root/radiance/ray/src/rt/p_func.c
Revision: 1.2
Committed: Thu Aug 8 11:29:58 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.1: +2 -4 lines
added contexts to function files
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * p_func.c - routine for procedural patterns.
9 *
10 * 4/8/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * A procedural pattern can either be a brightness or a
17 * color function. A brightness function is given as:
18 *
19 * modifier brightfunc name
20 * 2+ bvarname filename xf
21 * 0
22 * n A1 A2 ..
23 *
24 * A color function is given as:
25 *
26 * modifier colorfunc name
27 * 4+ rvarname gvarname bvarname filename xf
28 * 0
29 * n A1 A2 ..
30 *
31 * Filename is the name of the file where the variable definitions
32 * can be found. The list of real arguments can be accessed by
33 * definitions in the file. The xf is a transformation
34 * to get from the original coordinates to the current coordinates.
35 */
36
37
38 p_bfunc(m, r) /* compute brightness pattern */
39 register OBJREC *m;
40 RAY *r;
41 {
42 extern double varvalue();
43 extern int errno;
44 double bval;
45 register char **sa;
46
47 setfunc(m, r);
48
49 sa = m->oargs.sarg;
50
51 if (m->oargs.nsargs < 2)
52 objerror(m, USER, "bad # arguments");
53 funcfile(sa[1]);
54 errno = 0;
55 bval = varvalue(sa[0]);
56 if (errno) {
57 objerror(m, WARNING, "compute error");
58 return;
59 }
60 scalecolor(r->pcol, bval);
61 }
62
63
64 p_cfunc(m, r) /* compute color pattern */
65 register OBJREC *m;
66 RAY *r;
67 {
68 extern double varvalue();
69 extern int errno;
70 COLOR cval;
71 register char **sa;
72
73 setfunc(m, r);
74
75 sa = m->oargs.sarg;
76
77 if (m->oargs.nsargs < 4)
78 objerror(m, USER, "bad # arguments");
79 funcfile(sa[3]);
80 errno = 0;
81 setcolor(cval, varvalue(sa[0]),
82 varvalue(sa[1]),
83 varvalue(sa[2]));
84 if (errno) {
85 objerror(m, WARNING, "compute error");
86 return;
87 }
88 multcolor(r->pcol, cval);
89 }
