root/Development/ray/src/rt/oococt.h
Revision: 2.3
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 7 months ago) by rschregle
CVS Tags: rad5R4, rad5R3, rad5R2, rad5R1
Changes since 2.2: +219 -104 lines
1 /*
2 ======================================================================
3 Out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ======================================================================
9
10 $Id: oococt.h,v 1.22 2015/11/13 17:26:05 taschreg Exp taschreg $
11 */
12
13
14 #ifndef OOC_OCT_H
15 #define OOC_OCT_H
16
17 #include "oocmorton.h"
18 #include "ooccache.h"
19 #include <stdint.h>
20 #include <stdio.h>
21
22
23
24 /* ===================================================================
25 * CONSTS
26 * =================================================================== */
27
28 /* Octree index & data counter types */
29 typedef uint32_t OOC_NodeIdx;
30 typedef uint32_t OOC_DataIdx;
31 typedef uint8_t OOC_OctCnt;
32
33 /* Octree node field sizes for above */
34 #define OOC_NODEIDX_BITS 31
35 #define OOC_DATAIDX_BITS 32
36
37 /* Limits for above */
38 #define OOC_NODEIDX_MAX ((1L << OOC_NODEIDX_BITS) - 1)
39 #define OOC_DATAIDX_MAX ((1L << OOC_DATAIDX_BITS) - 2)
40 #define OOC_OCTCNT_MAX UINT8_MAX
41
42 /* Reserved values for above */
43 #define OOC_DATAIDX_ERR (OOC_DATAIDX_MAX + 1)
44
45 /* Block size for node allocation (8k) */
46 #define OOC_BLKSIZE (1L << 13)
47
48
49
50 /* ===================================================================
51 * UTILZ
52 * =================================================================== */
53
54 /* Test/set leaf flag for node n */
55 #define OOC_ISLEAF(n) ((n) -> node.type)
56 #define OOC_SETLEAF(n) ((n) -> node.type = 1)
57
58 /* Test/set branch bit for octant k in node n */
59 #define OOC_ISBRANCH(n,k) (!OOC_ISLEAF(n) && (n) -> node.branch & 1 << (k))
60 #define OOC_SETBRANCH(n,k) ((n) -> node.branch |= 1 << (k))
61
62 /* Return index to node's 1st kid */
63 #define OOC_KID1(o,n) (!OOC_ISLEAF(n) ? (o)->nodes + (n)->node.kid \
64 : NULL)
65
66 /* Get index to last node in octree; -1 indicates empty octree */
67 #define OOC_ROOTIDX(o) ((o) -> nodes && (o) -> numNodes > 0 \
68 ? (o) -> numNodes - 1 : -1)
69
70 /* Get octree root; this is at the *end* of the node array! */
71 #define OOC_ROOT(o) (OOC_ROOTIDX(o) >= 0 \
72 ? (o) -> nodes + OOC_ROOTIDX(o) : NULL)
73
74 /* Copy node to octree root */
75 #define OOC_SETROOT(o,n) (memcpy(OOC_ROOT(o), (n), sizeof(OOC_Node)))
76
77 /* Set all node fields to 0 */
78 #define OOC_CLEARNODE(n) (memset((n), 0, sizeof(OOC_Node)))
79
80 /* Modify origin o for octant k of size s */
81 #define OOC_OCTORIGIN(o,k,s) ((o) [0] += (s) * ((k) & 1), \
82 (o) [1] += (s) * ((k) >> 1 & 1), \
83 (o) [2] += (s) * ((k) >> 2 & 1))
84
85 /* Get num records stored in node (also handles leaves and NULL pointer) */
86 #define OOC_DATACNT(n) \
87 ((n) ? OOC_ISLEAF(n) ? (n) -> leaf.num [0] + (n) -> leaf.num [1] + \
88 (n) -> leaf.num [2] + (n) -> leaf.num [3] + \
89 (n) -> leaf.num [4] + (n) -> leaf.num [5] + \
90 (n) -> leaf.num [6] + (n) -> leaf.num [7] \
91 : (n) -> node.num \
92 : 0)
93
94 /* Shortcuts for morton code from key and data record */
95 #define OOC_KEY2MORTON(k, o) OOC_Key2Morton((k), (o) -> org, \
96 (o) -> mortonScale)
97 #define OOC_REC2MORTON(r, o) OOC_Key2Morton((o) -> key(r), (o) -> org, \
98 (o) -> mortonScale)
99
100
101
102 /* ===================================================================
103 * DATA TYPEZ
104 * =================================================================== */
105
106 /* Octree node */
107 typedef struct {
108 union {
109 struct {
110 /* Interior node (node.type = 0) with:
111 node.kid = index to 1st child node in octree array (a.k.a
112 "Number One Son"), immediately followed by its
113 nonzero siblings as indicated by branch
114 node.num = num records stored in this subtree,
115 node.branch = branch bitmask indicating nonzero kid nodes */
116 char type : 1;
117 OOC_NodeIdx kid : OOC_NODEIDX_BITS;
118 OOC_DataIdx num : OOC_DATAIDX_BITS;
119 uint8_t branch;
120
121 /* NOTE that we can't make the kid's index relative to parent
122 * (which would be more compact), since we don't know the
123 * parent's index a priori during the bottom-up construction! */
124 } node;
125
126 struct {
127 /* Leaf node (leaf.type = node.type = 1 with:
128 leaf.num [k] = num records stored in octant k */
129 char type : 1;
130 OOC_OctCnt num [8];
131 } leaf;
132 };
133 } OOC_Node;
134
135
136
137 /* Top level octree container */
138 typedef struct {
139 FVECT org, bound; /* Cube origin (min. XYZ), size, and
140 resulting bounds (max. XYZ) */
141 RREAL size,
142 *(*key)(const void*); /* Callback for data rec coords */
143 RREAL mortonScale; /* Scale factor for generating Morton
144 codes from coords */
145 OOC_Node *nodes; /* Pointer to node array */
146 /* *************************************
147 * **** NODES ARE STORED IN POSTFIX ****
148 * **** ORDER, I.E. ROOT IS LAST! ****
149 * *************************************/
150 OOC_DataIdx numData; /* Num records in leaves */
151 OOC_NodeIdx maxNodes, /* Num currently allocated nodes */
152 numNodes; /* Num used nodes (<= maxNodes) */
153 unsigned recSize, /* Size of data record in bytes */
154 leafMax, /* Max #records per leaf (for build) */
155 maxDepth; /* Max subdivision depth (for build) */
156 FILE *leafFile; /* File containing data in leaves */
157 OOC_Cache *cache; /* I/O cache for leafFile */
158 } OOC_Octree;
159
160 /* DOAN' FORGET: NODES IN ***POSTFIX*** ORDAH!!! */
161
162
163
164 /* ===================================================================
165 * FUNKZ
166 * =================================================================== */
167
168 /* Init empty octree */
169 void OOC_Null (OOC_Octree *oct);
170
171
172 /* Initialises octree for records of size recSize with 3D coordinates,
173 * accessed via key() callback. The octree's bounding box is defined by
174 * its origin org and size per axis, and must contain all keys. The
175 * octree is associated with the specified leaf file containing the
176 * records in Morton order */
177 void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
178 RREAL *(*key)(const void*), FILE *leafFile);
179
180
181 /* Allocate new octree node, enlarge array if necessary. Returns pointer
182 to new node or NULL if failed. */
183 OOC_Node *NewNode (OOC_Octree *oct);
184
185
186 /* Reads indexed data record from leaf file and copies it to rec, else
187 * returns -1 on failure */
188 int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec);
189
190
191 /* Appends octree nodes to specified file along with metadata. Uses
192 * RADIANCE's portable I/O routines. Returns 0 on success, else -1. */
193 int OOC_SaveOctree (const OOC_Octree *oct, FILE *nodeFile);
194
195
196 /* Load octree nodes and metadata from nodeFile and associate with
197 * records in leafFile. Uses RADIANCE's portable I/O routines. Returns
198 * 0 on success, else -1. */
199 int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
200 RREAL *(*key)(const void*), FILE *leafFile);
201
202 #ifdef DEBUG_OOC
203 /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
204 * return 0 if ok, otherwise -1 */
205 int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
206 FVECT org, RREAL size, OOC_DataIdx dataIdx);
207 #endif
208
209 /* Check whether key lies within bounding box defined by org and size */
210 int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
211 const FVECT key);
212
213 /* Return index of octant containing key and corresponding origin if
214 * nuOrg = NULL, or -1 if key lies outside all octants. Size is already
215 * assumed to be halved, i.e. corresponding to the length of an octant
216 * axis. */
217 int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
218 const FVECT key, FVECT nuOrg);
219
220 /* Optimised version of OOC_Branch() with precomputed key Morton code */
221 int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
222 OOC_MortonIdx keyZ, FVECT nuOrg);
223
224 /* For a given octree node, return the sum of the data counters for kids
225 * [0..k-1]. On return, the node either points to the k'th kid, or
226 * NULL if the kid is nonexistent or the node is a leaf */
227 OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node,
228 unsigned k);
229
230 /* Self-destruct */
231 void OOC_Delete (OOC_Octree *oct);
232
233 /* DID WE MENTION NODES ARE IN POSTFIX ORDAH? */
234 #endif
