root/radiance/ray/src/rt/oococt.c
Revision: 2.4
Committed: Mon Aug 14 21:12:10 2017 UTC (8 years ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes since 2.3: +10 -22 lines
Updated photon map code for Windows; no multproc or ooC for now
4
5
6 /*
7 ======================================================================
8 Out-of-core octree data structure
9
10 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11 (c) Lucerne University of Applied Sciences and Arts,
12 supported by the Swiss National Science Foundation (SNSF, #147053)
13 ======================================================================
14
15 $Id: oococt.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
16 */
17
18
19 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
20 /* No Windoze support for now */
21
22 #include "oococt.h"
23 #include "rtio.h"
24 #include <stdlib.h>
25 #include <unistd.h>
26
27
28
29 void OOC_Null (OOC_Octree *oct)
30 /* Init empty octree */
31 {
32 oct -> maxNodes = oct -> numNodes = oct -> leafMax = oct -> maxDepth =
33 oct -> numData = oct -> size = oct -> recSize = oct -> mortonScale = 0;
34 oct -> org [0] = oct -> org [1] = oct -> org [2] =
35 oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = 0;
36 oct -> key = NULL;
37 oct -> nodes = NULL;
38 oct -> leafFile = NULL;
39 oct -> cache = NULL;
40 }
41
42
43
44 void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
45 RREAL *(*key)(const void*), FILE *leafFile)
46 {
47 oct -> maxNodes = oct -> numNodes = oct -> leafMax =
48 oct -> maxDepth = oct -> numData = 0;
49 VCOPY(oct -> org, org);
50 oct -> size = oct -> bound[0] = oct -> bound[1] = oct -> bound[2] = size;
51 VADD(oct -> bound, oct -> bound, org);
52 oct -> mortonScale = size > 0 ? OOC_MORTON_MAX / size : 0;
53 oct -> recSize = recSize;
54 oct -> key = key;
55 oct -> nodes = NULL;
56 oct -> leafFile = leafFile;
57 oct -> cache = NULL; /* Cache currently initialised externally */
58 }
59
60
61
62 OOC_Node *NewNode (OOC_Octree *oct)
63 /* Allocate new octree node, enlarge array if necessary.
64 Return pointer to new node or NULL if failed. */
65 {
66 OOC_Node *n = NULL;
67
68 if (oct -> numNodes >= OOC_NODEIDX_MAX) {
69 /* Node index overflow */
70 fprintf(stderr, "OOC_NewNode: node index overflow (numNodes = %d)\n",
71 oct -> numNodes);
72 return NULL;
73 }
74
75 if (++oct -> numNodes > oct -> maxNodes) {
76 /* Need to allocate root or enlarge array */
77 oct -> maxNodes += OOC_BLKSIZE / sizeof(OOC_Node);
78 oct -> nodes = realloc(oct -> nodes,
79 oct -> maxNodes * sizeof(OOC_Node));
80 if (!oct -> nodes) {
81 perror("OOC_NewNode: couldn't realloc() nodes");
82 return NULL;
83 }
84 }
85
86 n = oct -> nodes + oct -> numNodes - 1;
87 n -> node.num = n -> node.kid = n -> node.branch = n -> node.type = 0;
88
89 return n;
90 }
91
92
93
94 int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec)
95 /* Reads indexed data record from leaf file and copies it to rec, else
96 * returns -1 on failure */
97 {
98 if (!oct || !rec)
99 return -1;
100
101 if (idx >= oct -> numData) {
102 fprintf(stderr, "OOC_GetData: invalid data record index %u\n", idx);
103 return -1;
104 }
105
106 if (oct -> cache) {
107 /* Retrieve record from leaf file via I/O cache */
108 void *cachedRec;
109
110 if (!(cachedRec = OOC_CacheData(oct -> cache, oct -> leafFile, idx)))
111 return -1;
112
113 /* It's safer to copy the record to the caller's local buffer as a
114 * returned pointer may be invalidated by subsequent calls if the
115 * page it points to is swapped out */
116 memcpy(rec, cachedRec, oct -> recSize);
117 }
118 else {
119 /* No I/O caching; do (SLOW!) per-record I/O from leaf file */
120 const unsigned long pos = (unsigned long)oct -> recSize * idx;
121
122 if (pread(fileno(oct -> leafFile), rec, oct -> recSize, pos) !=
123 oct -> recSize) {
124 perror("OOC_GetData: failed seek/read in leaf file");
125 return -1;
126 }
127 }
128
129 return 0;
130 }
131
132
133
134 int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
135 const FVECT key)
136 /* Check whether key lies within bounding box defined by org and size.
137 * Compares Morton codes rather than the coordinates directly to account
138 * for dicretisation error introduced by the former. */
139 {
140 const OOC_MortonIdx keyZ = OOC_KEY2MORTON(key, oct);
141 FVECT bbox = {size, size, size};
142
143 VADD(bbox, org, bbox);
144 return keyZ > OOC_KEY2MORTON(org, oct) &&
145 keyZ < OOC_KEY2MORTON(bbox, oct);
146 }
147
148
149
150 int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
151 const FVECT key, FVECT nuOrg)
152 /* Return index of octant containing key and corresponding origin if nuOrg
153 * != NULL, or -1 if key lies outside all octants. Size is already assumed
154 * to be halved, i.e. corresponding to the length of an octant axis.
155 * Compares Morton codes rather than the coordinates directly to account
156 * for dicretisation error introduced by the former. */
157 {
158 int o;
159 FVECT octOrg;
160
161 for (o = 0; o < 8; o++) {
162 VCOPY(octOrg, org);
163 OOC_OCTORIGIN(octOrg, o, size);
164
165 if (OOC_InBBox(oct, octOrg, size, key)) {
166 if (nuOrg)
167 VCOPY(nuOrg, octOrg);
168
169 return o;
170 }
171 }
172
173 return -1;
174 }
175
176
177
178 int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
179 OOC_MortonIdx keyZ, FVECT nuOrg)
180 /* Optimised version of OOC_Branch() with precomputed key Morton code */
181 {
182 int o;
183 const FVECT cent = {size, size, size};
184 FVECT octOrg, bbox;
185
186 for (o = 0; o < 8; o++) {
187 VCOPY(octOrg, org);
188 OOC_OCTORIGIN(octOrg, o, size);
189 VADD(bbox, octOrg, cent);
190
191 if (keyZ > OOC_KEY2MORTON(octOrg, oct) &&
192 keyZ < OOC_KEY2MORTON(bbox, oct)) {
193 if (nuOrg)
194 VCOPY(nuOrg, octOrg);
195
196 return o;
197 }
198 }
199
200 return -1;
201 }
202
203
204
205 OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node, unsigned kid)
206 /* For a given octree node, return the sum of the data counters for kids
207 * [0..k-1]. On return, the node either points to the k'th kid, or
208 * NULL if the kid is nonexistent or the node is a leaf */
209 {
210 unsigned k;
211 OOC_Node *kidNode = OOC_KID1(oct, *node); /* NULL if leaf */
212 OOC_DataIdx dataIdx = 0;
213
214 for (k = 0; k < kid; k++) {
215 if (OOC_ISLEAF(*node))
216 /* Sum data counters of leaf octants */
217 dataIdx += (*node) -> leaf.num [k];
218 else
219 /* Sum data counter of inner node's nonempty kids and advance
220 * pointer to sibling */
221 if (OOC_ISBRANCH(*node, k)) {
222 dataIdx += OOC_DATACNT(kidNode);
223 kidNode++;
224 }
225 }
226
227 /* Update node pointer to selected kid (or NULL if nonexistent or node is
228 * a leaf) */
229 *node = OOC_ISBRANCH(*node, kid) ? kidNode : NULL;
230 return dataIdx;
231 }
232
233
234
235 #ifdef DEBUG_OOC
236 int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
237 FVECT org, RREAL size, OOC_DataIdx dataIdx)
238 /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
239 * return 0 if ok, otherwise -1 */
240 {
241 unsigned k;
242 FVECT kidOrg;
243 const RREAL kidSize = size * 0.5;
244
245 if (!oct || !node)
246 return -1;
247
248 if (OOC_ISLEAF(node)) {
249 /* Node is a leaf; check records in each octant */
250 char rec [oct -> recSize]; /* Violates C89! */
251 OOC_OctCnt d;
252 RREAL *key;
253
254 for (k = 0; k < 8; k++) {
255 VCOPY(kidOrg, org);
256 OOC_OCTORIGIN(kidOrg, k, kidSize);
257
258 for (d = node -> leaf.num [k]; d; d--, dataIdx++) {
259 #ifdef DEBUG_OOC_CHECK
260 fprintf(stderr, "OOC_Check: checking record %lu\n",
261 (unsigned long)dataIdx);
262 #endif
263 if (OOC_GetData(oct, dataIdx, rec)) {
264 fprintf(stderr, "OOC_Check: failed getting record at %lu\n",
265 (unsigned long)dataIdx);
266 return -1;
267 }
268
269 key = oct -> key(rec);
270 if (!OOC_InBBox(oct, kidOrg, kidSize, key)) {
271 fprintf(stderr, "OOC_Check: key [%f, %f, %f] (zIdx %020lu) "
272 "outside bbox [[%f-%f], [%f-%f], [%f-%f]] "
273 "in octant %d (should be %d)\n",
274 key [0], key [1], key [2],
275 OOC_KEY2MORTON(key, oct),
276 kidOrg [0], kidOrg [0] + kidSize,
277 kidOrg [1], kidOrg [1] + kidSize,
278 kidOrg [2], kidOrg [2] + kidSize,
279 k, OOC_Branch(oct, org, kidSize, key, NULL));
280 /* return -1; */
281 }
282 }
283 }
284 }
285 else {
286 /* Internal node; recurse on all kids */
287 const OOC_Node *kid = OOC_KID1(oct, node);
288 OOC_DataIdx numData = 0;
289
290 if (node -> node.kid >= oct -> numNodes) {
291 fprintf(stderr, "OOC_Check: invalid node index %u\n",
292 node -> node.kid);
293 return -1;
294 }
295
296 if (!node -> node.num) {
297 fputs("OOC_Check: empty octree node\n", stderr);
298 return -1;
299 }
300
301 for (k = 0; k < 8; k++)
302 if (OOC_ISBRANCH(node, k)) {
303 VCOPY(kidOrg, org);
304 OOC_OCTORIGIN(kidOrg, k, kidSize);
305
306 if (OOC_Check(oct, kid, kidOrg, kidSize, dataIdx))
307 return -1;
308
309 dataIdx += OOC_DATACNT(kid);
310 numData += OOC_DATACNT(kid);
311 kid++;
312 }
313
314 if (node -> node.num != numData) {
315 fprintf(stderr,
316 "Parent/kid data count mismatch; expected %u, found %u\n",
317 node -> node.num, numData);
318 return -1;
319 }
320 }
321
322 return 0;
323 }
324 #endif
325
326
327
328 int OOC_SaveOctree (const OOC_Octree *oct, FILE *out)
329 /* Appends octree nodes to specified file along with metadata. Uses
330 * RADIANCE's portable I/O routines. Returns 0 on success, else -1. Note
331 * the internal representation of the nodes is platform specific as they
332 * contain unions, therefore we use the portable I/O routines from the
333 * RADIANCE library */
334 {
335 int i;
336 OOC_NodeIdx nc;
337 OOC_Node *np = NULL;
338
339 if (!oct || !oct->nodes || !oct->numData || !oct->numNodes || !out) {
340 fputs("OOC_SaveOctree: empty octree\n", stderr);
341 return -1;
342 }
343
344 /* Write octree origin, size, data record size, number of records, and
345 * number of nodes */
346 for (i = 0; i < 3; i++)
347 putflt(oct -> org [i], out);
348
349 putflt(oct -> size, out);
350 putint(oct -> recSize, sizeof(oct -> recSize), out);
351 putint(oct -> numData, sizeof(oct -> numData), out);
352 putint(oct -> numNodes, sizeof(oct -> numNodes), out);
353
354 /* Write nodes to file */
355 for (nc = oct -> numNodes, np = oct -> nodes; nc; nc--, np++) {
356 if (OOC_ISLEAF(np)) {
357 /* Write leaf marker */
358 putint(-1, 1, out);
359
360 /* Write leaf octant counters */
361 for (i = 0; i < 8; i++)
362 putint(np -> leaf.num [i], sizeof(np -> leaf.num [i]), out);
363 }
364 else {
365 /* Write node marker */
366 putint(0, 1, out);
367
368 /* Write node, rounding field size up to nearest number of bytes */
369 putint(np -> node.kid, (OOC_NODEIDX_BITS + 7) >> 3, out);
370 putint(np -> node.num, (OOC_DATAIDX_BITS + 7) >> 3, out);
371 putint(np -> node.branch, 1, out);
372 }
373
374 if (ferror(out)) {
375 fputs("OOC_SaveOctree: failed writing to node file", stderr);
376 return -1;
377 }
378 }
379
380 fflush(out);
381 return 0;
382 }
383
384
385
386 int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
387 RREAL *(*key)(const void*), FILE *leafFile)
388 /* Load octree nodes and metadata from nodeFile and associate with records
389 * in leafFile. Uses RADIANCE's portable I/O routines. Returns 0 on
390 * success, else -1. */
391 {
392 int i;
393 OOC_NodeIdx nc;
394 OOC_Node *np = NULL;
395
396 if (!oct || !nodeFile)
397 return -1;
398
399 OOC_Null(oct);
400
401 /* Read octree origin, size, record size, #records and #nodes */
402 for (i = 0; i < 3; i++)
403 oct -> org [i] = getflt(nodeFile);
404
405 oct -> size = getflt(nodeFile);
406 oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = oct -> size;
407 VADD(oct -> bound, oct -> bound, oct -> org);
408 oct -> mortonScale = OOC_MORTON_MAX / oct -> size;
409 oct -> recSize = getint(sizeof(oct -> recSize), nodeFile);
410 oct -> numData = getint(sizeof(oct -> numData), nodeFile);
411 oct -> numNodes = getint(sizeof(oct -> numNodes), nodeFile);
412 oct -> key = key;
413 oct -> leafFile = leafFile;
414
415 if (feof(nodeFile) || !oct -> numData || !oct -> numNodes) {
416 fputs("OOC_LoadOctree: empty octree\n", stderr);
417 return -1;
418 }
419
420 /* Allocate octree nodes */
421 if (!(oct -> nodes = calloc(oct -> numNodes, sizeof(OOC_Node)))) {
422 fputs("OOC_LoadOctree: failed octree allocation\n", stderr);
423 return -1;
424 }
425
426 /* Read nodes from file */
427 for (nc = oct -> numNodes, np = oct -> nodes; nc; nc--, np++) {
428 OOC_CLEARNODE(np);
429
430 /* Read node type marker */
431 if (getint(1, nodeFile)) {
432 /* Read leaf octant counters and set node type */
433 for (i = 0; i < 8; i++)
434 np -> leaf.num [i] = getint(sizeof(np -> leaf.num [i]),
435 nodeFile);
436
437 OOC_SETLEAF(np);
438 }
439 else {
440 /* Read node, rounding field size up to nearest number of bytes */
441 np -> node.kid = getint((OOC_NODEIDX_BITS + 7) >> 3, nodeFile);
442 np -> node.num = getint((OOC_DATAIDX_BITS + 7) >> 3, nodeFile);
443 np -> node.branch = getint(1, nodeFile);
444 }
445
446 if (ferror(nodeFile)) {
447 fputs("OOC_LoadOctree: failed reading from node file\n", stderr);
448 return -1;
449 }
450 }
451
452 return 0;
453 }
454
455
456
457 void OOC_Delete (OOC_Octree *oct)
458 /* Self-destruct */
459 {
460 free(oct -> nodes);
461 fclose(oct -> leafFile);
462
463 if (oct -> cache)
464 OOC_DeleteCache(oct -> cache);
465 }
466
467 #endif /* NIX / PMAP_OOC */
