root/Development/ray/src/rt/oococt.h
Revision: 2.3
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 7 months ago) by rschregle
CVS Tags: rad5R4, rad5R3, rad5R2, rad5R1
Changes since 2.2: +219 -104 lines
# User Rev Content
1 greg 2.1 /*
2 rschregle 2.3 ======================================================================
3 greg 2.1 Out-of-core octree data structure
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
7     supported by the Swiss National Science Foundation (SNSF, #147053)
8     ======================================================================
9 greg 2.1
10 rschregle 2.3 $Id: oococt.h,v 1.22 2015/11/13 17:26:05 taschreg Exp taschreg $
11 greg 2.1 */
12
13
14 rschregle 2.3 #ifndef OOC_OCT_H
15     #define OOC_OCT_H
16
17     #include "oocmorton.h"
18     #include "ooccache.h"
19     #include <stdint.h>
20     #include <stdio.h>
21
22
23
24     /* ===================================================================
25     * CONSTS
26     * =================================================================== */
27
28     /* Octree index & data counter types */
29     typedef uint32_t OOC_NodeIdx;
30     typedef uint32_t OOC_DataIdx;
31     typedef uint8_t OOC_OctCnt;
32
33     /* Octree node field sizes for above */
34     #define OOC_NODEIDX_BITS 31
35     #define OOC_DATAIDX_BITS 32
36
37     /* Limits for above */
38     #define OOC_NODEIDX_MAX ((1L << OOC_NODEIDX_BITS) - 1)
39     #define OOC_DATAIDX_MAX ((1L << OOC_DATAIDX_BITS) - 2)
40     #define OOC_OCTCNT_MAX UINT8_MAX
41
42     /* Reserved values for above */
43     #define OOC_DATAIDX_ERR (OOC_DATAIDX_MAX + 1)
44
45     /* Block size for node allocation (8k) */
46     #define OOC_BLKSIZE (1L << 13)
47
48
49 greg 2.1
50 rschregle 2.3 /* ===================================================================
51     * UTILZ
52     * =================================================================== */
53 greg 2.1
54 rschregle 2.3 /* Test/set leaf flag for node n */
55     #define OOC_ISLEAF(n) ((n) -> node.type)
56     #define OOC_SETLEAF(n) ((n) -> node.type = 1)
57
58     /* Test/set branch bit for octant k in node n */
59     #define OOC_ISBRANCH(n,k) (!OOC_ISLEAF(n) && (n) -> node.branch & 1 << (k))
60     #define OOC_SETBRANCH(n,k) ((n) -> node.branch |= 1 << (k))
61
62     /* Return index to node's 1st kid */
63     #define OOC_KID1(o,n) (!OOC_ISLEAF(n) ? (o)->nodes + (n)->node.kid \
64     : NULL)
65
66     /* Get index to last node in octree; -1 indicates empty octree */
67     #define OOC_ROOTIDX(o) ((o) -> nodes && (o) -> numNodes > 0 \
68     ? (o) -> numNodes - 1 : -1)
69
70     /* Get octree root; this is at the *end* of the node array! */
71     #define OOC_ROOT(o) (OOC_ROOTIDX(o) >= 0 \
72     ? (o) -> nodes + OOC_ROOTIDX(o) : NULL)
73
74     /* Copy node to octree root */
75     #define OOC_SETROOT(o,n) (memcpy(OOC_ROOT(o), (n), sizeof(OOC_Node)))
76
77     /* Set all node fields to 0 */
78     #define OOC_CLEARNODE(n) (memset((n), 0, sizeof(OOC_Node)))
79 greg 2.1
80 rschregle 2.3 /* Modify origin o for octant k of size s */
81     #define OOC_OCTORIGIN(o,k,s) ((o) [0] += (s) * ((k) & 1), \
82     (o) [1] += (s) * ((k) >> 1 & 1), \
83     (o) [2] += (s) * ((k) >> 2 & 1))
84
85     /* Get num records stored in node (also handles leaves and NULL pointer) */
86     #define OOC_DATACNT(n) \
87     ((n) ? OOC_ISLEAF(n) ? (n) -> leaf.num [0] + (n) -> leaf.num [1] + \
88     (n) -> leaf.num [2] + (n) -> leaf.num [3] + \
89     (n) -> leaf.num [4] + (n) -> leaf.num [5] + \
90     (n) -> leaf.num [6] + (n) -> leaf.num [7] \
91     : (n) -> node.num \
92     : 0)
93
94     /* Shortcuts for morton code from key and data record */
95     #define OOC_KEY2MORTON(k, o) OOC_Key2Morton((k), (o) -> org, \
96     (o) -> mortonScale)
97     #define OOC_REC2MORTON(r, o) OOC_Key2Morton((o) -> key(r), (o) -> org, \
98     (o) -> mortonScale)
99
100
101
102     /* ===================================================================
103     * DATA TYPEZ
104     * =================================================================== */
105
106     /* Octree node */
107     typedef struct {
108     union {
109     struct {
110     /* Interior node (node.type = 0) with:
111     node.kid = index to 1st child node in octree array (a.k.a
112     "Number One Son"), immediately followed by its
113     nonzero siblings as indicated by branch
114     node.num = num records stored in this subtree,
115     node.branch = branch bitmask indicating nonzero kid nodes */
116     char type : 1;
117     OOC_NodeIdx kid : OOC_NODEIDX_BITS;
118     OOC_DataIdx num : OOC_DATAIDX_BITS;
119     uint8_t branch;
120
121     /* NOTE that we can't make the kid's index relative to parent
122     * (which would be more compact), since we don't know the
123     * parent's index a priori during the bottom-up construction! */
124     } node;
125
126     struct {
127     /* Leaf node (leaf.type = node.type = 1 with:
128     leaf.num [k] = num records stored in octant k */
129     char type : 1;
130     OOC_OctCnt num [8];
131     } leaf;
132     };
133     } OOC_Node;
134
135
136
137     /* Top level octree container */
138     typedef struct {
139     FVECT org, bound; /* Cube origin (min. XYZ), size, and
140     resulting bounds (max. XYZ) */
141     RREAL size,
142     *(*key)(const void*); /* Callback for data rec coords */
143     RREAL mortonScale; /* Scale factor for generating Morton
144     codes from coords */
145     OOC_Node *nodes; /* Pointer to node array */
146     /* *************************************
147     * **** NODES ARE STORED IN POSTFIX ****
148     * **** ORDER, I.E. ROOT IS LAST! ****
149     * *************************************/
150     OOC_DataIdx numData; /* Num records in leaves */
151     OOC_NodeIdx maxNodes, /* Num currently allocated nodes */
152     numNodes; /* Num used nodes (<= maxNodes) */
153     unsigned recSize, /* Size of data record in bytes */
154     leafMax, /* Max #records per leaf (for build) */
155     maxDepth; /* Max subdivision depth (for build) */
156     FILE *leafFile; /* File containing data in leaves */
157     OOC_Cache *cache; /* I/O cache for leafFile */
158     } OOC_Octree;
159
160     /* DOAN' FORGET: NODES IN ***POSTFIX*** ORDAH!!! */
161
162
163
164     /* ===================================================================
165     * FUNKZ
166     * =================================================================== */
167
168     /* Init empty octree */
169     void OOC_Null (OOC_Octree *oct);
170
171
172     /* Initialises octree for records of size recSize with 3D coordinates,
173     * accessed via key() callback. The octree's bounding box is defined by
174     * its origin org and size per axis, and must contain all keys. The
175     * octree is associated with the specified leaf file containing the
176     * records in Morton order */
177     void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
178     RREAL *(*key)(const void*), FILE *leafFile);
179
180
181     /* Allocate new octree node, enlarge array if necessary. Returns pointer
182     to new node or NULL if failed. */
183     OOC_Node *NewNode (OOC_Octree *oct);
184
185
186     /* Reads indexed data record from leaf file and copies it to rec, else
187     * returns -1 on failure */
188     int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec);
189
190 greg 2.1
191 rschregle 2.3 /* Appends octree nodes to specified file along with metadata. Uses
192     * RADIANCE's portable I/O routines. Returns 0 on success, else -1. */
193     int OOC_SaveOctree (const OOC_Octree *oct, FILE *nodeFile);
194
195
196     /* Load octree nodes and metadata from nodeFile and associate with
197     * records in leafFile. Uses RADIANCE's portable I/O routines. Returns
198     * 0 on success, else -1. */
199     int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
200     RREAL *(*key)(const void*), FILE *leafFile);
201
202     #ifdef DEBUG_OOC
203     /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
204     * return 0 if ok, otherwise -1 */
205     int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
206     FVECT org, RREAL size, OOC_DataIdx dataIdx);
207 greg 2.1 #endif
208
209 rschregle 2.3 /* Check whether key lies within bounding box defined by org and size */
210     int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
211     const FVECT key);
212
213     /* Return index of octant containing key and corresponding origin if
214     * nuOrg = NULL, or -1 if key lies outside all octants. Size is already
215     * assumed to be halved, i.e. corresponding to the length of an octant
216     * axis. */
217     int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
218     const FVECT key, FVECT nuOrg);
219
220     /* Optimised version of OOC_Branch() with precomputed key Morton code */
221     int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
222     OOC_MortonIdx keyZ, FVECT nuOrg);
223
224     /* For a given octree node, return the sum of the data counters for kids
225     * [0..k-1]. On return, the node either points to the k'th kid, or
226     * NULL if the kid is nonexistent or the node is a leaf */
227     OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node,
228     unsigned k);
229
230     /* Self-destruct */
231     void OOC_Delete (OOC_Octree *oct);
232
233     /* DID WE MENTION NODES ARE IN POSTFIX ORDAH? */
234 greg 2.1 #endif
