root/radiance/ray/src/rt/p_data.c
Revision: 1.2
Committed: Tue Mar 14 11:12:55 1989 UTC (35 years, 2 months ago) by greg
simplified errno test
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * p_data.c - routine for stored patterns.
9 *
10 * 6/4/86
11 */
12
13 #include "ray.h"
14
15 #include "data.h"
16
17 /*
18 * A stored pattern can either be brightness or
19 * color data. Brightness data is specified as:
20 *
21 * modifier brightdata name
22 * 4+ func dfname vfname v0 v1 .. xf
23 * 0
24 * n A1 A2 ..
25 *
26 * Color data is specified as:
27 *
28 * modifier colordata name
29 * 8+ rfunc gfunc bfunc rdfname gdfname bdfname vfname v0 v1 .. xf
30 * 0
31 * n A1 A2 ..
32 *
33 * Color picture data is specified as:
34 *
35 * modifier colorpict name
36 * 7+ rfunc gfunc bfunc pfname vfname vx vy xf
37 * 0
38 * n A1 A2 ..
39 *
40 * Vfname is the name of the file where the variable definitions
41 * can be found. The list of real arguments can be accessed by
42 * definitions in the file. The dfnames are the data file
43 * names. The dimensions of the data files and the number
44 * of variables must match. The funcs take a single argument
45 * for brightdata, and three for colordata and colorpict to produce
46 * interpolated values from the file. The xf is a transformation
47 * to get from the original coordinates to the current coordinates.
48 */
49
50
51 p_bdata(m, r) /* interpolate brightness data */
52 register OBJREC *m;
53 RAY *r;
54 {
55 extern double varvalue(), funvalue(), datavalue();
56 extern int errno;
57 int nv;
58 double bval;
59 double pt[MAXDIM];
60 DATARRAY *dp;
61 register char **sa;
62
63 setfunc(m, r);
64
65 sa = m->oargs.sarg;
66
67 if (m->oargs.nsargs < 4)
68 objerror(m, USER, "bad # arguments");
69 if (!vardefined(sa[3]))
70 loadfunc(sa[2]);
71 errno = 0;
72 for (nv = 0; nv+3 < m->oargs.nsargs &&
73 sa[nv+3][0] != '-'; nv++) {
74 if (nv >= MAXDIM)
75 goto dimerr;
76 pt[nv] = varvalue(sa[nv+3]);
77 }
78 if (errno)
79 goto computerr;
80 dp = getdata(sa[1]);
81 if (dp->nd != nv)
82 goto dimerr;
83 bval = datavalue(dp, pt);
84 errno = 0;
85 bval = funvalue(sa[0], 1, &bval);
86 if (errno)
87 goto computerr;
88 scalecolor(r->pcol, bval);
89 return;
90
91 dimerr:
92 objerror(m, USER, "dimension error");
93
94 computerr:
95 objerror(m, WARNING, "compute error");
96 return;
97 }
98
99
100 p_cdata(m, r) /* interpolate color data */
101 register OBJREC *m;
102 RAY *r;
103 {
104 extern double varvalue(), funvalue(), datavalue();
105 extern int errno;
106 int i, nv;
107 double col[3];
108 COLOR cval;
109 double pt[MAXDIM];
110 DATARRAY *dp;
111 register char **sa;
112
113 setfunc(m, r);
114
115 sa = m->oargs.sarg;
116
117 if (m->oargs.nsargs < 8)
118 objerror(m, USER, "bad # arguments");
119 if (!vardefined(sa[7]))
120 loadfunc(sa[6]);
121 for (nv = 0; nv+7 < m->oargs.nsargs &&
122 sa[nv+7][0] != '-'; nv++) {
123 if (nv >= MAXDIM)
124 goto dimerr;
125 errno = 0;
126 pt[nv] = varvalue(sa[nv+7]);
127 if (errno)
128 goto computerr;
129 }
130 for (i = 0; i < 3; i++) {
131 dp = getdata(sa[i+3]);
132 if (dp->nd != nv)
133 goto dimerr;
134 col[i] = datavalue(dp, pt);
135 }
136 errno = 0;
137 setcolor(cval, funvalue(sa[0], 3, col),
138 funvalue(sa[1], 3, col),
139 funvalue(sa[2], 3, col));
140 if (errno)
141 goto computerr;
142 multcolor(r->pcol, cval);
143 return;
144
145 dimerr:
146 objerror(m, USER, "dimension error");
147
148 computerr:
149 objerror(m, WARNING, "compute error");
150 return;
151 }
152
153
154 p_pdata(m, r) /* interpolate picture data */
155 register OBJREC *m;
156 RAY *r;
157 {
158 extern double varvalue(), funvalue(), datavalue();
159 extern int errno;
160 int i;
161 double col[3];
162 COLOR cval;
163 double pt[2];
164 DATARRAY *dp;
165 register char **sa;
166
167 setfunc(m, r);
168
169 sa = m->oargs.sarg;
170
171 if (m->oargs.nsargs < 7)
172 objerror(m, USER, "bad # arguments");
173 if (!vardefined(sa[5]))
174 loadfunc(sa[4]);
175 for (i = 0; i < 2; i++) {
176 errno = 0;
177 pt[i] = varvalue(sa[i+5]);
178 if (errno)
179 goto computerr;
180 }
181 dp = getpict(sa[3]);
182 for (i = 0; i < 3; i++)
183 col[i] = datavalue(dp+i, pt);
184 errno = 0;
185 setcolor(cval, funvalue(sa[0], 3, col),
186 funvalue(sa[1], 3, col),
187 funvalue(sa[2], 3, col));
188 if (errno)
189 goto computerr;
190 multcolor(r->pcol, cval);
191 return;
192
193 computerr:
194 objerror(m, WARNING, "compute error");
195 return;
196 }
