root/Development/ray/src/rt/oococt.h
Revision: 2.4
Committed: Tue Sep 17 16:36:04 2024 UTC (13 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.3: +8 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
# User Rev Content
1 greg 2.1 /*
2 rschregle 2.3 ======================================================================
3 greg 2.1 Out-of-core octree data structure
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
7     supported by the Swiss National Science Foundation (SNSF, #147053)
8     ======================================================================
9 greg 2.1
10 greg 2.4 $Id: oococt.h,v 2.3 2016/05/17 17:39:47 rschregle Exp $
11 greg 2.1 */
12
13
14 rschregle 2.3 #ifndef OOC_OCT_H
15     #define OOC_OCT_H
16
17     #include "oocmorton.h"
18     #include "ooccache.h"
19     #include <stdint.h>
20     #include <stdio.h>
21
22
23     /* ===================================================================
24     * CONSTS
25     * =================================================================== */
26
27     /* Octree index & data counter types */
28     typedef uint32_t OOC_NodeIdx;
29     typedef uint32_t OOC_DataIdx;
30     typedef uint8_t OOC_OctCnt;
31
32     /* Octree node field sizes for above */
33     #define OOC_NODEIDX_BITS 31
34     #define OOC_DATAIDX_BITS 32
35
36     /* Limits for above */
37     #define OOC_NODEIDX_MAX ((1L << OOC_NODEIDX_BITS) - 1)
38     #define OOC_DATAIDX_MAX ((1L << OOC_DATAIDX_BITS) - 2)
39     #define OOC_OCTCNT_MAX UINT8_MAX
40
41     /* Reserved values for above */
42     #define OOC_DATAIDX_ERR (OOC_DATAIDX_MAX + 1)
43
44     /* Block size for node allocation (8k) */
45     #define OOC_BLKSIZE (1L << 13)
46
47
48 greg 2.1
49 rschregle 2.3 /* ===================================================================
50     * UTILZ
51     * =================================================================== */
52 greg 2.1
53 rschregle 2.3 /* Test/set leaf flag for node n */
54     #define OOC_ISLEAF(n) ((n) -> node.type)
55     #define OOC_SETLEAF(n) ((n) -> node.type = 1)
56
57     /* Test/set branch bit for octant k in node n */
58     #define OOC_ISBRANCH(n,k) (!OOC_ISLEAF(n) && (n) -> node.branch & 1 << (k))
59     #define OOC_SETBRANCH(n,k) ((n) -> node.branch |= 1 << (k))
60
61     /* Return index to node's 1st kid */
62     #define OOC_KID1(o,n) (!OOC_ISLEAF(n) ? (o)->nodes + (n)->node.kid \
63     : NULL)
64
65     /* Get index to last node in octree; -1 indicates empty octree */
66     #define OOC_ROOTIDX(o) ((o) -> nodes && (o) -> numNodes > 0 \
67     ? (o) -> numNodes - 1 : -1)
68
69     /* Get octree root; this is at the *end* of the node array! */
70     #define OOC_ROOT(o) (OOC_ROOTIDX(o) >= 0 \
71     ? (o) -> nodes + OOC_ROOTIDX(o) : NULL)
72
73     /* Copy node to octree root */
74     #define OOC_SETROOT(o,n) (memcpy(OOC_ROOT(o), (n), sizeof(OOC_Node)))
75
76     /* Set all node fields to 0 */
77     #define OOC_CLEARNODE(n) (memset((n), 0, sizeof(OOC_Node)))
78 greg 2.1
79 rschregle 2.3 /* Modify origin o for octant k of size s */
80     #define OOC_OCTORIGIN(o,k,s) ((o) [0] += (s) * ((k) & 1), \
81     (o) [1] += (s) * ((k) >> 1 & 1), \
82     (o) [2] += (s) * ((k) >> 2 & 1))
83
84     /* Get num records stored in node (also handles leaves and NULL pointer) */
85     #define OOC_DATACNT(n) \
86     ((n) ? OOC_ISLEAF(n) ? (n) -> leaf.num [0] + (n) -> leaf.num [1] + \
87     (n) -> leaf.num [2] + (n) -> leaf.num [3] + \
88     (n) -> leaf.num [4] + (n) -> leaf.num [5] + \
89     (n) -> leaf.num [6] + (n) -> leaf.num [7] \
90     : (n) -> node.num \
91     : 0)
92
93     /* Shortcuts for morton code from key and data record */
94     #define OOC_KEY2MORTON(k, o) OOC_Key2Morton((k), (o) -> org, \
95     (o) -> mortonScale)
96     #define OOC_REC2MORTON(r, o) OOC_Key2Morton((o) -> key(r), (o) -> org, \
97     (o) -> mortonScale)
98
99
100
101     /* ===================================================================
102     * DATA TYPEZ
103     * =================================================================== */
104
105     /* Octree node */
106     typedef struct {
107     union {
108     struct {
109     /* Interior node (node.type = 0) with:
110     node.kid = index to 1st child node in octree array (a.k.a
111     "Number One Son"), immediately followed by its
112     nonzero siblings as indicated by branch
113     node.num = num records stored in this subtree,
114     node.branch = branch bitmask indicating nonzero kid nodes */
115     char type : 1;
116     OOC_NodeIdx kid : OOC_NODEIDX_BITS;
117     OOC_DataIdx num : OOC_DATAIDX_BITS;
118     uint8_t branch;
119
120     /* NOTE that we can't make the kid's index relative to parent
121     * (which would be more compact), since we don't know the
122     * parent's index a priori during the bottom-up construction! */
123     } node;
124
125     struct {
126     /* Leaf node (leaf.type = node.type = 1 with:
127     leaf.num [k] = num records stored in octant k */
128     char type : 1;
129     OOC_OctCnt num [8];
130     } leaf;
131     };
132     } OOC_Node;
133
134
135
136     /* Top level octree container */
137     typedef struct {
138     FVECT org, bound; /* Cube origin (min. XYZ), size, and
139     resulting bounds (max. XYZ) */
140     RREAL size,
141     *(*key)(const void*); /* Callback for data rec coords */
142     RREAL mortonScale; /* Scale factor for generating Morton
143     codes from coords */
144     OOC_Node *nodes; /* Pointer to node array */
145     /* *************************************
146     * **** NODES ARE STORED IN POSTFIX ****
147     * **** ORDER, I.E. ROOT IS LAST! ****
148     * *************************************/
149     OOC_DataIdx numData; /* Num records in leaves */
150     OOC_NodeIdx maxNodes, /* Num currently allocated nodes */
151     numNodes; /* Num used nodes (<= maxNodes) */
152     unsigned recSize, /* Size of data record in bytes */
153     leafMax, /* Max #records per leaf (for build) */
154     maxDepth; /* Max subdivision depth (for build) */
155     FILE *leafFile; /* File containing data in leaves */
156     OOC_Cache *cache; /* I/O cache for leafFile */
157     } OOC_Octree;
158
159     /* DOAN' FORGET: NODES IN ***POSTFIX*** ORDAH!!! */
160
161 greg 2.4 #ifdef __cplusplus
162     extern "C" {
163     #endif
164 rschregle 2.3
165
166     /* ===================================================================
167     * FUNKZ
168     * =================================================================== */
169
170     /* Init empty octree */
171     void OOC_Null (OOC_Octree *oct);
172
173
174     /* Initialises octree for records of size recSize with 3D coordinates,
175     * accessed via key() callback. The octree's bounding box is defined by
176     * its origin org and size per axis, and must contain all keys. The
177     * octree is associated with the specified leaf file containing the
178     * records in Morton order */
179     void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
180     RREAL *(*key)(const void*), FILE *leafFile);
181
182
183     /* Allocate new octree node, enlarge array if necessary. Returns pointer
184     to new node or NULL if failed. */
185     OOC_Node *NewNode (OOC_Octree *oct);
186
187
188     /* Reads indexed data record from leaf file and copies it to rec, else
189     * returns -1 on failure */
190     int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec);
191
192 greg 2.1
193 rschregle 2.3 /* Appends octree nodes to specified file along with metadata. Uses
194     * RADIANCE's portable I/O routines. Returns 0 on success, else -1. */
195     int OOC_SaveOctree (const OOC_Octree *oct, FILE *nodeFile);
196
197
198     /* Load octree nodes and metadata from nodeFile and associate with
199     * records in leafFile. Uses RADIANCE's portable I/O routines. Returns
200     * 0 on success, else -1. */
201     int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
202     RREAL *(*key)(const void*), FILE *leafFile);
203
204     #ifdef DEBUG_OOC
205     /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
206     * return 0 if ok, otherwise -1 */
207     int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
208     FVECT org, RREAL size, OOC_DataIdx dataIdx);
209 greg 2.1 #endif
210
211 rschregle 2.3 /* Check whether key lies within bounding box defined by org and size */
212     int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
213     const FVECT key);
214
215     /* Return index of octant containing key and corresponding origin if
216     * nuOrg = NULL, or -1 if key lies outside all octants. Size is already
217     * assumed to be halved, i.e. corresponding to the length of an octant
218     * axis. */
219     int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
220     const FVECT key, FVECT nuOrg);
221
222     /* Optimised version of OOC_Branch() with precomputed key Morton code */
223     int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
224     OOC_MortonIdx keyZ, FVECT nuOrg);
225
226     /* For a given octree node, return the sum of the data counters for kids
227     * [0..k-1]. On return, the node either points to the k'th kid, or
228     * NULL if the kid is nonexistent or the node is a leaf */
229     OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node,
230     unsigned k);
231
232     /* Self-destruct */
233     void OOC_Delete (OOC_Octree *oct);
234
235 greg 2.4 #ifdef __cplusplus
236     }
237     #endif
238
239 rschregle 2.3 /* DID WE MENTION NODES ARE IN POSTFIX ORDAH? */
240 greg 2.1 #endif
