root/radiance/ray/src/rt/p_func.c
Revision: 2.9
Committed: Wed Nov 15 18:02:53 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 2.8: +66 -7 lines
2 static const char RCSid[] = "$Id: p_func.c,v 2.8 2014/07/08 18:25:00 greg Exp $";
5 * p_func.c - routine for procedural patterns.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "func.h"
12 #include "rtotypes.h"
13
14 /*
15 * A procedural pattern can either be a brightness or a
16 * color function. A brightness function is given as:
17 *
18 * modifier brightfunc name
19 * 2+ bvarname filename xf
20 * 0
21 * n A1 A2 ..
22 *
23 * A color function is given as:
24 *
25 * modifier colorfunc name
26 * 4+ rvarname gvarname bvarname filename xf
27 * 0
28 * n A1 A2 ..
29 *
30 * A spectral function is given as:
31 *
32 * modifier specfunc name
33 * 2+ sval filename xf
34 * 0
35 * 2+ nmA nmB A3 ..
36 *
37 * Filename is the name of the file where the variable definitions
38 * can be found. The list of real arguments can be accessed by
39 * definitions in the file. The xf is a transformation
40 * to get from the original coordinates to the current coordinates.
41 * For the "specfunc" primitive, sval(nm) is a function of wavelength
42 * and must be defined from nmA to nmB, and should average to 1 over
43 * its range.
44 */
45
46
47 int
48 p_bfunc( /* compute brightness pattern */
49 OBJREC *m,
50 RAY *r
51 )
52 {
53 double bval;
54 MFUNC *mf;
55
56 if (m->oargs.nsargs < 2)
57 objerror(m, USER, "bad # arguments");
58 mf = getfunc(m, 1, 0x1, 0);
59 setfunc(m, r);
60 errno = 0;
61 bval = evalue(mf->ep[0]);
62 if ((errno == EDOM) | (errno == ERANGE)) {
63 objerror(m, WARNING, "compute error");
64 return(0);
65 }
66 scalescolor(r->pcol, bval);
67 return(0);
68 }
69
70
71 int
72 p_cfunc( /* compute color pattern */
73 OBJREC *m,
74 RAY *r
75 )
76 {
77 SCOLOR scval;
78 MFUNC *mf;
79
80 if (m->oargs.nsargs < 4)
81 objerror(m, USER, "bad # arguments");
82 mf = getfunc(m, 3, 0x7, 0);
83 setfunc(m, r);
84 errno = 0;
85 setscolor(scval, evalue(mf->ep[0]),
86 evalue(mf->ep[1]),
87 evalue(mf->ep[2]));
88 if ((errno == EDOM) | (errno == ERANGE)) {
89 objerror(m, WARNING, "compute error");
90 return(0);
91 }
92 smultscolor(r->pcol, scval);
93 return(0);
94 }
95
96
97 int
98 p_specfunc( /* compute spectral pattern */
99 OBJREC *m,
100 RAY *r
101 )
102 {
103 SCOLOR scsamp;
104 SCOLOR scval;
105 double wl, wlmin, wlmax, wlstep;
106 int ns, i;
107 MFUNC *mf;
108
109 if ((m->oargs.nsargs < 2) | (m->oargs.nfargs < 2))
110 objerror(m, USER, "bad # arguments");
111 if (m->oargs.farg[0] < m->oargs.farg[1]) {
112 wlmin = m->oargs.farg[0];
113 wlmax = m->oargs.farg[1];
114 } else {
115 wlmin = m->oargs.farg[1];
116 wlmax = m->oargs.farg[0];
117 }
118 if (wlmin < WLPART[3]) wlmin = WLPART[3];
119 if (wlmax > WLPART[0]) wlmax = WLPART[0];
120 if (wlmin >= wlmax) {
121 objerror(m, WARNING, "incompatible wavelength sampling");
122 return(0);
123 }
124 wlstep = (wlmax - wlmin)/(double)MAXCSAMP;
125 if (wlstep*(5.*NCSAMP) < WLPART[0] - WLPART[3])
126 wlstep = (WLPART[0] - WLPART[3])/(5.*NCSAMP);
127 mf = getfunc(m, 1, 0, 0);
128 setfunc(m, r);
129 errno = 0;
130 ns = (wlmax - wlmin)/wlstep + .1;
131 wl = wlmax - .5*wlstep;
132 for (i = ns; i-- > 0; wl -= wlstep) {
133 scsamp[i] = funvalue(m->oargs.sarg[0], 1, &wl);
134 if ((errno == EDOM) | (errno == ERANGE)) {
135 objerror(m, WARNING, "compute error");
136 return(0);
137 }
138 }
139 convertscolor(scval, NCSAMP, WLPART[0], WLPART[3],
140 scsamp, ns, wlmin, wlmax);
141 smultscolor(r->pcol, scval);
142 return(0);
143 }
