root/radiance/ray/src/rt/oococt.c
Revision: 2.1
Committed: Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
1 /*
2 ==================================================================
3 Out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Fraunhofer Institute for Solar Energy Systems,
7 Lucerne University of Applied Sciences & Arts
8 ==================================================================
9
10 $Id$
11 */
12
13
14 #include <stdlib.h>
15 #include "oococt.h"
16 #include "oocsort.h"
17
18
19 static OOC_Sort_Key zInterleave (OOC_Sort_Key k)
20 /* Interleave lower 21 bits of k with 00, resulting in 63 bits.
21 This code taken from
22 http://www.forceflow.be/2013/10/07/
23 morton-encodingdecoding-through-bit-interleaving-implementations/ */
24 {
25 /* Mask out lower 21 bits, the rest is cryptic */
26 OOC_Sort_Key i = k & 0x1fffff;
27
28 i = (i | i << 32) & 0x001f00000000ffff;
29 i = (i | i << 16) & 0x001f0000ff0000ff;
30 i = (i | i << 8) & 0x100f00f00f00f00f;
31 i = (i | i << 4) & 0x10c30c30c30c30c3;
32 i = (i | i << 2) & 0x1249249249249249;
33
34 return i;
35 }
36
37
38 static OOC_Sort_Key Key2zOrder (OOC_Octree *oct, FVECT key)
39 /* Compute 63-bit Morton (Z-order) index for 3D key */
40 {
41 int i;
42 OOC_Sort_Key k [3];
43
44 /* Normalise key and map to 21-bit int */
45 for (i = 0; i < 3; i++)
46 k [i] = (((OOC_Sort_Key)1 << 21) - 1) / oct -> size *
47 (key [i] - oct -> org [i]);
48
49 /* Interleave each dim with zeros and merge */
50 return zInterleave(k [0]) | zInterleave(k [1]) << 1 |
51 zInterleave(k [2]) << 2;
52 }
53
54
55 static OOC_Node *NewNode (OOC_Octree *oct)
56 /* Allocate new octree node, enlarge array if necessary.
57 Return pointer to new node or NULL if failed. */
58 {
59 OOC_Node *n = NULL;
60
61 if (++oct -> numNodes > oct -> maxNodes) {
62 /* Need to allocate root or enlarge array */
63 oct -> maxNodes += OOC_BLKSIZE / sizeof(OOC_Node);
64 realloc(oct -> root, oct -> maxNodes * sizeof(OOC_Node));
65 if (!oct -> root)
66 return NULL;
67 }
68
69 n = oct -> root + oct -> numNodes - 1;
70 n -> num = n -> kid = 0;
71 }
72
73
74 int OOC_Init (OOC_Octree *oct, unsigned recSize, unsigned leafMax,
75 unsigned maxDepth)
76 {
77 ooc -> org [0] = oct -> org [1] = oct -> org [2] = FHUGE;
78 ooc -> size = oct -> maxNodes = oct -> lastNode = 0;
79 ooc -> recSize = recSize;
80 ooc -> leafMax = leafMax;
81 ooc -> maxDepth = maxDepth;
82 ooc -> root = NULL;
83
84 return NewNode(oct) ? 0 : -1;
85 }
86
87
88 int OOC_Branch (FVECT key, FVECT org, RREAL *size);
89 /* Return index of kid containing key, update origin and size accordingly */
90 {
91 size *= 0.5;
92 int kidIdx = 0;
93
94 for (int i = 0; i < 3; i++) {
95 RREAL cent = org [i] + size;
96 if (key [i] > cent) {
97 kidIdx |= 1 << i;
98 org [i] = cent;
99 }
100 }
101
102 return kidIdx;
103 }
104
105
106 OOC_Idx OOC_Find (OOC_Octree *oct, FVECT key)
107 /* Iterative search for given key */
108 {
109 FVECT org;
110 RREAL size;
111 OOC_Idx dataIdx = 0;
112 OOC_Node *node = NULL;
113
114 if (!oct || !oct -> root)
115 return -1;
116
117 node = oct -> root;
118 VCOPY(org, oct -> org);
119 size = oct -> size;
120
121 /* Quit at terminal/empty node or internal leaf */
122 while (OOC_INTNODE(*node)) {
123 /* Determine kid to branch into and update data index with skipped
124 * kids' data counts */
125 int kidIdx = OOC_Branch(key, org, size);
126 node = oct -> root + OOC_KID(*node);
127 while (kidIdx--)
128 dataIdx += OOC_NUMDATA(node++);
129 }
130
131 /* Reached empty node -> not found */
132 if (OOC_EMPTYNODE(*node))
133 return -1;
134
135 /* Reached terminal node -> find leaf to branch into and update data
136 * index with skipped leaves' data counts */
137 if (OOC_TERMNODE(*node)) {
138 OOC_Leaf *leaf = ooc -> leaves [OOC_KID(*node)];
139 int leafIdx = OOC_Branch(key, org, size);
140 while (leafIdx--)
141 dataIdx += *leaf++;
142 }
143
144 /* (Reached internal leaf -> already have data index) */
145 return dataIdx;
146 }
147
148
149 #if 0
150 OOC_Node *FindNode (OOC_Octree *oct, FVECT key, OOC_Idx *dataIdx, int flags)
151 /* ITERATIVE node search for given key */
152 {
153 FVECT org;
154 double size;
155 OOC_Idx dataIdx = 0;
156 OOC_Node *node = NULL;
157
158 if (!oct || !oct -> root)
159 return NULL;
160
161 node = oct -> root;
162 VCOPY(org, oct -> org);
163 size = oct -> size;
164
165 /* Quit at terminal or empty node */
166 while (!OOC_TERM(*node) && !OOC_EMPTY(*node)) {
167 size *= 0.5;
168 int kidIdx = 0;
169
170 /* Determine kid to branch into and update origin accordingly */
171 for (int i = 0; i < 3; i++) {
172 RREAL cent = org [i] + size;
173 if (key [i] > cent) {
174 kidIdx |= 1 << i;
175 org [i] = cent;
176 }
177 }
178
179 /* Increment node's data counter if inserting */
180 if (flags & OOC_INSERT)
181 node -> numData++;
182
183 /* Update data index with skipped kids' data counts */
184 node = oct -> root + node -> kid;
185 while (kidIdx--)
186 dataIdx += node++ -> numData;
187 }
188
189 return node;
190 }
191
192
193 OOC_Idx FindLeaf (OOC_Leaf *leaf, FVECT key, OOC_Idx *dataIdx);
194 /* Return index into data block for leaf containing key */
195 {
196 int kidIdx = 0;
197 OOC_Idx =
198
199 for (int i = 0; i < 3; i++) {
200 if (key [i]
201 #endif
