64 RAY *r
65 )
66 {
67 COLOR cval;
68 MFUNC *mf;
69
70 if (m->oargs.nsargs < 4)
71 objerror(m, USER, "bad # arguments");
72 mf = getfunc(m, 3, 0x7, 0);
73 setfunc(m, r);
74 errno = 0;
75 setcolor(cval, evalue(mf->ep[0]),
76 evalue(mf->ep[1]),
77 evalue(mf->ep[2]));
78 if (errno == EDOM || errno == ERANGE) {
79 objerror(m, WARNING, "compute error");
80 return(0);
81 }
82 multcolor(r->pcol, cval);
83 return(0);
84 }
