root/radiance/ray/src/rt/p_data.c
Revision: 2.10
Committed: Wed Nov 15 18:02:53 2023 UTC (19 months, 2 weeks ago) by greg
Changes since 2.9: +101 -15 lines
2 static const char RCSid[] = "$Id: p_data.c,v 2.9 2014/07/08 18:25:00 greg Exp $";
5 * p_data.c - routine for stored patterns.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "data.h"
12 #include "func.h"
13 #include "rtotypes.h"
14
15 /*
16 * A stored pattern can either be brightness,
17 * color, or spectral data. Brightness data is specified as:
18 *
19 * modifier brightdata name
20 * 4+ func dfname vfname v0 v1 .. xf
21 * 0
22 * n A1 A2 ..
23 *
24 * Color data is specified as:
25 *
26 * modifier colordata name
27 * 8+ rfunc gfunc bfunc rdfname gdfname bdfname vfname v0 v1 .. xf
28 * 0
29 * n A1 A2 ..
30 *
31 * Color picture data is specified as:
32 *
33 * modifier colorpict name
34 * 7+ rfunc gfunc bfunc pfname vfname vx vy xf
35 * 0
36 * n A1 A2 ..
37 *
38 * A simple spectrum is specified as:
39 *
40 * modifier spectrum name
41 * 0
42 * 0
43 * 5+ nmA nmB s1 s2 s3 ..
44 *
45 * A constant spectrum from a data file is given as:
46 *
47 * modifier specfile name
48 * 1 dfname
49 * 0
50 * 0
51 *
52 * Vfname is the name of the file where the variable definitions
53 * can be found. The list of real arguments can be accessed by
54 * definitions in the file. The dfnames are the data file
55 * names. The dimensions of the data files and the number
56 * of variables must match. The funcs take a single argument
57 * for brightdata, and three for colordata and colorpict to produce
58 * interpolated values from the file. The xf is a transform spec
59 * to get from the original coordinates to the current coordinates.
60 */
61
62
63 int
64 p_bdata( /* interpolate brightness data */
65 OBJREC *m,
66 RAY *r
67 )
68 {
69 double bval;
70 double pt[MAXDDIM];
71 DATARRAY *dp;
72 MFUNC *mf;
73 int i;
74
75 if (m->oargs.nsargs < 4)
76 objerror(m, USER, "bad # arguments");
77 dp = getdata(m->oargs.sarg[1]);
78 i = (1 << dp->nd) - 1;
79 mf = getfunc(m, 2, i<<3, 0);
80 setfunc(m, r);
81 errno = 0;
82 for (i = dp->nd; i-- > 0; ) {
83 pt[i] = evalue(mf->ep[i]);
84 if ((errno == EDOM) | (errno == ERANGE))
85 goto computerr;
86 }
87 bval = datavalue(dp, pt);
88 errno = 0;
89 bval = funvalue(m->oargs.sarg[0], 1, &bval);
90 if ((errno == EDOM) | (errno == ERANGE))
91 goto computerr;
92 scalescolor(r->pcol, bval);
93 return(0);
94 computerr:
95 objerror(m, WARNING, "compute error");
96 return(0);
97 }
98
99
100 int
101 p_cdata( /* interpolate color data */
102 OBJREC *m,
103 RAY *r
104 )
105 {
106 double col[3];
107 COLOR cval;
108 double pt[MAXDDIM];
109 int nv;
110 DATARRAY *dp;
111 MFUNC *mf;
112 int i;
113
114 if (m->oargs.nsargs < 8)
115 objerror(m, USER, "bad # arguments");
116 dp = getdata(m->oargs.sarg[3]);
117 i = (1 << (nv = dp->nd)) - 1;
118 mf = getfunc(m, 6, i<<7, 0);
119 setfunc(m, r);
120 errno = 0;
121 for (i = 0; i < nv; i++) {
122 pt[i] = evalue(mf->ep[i]);
123 if ((errno == EDOM) | (errno == ERANGE))
124 goto computerr;
125 }
126 col[0] = datavalue(dp, pt);
127 for (i = 1; i < 3; i++) {
128 dp = getdata(m->oargs.sarg[i+3]);
129 if (dp->nd != nv)
130 objerror(m, USER, "dimension error");
131 col[i] = datavalue(dp, pt);
132 }
133 errno = 0;
134 for (i = 0; i < 3; i++)
135 if (fundefined(m->oargs.sarg[i]) < 3)
136 colval(cval,i) = funvalue(m->oargs.sarg[i], 1, col+i);
137 else
138 colval(cval,i) = funvalue(m->oargs.sarg[i], 3, col);
139 if ((errno == EDOM) | (errno == ERANGE))
140 goto computerr;
141 smultcolor(r->pcol, cval);
142 return(0);
143 computerr:
144 objerror(m, WARNING, "compute error");
145 return(0);
146 }
147
148
149 int
150 p_pdata( /* interpolate picture data */
151 OBJREC *m,
152 RAY *r
153 )
154 {
155 double col[3];
156 COLOR cval;
157 double pt[2];
158 DATARRAY *dp;
159 MFUNC *mf;
160 int i;
161
162 if (m->oargs.nsargs < 7)
163 objerror(m, USER, "bad # arguments");
164 mf = getfunc(m, 4, 0x3<<5, 0);
165 setfunc(m, r);
166 errno = 0;
167 pt[1] = evalue(mf->ep[0]); /* y major ordering */
168 pt[0] = evalue(mf->ep[1]);
169 if ((errno == EDOM) | (errno == ERANGE))
170 goto computerr;
171 dp = getpict(m->oargs.sarg[3]);
172 for (i = 0; i < 3; i++)
173 col[i] = datavalue(dp+i, pt);
174 errno = 0;
175 for (i = 0; i < 3; i++)
176 if (fundefined(m->oargs.sarg[i]) < 3)
177 colval(cval,i) = funvalue(m->oargs.sarg[i], 1, col+i);
178 else
179 colval(cval,i) = funvalue(m->oargs.sarg[i], 3, col);
180 if ((errno == EDOM) | (errno == ERANGE))
181 goto computerr;
182 smultcolor(r->pcol, cval);
183 return(0);
184
185 computerr:
186 objerror(m, WARNING, "compute error");
187 return(0);
188 }
189
190
191 int
192 p_spectrum( /* simple constant spectrum */
193 OBJREC *m,
194 RAY *r
195 )
196 {
197 COLORV *scval;
198
199 if ((scval = (COLORV *)m->os) == NULL) {
200 COLORV *sinp;
201 double hstep;
202 int i;
203 if (m->oargs.nfargs < 5)
204 objerror(m, USER, "bad # arguments");
205 sinp = (COLORV *)malloc(sizeof(COLORV)*(m->oargs.nfargs-2));
206 scval = (COLORV *)malloc(sizeof(COLORV)*NCSAMP);
207 if ((sinp == NULL) | (scval == NULL))
208 objerror(m, SYSTEM, "out of memory");
209 for (i = m->oargs.nfargs-2; i--; )
210 sinp[i] = (COLORV)m->oargs.farg[i+2];
211 hstep = 0.5 * (m->oargs.farg[1] - m->oargs.farg[0]) /
212 (m->oargs.nfargs-3.0);
213 convertscolor(scval, NCSAMP, WLPART[0], WLPART[3],
214 sinp, m->oargs.nfargs-2,
215 m->oargs.farg[0]-hstep, m->oargs.farg[1]+hstep);
216 free(sinp);
217 m->os = (void *)scval;
218 }
219 smultscolor(r->pcol, scval);
220 return(0);
221 }
222
223
224 int
225 p_specfile( /* constant spectrum from 1-D data file */
226 OBJREC *m,
227 RAY *r
228 )
229 {
230 COLORV *scval;
231
232 if ((scval = (COLORV *)m->os) == NULL) {
233 DATARRAY *dp;
234 COLORV *sinp;
235 double step;
236 int i;
237 if (m->oargs.nsargs != 1)
238 objerror(m, USER, "bad # arguments");
239 dp = getdata(m->oargs.sarg[0]);
240 if (dp->nd != 1)
241 objerror(m, USER, "data file must be 1-dimensional");
242
243 sinp = (COLORV *)malloc(sizeof(COLORV)*dp->dim[0].ne);
244 scval = (COLORV *)malloc(sizeof(COLORV)*NCSAMP);
245 if ((sinp == NULL) | (scval == NULL))
246 objerror(m, SYSTEM, "out of memory");
247 step = dp->dim[0].siz / (dp->dim[0].ne - 1.0);
248 for (i = dp->dim[0].ne; i-- > 0; ) {
249 double wl = dp->dim[0].org + i*step;
250 sinp[i] = (COLORV)datavalue(dp, &wl);
251 }
252 convertscolor(scval, NCSAMP, WLPART[0], WLPART[3],
253 sinp, dp->dim[0].ne, dp->dim[0].org-.5*step,
254 dp->dim[0].org+dp->dim[0].siz+.5*step);
255 free(sinp);
256 m->os = (void *)scval;
257 }
258 smultscolor(r->pcol, scval);
259 return(0);
260 }
