1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: p_data.c,v 2.12 2023/12/14 00:51:12 greg Exp $"; |
3 |
#endif |
4 |
5 |
* p_data.c - routine for stored patterns. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "data.h" |
12 |
#include "func.h" |
13 |
#include "rtotypes.h" |
14 |
15 |
16 |
* A stored pattern can either be brightness, |
17 |
* color, or spectral data. Brightness data is specified as: |
18 |
19 |
* modifier brightdata name |
20 |
* 4+ func dfname vfname v0 v1 .. xf |
21 |
* 0 |
22 |
* n A1 A2 .. |
23 |
24 |
* Color data is specified as: |
25 |
26 |
* modifier colordata name |
27 |
* 8+ rfunc gfunc bfunc rdfname gdfname bdfname vfname v0 v1 .. xf |
28 |
* 0 |
29 |
* n A1 A2 .. |
30 |
31 |
* Color picture data is specified as: |
32 |
33 |
* modifier colorpict name |
34 |
* 7+ rfunc gfunc bfunc pfname vfname vx vy xf |
35 |
* 0 |
36 |
* n A1 A2 .. |
37 |
38 |
* A simple spectrum is specified as: |
39 |
40 |
* modifier spectrum name |
41 |
* 0 |
42 |
* 0 |
43 |
* 5+ nmA nmB s1 s2 s3 .. |
44 |
45 |
* A constant spectrum from a data file is given as: |
46 |
47 |
* modifier specfile name |
48 |
* 1 dfname |
49 |
* 0 |
50 |
* 0 |
51 |
52 |
* A spectral data file is given as: |
53 |
54 |
* modifier specdata name |
55 |
* 4+ sfunc dfname vfname v0 .. xf |
56 |
* 0 |
57 |
* n A1 A2 .. |
58 |
59 |
* A spectral image is given as: |
60 |
61 |
* modifier specpict name |
62 |
* 5+ sfunc sfname vfname vx vy xf |
63 |
* 0 |
64 |
* n A1 A2 .. |
65 |
66 |
* Vfname is the name of the file where the variable definitions |
67 |
* can be found. The list of real arguments can be accessed by |
68 |
* definitions in the file. The dfnames are the data file |
69 |
* names. The dimensions of the data files and the number |
70 |
* of variables must match, except for specdata, which has a "hidden" |
71 |
* last variable for the wavelength. The funcs take a single argument |
72 |
* for brightdata, three for colordata and colorpict, and two for |
73 |
* specdata and specpict to modify interpolated values from the file. |
74 |
* The xf is a transform spec to get from the original coordinates to |
75 |
* the current coordinates. |
76 |
77 |
78 |
79 |
int |
80 |
p_bdata( /* interpolate brightness data */ |
81 |
OBJREC *m, |
82 |
RAY *r |
83 |
84 |
85 |
double bval; |
86 |
double pt[MAXDDIM]; |
87 |
DATARRAY *dp; |
88 |
MFUNC *mf; |
89 |
int i; |
90 |
91 |
if (m->oargs.nsargs < 4) |
92 |
objerror(m, USER, "bad # arguments"); |
93 |
dp = getdata(m->oargs.sarg[1]); |
94 |
i = (1 << dp->nd) - 1; |
95 |
mf = getfunc(m, 2, i<<3, 0); |
96 |
setfunc(m, r); |
97 |
errno = 0; |
98 |
for (i = dp->nd; i-- > 0; ) { |
99 |
pt[i] = evalue(mf->ep[i]); |
100 |
if ((errno == EDOM) | (errno == ERANGE)) |
101 |
goto computerr; |
102 |
103 |
bval = datavalue(dp, pt); |
104 |
errno = 0; |
105 |
bval = funvalue(m->oargs.sarg[0], 1, &bval); |
106 |
107 |
goto computerr; |
108 |
scalescolor(r->pcol, bval); |
109 |
return(0); |
110 |
computerr: |
111 |
objerror(m, WARNING, "compute error"); |
112 |
return(0); |
113 |
114 |
115 |
116 |
int |
117 |
p_cdata( /* interpolate color data */ |
118 |
OBJREC *m, |
119 |
RAY *r |
120 |
121 |
122 |
double col[3]; |
123 |
COLOR cval; |
124 |
125 |
int nv; |
126 |
DATARRAY *dp; |
127 |
MFUNC *mf; |
128 |
int i; |
129 |
130 |
if (m->oargs.nsargs < 8) |
131 |
132 |
dp = getdata(m->oargs.sarg[3]); |
133 |
i = (1 << (nv = dp->nd)) - 1; |
134 |
mf = getfunc(m, 6, i<<7, 0); |
135 |
setfunc(m, r); |
136 |
errno = 0; |
137 |
for (i = 0; i < nv; i++) { |
138 |
139 |
140 |
goto computerr; |
141 |
142 |
col[0] = datavalue(dp, pt); |
143 |
for (i = 1; i < 3; i++) { |
144 |
dp = getdata(m->oargs.sarg[3+i]); |
145 |
if (dp->nd != nv) |
146 |
objerror(m, USER, "dimension error"); |
147 |
col[i] = datavalue(dp, pt); |
148 |
149 |
errno = 0; |
150 |
for (i = 0; i < 3; i++) |
151 |
if (i && fundefined(m->oargs.sarg[i]) < 3) |
152 |
colval(cval,i) = funvalue(m->oargs.sarg[i], 1, col+i); |
153 |
else |
154 |
colval(cval,i) = funvalue(m->oargs.sarg[i], 3, col); |
155 |
156 |
goto computerr; |
157 |
smultcolor(r->pcol, cval); |
158 |
return(0); |
159 |
computerr: |
160 |
161 |
return(0); |
162 |
163 |
164 |
165 |
int |
166 |
p_pdata( /* interpolate picture data */ |
167 |
OBJREC *m, |
168 |
RAY *r |
169 |
170 |
171 |
double col[3]; |
172 |
COLOR cval; |
173 |
double pt[2]; |
174 |
DATARRAY *dp; |
175 |
MFUNC *mf; |
176 |
int i; |
177 |
178 |
if (m->oargs.nsargs < 7) |
179 |
180 |
mf = getfunc(m, 4, 0x3<<5, 0); |
181 |
setfunc(m, r); |
182 |
errno = 0; |
183 |
pt[1] = evalue(mf->ep[0]); /* y major ordering */ |
184 |
pt[0] = evalue(mf->ep[1]); |
185 |
186 |
goto computerr; |
187 |
dp = getpict(m->oargs.sarg[3]); |
188 |
189 |
col[i] = datavalue(dp+i, pt); |
190 |
errno = 0; |
191 |
192 |
193 |
194 |
else |
195 |
196 |
197 |
goto computerr; |
198 |
199 |
return(0); |
200 |
201 |
computerr: |
202 |
203 |
return(0); |
204 |
205 |
206 |
207 |
int |
208 |
p_spectrum( /* simple constant spectrum */ |
209 |
OBJREC *m, |
210 |
RAY *r |
211 |
212 |
213 |
COLORV *scval; |
214 |
215 |
if ((scval = (COLORV *)m->os) == NULL) { |
216 |
COLORV *sinp; |
217 |
double hstep; |
218 |
int i; |
219 |
if (m->oargs.nfargs < 5) |
220 |
221 |
sinp = (COLORV *)malloc(sizeof(COLORV)*(m->oargs.nfargs-2)); |
222 |
scval = (COLORV *)malloc(sizeof(COLORV)*NCSAMP); |
223 |
if ((sinp == NULL) | (scval == NULL)) |
224 |
objerror(m, SYSTEM, "out of memory"); |
225 |
for (i = m->oargs.nfargs-2; i--; ) |
226 |
sinp[i] = (COLORV)m->oargs.farg[i+2]; |
227 |
hstep = 0.5 * (m->oargs.farg[1] - m->oargs.farg[0]) / |
228 |
(m->oargs.nfargs-3.0); |
229 |
convertscolorcol(scval, sinp, m->oargs.nfargs-2, |
230 |
m->oargs.farg[0]-hstep, m->oargs.farg[1]+hstep); |
231 |
free(sinp); |
232 |
m->os = (void *)scval; |
233 |
234 |
smultscolor(r->pcol, scval); |
235 |
return(0); |
236 |
237 |
238 |
239 |
int |
240 |
p_specfile( /* constant spectrum from 1-D data file */ |
241 |
OBJREC *m, |
242 |
RAY *r |
243 |
244 |
245 |
COLORV *scval; |
246 |
247 |
248 |
DATARRAY *dp; |
249 |
COLORV *sinp; |
250 |
double step; |
251 |
int i; |
252 |
if (m->oargs.nsargs != 1) |
253 |
254 |
dp = getdata(m->oargs.sarg[0]); |
255 |
if (dp->nd != 1) |
256 |
objerror(m, USER, "data file must be 1-dimensional"); |
257 |
258 |
sinp = (COLORV *)malloc(sizeof(COLORV)*dp->dim[0].ne); |
259 |
260 |
261 |
262 |
step = dp->dim[0].siz / (dp->dim[0].ne - 1.0); |
263 |
for (i = dp->dim[0].ne; i-- > 0; ) { |
264 |
double wl = dp->dim[0].org + i*step; |
265 |
sinp[i] = (COLORV)datavalue(dp, &wl); |
266 |
267 |
convertscolorcol(scval, sinp, dp->dim[0].ne, |
268 |
dp->dim[0].org-.5*step, |
269 |
dp->dim[0].org+dp->dim[0].siz+.5*step); |
270 |
free(sinp); |
271 |
272 |
273 |
274 |
return(0); |
275 |
276 |
277 |
278 |
int |
279 |
p_specdata( /* varied spectrum from (N+1)-D file */ |
280 |
OBJREC *m, |
281 |
RAY *r |
282 |
283 |
284 |
SCOLOR scval; |
285 |
COLORV *scdat; |
286 |
287 |
DATARRAY *dp; |
288 |
MFUNC *mf; |
289 |
double step; |
290 |
int i; |
291 |
292 |
293 |
294 |
295 |
if (dp->nd < 2) |
296 |
objerror(m, USER, "need at least 2-dimensional data"); |
297 |
i = (1 << (dp->nd-1)) - 1; |
298 |
299 |
setfunc(m, r); |
300 |
errno = 0; |
301 |
for (i = dp->nd-1; i-- > 0; ) { |
302 |
303 |
304 |
goto computerr; |
305 |
306 |
step = dp->dim[dp->nd-1].siz / (dp->dim[dp->nd-1].ne - 1.0); |
307 |
scdat = (COLORV *)malloc(sizeof(COLORV)*dp->dim[dp->nd-1].ne); |
308 |
if (scdat == NULL) |
309 |
310 |
for (i = dp->dim[dp->nd-1].ne; i-- > 0; ) { |
311 |
double bval[2]; |
312 |
pt[dp->nd-1] = dp->dim[dp->nd-1].org + i*step; |
313 |
bval[0] = datavalue(dp, pt); |
314 |
bval[1] = pt[dp->nd-1]; |
315 |
errno = 0; |
316 |
scdat[i] = funvalue(m->oargs.sarg[0], 2, bval); |
317 |
318 |
goto computerr; |
319 |
320 |
convertscolorcol(scval, scdat, dp->dim[dp->nd-1].ne, |
321 |
dp->dim[dp->nd-1].org-.5*step, |
322 |
dp->dim[dp->nd-1].org+dp->dim[dp->nd-1].siz+.5*step); |
323 |
free(scdat); |
324 |
325 |
return(0); |
326 |
computerr: |
327 |
328 |
return(0); |
329 |
330 |
331 |
332 |
int |
333 |
p_specpict( /* interpolate hyperspectral image data */ |
334 |
OBJREC *m, |
335 |
RAY *r |
336 |
337 |
338 |
SCOLOR scdat, scval; |
339 |
double pt[3]; |
340 |
DATARRAY *dp; |
341 |
MFUNC *mf; |
342 |
double step; |
343 |
int i; |
344 |
345 |
if (m->oargs.nsargs < 5) |
346 |
347 |
mf = getfunc(m, 2, 0x3<<3, 0); |
348 |
setfunc(m, r); |
349 |
errno = 0; |
350 |
351 |
352 |
353 |
goto computerr; |
354 |
dp = getspec(m->oargs.sarg[1]); |
355 |
step = dp->dim[2].siz / (dp->dim[2].ne - 1.0); |
356 |
for (i = dp->dim[2].ne; i-- > 0; ) { |
357 |
double bval[2]; |
358 |
pt[2] = dp->dim[2].org + i*step; |
359 |
360 |
bval[1] = pt[2]; |
361 |
errno = 0; |
362 |
363 |
364 |
goto computerr; |
365 |
366 |
convertscolorcol(scval, scdat, dp->dim[2].ne, |
367 |
dp->dim[2].org-.5*step, |
368 |
dp->dim[2].org+dp->dim[2].siz+.5*step); |
369 |
370 |
return(0); |
371 |
computerr: |
372 |
373 |
return(0); |
374 |
