root/radiance/ray/src/rt/oocsort.c
Revision: 2.4
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
CVS Tags: rad5R2, rad5R3, rad5R1
Changes since 2.3: +10 -2 lines
Updated photon map code for Windows; no multproc or ooC for now
4
5
6 /*
7 =========================================================================
8 N-way out-of-core merge sort for records with 3D keys. Recursively
9 subdivides input into N blocks until these are of sufficiently small size
10 to be sorted in-core according to Z-order (Morton code), then N-way
11 merging them out-of-core using a priority queue as the stack unwinds.
12
13 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
14 (c) Lucerne University of Applied Sciences and Arts,
15 supported by the Swiss National Science Foundation (SNSF, #147053)
16 ==========================================================================
17
18 $Id: oocsort.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
19 */
20
21
22 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
23 /* No Windoze support for now */
24
25 #include "oocsort.h"
26 #include "oocmorton.h"
27 #include <stdio.h>
28 #include <stdlib.h>
29 #include <unistd.h>
30 #include <fcntl.h>
31 #include <sys/wait.h>
32
33
34 /* Priority queue node */
35 typedef struct {
36 OOC_MortonIdx pri; /* Record's priority (sort key) */
37 unsigned blk; /* Block containing record */
38 } OOC_SortQueueNode;
39
40
41 /* Priority queue */
42 typedef struct {
43 OOC_SortQueueNode *node;
44 unsigned len, tail;
45 } OOC_SortQueue;
46
47
48 /* Additional data for qsort() compare function. We resort to instancing
49 * this as a global variable instead of passing it to the compare func via
50 * qsort_r(), since the latter is a non-portable GNU extension. */
51 typedef struct {
52 RREAL *(*key)(const void*); /* Callback to access 3D key in record */
53 FVECT bbOrg; /* Origin of bbox containing keys */
54 RREAL mortonScale; /* Scale for generating Morton code */
55 } OOC_KeyData;
56
57 static OOC_KeyData keyData;
58
59
60
61 static int OOC_KeyCompare (const void *rec1, const void *rec2)
62 /* Comparison function for in-core quicksort */
63 {
64 OOC_MortonIdx pri1, pri2;
65
66 if (!rec1 || !rec2)
67 return 0;
68
69 pri1 = OOC_Key2Morton(keyData.key(rec1), keyData.bbOrg,
70 keyData.mortonScale);
71 pri2 = OOC_Key2Morton(keyData.key(rec2), keyData.bbOrg,
72 keyData.mortonScale);
73
74 if (pri1 < pri2)
75 return -1;
76 else if (pri1 > pri2)
77 return 1;
78 else
79 return 0;
80 }
81
82
83
84 static int OOC_SortRead (FILE *file, unsigned recSize, char *rec)
85 /* Read next record from file; return 0 and record in rec on success,
86 * else -1 */
87 {
88 if (!rec || feof(file) || !fread(rec, recSize, 1, file))
89 return -1;
90
91 return 0;
92 }
93
94
95
96 static int OOC_SortPeek (FILE *file, unsigned recSize, char *rec)
97 /* Return next record from file WITHOUT advancing file position;
98 * return 0 and record in rec on success, else -1 */
99 {
100 const unsigned long filePos = ftell(file);
101
102 if (OOC_SortRead(file, recSize, rec))
103 return -1;
104
105 /* Workaround; fseek(file, -recSize, SEEK_CUR) causes subsequent
106 * fread()'s to fail until rewind() */
107 rewind(file);
108 if (fseek(file, filePos, SEEK_SET) < 0)
109 return -1;
110
111 return 0;
112 }
113
114
115
116 static int OOC_SortWrite (FILE *file, unsigned recSize, const char *rec)
117 /* Output record to file; return 0 on success, else -1 */
118 {
119 if (!rec || !fwrite(rec, recSize, 1, file))
120 return -1;
121
122 return 0;
123 }
124
125
126
127 #ifdef DEBUG_OOC_SORT
128 static int OOC_SortQueueCheck (OOC_SortQueue *pq, unsigned root)
129 /* Priority queue sanity check */
130 {
131 unsigned kid;
132
133 if (root < pq -> tail) {
134 if ((kid = (root << 1) + 1) < pq -> tail) {
135 if (pq -> node [kid].pri < pq -> node [root].pri)
136 return -1;
137 else return OOC_SortQueueCheck(pq, kid);
138 }
139
140 if ((kid = kid + 1) < pq -> tail) {
141 if (pq -> node [kid].pri < pq -> node [root].pri)
142 return -1;
143 else return OOC_SortQueueCheck(pq, kid);
144 }
145 }
146
147 return 0;
148 }
149 #endif
150
151
152
153 static int OOC_SortPush (OOC_SortQueue *pq, OOC_MortonIdx pri, unsigned blk)
154 /* Insert specified block index into priority queue; return block index
155 * or -1 if queue is full */
156 {
157 OOC_SortQueueNode *pqn = pq -> node;
158 unsigned kid, root;
159
160 if (pq -> tail >= pq -> len)
161 /* Queue full */
162 return -1;
163
164 /* Append node at tail and re-sort */
165 kid = pq -> tail++;
166
167 while (kid) {
168 root = (kid - 1) >> 1;
169
170 /* Compare with parent node and swap if necessary, else terminate */
171 if (pri < pqn [root].pri) {
172 pqn [kid].pri = pqn [root].pri;
173 pqn [kid].blk = pqn [root].blk;
174 kid = root;
175 }
176 else break;
177 }
178
179 pqn [kid].pri = pri;
180 pqn [kid].blk = blk;
181
182 #ifdef DEBUG_OOC_SORT
183 if (OOC_SortQueueCheck(pq, 0) < 0) {
184 fprintf(stderr, "OOC_Sort: priority queue inconsistency\n");
185 return -1;
186 }
187 #endif
188
189 return blk;
190 }
191
192
193
194 static int OOC_SortPop (OOC_SortQueue *pq)
195 /* Remove head of priority queue and return its block index
196 or -1 if queue empty */
197 {
198 OOC_SortQueueNode *pqn = pq -> node;
199 OOC_MortonIdx pri;
200 unsigned kid, kid2, root = 0, blk, res;
201
202 if (!pq -> tail)
203 /* Queue empty */
204 return -1;
205
206 res = pqn -> blk;
207 pri = pqn [--pq -> tail].pri;
208 blk = pqn [pq -> tail].blk;
209
210 /* Replace head with tail node and re-sort */
211 while ((kid = (root << 1) + 1) < pq -> tail) {
212 /* Compare with smaller kid and swap if necessary, else terminate */
213 if ((kid2 = (kid + 1)) < pq -> tail && pqn [kid2].pri < pqn [kid].pri)
214 kid = kid2;
215
216 if (pri > pqn [kid].pri) {
217 pqn [root].pri = pqn [kid].pri;
218 pqn [root].blk = pqn [kid].blk;
219 }
220 else break;
221
222 root = kid;
223 }
224
225 pqn [root].pri = pri;
226 pqn [root].blk = blk;
227
228 #ifdef DEBUG_OOC_SORT
229 if (OOC_SortQueueCheck(pq, 0) < 0) {
230 fprintf(stderr, "OOC_Sort: priority queue inconsistency\n");
231 return -1;
232 }
233 #endif
234
235 return res;
236 }
237
238
239
240 /* Active subprocess counter updated by parent process; must persist when
241 * recursing into OOC_SortRecurse(), hence global */
242 static unsigned procCnt = 0;
243
244 static int OOC_SortRecurse (FILE *in, unsigned long blkLo,
245 unsigned long blkHi, FILE *out,
246 unsigned numBlk, unsigned long maxBlkSize,
247 unsigned numProc, unsigned recSize,
248 char *sortBuf, OOC_SortQueue *pqueue,
249 const OOC_KeyData *keyData)
250 /* Recursive part of OOC_Sort(). Reads block of records from input file
251 * within the interval [blkLo, blkHi] and divides it into numBlk blocks
252 * until the size (in bytes) does not exceed maxBlkSize, then quicksorts
253 * each block into a temporary file. These files are then mergesorted via a
254 * priority queue to the output file as the stack unwinds. NOTE: Critical
255 * sections are prepended with '!!!'
256 *
257 * Parameters are as follows:
258 * in Input file containing unsorted records (assumed to be open)
259 * blkLo Start of current block in input file, in number of records
260 * blkHi End of current block in input file, in number of records
261 * out Output file containing sorted records (assumed to be open)
262 * numBlk Number of blocks to divide into / merge from
263 * maxBlkSize Max block size and size of in-core sort buffer, in bytes
264 * numProc Number of parallel processes for in-core sort
265 * recSize Size of input records in bytes
266 * sortBuf Preallocated in-core sort buffer of size maxBlkSize
267 * pqueue Preallocated priority queue of length numBlk for block merge
268 * keyData Aggregate data for Morton code generation and comparison
269 */
270 {
271 const unsigned long blkLen = blkHi - blkLo + 1,
272 blkSize = blkLen * recSize;
273 int stat;
274
275 if (!blkLen || blkHi < blkLo)
276 return 0;
277
278 if (blkSize > maxBlkSize) {
279 unsigned long blkLo2 = blkLo, blkHi2 = blkLo, blkSize2;
280 const double blkLen2 = (double)blkLen / numBlk;
281 FILE *blkFile [numBlk]; /* Violates C89! */
282 char rec [recSize]; /* Ditto */
283 OOC_MortonIdx pri;
284 int b, pid;
285 #ifdef DEBUG_OOC_SORT
286 unsigned long pqCnt = 0;
287 #endif
288
289 /* ======================================================
290 * Block too large for in-core sort -> divide into numBlk
291 * subblocks and recurse
292 * ====================================================== */
293
294 #ifdef DEBUG_OOC_SORT
295 fprintf(stderr, "OOC_Sort: splitting block [%lu - %lu]\n",
296 blkLo, blkHi);
297 #endif
298
299 for (b = 0; b < numBlk; b++) {
300 /* Open temporary file as output for subblock */
301 if (!(blkFile [b] = tmpfile())) {
302 perror("OOC_Sort: failed opening temporary block file");
303 return -1;
304 }
305
306 /* Subblock interval [blkLo2, blkHi2] of size blkSize2 */
307 blkHi2 = blkLo + (b + 1) * blkLen2 - 1;
308 blkSize2 = (blkHi2 - blkLo2 + 1) * recSize;
309
310 if (blkSize2 <= maxBlkSize) {
311 /* !!! Will be in-core sorted on recursion -> fork kid process,
312 * !!! but don't fork more than numProc kids; wait if necessary */
313 while (procCnt >= numProc && wait(&stat) >= 0) {
314 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
315 return -1;
316
317 procCnt--;
318 }
319
320 /* Now fork kid process */
321 if (!(pid = fork())) {
322 /* Recurse on subblocks with new input filehandle; */
323 if (OOC_SortRecurse(in, blkLo2, blkHi2, blkFile [b], numBlk,
324 maxBlkSize, numProc, recSize, sortBuf,
325 pqueue, keyData))
326 exit(-1);
327
328 /* !!! Apparently the parent's tmpfile isn't deleted when the
329 * !!! child exits (which is what we want), though some
330 * !!! sources suggest using _Exit() instead; is this
331 * !!! implementation specific? */
332 exit(0);
333 }
334 else if (pid < 0) {
335 fprintf(stderr, "OOC_Sort: failed to fork subprocess\n");
336 return -1;
337 }
338
339 #ifdef DEBUG_OOC_FORK
340 fprintf(stderr, "OOC_Sort: forking kid %d for block %d\n",
341 procCnt, b);
342 #endif
343
344 /* Parent continues here */
345 procCnt++;
346 }
347 else {
348 /* Recurse on subblock; without forking */
349 if (OOC_SortRecurse(in, blkLo2, blkHi2, blkFile [b], numBlk,
350 maxBlkSize, numProc, recSize, sortBuf,
351 pqueue, keyData))
352 return -1;
353 }
354
355 /* Prepare for next block */
356 blkLo2 = blkHi2 + 1;
357 }
358
359 /* !!! Wait for any forked processes to terminate */
360 while (procCnt && wait(&stat) >= 0) {
361 if (!WIFEXITED(stat) || WEXITSTATUS(stat))
362 return -1;
363
364 procCnt--;
365 }
366
367 /* ===============================================================
368 * Subblocks are now sorted; prepare priority queue by peeking and
369 * enqueueing first record from corresponding temporary file
370 * =============================================================== */
371
372 #ifdef DEBUG_OOC_SORT
373 fprintf(stderr, "OOC_Sort: merging block [%lu - %lu]\n", blkLo, blkHi);
374 #endif
375
376 for (b = 0; b < numBlk; b++) {
377 #ifdef DEBUG_OOC_SORT
378 fseek(blkFile [b], 0, SEEK_END);
379 if (ftell(blkFile [b]) % recSize) {
380 fprintf(stderr, "OOC_Sort: truncated record in tmp block "
381 "file %d\n", b);
382 return -1;
383 }
384
385 fprintf(stderr, "OOC_Sort: tmp block file %d contains %ld rec\n",
386 b, ftell(blkFile [b]) / recSize);
387 #endif
388
389 rewind(blkFile [b]);
390
391 if (OOC_SortPeek(blkFile [b], recSize, rec)) {
392 fprintf(stderr, "OOC_Sort: error reading from block file\n");
393 return -1;
394 }
395
396 /* Enqueue record along with its Morton code as priority */
397 pri = OOC_Key2Morton(keyData -> key(rec), keyData -> bbOrg,
398 keyData -> mortonScale);
399
400 if (OOC_SortPush(pqueue, pri, b) < 0) {
401 fprintf(stderr, "OOC_Sort: failed priority queue insertion\n");
402 return -1;
403 }
404 }
405
406 /* ==========================================================
407 * Subblocks now sorted and priority queue filled; merge from
408 * temporary files
409 * ========================================================== */
410
411 do {
412 /* Get next node in priority queue, read next record in corresponding
413 * block, and send to output */
414 b = OOC_SortPop(pqueue);
415
416 if (b >= 0) {
417 /* Priority queue non-empty */
418 if (OOC_SortRead(blkFile [b], recSize, rec)) {
419 /* Corresponding record should still be in the input block */
420 fprintf(stderr, "OOC_Sort: unexpected end reading block file\n");
421 return -1;
422 }
423
424 if (OOC_SortWrite(out, recSize, rec)) {
425 fprintf(stderr, "OOC_Sort; error writing output file\n");
426 return -1;
427 }
428
429 #ifdef DEBUG_OOC_SORT
430 pqCnt++;
431 #endif
432
433 /* Peek next record from same block and insert in priority queue */
434 if (!OOC_SortPeek(blkFile [b], recSize, rec)) {
435 /* Block not exhausted */
436 pri = OOC_Key2Morton(keyData -> key(rec), keyData -> bbOrg,
437 keyData -> mortonScale);
438
439 if (OOC_SortPush(pqueue, pri, b) < 0) {
440 fprintf(stderr, "OOC_Sort: failed priority queue insert\n");
441 return -1;
442 }
443 }
444 }
445 } while (b >= 0);
446
447 #ifdef DEBUG_OOC_SORT
448 fprintf(stderr, "OOC_Sort: dequeued %lu rec\n", pqCnt);
449 fprintf(stderr, "OOC_Sort: merged file contains %lu rec\n",
450 ftell(out) / recSize);
451 #endif
452
453 /* Priority queue now empty -> done; close temporary subblock files,
454 * causing them to be automatically deleted. */
455 for (b = 0; b < numBlk; b++) {
456 fclose(blkFile [b]);
457 }
458
459 /* !!! Commit output file to disk before caller reads it; omitting
460 * !!! this apparently leads to corrupted files (race condition?) when
461 * !!! the caller tries to read them! */
462 fflush(out);
463 fsync(fileno(out));
464 }
465
466 else {
467 /* ======================================
468 * Block is small enough for in-core sort
469 * ====================================== */
470 int ifd = fileno(in), ofd = fileno(out);
471
472 #ifdef DEBUG_OOC_SORT
473 fprintf(stderr, "OOC_Sort: Proc %d (%d/%d) sorting block [%lu - %lu]\n",
474 getpid(), procCnt, numProc - 1, blkLo, blkHi);
475
476 #endif
477
478 /* Atomically seek and read block into in-core sort buffer */
479 /* !!! Unbuffered I/O via pread() avoids potential race conditions
480 * !!! and buffer corruption which can occur with lseek()/fseek()
481 * !!! followed by read()/fread(). */
482 if (pread(ifd, sortBuf, blkSize, blkLo * recSize) != blkSize) {
483 perror("OOC_Sort: error reading from input file");
484 return -1;
485 }
486
487 /* Quicksort block in-core and write to output file */
488 qsort(sortBuf, blkLen, recSize, OOC_KeyCompare);
489
490 if (write(ofd, sortBuf, blkSize) != blkSize) {
491 perror("OOC_Sort: error writing to block file");
492 return -1;
493 }
494
495 fsync(ofd);
496
497 #ifdef DEBUG_OOC_SORT
498 fprintf(stderr, "OOC_Sort: proc %d wrote %ld records\n",
499 getpid(), lseek(ofd, 0, SEEK_END) / recSize);
500 #endif
501 }
502
503 return 0;
504 }
505
506
507
508 int OOC_Sort (FILE *in, FILE *out, unsigned numBlk,
509 unsigned long blkSize, unsigned numProc, unsigned recSize,
510 FVECT bbOrg, RREAL bbSize, RREAL *(*key)(const void*))
511 /* Sort records in inFile and append to outFile by subdividing inFile into
512 * small blocks, sorting these in-core, and merging them out-of-core via a
513 * priority queue.
514 *
515 * This is implemented as a recursive (numBlk)-way sort; the input is
516 * successively split into numBlk smaller blocks until these are of size <=
517 * blkSize, i.e. small enough for in-core sorting, then merging the sorted
518 * blocks as the stack unwinds. The in-core sort is parallelised over
519 * numProx processes.
520 *
521 * Parameters are as follows:
522 * inFile Opened input file containing unsorted records
523 * outFile Opened output file containing sorted records
524 * numBlk Number of blocks to divide into / merge from
525 * blkSize Max block size and size of in-core sort buffer, in bytes
526 * numProc Number of parallel processes for in-core sort
527 * recSize Size of input records in bytes
528 * bbOrg Origin of bounding box containing record keys for Morton code
529 * bbSize Extent of bounding box containing record keys for Morton code
530 * key Callback to access 3D coords from records for Morton code
531 */
532 {
533 unsigned long numRec;
534 OOC_SortQueue pqueue;
535 char *sortBuf = NULL;
536 int stat;
537
538 if (numBlk < 1)
539 numBlk = 1;
540
541 /* Open input file & get size in number of records */
542 if (fseek(in, 0, SEEK_END) < 0) {
543 fputs("OOC_Sort: failed seek in input file\n", stderr);
544 return -1;
545 }
546
547 if (!(numRec = ftell(in) / recSize)) {
548 fputs("OOC_Sort: empty input file\n", stderr);
549 return -1;
550 }
551
552 /* Allocate & init priority queue */
553 if (!(pqueue.node = calloc(numBlk, sizeof(OOC_SortQueueNode)))) {
554 fputs("OOC_Sort: failure allocating priority queue\n", stderr);
555 return -1;
556 }
557 pqueue.tail = 0;
558 pqueue.len = numBlk;
559
560 /* Allocate in-core sort buffa */
561 if (!(sortBuf = malloc(blkSize))) {
562 fprintf(stderr, "OOC_Sort: failure allocating in-core sort buffer");
563 return -1;
564 }
565
566 /* Set up key data to pass to qsort()'s comparison func */
567 keyData.key = key;
568 keyData.mortonScale = OOC_MORTON_MAX / bbSize;
569 VCOPY(keyData.bbOrg, bbOrg);
570
571 stat = OOC_SortRecurse(in, 0, numRec - 1, out, numBlk, blkSize, numProc,
572 recSize, sortBuf, &pqueue, &keyData);
573
574 /* Cleanup */
575 free(pqueue.node);
576 free(sortBuf);
577
578 return stat;
579 }
580
581 #endif /* NIX / PMAP_OOC */
