--- ray/src/rt/p_data.c 2003/02/25 02:47:23 2.6 +++ ray/src/rt/p_data.c 2023/11/15 18:02:53 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: p_data.c,v 2.6 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: p_data.c,v 2.10 2023/11/15 18:02:53 greg Exp $"; #endif /* * p_data.c - routine for stored patterns. @@ -8,14 +8,13 @@ static const char RCSid[] = "$Id: p_data.c,v 2.6 2003/ #include "copyright.h" #include "ray.h" - #include "data.h" - #include "func.h" +#include "rtotypes.h" /* - * A stored pattern can either be brightness or - * color data. Brightness data is specified as: + * A stored pattern can either be brightness, + * color, or spectral data. Brightness data is specified as: * * modifier brightdata name * 4+ func dfname vfname v0 v1 .. xf @@ -36,26 +35,42 @@ static const char RCSid[] = "$Id: p_data.c,v 2.6 2003/ * 0 * n A1 A2 .. * + * A simple spectrum is specified as: + * + * modifier spectrum name + * 0 + * 0 + * 5+ nmA nmB s1 s2 s3 .. + * + * A constant spectrum from a data file is given as: + * + * modifier specfile name + * 1 dfname + * 0 + * 0 + * * Vfname is the name of the file where the variable definitions * can be found. The list of real arguments can be accessed by * definitions in the file. The dfnames are the data file * names. The dimensions of the data files and the number * of variables must match. The funcs take a single argument * for brightdata, and three for colordata and colorpict to produce - * interpolated values from the file. The xf is a transformation + * interpolated values from the file. The xf is a transform spec * to get from the original coordinates to the current coordinates. */ -p_bdata(m, r) /* interpolate brightness data */ -register OBJREC *m; -RAY *r; +int +p_bdata( /* interpolate brightness data */ + OBJREC *m, + RAY *r +) { double bval; - double pt[MAXDIM]; + double pt[MAXDDIM]; DATARRAY *dp; - register MFUNC *mf; - register int i; + MFUNC *mf; + int i; if (m->oargs.nsargs < 4) objerror(m, USER, "bad # arguments"); @@ -66,15 +81,15 @@ RAY *r; errno = 0; for (i = dp->nd; i-- > 0; ) { pt[i] = evalue(mf->ep[i]); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; } bval = datavalue(dp, pt); errno = 0; bval = funvalue(m->oargs.sarg[0], 1, &bval); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; - scalecolor(r->pcol, bval); + scalescolor(r->pcol, bval); return(0); computerr: objerror(m, WARNING, "compute error"); @@ -82,17 +97,19 @@ computerr: } -p_cdata(m, r) /* interpolate color data */ -register OBJREC *m; -RAY *r; +int +p_cdata( /* interpolate color data */ + OBJREC *m, + RAY *r +) { double col[3]; COLOR cval; - double pt[MAXDIM]; + double pt[MAXDDIM]; int nv; DATARRAY *dp; - register MFUNC *mf; - register int i; + MFUNC *mf; + int i; if (m->oargs.nsargs < 8) objerror(m, USER, "bad # arguments"); @@ -103,7 +120,7 @@ RAY *r; errno = 0; for (i = 0; i < nv; i++) { pt[i] = evalue(mf->ep[i]); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; } col[0] = datavalue(dp, pt); @@ -119,9 +136,9 @@ RAY *r; colval(cval,i) = funvalue(m->oargs.sarg[i], 1, col+i); else colval(cval,i) = funvalue(m->oargs.sarg[i], 3, col); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; - multcolor(r->pcol, cval); + smultcolor(r->pcol, cval); return(0); computerr: objerror(m, WARNING, "compute error"); @@ -129,16 +146,18 @@ computerr: } -p_pdata(m, r) /* interpolate picture data */ -register OBJREC *m; -RAY *r; +int +p_pdata( /* interpolate picture data */ + OBJREC *m, + RAY *r +) { double col[3]; COLOR cval; double pt[2]; DATARRAY *dp; - register MFUNC *mf; - register int i; + MFUNC *mf; + int i; if (m->oargs.nsargs < 7) objerror(m, USER, "bad # arguments"); @@ -147,7 +166,7 @@ RAY *r; errno = 0; pt[1] = evalue(mf->ep[0]); /* y major ordering */ pt[0] = evalue(mf->ep[1]); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; dp = getpict(m->oargs.sarg[3]); for (i = 0; i < 3; i++) @@ -158,12 +177,84 @@ RAY *r; colval(cval,i) = funvalue(m->oargs.sarg[i], 1, col+i); else colval(cval,i) = funvalue(m->oargs.sarg[i], 3, col); - if (errno) + if ((errno == EDOM) | (errno == ERANGE)) goto computerr; - multcolor(r->pcol, cval); + smultcolor(r->pcol, cval); return(0); computerr: objerror(m, WARNING, "compute error"); + return(0); +} + + +int +p_spectrum( /* simple constant spectrum */ + OBJREC *m, + RAY *r +) +{ + COLORV *scval; + + if ((scval = (COLORV *)m->os) == NULL) { + COLORV *sinp; + double hstep; + int i; + if (m->oargs.nfargs < 5) + objerror(m, USER, "bad # arguments"); + sinp = (COLORV *)malloc(sizeof(COLORV)*(m->oargs.nfargs-2)); + scval = (COLORV *)malloc(sizeof(COLORV)*NCSAMP); + if ((sinp == NULL) | (scval == NULL)) + objerror(m, SYSTEM, "out of memory"); + for (i = m->oargs.nfargs-2; i--; ) + sinp[i] = (COLORV)m->oargs.farg[i+2]; + hstep = 0.5 * (m->oargs.farg[1] - m->oargs.farg[0]) / + (m->oargs.nfargs-3.0); + convertscolor(scval, NCSAMP, WLPART[0], WLPART[3], + sinp, m->oargs.nfargs-2, + m->oargs.farg[0]-hstep, m->oargs.farg[1]+hstep); + free(sinp); + m->os = (void *)scval; + } + smultscolor(r->pcol, scval); + return(0); +} + + +int +p_specfile( /* constant spectrum from 1-D data file */ + OBJREC *m, + RAY *r +) +{ + COLORV *scval; + + if ((scval = (COLORV *)m->os) == NULL) { + DATARRAY *dp; + COLORV *sinp; + double step; + int i; + if (m->oargs.nsargs != 1) + objerror(m, USER, "bad # arguments"); + dp = getdata(m->oargs.sarg[0]); + if (dp->nd != 1) + objerror(m, USER, "data file must be 1-dimensional"); + + sinp = (COLORV *)malloc(sizeof(COLORV)*dp->dim[0].ne); + scval = (COLORV *)malloc(sizeof(COLORV)*NCSAMP); + if ((sinp == NULL) | (scval == NULL)) + objerror(m, SYSTEM, "out of memory"); + step = dp->dim[0].siz / (dp->dim[0].ne - 1.0); + for (i = dp->dim[0].ne; i-- > 0; ) { + double wl = dp->dim[0].org + i*step; + sinp[i] = (COLORV)datavalue(dp, &wl); + } + convertscolor(scval, NCSAMP, WLPART[0], WLPART[3], + sinp, dp->dim[0].ne, dp->dim[0].org-.5*step, + dp->dim[0].org+dp->dim[0].siz+.5*step); + free(sinp); + m->os = (void *)scval; + } + smultscolor(r->pcol, scval); return(0); }
