root/radiance/ray/src/rt/oococt.h
Revision: 2.4
Committed: Tue Sep 17 16:36:04 2024 UTC (8 months ago) by greg
Changes since 2.3: +8 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 ======================================================================
3 Out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 ======================================================================
9
10 $Id: oococt.h,v 2.3 2016/05/17 17:39:47 rschregle Exp $
11 */
12
13
14 #ifndef OOC_OCT_H
15 #define OOC_OCT_H
16
17 #include "oocmorton.h"
18 #include "ooccache.h"
19 #include <stdint.h>
20 #include <stdio.h>
21
22
23 /* ===================================================================
24 * CONSTS
25 * =================================================================== */
26
27 /* Octree index & data counter types */
28 typedef uint32_t OOC_NodeIdx;
29 typedef uint32_t OOC_DataIdx;
30 typedef uint8_t OOC_OctCnt;
31
32 /* Octree node field sizes for above */
33 #define OOC_NODEIDX_BITS 31
34 #define OOC_DATAIDX_BITS 32
35
36 /* Limits for above */
37 #define OOC_NODEIDX_MAX ((1L << OOC_NODEIDX_BITS) - 1)
38 #define OOC_DATAIDX_MAX ((1L << OOC_DATAIDX_BITS) - 2)
39 #define OOC_OCTCNT_MAX UINT8_MAX
40
41 /* Reserved values for above */
42 #define OOC_DATAIDX_ERR (OOC_DATAIDX_MAX + 1)
43
44 /* Block size for node allocation (8k) */
45 #define OOC_BLKSIZE (1L << 13)
46
47
48
49 /* ===================================================================
50 * UTILZ
51 * =================================================================== */
52
53 /* Test/set leaf flag for node n */
54 #define OOC_ISLEAF(n) ((n) -> node.type)
55 #define OOC_SETLEAF(n) ((n) -> node.type = 1)
56
57 /* Test/set branch bit for octant k in node n */
58 #define OOC_ISBRANCH(n,k) (!OOC_ISLEAF(n) && (n) -> node.branch & 1 << (k))
59 #define OOC_SETBRANCH(n,k) ((n) -> node.branch |= 1 << (k))
60
61 /* Return index to node's 1st kid */
62 #define OOC_KID1(o,n) (!OOC_ISLEAF(n) ? (o)->nodes + (n)->node.kid \
63 : NULL)
64
65 /* Get index to last node in octree; -1 indicates empty octree */
66 #define OOC_ROOTIDX(o) ((o) -> nodes && (o) -> numNodes > 0 \
67 ? (o) -> numNodes - 1 : -1)
68
69 /* Get octree root; this is at the *end* of the node array! */
70 #define OOC_ROOT(o) (OOC_ROOTIDX(o) >= 0 \
71 ? (o) -> nodes + OOC_ROOTIDX(o) : NULL)
72
73 /* Copy node to octree root */
74 #define OOC_SETROOT(o,n) (memcpy(OOC_ROOT(o), (n), sizeof(OOC_Node)))
75
76 /* Set all node fields to 0 */
77 #define OOC_CLEARNODE(n) (memset((n), 0, sizeof(OOC_Node)))
78
79 /* Modify origin o for octant k of size s */
80 #define OOC_OCTORIGIN(o,k,s) ((o) [0] += (s) * ((k) & 1), \
81 (o) [1] += (s) * ((k) >> 1 & 1), \
82 (o) [2] += (s) * ((k) >> 2 & 1))
83
84 /* Get num records stored in node (also handles leaves and NULL pointer) */
85 #define OOC_DATACNT(n) \
86 ((n) ? OOC_ISLEAF(n) ? (n) -> leaf.num [0] + (n) -> leaf.num [1] + \
87 (n) -> leaf.num [2] + (n) -> leaf.num [3] + \
88 (n) -> leaf.num [4] + (n) -> leaf.num [5] + \
89 (n) -> leaf.num [6] + (n) -> leaf.num [7] \
90 : (n) -> node.num \
91 : 0)
92
93 /* Shortcuts for morton code from key and data record */
94 #define OOC_KEY2MORTON(k, o) OOC_Key2Morton((k), (o) -> org, \
95 (o) -> mortonScale)
96 #define OOC_REC2MORTON(r, o) OOC_Key2Morton((o) -> key(r), (o) -> org, \
97 (o) -> mortonScale)
98
99
100
101 /* ===================================================================
102 * DATA TYPEZ
103 * =================================================================== */
104
105 /* Octree node */
106 typedef struct {
107 union {
108 struct {
109 /* Interior node (node.type = 0) with:
110 node.kid = index to 1st child node in octree array (a.k.a
111 "Number One Son"), immediately followed by its
112 nonzero siblings as indicated by branch
113 node.num = num records stored in this subtree,
114 node.branch = branch bitmask indicating nonzero kid nodes */
115 char type : 1;
116 OOC_NodeIdx kid : OOC_NODEIDX_BITS;
117 OOC_DataIdx num : OOC_DATAIDX_BITS;
118 uint8_t branch;
119
120 /* NOTE that we can't make the kid's index relative to parent
121 * (which would be more compact), since we don't know the
122 * parent's index a priori during the bottom-up construction! */
123 } node;
124
125 struct {
126 /* Leaf node (leaf.type = node.type = 1 with:
127 leaf.num [k] = num records stored in octant k */
128 char type : 1;
129 OOC_OctCnt num [8];
130 } leaf;
131 };
132 } OOC_Node;
133
134
135
136 /* Top level octree container */
137 typedef struct {
138 FVECT org, bound; /* Cube origin (min. XYZ), size, and
139 resulting bounds (max. XYZ) */
140 RREAL size,
141 *(*key)(const void*); /* Callback for data rec coords */
142 RREAL mortonScale; /* Scale factor for generating Morton
143 codes from coords */
144 OOC_Node *nodes; /* Pointer to node array */
145 /* *************************************
146 * **** NODES ARE STORED IN POSTFIX ****
147 * **** ORDER, I.E. ROOT IS LAST! ****
148 * *************************************/
149 OOC_DataIdx numData; /* Num records in leaves */
150 OOC_NodeIdx maxNodes, /* Num currently allocated nodes */
151 numNodes; /* Num used nodes (<= maxNodes) */
152 unsigned recSize, /* Size of data record in bytes */
153 leafMax, /* Max #records per leaf (for build) */
154 maxDepth; /* Max subdivision depth (for build) */
155 FILE *leafFile; /* File containing data in leaves */
156 OOC_Cache *cache; /* I/O cache for leafFile */
157 } OOC_Octree;
158
159 /* DOAN' FORGET: NODES IN ***POSTFIX*** ORDAH!!! */
160
161 #ifdef __cplusplus
162 extern "C" {
163 #endif
164
165
166 /* ===================================================================
167 * FUNKZ
168 * =================================================================== */
169
170 /* Init empty octree */
171 void OOC_Null (OOC_Octree *oct);
172
173
174 /* Initialises octree for records of size recSize with 3D coordinates,
175 * accessed via key() callback. The octree's bounding box is defined by
176 * its origin org and size per axis, and must contain all keys. The
177 * octree is associated with the specified leaf file containing the
178 * records in Morton order */
179 void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
180 RREAL *(*key)(const void*), FILE *leafFile);
181
182
183 /* Allocate new octree node, enlarge array if necessary. Returns pointer
184 to new node or NULL if failed. */
185 OOC_Node *NewNode (OOC_Octree *oct);
186
187
188 /* Reads indexed data record from leaf file and copies it to rec, else
189 * returns -1 on failure */
190 int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec);
191
192
193 /* Appends octree nodes to specified file along with metadata. Uses
194 * RADIANCE's portable I/O routines. Returns 0 on success, else -1. */
195 int OOC_SaveOctree (const OOC_Octree *oct, FILE *nodeFile);
196
197
198 /* Load octree nodes and metadata from nodeFile and associate with
199 * records in leafFile. Uses RADIANCE's portable I/O routines. Returns
200 * 0 on success, else -1. */
201 int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
202 RREAL *(*key)(const void*), FILE *leafFile);
203
204 #ifdef DEBUG_OOC
205 /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
206 * return 0 if ok, otherwise -1 */
207 int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
208 FVECT org, RREAL size, OOC_DataIdx dataIdx);
209 #endif
210
211 /* Check whether key lies within bounding box defined by org and size */
212 int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
213 const FVECT key);
214
215 /* Return index of octant containing key and corresponding origin if
216 * nuOrg = NULL, or -1 if key lies outside all octants. Size is already
217 * assumed to be halved, i.e. corresponding to the length of an octant
218 * axis. */
219 int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
220 const FVECT key, FVECT nuOrg);
221
222 /* Optimised version of OOC_Branch() with precomputed key Morton code */
223 int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
224 OOC_MortonIdx keyZ, FVECT nuOrg);
225
226 /* For a given octree node, return the sum of the data counters for kids
227 * [0..k-1]. On return, the node either points to the k'th kid, or
228 * NULL if the kid is nonexistent or the node is a leaf */
229 OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node,
230 unsigned k);
231
232 /* Self-destruct */
233 void OOC_Delete (OOC_Octree *oct);
234
235 #ifdef __cplusplus
236 }
237 #endif
238
239 /* DID WE MENTION NODES ARE IN POSTFIX ORDAH? */
240 #endif
