root/radiance/ray/src/rt/oocsort.c
Revision: 2.5
Committed: Wed Feb 10 21:48:50 2021 UTC (4 years, 5 months ago) by rschregle
CVS Tags: rad5R4, rad6R0, HEAD
fix(mkpmap): Modified OOC_SortRecurse() to output system error if fork()
fails
# User Rev Content
1 rschregle 2.4 #ifndef lint
2 rschregle 2.5 static const char RCSid[] = "$Id: oocsort.c,v 2.4 2017/08/14 21:12:10 rschregle Exp $";
3 rschregle 2.4 #endif
4
5
6 greg 2.1 /*
7 rschregle 2.3 =========================================================================
8     N-way out-of-core merge sort for records with 3D keys. Recursively
9     subdivides input into N blocks until these are of sufficiently small size
10     to be sorted in-core according to Z-order (Morton code), then N-way
11     merging them out-of-core using a priority queue as the stack unwinds.
12
13     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
14     (c) Lucerne University of Applied Sciences and Arts,
15     supported by the Swiss National Science Foundation (SNSF, #147053)
16     ==========================================================================
17 greg 2.1
18 rschregle 2.5 $Id: oocsort.c,v 2.4 2017/08/14 21:12:10 rschregle Exp $
19 greg 2.1 */
20
21
22 rschregle 2.4 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
23     /* No Windoze support for now */
24 rschregle 2.3
25 greg 2.1 #include "oocsort.h"
26 rschregle 2.3 #include "oocmorton.h"
27 greg 2.1 #include <stdio.h>
28     #include <stdlib.h>
29 rschregle 2.3 #include <unistd.h>
30     #include <fcntl.h>
31     #include <sys/wait.h>
32
33 greg 2.1
34     /* Priority queue node */
35     typedef struct {
36 rschregle 2.3 OOC_MortonIdx pri; /* Record's priority (sort key) */
37     unsigned blk; /* Block containing record */
38     } OOC_SortQueueNode;
39
40 greg 2.1
41 rschregle 2.3 /* Priority queue */
42 greg 2.1 typedef struct {
43 rschregle 2.3 OOC_SortQueueNode *node;
44     unsigned len, tail;
45     } OOC_SortQueue;
46 greg 2.1
47 rschregle 2.3
48     /* Additional data for qsort() compare function. We resort to instancing
49     * this as a global variable instead of passing it to the compare func via
50     * qsort_r(), since the latter is a non-portable GNU extension. */
51 greg 2.1 typedef struct {
52 rschregle 2.3 RREAL *(*key)(const void*); /* Callback to access 3D key in record */
53     FVECT bbOrg; /* Origin of bbox containing keys */
54     RREAL mortonScale; /* Scale for generating Morton code */
55     } OOC_KeyData;
56 greg 2.1
57 rschregle 2.3 static OOC_KeyData keyData;
58 greg 2.1
59
60
61 rschregle 2.3 static int OOC_KeyCompare (const void *rec1, const void *rec2)
62     /* Comparison function for in-core quicksort */
63 greg 2.1 {
64 rschregle 2.3 OOC_MortonIdx pri1, pri2;
65 greg 2.1
66     if (!rec1 || !rec2)
67     return 0;
68 rschregle 2.3
69     pri1 = OOC_Key2Morton(keyData.key(rec1), keyData.bbOrg,
70     keyData.mortonScale);
71     pri2 = OOC_Key2Morton(keyData.key(rec2), keyData.bbOrg,
72     keyData.mortonScale);
73 greg 2.1
74     if (pri1 < pri2)
75     return -1;
76     else if (pri1 > pri2)
77     return 1;
78     else
79     return 0;
80     }
81
82
83 rschregle 2.3
84     static int OOC_SortRead (FILE *file, unsigned recSize, char *rec)
85     /* Read next record from file; return 0 and record in rec on success,
86     * else -1 */
87 greg 2.1 {
88 rschregle 2.3 if (!rec || feof(file) || !fread(rec, recSize, 1, file))
89     return -1;
90
91     return 0;
92 greg 2.1 }
93
94
95 rschregle 2.3
96     static int OOC_SortPeek (FILE *file, unsigned recSize, char *rec)
97     /* Return next record from file WITHOUT advancing file position;
98     * return 0 and record in rec on success, else -1 */
99 greg 2.1 {
100 rschregle 2.3 const unsigned long filePos = ftell(file);
101
102     if (OOC_SortRead(file, recSize, rec))
103     return -1;
104
105     /* Workaround; fseek(file, -recSize, SEEK_CUR) causes subsequent
106     * fread()'s to fail until rewind() */
107     rewind(file);
108     if (fseek(file, filePos, SEEK_SET) < 0)
109     return -1;
110
111     return 0;
112 greg 2.1 }
113
114
115 rschregle 2.3
116     static int OOC_SortWrite (FILE *file, unsigned recSize, const char *rec)
117     /* Output record to file; return 0 on success, else -1 */
118 greg 2.1 {
119 rschregle 2.3 if (!rec || !fwrite(rec, recSize, 1, file))
120     return -1;
121 greg 2.1
122 rschregle 2.3 return 0;
123 greg 2.1 }
124
125
126 rschregle 2.3
127     #ifdef DEBUG_OOC_SORT
128     static int OOC_SortQueueCheck (OOC_SortQueue *pq, unsigned root)
129 greg 2.1 /* Priority queue sanity check */
130     {
131     unsigned kid;
132
133     if (root < pq -> tail) {
134 rschregle 2.3 if ((kid = (root << 1) + 1) < pq -> tail) {
135 greg 2.1 if (pq -> node [kid].pri < pq -> node [root].pri)
136     return -1;
137 rschregle 2.3 else return OOC_SortQueueCheck(pq, kid);
138     }
139 greg 2.1
140 rschregle 2.3 if ((kid = kid + 1) < pq -> tail) {
141 greg 2.1 if (pq -> node [kid].pri < pq -> node [root].pri)
142     return -1;
143 rschregle 2.3 else return OOC_SortQueueCheck(pq, kid);
144     }
145 greg 2.1 }
146
147     return 0;
148     }
149     #endif
150
151
152 rschregle 2.3
153     static int OOC_SortPush (OOC_SortQueue *pq, OOC_MortonIdx pri, unsigned blk)
154 greg 2.1 /* Insert specified block index into priority queue; return block index
155     * or -1 if queue is full */
156     {
157 rschregle 2.3 OOC_SortQueueNode *pqn = pq -> node;
158     unsigned kid, root;
159 greg 2.1
160     if (pq -> tail >= pq -> len)
161     /* Queue full */
162     return -1;
163
164     /* Append node at tail and re-sort */
165     kid = pq -> tail++;
166
167     while (kid) {
168 rschregle 2.3 root = (kid - 1) >> 1;
169 greg 2.1
170     /* Compare with parent node and swap if necessary, else terminate */
171     if (pri < pqn [root].pri) {
172     pqn [kid].pri = pqn [root].pri;
173     pqn [kid].blk = pqn [root].blk;
174     kid = root;
175     }
176     else break;
177     }
178
179     pqn [kid].pri = pri;
180     pqn [kid].blk = blk;
181
182 rschregle 2.3 #ifdef DEBUG_OOC_SORT
183     if (OOC_SortQueueCheck(pq, 0) < 0) {
184 greg 2.1 fprintf(stderr, "OOC_Sort: priority queue inconsistency\n");
185     return -1;
186     }
187     #endif
188
189     return blk;
190     }
191
192
193 rschregle 2.3
194     static int OOC_SortPop (OOC_SortQueue *pq)
195 greg 2.1 /* Remove head of priority queue and return its block index
196 rschregle 2.3 or -1 if queue empty */
197 greg 2.1 {
198 rschregle 2.3 OOC_SortQueueNode *pqn = pq -> node;
199     OOC_MortonIdx pri;
200     unsigned kid, kid2, root = 0, blk, res;
201 greg 2.1
202     if (!pq -> tail)
203     /* Queue empty */
204     return -1;
205
206     res = pqn -> blk;
207     pri = pqn [--pq -> tail].pri;
208     blk = pqn [pq -> tail].blk;
209
210     /* Replace head with tail node and re-sort */
211     while ((kid = (root << 1) + 1) < pq -> tail) {
212 rschregle 2.3 /* Compare with smaller kid and swap if necessary, else terminate */
213 greg 2.1 if ((kid2 = (kid + 1)) < pq -> tail && pqn [kid2].pri < pqn [kid].pri)
214     kid = kid2;
215
216     if (pri > pqn [kid].pri) {
217     pqn [root].pri = pqn [kid].pri;
218     pqn [root].blk = pqn [kid].blk;
219     }
220     else break;
221
222     root = kid;
223     }
224
225     pqn [root].pri = pri;
226     pqn [root].blk = blk;
227
228 rschregle 2.3 #ifdef DEBUG_OOC_SORT
229     if (OOC_SortQueueCheck(pq, 0) < 0) {
230 greg 2.1 fprintf(stderr, "OOC_Sort: priority queue inconsistency\n");
231     return -1;
232     }
233     #endif
234
235     return res;
236     }
237
238 rschregle 2.3
239
240     /* Active subprocess counter updated by parent process; must persist when
241     * recursing into OOC_SortRecurse(), hence global */
242     static unsigned procCnt = 0;
243
244     static int OOC_SortRecurse (FILE *in, unsigned long blkLo,
245     unsigned long blkHi, FILE *out,
246     unsigned numBlk, unsigned long maxBlkSize,
247     unsigned numProc, unsigned recSize,
248     char *sortBuf, OOC_SortQueue *pqueue,
249     const OOC_KeyData *keyData)
250     /* Recursive part of OOC_Sort(). Reads block of records from input file
251     * within the interval [blkLo, blkHi] and divides it into numBlk blocks
252     * until the size (in bytes) does not exceed maxBlkSize, then quicksorts
253     * each block into a temporary file. These files are then mergesorted via a
254     * priority queue to the output file as the stack unwinds. NOTE: Critical
255     * sections are prepended with '!!!'
256     *
257     * Parameters are as follows:
258     * in Input file containing unsorted records (assumed to be open)
259     * blkLo Start of current block in input file, in number of records
260     * blkHi End of current block in input file, in number of records
261     * out Output file containing sorted records (assumed to be open)
262     * numBlk Number of blocks to divide into / merge from
263     * maxBlkSize Max block size and size of in-core sort buffer, in bytes
264     * numProc Number of parallel processes for in-core sort
265     * recSize Size of input records in bytes
266     * sortBuf Preallocated in-core sort buffer of size maxBlkSize
267     * pqueue Preallocated priority queue of length numBlk for block merge
268     * keyData Aggregate data for Morton code generation and comparison
269     */
270 greg 2.1 {
271 rschregle 2.3 const unsigned long blkLen = blkHi - blkLo + 1,
272     blkSize = blkLen * recSize;
273     int stat;
274 greg 2.1
275 rschregle 2.3 if (!blkLen || blkHi < blkLo)
276     return 0;
277
278     if (blkSize > maxBlkSize) {
279     unsigned long blkLo2 = blkLo, blkHi2 = blkLo, blkSize2;
280     const double blkLen2 = (double)blkLen / numBlk;
281     FILE *blkFile [numBlk]; /* Violates C89! */
282     char rec [recSize]; /* Ditto */
283     OOC_MortonIdx pri;
284     int b, pid;
285     #ifdef DEBUG_OOC_SORT
286     unsigned long pqCnt = 0;
287     #endif
288
289     /* ======================================================
290     * Block too large for in-core sort -> divide into numBlk
291     * subblocks and recurse
292     * ====================================================== */
293
294     #ifdef DEBUG_OOC_SORT
295     fprintf(stderr, "OOC_Sort: splitting block [%lu - %lu]\n",
296     blkLo, blkHi);
297     #endif
298
299     for (b = 0; b < numBlk; b++) {
300     /* Open temporary file as output for subblock */
301     if (!(blkFile [b] = tmpfile())) {
302     perror("OOC_Sort: failed opening temporary block file");
303     return -1;
304     }
305
306     /* Subblock interval [blkLo2, blkHi2] of size blkSize2 */
307     blkHi2 = blkLo + (b + 1) * blkLen2 - 1;
308     blkSize2 = (blkHi2 - blkLo2 + 1) * recSize;
309
310     if (blkSize2 <= maxBlkSize) {
311     /* !!! Will be in-core sorted on recursion -> fork kid process,
312     * !!! but don't fork more than numProc kids; wait if necessary */
313     while (procCnt >= numProc && wait(&stat) >= 0) {
314     if (!WIFEXITED(stat) || WEXITSTATUS(stat))
315     return -1;
316
317     procCnt--;
318     }
319
320     /* Now fork kid process */
321     if (!(pid = fork())) {
322     /* Recurse on subblocks with new input filehandle; */
323     if (OOC_SortRecurse(in, blkLo2, blkHi2, blkFile [b], numBlk,
324     maxBlkSize, numProc, recSize, sortBuf,
325     pqueue, keyData))
326     exit(-1);
327
328     /* !!! Apparently the parent's tmpfile isn't deleted when the
329     * !!! child exits (which is what we want), though some
330     * !!! sources suggest using _Exit() instead; is this
331     * !!! implementation specific? */
332     exit(0);
333     }
334     else if (pid < 0) {
335 rschregle 2.5 perror("OOC_Sort: failed to fork subprocess");
336 rschregle 2.3 return -1;
337     }
338
339     #ifdef DEBUG_OOC_FORK
340     fprintf(stderr, "OOC_Sort: forking kid %d for block %d\n",
341     procCnt, b);
342     #endif
343
344     /* Parent continues here */
345     procCnt++;
346     }
347     else {
348     /* Recurse on subblock; without forking */
349     if (OOC_SortRecurse(in, blkLo2, blkHi2, blkFile [b], numBlk,
350     maxBlkSize, numProc, recSize, sortBuf,
351     pqueue, keyData))
352     return -1;
353     }
354
355     /* Prepare for next block */
356     blkLo2 = blkHi2 + 1;
357     }
358
359     /* !!! Wait for any forked processes to terminate */
360     while (procCnt && wait(&stat) >= 0) {
361     if (!WIFEXITED(stat) || WEXITSTATUS(stat))
362     return -1;
363
364     procCnt--;
365     }
366
367     /* ===============================================================
368     * Subblocks are now sorted; prepare priority queue by peeking and
369     * enqueueing first record from corresponding temporary file
370     * =============================================================== */
371
372     #ifdef DEBUG_OOC_SORT
373     fprintf(stderr, "OOC_Sort: merging block [%lu - %lu]\n", blkLo, blkHi);
374     #endif
375 greg 2.1
376 rschregle 2.3 for (b = 0; b < numBlk; b++) {
377     #ifdef DEBUG_OOC_SORT
378     fseek(blkFile [b], 0, SEEK_END);
379     if (ftell(blkFile [b]) % recSize) {
380     fprintf(stderr, "OOC_Sort: truncated record in tmp block "
381     "file %d\n", b);
382     return -1;
383     }
384
385     fprintf(stderr, "OOC_Sort: tmp block file %d contains %ld rec\n",
386     b, ftell(blkFile [b]) / recSize);
387 greg 2.1 #endif
388
389 rschregle 2.3 rewind(blkFile [b]);
390
391     if (OOC_SortPeek(blkFile [b], recSize, rec)) {
392     fprintf(stderr, "OOC_Sort: error reading from block file\n");
393     return -1;
394     }
395
396     /* Enqueue record along with its Morton code as priority */
397     pri = OOC_Key2Morton(keyData -> key(rec), keyData -> bbOrg,
398     keyData -> mortonScale);
399
400     if (OOC_SortPush(pqueue, pri, b) < 0) {
401     fprintf(stderr, "OOC_Sort: failed priority queue insertion\n");
402     return -1;
403     }
404 greg 2.1 }
405
406 rschregle 2.3 /* ==========================================================
407     * Subblocks now sorted and priority queue filled; merge from
408     * temporary files
409     * ========================================================== */
410
411     do {
412     /* Get next node in priority queue, read next record in corresponding
413     * block, and send to output */
414     b = OOC_SortPop(pqueue);
415
416     if (b >= 0) {
417     /* Priority queue non-empty */
418     if (OOC_SortRead(blkFile [b], recSize, rec)) {
419     /* Corresponding record should still be in the input block */
420     fprintf(stderr, "OOC_Sort: unexpected end reading block file\n");
421     return -1;
422     }
423
424     if (OOC_SortWrite(out, recSize, rec)) {
425     fprintf(stderr, "OOC_Sort; error writing output file\n");
426     return -1;
427     }
428
429     #ifdef DEBUG_OOC_SORT
430     pqCnt++;
431     #endif
432
433     /* Peek next record from same block and insert in priority queue */
434     if (!OOC_SortPeek(blkFile [b], recSize, rec)) {
435     /* Block not exhausted */
436     pri = OOC_Key2Morton(keyData -> key(rec), keyData -> bbOrg,
437     keyData -> mortonScale);
438
439     if (OOC_SortPush(pqueue, pri, b) < 0) {
440     fprintf(stderr, "OOC_Sort: failed priority queue insert\n");
441     return -1;
442     }
443     }
444     }
445     } while (b >= 0);
446
447     #ifdef DEBUG_OOC_SORT
448     fprintf(stderr, "OOC_Sort: dequeued %lu rec\n", pqCnt);
449     fprintf(stderr, "OOC_Sort: merged file contains %lu rec\n",
450     ftell(out) / recSize);
451     #endif
452 greg 2.1
453 rschregle 2.3 /* Priority queue now empty -> done; close temporary subblock files,
454     * causing them to be automatically deleted. */
455     for (b = 0; b < numBlk; b++) {
456     fclose(blkFile [b]);
457 greg 2.1 }
458
459 rschregle 2.3 /* !!! Commit output file to disk before caller reads it; omitting
460     * !!! this apparently leads to corrupted files (race condition?) when
461     * !!! the caller tries to read them! */
462     fflush(out);
463     fsync(fileno(out));
464     }
465
466     else {
467     /* ======================================
468     * Block is small enough for in-core sort
469     * ====================================== */
470     int ifd = fileno(in), ofd = fileno(out);
471
472     #ifdef DEBUG_OOC_SORT
473     fprintf(stderr, "OOC_Sort: Proc %d (%d/%d) sorting block [%lu - %lu]\n",
474     getpid(), procCnt, numProc - 1, blkLo, blkHi);
475
476     #endif
477
478     /* Atomically seek and read block into in-core sort buffer */
479     /* !!! Unbuffered I/O via pread() avoids potential race conditions
480     * !!! and buffer corruption which can occur with lseek()/fseek()
481     * !!! followed by read()/fread(). */
482     if (pread(ifd, sortBuf, blkSize, blkLo * recSize) != blkSize) {
483     perror("OOC_Sort: error reading from input file");
484     return -1;
485     }
486
487     /* Quicksort block in-core and write to output file */
488     qsort(sortBuf, blkLen, recSize, OOC_KeyCompare);
489
490     if (write(ofd, sortBuf, blkSize) != blkSize) {
491     perror("OOC_Sort: error writing to block file");
492 greg 2.1 return -1;
493     }
494
495 rschregle 2.3 fsync(ofd);
496
497     #ifdef DEBUG_OOC_SORT
498     fprintf(stderr, "OOC_Sort: proc %d wrote %ld records\n",
499     getpid(), lseek(ofd, 0, SEEK_END) / recSize);
500     #endif
501     }
502
503     return 0;
504     }
505
506
507 greg 2.1
508 rschregle 2.3 int OOC_Sort (FILE *in, FILE *out, unsigned numBlk,
509     unsigned long blkSize, unsigned numProc, unsigned recSize,
510     FVECT bbOrg, RREAL bbSize, RREAL *(*key)(const void*))
511     /* Sort records in inFile and append to outFile by subdividing inFile into
512     * small blocks, sorting these in-core, and merging them out-of-core via a
513     * priority queue.
514     *
515     * This is implemented as a recursive (numBlk)-way sort; the input is
516     * successively split into numBlk smaller blocks until these are of size <=
517     * blkSize, i.e. small enough for in-core sorting, then merging the sorted
518     * blocks as the stack unwinds. The in-core sort is parallelised over
519     * numProx processes.
520     *
521     * Parameters are as follows:
522     * inFile Opened input file containing unsorted records
523     * outFile Opened output file containing sorted records
524     * numBlk Number of blocks to divide into / merge from
525     * blkSize Max block size and size of in-core sort buffer, in bytes
526     * numProc Number of parallel processes for in-core sort
527     * recSize Size of input records in bytes
528     * bbOrg Origin of bounding box containing record keys for Morton code
529     * bbSize Extent of bounding box containing record keys for Morton code
530     * key Callback to access 3D coords from records for Morton code
531     */
532     {
533     unsigned long numRec;
534     OOC_SortQueue pqueue;
535     char *sortBuf = NULL;
536     int stat;
537
538     if (numBlk < 1)
539     numBlk = 1;
540 greg 2.1
541 rschregle 2.3 /* Open input file & get size in number of records */
542     if (fseek(in, 0, SEEK_END) < 0) {
543     fputs("OOC_Sort: failed seek in input file\n", stderr);
544 greg 2.1 return -1;
545     }
546
547 rschregle 2.3 if (!(numRec = ftell(in) / recSize)) {
548     fputs("OOC_Sort: empty input file\n", stderr);
549     return -1;
550 greg 2.1 }
551 rschregle 2.3
552     /* Allocate & init priority queue */
553     if (!(pqueue.node = calloc(numBlk, sizeof(OOC_SortQueueNode)))) {
554     fputs("OOC_Sort: failure allocating priority queue\n", stderr);
555 greg 2.1 return -1;
556     }
557 rschregle 2.3 pqueue.tail = 0;
558     pqueue.len = numBlk;
559
560     /* Allocate in-core sort buffa */
561     if (!(sortBuf = malloc(blkSize))) {
562     fprintf(stderr, "OOC_Sort: failure allocating in-core sort buffer");
563 greg 2.1 return -1;
564     }
565
566 rschregle 2.3 /* Set up key data to pass to qsort()'s comparison func */
567     keyData.key = key;
568     keyData.mortonScale = OOC_MORTON_MAX / bbSize;
569     VCOPY(keyData.bbOrg, bbOrg);
570
571     stat = OOC_SortRecurse(in, 0, numRec - 1, out, numBlk, blkSize, numProc,
572     recSize, sortBuf, &pqueue, &keyData);
573 greg 2.1
574 rschregle 2.3 /* Cleanup */
575 greg 2.1 free(pqueue.node);
576 rschregle 2.3 free(sortBuf);
577 greg 2.1
578 rschregle 2.3 return stat;
579     }
580 rschregle 2.4
581     #endif /* NIX / PMAP_OOC */
