root/radiance/ray/src/rt/p_data.c
Tue Mar 12 16:54:51 2024 UTC (2 months ago) by greg
Changes since 2.14: +24 -24 lines
perf: added datavector() call for quicker spectral interpolation
Thu Feb 22 20:11:54 2024 UTC (2 months, 3 weeks ago) by greg
perf: Eliminated redundant calculations when same data file is reused for RGB
Wed Jan 17 17:35:35 2024 UTC (3 months, 4 weeks ago) by greg
Changes since 2.12: +6 -9 lines
perf(rvu, rpict, rtrace, rcontrib): Better rendering of spectral primitives in RGB mode
Thu Dec 14 00:51:12 2023 UTC (5 months ago) by greg
fix: Removed spurious error
Wed Dec 13 23:26:16 2023 UTC (5 months ago) by greg
Changes since 2.10: +127 -8 lines
feat(rpict,rvu,rtrace,rcontrib): Added "specdata" and "specpict" pattern primitives
Wed Nov 15 18:02:53 2023 UTC (6 months ago) by greg
Changes since 2.9: +101 -15 lines
Tue Jul 8 18:25:00 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.8: +13 -13 lines
Changes since 2.7: +17 -12 lines
Wed Mar 5 16:16:53 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.4: +57 -5 lines
Wed Jan 12 16:46:48 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.3: +6 -6 lines
Tue Dec 22 10:02:58 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.2: +11 -7 lines
modified use of functional modifiers to allow single argument
Mon Nov 25 09:50:53 1991 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +40 -64 lines
Tue Nov 12 17:09:34 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 2.5
Thu Aug 8 11:30:04 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.4: +3 -6 lines
Diff to previous 1.4 , to selected 2.5
added contexts to function files
Wed Jan 2 18:22:40 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.3: +6 -7 lines
Diff to previous 1.3 , to selected 2.5
eliminated unnecessary loopy
Tue May 1 17:01:03 1990 UTC (34 years ago) by greg
changed ordering of in-memory array for pictures
Tue Mar 14 11:12:55 1989 UTC (35 years, 2 months ago) by greg
simplified errno test
Thu Feb 2 10:41:33 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.5
