root/radiance/ray/src/rt/oocsort.h
Revision: 2.3
Committed: Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1
Changes since 2.2: +33 -30 lines
1 /*
2 ======================================================================
3 Header for N-way out-of-core merge sort for records with 3D keys.
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ======================================================================
9
10 $Id: oocsort.h,v 1.16 2015/09/15 13:33:22 taschreg Exp taschreg $
11 */
12
13 #ifndef OOC_SORT_H
14 #define OOC_SORT_H
15
16 #include "fvect.h"
17 #include <stdio.h>
18
19
20 /* Sort records in inFile and append to outFile by subdividing inFile
21 * into small blocks, sorting these in-core, and merging them out-of-core
22 * via a priority queue.
23 *
24 * This is implemented as a recursive (numBlk)-way sort; the input is
25 * successively split into numBlk smaller blocks until these are of size
26 * <= blkSize, i.e. small enough for in-core sorting, then merging the
27 * sorted blocks as the stack unwinds. The in-core sort is parallelised
28 * over numProc processes.
29 *
30 * Parameters are as follows:
31 * inFile Opened input file containing unsorted records
32 * outFile Opened output file containing sorted records
33 * numBlk Number of blocks to divide into / merge from
34 * blkSize Max block size and size of in-core sort buffer, in bytes
35 * numProc Number of parallel processes for in-core sort
36 * recSize Size of input records in bytes
37 * bbOrg Origin of bounding box containing record keys for Morton code
38 * bbSize Extent of bounding box containing record keys for Morton code
39 * key Callback to access 3D coords from records for Morton code
40 */
41 int OOC_Sort (FILE *inFile, FILE *outFile, unsigned numBlk,
42 unsigned long blkSize, unsigned numProc, unsigned recSize,
43 FVECT bbOrg, RREAL bbSize, RREAL *(*key)(const void*));
44 #endif
