| 1 | /* |
| 2 | ====================================================================== |
| 3 | Out-of-core octree data structure |
| 4 |  |
| 5 | Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 6 | (c) Lucerne University of Applied Sciences and Arts, |
| 7 | supported by the Swiss National Science Foundation (SNSF, #147053) |
| 8 | ====================================================================== |
| 9 |  |
| 10 | $Id: oococt.h,v 2.3 2016/05/17 17:39:47 rschregle Exp $ |
| 11 | */ |
| 12 |  |
| 13 |  |
| 14 | #ifndef OOC_OCT_H |
| 15 | #define OOC_OCT_H |
| 16 |  |
| 17 | #include "oocmorton.h" |
| 18 | #include "ooccache.h" |
| 19 | #include <stdint.h> |
| 20 | #include <stdio.h> |
| 21 |  |
| 22 |  |
| 23 | /* =================================================================== |
| 24 | * CONSTS |
| 25 | * =================================================================== */ |
| 26 |  |
| 27 | /* Octree index & data counter types */ |
| 28 | typedef uint32_t           OOC_NodeIdx; |
| 29 | typedef uint32_t           OOC_DataIdx; |
| 30 | typedef uint8_t            OOC_OctCnt; |
| 31 |  |
| 32 | /* Octree node field sizes for above */ |
| 33 | #define OOC_NODEIDX_BITS   31 |
| 34 | #define OOC_DATAIDX_BITS   32 |
| 35 |  |
| 36 | /* Limits for above */ |
| 37 | #define OOC_NODEIDX_MAX    ((1L << OOC_NODEIDX_BITS) - 1) |
| 38 | #define OOC_DATAIDX_MAX    ((1L << OOC_DATAIDX_BITS) - 2) |
| 39 | #define OOC_OCTCNT_MAX     UINT8_MAX |
| 40 |  |
| 41 | /* Reserved values for above */ |
| 42 | #define OOC_DATAIDX_ERR    (OOC_DATAIDX_MAX + 1) |
| 43 |  |
| 44 | /* Block size for node allocation (8k) */ |
| 45 | #define OOC_BLKSIZE        (1L << 13) |
| 46 |  |
| 47 |  |
| 48 |  |
| 49 | /* =================================================================== |
| 50 | * UTILZ |
| 51 | * =================================================================== */ |
| 52 |  |
| 53 | /* Test/set leaf flag for node n */ |
| 54 | #define OOC_ISLEAF(n)      ((n) -> node.type) |
| 55 | #define OOC_SETLEAF(n)     ((n) -> node.type = 1) |
| 56 |  |
| 57 | /* Test/set branch bit for octant k in node n */ |
| 58 | #define OOC_ISBRANCH(n,k)  (!OOC_ISLEAF(n) && (n) -> node.branch & 1 << (k)) |
| 59 | #define OOC_SETBRANCH(n,k) ((n) -> node.branch |=  1 << (k)) |
| 60 |  |
| 61 | /* Return index to node's 1st kid */ |
| 62 | #define OOC_KID1(o,n)      (!OOC_ISLEAF(n) ? (o)->nodes + (n)->node.kid \ |
| 63 | : NULL) |
| 64 |  |
| 65 | /* Get index to last node in octree; -1 indicates empty octree */ |
| 66 | #define OOC_ROOTIDX(o)     ((o) -> nodes && (o) -> numNodes > 0 \ |
| 67 | ? (o) -> numNodes - 1 : -1) |
| 68 |  |
| 69 | /* Get octree root; this is at the *end* of the node array! */ |
| 70 | #define OOC_ROOT(o)        (OOC_ROOTIDX(o) >= 0 \ |
| 71 | ? (o) -> nodes + OOC_ROOTIDX(o) : NULL) |
| 72 |  |
| 73 | /* Copy node to octree root */ |
| 74 | #define OOC_SETROOT(o,n)   (memcpy(OOC_ROOT(o), (n), sizeof(OOC_Node))) |
| 75 |  |
| 76 | /* Set all node fields to 0 */ |
| 77 | #define OOC_CLEARNODE(n)   (memset((n), 0, sizeof(OOC_Node))) |
| 78 |  |
| 79 | /* Modify origin o for octant k of size s */ |
| 80 | #define OOC_OCTORIGIN(o,k,s)  ((o) [0] += (s) * ((k)      & 1), \ |
| 81 | (o) [1] += (s) * ((k) >> 1 & 1), \ |
| 82 | (o) [2] += (s) * ((k) >> 2 & 1)) |
| 83 |  |
| 84 | /* Get num records stored in node (also handles leaves and NULL pointer) */ |
| 85 | #define OOC_DATACNT(n) \ |
| 86 | ((n) ? OOC_ISLEAF(n) ? (n) -> leaf.num [0] + (n) -> leaf.num [1] + \ |
| 87 | (n) -> leaf.num [2] + (n) -> leaf.num [3] + \ |
| 88 | (n) -> leaf.num [4] + (n) -> leaf.num [5] + \ |
| 89 | (n) -> leaf.num [6] + (n) -> leaf.num [7]   \ |
| 90 | : (n) -> node.num \ |
| 91 | : 0) |
| 92 |  |
| 93 | /* Shortcuts for morton code from key and data record */ |
| 94 | #define OOC_KEY2MORTON(k, o)  OOC_Key2Morton((k), (o) -> org, \ |
| 95 | (o) -> mortonScale) |
| 96 | #define OOC_REC2MORTON(r, o)  OOC_Key2Morton((o) -> key(r), (o) -> org, \ |
| 97 | (o) -> mortonScale) |
| 98 |  |
| 99 |  |
| 100 |  |
| 101 | /* =================================================================== |
| 102 | * DATA TYPEZ |
| 103 | * =================================================================== */ |
| 104 |  |
| 105 | /* Octree node */ |
| 106 | typedef struct { |
| 107 | union { |
| 108 | struct { |
| 109 | /* Interior node (node.type = 0) with: |
| 110 | node.kid    = index to 1st child node in octree array (a.k.a |
| 111 | "Number One Son"), immediately followed by its |
| 112 | nonzero siblings as indicated by branch |
| 113 | node.num    = num records stored in this subtree, |
| 114 | node.branch = branch bitmask indicating nonzero kid nodes */ |
| 115 | char           type  : 1; |
| 116 | OOC_NodeIdx    kid   : OOC_NODEIDX_BITS; |
| 117 | OOC_DataIdx    num   : OOC_DATAIDX_BITS; |
| 118 | uint8_t        branch; |
| 119 |  |
| 120 | /* NOTE that we can't make the kid's index relative to parent |
| 121 | * (which would be more compact), since we don't know the |
| 122 | * parent's index a priori during the bottom-up construction! */ |
| 123 | } node; |
| 124 |  |
| 125 | struct { |
| 126 | /* Leaf node (leaf.type = node.type = 1 with: |
| 127 | leaf.num [k] = num records stored in octant k */ |
| 128 | char           type  : 1; |
| 129 | OOC_OctCnt     num   [8]; |
| 130 | } leaf; |
| 131 | }; |
| 132 | } OOC_Node; |
| 133 |  |
| 134 |  |
| 135 |  |
| 136 | /* Top level octree container */ |
| 137 | typedef struct { |
| 138 | FVECT          org, bound;    /* Cube origin (min. XYZ), size, and |
| 139 | resulting bounds (max. XYZ) */ |
| 140 | RREAL          size, |
| 141 | *(*key)(const void*); /* Callback for data rec coords */ |
| 142 | RREAL          mortonScale;   /* Scale factor for generating Morton |
| 143 | codes from coords */ |
| 144 | OOC_Node       *nodes;        /* Pointer to node array */ |
| 145 | /* ************************************* |
| 146 | * **** NODES ARE STORED IN POSTFIX **** |
| 147 | * **** ORDER, I.E. ROOT IS LAST!   **** |
| 148 | * *************************************/ |
| 149 | OOC_DataIdx    numData;       /* Num records in leaves */ |
| 150 | OOC_NodeIdx    maxNodes,      /* Num currently allocated nodes */ |
| 151 | numNodes;      /* Num used nodes (<= maxNodes) */ |
| 152 | unsigned       recSize,       /* Size of data record in bytes */ |
| 153 | leafMax,       /* Max #records per leaf (for build) */ |
| 154 | maxDepth;      /* Max subdivision depth (for build) */ |
| 155 | FILE           *leafFile;     /* File containing data in leaves */ |
| 156 | OOC_Cache      *cache;        /* I/O cache for leafFile */ |
| 157 | } OOC_Octree; |
| 158 |  |
| 159 | /* DOAN' FORGET: NODES IN ***POSTFIX*** ORDAH!!! */ |
| 160 |  |
| 161 | #ifdef __cplusplus |
| 162 | extern "C" { |
| 163 | #endif |
| 164 |  |
| 165 |  |
| 166 | /* =================================================================== |
| 167 | * FUNKZ |
| 168 | * =================================================================== */ |
| 169 |  |
| 170 | /* Init empty octree */ |
| 171 | void OOC_Null (OOC_Octree *oct); |
| 172 |  |
| 173 |  |
| 174 | /* Initialises octree for records of size recSize with 3D coordinates, |
| 175 | * accessed via key() callback.  The octree's bounding box is defined by |
| 176 | * its origin org and size per axis, and must contain all keys. The |
| 177 | * octree is associated with the specified leaf file containing the |
| 178 | * records in Morton order */ |
| 179 | void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size, |
| 180 | RREAL *(*key)(const void*), FILE *leafFile); |
| 181 |  |
| 182 |  |
| 183 | /* Allocate new octree node, enlarge array if necessary.  Returns pointer |
| 184 | to new node or NULL if failed.  */ |
| 185 | OOC_Node *NewNode (OOC_Octree *oct); |
| 186 |  |
| 187 |  |
| 188 | /* Reads indexed data record from leaf file and copies it to rec, else |
| 189 | * returns -1 on failure */ |
| 190 | int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec); |
| 191 |  |
| 192 |  |
| 193 | /* Appends octree nodes to specified file along with metadata. Uses |
| 194 | * RADIANCE's portable I/O routines. Returns 0 on success, else -1. */ |
| 195 | int OOC_SaveOctree (const OOC_Octree *oct, FILE *nodeFile); |
| 196 |  |
| 197 |  |
| 198 | /* Load octree nodes and metadata from nodeFile and associate with |
| 199 | * records in leafFile.  Uses RADIANCE's portable I/O routines.  Returns |
| 200 | * 0 on success, else -1.  */ |
| 201 | int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile, |
| 202 | RREAL *(*key)(const void*), FILE *leafFile); |
| 203 |  |
| 204 | #ifdef DEBUG_OOC |
| 205 | /* Traverse tree & check for valid nodes; oct -> leafFile must be open; |
| 206 | * return 0 if ok, otherwise -1 */ |
| 207 | int OOC_Check (OOC_Octree *oct, const OOC_Node *node, |
| 208 | FVECT org, RREAL size, OOC_DataIdx dataIdx); |
| 209 | #endif |
| 210 |  |
| 211 | /* Check whether key lies within bounding box defined by org and size */ |
| 212 | int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size, |
| 213 | const FVECT key); |
| 214 |  |
| 215 | /* Return index of octant containing key and corresponding origin if |
| 216 | * nuOrg = NULL, or -1 if key lies outside all octants. Size is already |
| 217 | * assumed to be halved, i.e. corresponding to the length of an octant |
| 218 | * axis. */ |
| 219 | int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size, |
| 220 | const FVECT key, FVECT nuOrg); |
| 221 |  |
| 222 | /* Optimised version of OOC_Branch() with precomputed key Morton code */ |
| 223 | int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size, |
| 224 | OOC_MortonIdx keyZ, FVECT nuOrg); |
| 225 |  |
| 226 | /* For a given octree node, return the sum of the data counters for kids |
| 227 | * [0..k-1].  On return, the node either points to the k'th kid, or |
| 228 | * NULL if the kid is nonexistent or the node is a leaf */ |
| 229 | OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node, |
| 230 | unsigned k); |
| 231 |  |
| 232 | /* Self-destruct */ |
| 233 | void OOC_Delete (OOC_Octree *oct); |
| 234 |  |
| 235 | #ifdef __cplusplus |
| 236 | } |
| 237 | #endif |
| 238 |  |
| 239 | /* DID WE MENTION NODES ARE IN POSTFIX ORDAH? */ |
| 240 | #endif |
