root/radiance/ray/src/rt/oococt.h
Revision: 2.1
Committed: Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
1 #ifndef OOC_OCT_H
2 #define OOC_OCT_H
3
5 ==================================================================
6 Out-of-core octree data structure
7
8 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
9 (c) Fraunhofer Institute for Solar Energy Systems,
10 Lucerne University of Applied Sciences & Arts
11 ==================================================================
12
13 $Id$
14 */
15
16
17 #include "fvect.h"
18
19
20 /* Pointer to i-th record */
21 #define OOC_RECPTR(p,i) ((p) +
22
23 /* Default data block size (8k) */
24 #define OOC_BLKBITS 13
25 #define OOC_BLKSIZE (1 << OOC_BLKBITS)
26
27 /* Index to data block and index within the block */
28 #define OOC_IDXTOBLK(i) ((i) >> OOC_BLKBITS)
29 #define OOC_IDXINBLK(i) ((i) & (1 << OOC_BLKBITS) - 1)
30
31 /* Check for block overflow when adding node
32 #define OOC_BLKFULL(n) ((!(n) * sizeof(OOC_Node) % OOC_BLKSIZE) */
33
34 /* Check for internal node, empty node, interior leaf, or terminal node
35 (8 leaves) */
36 #define OOC_INTNODE(n) ((n).num > 0 && (n).kid > 0)
37 #define OOC_EMPTYNODE(n) (!(n).num)
38 #define OOC_INTLEAF(n) ((n).kid < 0)
39 #define OOC_TERMNODE(n) ((n).num < 0)
40
41 /* Return record count and kid/leaf index for node */
42 #define OOC_NUMREC(n) abs((n).num)
43 #define OOC_KID(n) abs((n).kid)
44
45 /* Check for loaded data block */
46 #define OOC_LOADED(b) ((b).dataBlk != NULL)
47
48 /* (Mutually exclusive) operations on octree to be specified as flags */
49 #define OOC_INSERT 1
50 #define OOC_SEARCH 2
51
52 /* Counter for records at leaves (2 bytes) */
53 typedef unsigned short OOC_Leaf;
54
55 /* Node and record index type */
56 typedef int OOC_Idx;
57
58 /* Octree node */
59 typedef struct {
60 /*
61 For interior nodes (num > 0):
62 num = num records stored in this (sub)tree,
63 kid = index to 1st child node (immediately followed by its
64 siblings) in octree array.
65
66 For interior leaves (kid < 0):
67 num = num records stored in leaf,
68 abs(kid) = index to single leaf, no siblings.
69
70 For terminal nodes (num < 0):
71 abs(num) = num records stored in leaves,
72 kid = index to 1st of 8 leaves (immediately followed by its
73 siblings) in leaf array.
74 */
75 OOC_Idx num, kid;
76 } OOC_Node;
77
78
79 /* Load map entry; points to start of data block of size OOC_BLKSIZE, or
80 * NULL if not loaded. LRU counter counts accesses for paging from disk */
81 typedef struct {
82 void *dataBlk;
83 unsigned long lruCnt;
84 } OOC_Load;
85
86
87 /* Top level octree container */
88 typedef struct {
89 FVECT org; /* Cube origin (min. XYZ) and size */
90 RREAL size;
91 OOC_Node *root; /* Pointer to node array */
92 OOC_Idx maxNodes, /* Num currently allocated nodes */
93 numNodes; /* Num used nodes (< maxNodes) */
94 OOC_Load *loadMap; /* Pointer to load map */
95 OOC_Leaf *leaves; /* Pointer to leaf array */
96 unsigned recSize, /* Size of data record in bytes */
97 leafMax, /* Max num records per leaf */
98 maxDepth; /* Max subdivision depth */
99 } OOC_Octree;
100
101
102 /* Initialise octree for records of size recSize, return -1 on failure */
103 int OOC_Init (OOC_Octree *oct, unsigned recSize, unsigned leafMax);
104
105 /* Return index of kid containing key, update origin and size accordingly */
106 int OOC_Branch (FVECT key, FVECT org, RREAL *size);
107
108 /* Return data index to leaf containing key, or -1 if not found */
109 OOC_Idx OOC_Find (OOC_Octree *oct, FVECT key);
110
111 #if 0
112 /* Return pointer to terminal node containing key */
113 OOC_Node *FindNode (OOC_Octree *oct, FVECT key);
114
115 /* Return index into data block for leaf containing key */
116 OOC_Idx FindLeaf (OOC_Leaf *leaf, FVECT key);
117 #endif
118
119 #endif
