| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
| 8 |
Out-of-core octree data structure
| 9 |
| 10 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 11 |
(c) Lucerne University of Applied Sciences and Arts,
| 12 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 13 |
| 14 |
| 15 |
$Id: oococt.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
| 16 |
| 17 |
| 18 |
| 19 |
#if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
| 20 |
/* No Windoze support for now */
| 21 |
| 22 |
#include "oococt.h"
| 23 |
#include "rtio.h"
| 24 |
#include <stdlib.h>
| 25 |
#include <unistd.h>
| 26 |
| 27 |
| 28 |
| 29 |
void OOC_Null (OOC_Octree *oct)
| 30 |
/* Init empty octree */
| 31 |
| 32 |
oct -> maxNodes = oct -> numNodes = oct -> leafMax = oct -> maxDepth =
| 33 |
oct -> numData = oct -> size = oct -> recSize = oct -> mortonScale = 0;
| 34 |
oct -> org [0] = oct -> org [1] = oct -> org [2] =
| 35 |
oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = 0;
| 36 |
oct -> key = NULL;
| 37 |
oct -> nodes = NULL;
| 38 |
oct -> leafFile = NULL;
| 39 |
oct -> cache = NULL;
| 40 |
| 41 |
| 42 |
| 43 |
| 44 |
void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
| 45 |
RREAL *(*key)(const void*), FILE *leafFile)
| 46 |
| 47 |
| 48 |
oct -> maxDepth = oct -> numData = 0;
| 49 |
VCOPY(oct -> org, org);
| 50 |
oct -> size = oct -> bound[0] = oct -> bound[1] = oct -> bound[2] = size;
| 51 |
VADD(oct -> bound, oct -> bound, org);
| 52 |
oct -> mortonScale = size > 0 ? OOC_MORTON_MAX / size : 0;
| 53 |
oct -> recSize = recSize;
| 54 |
oct -> key = key;
| 55 |
| 56 |
oct -> leafFile = leafFile;
| 57 |
oct -> cache = NULL; /* Cache currently initialised externally */
| 58 |
| 59 |
| 60 |
| 61 |
| 62 |
OOC_Node *NewNode (OOC_Octree *oct)
| 63 |
/* Allocate new octree node, enlarge array if necessary.
| 64 |
Return pointer to new node or NULL if failed. */
| 65 |
| 66 |
OOC_Node *n = NULL;
| 67 |
| 68 |
if (oct -> numNodes >= OOC_NODEIDX_MAX) {
| 69 |
/* Node index overflow */
| 70 |
fprintf(stderr, "OOC_NewNode: node index overflow (numNodes = %d)\n",
| 71 |
oct -> numNodes);
| 72 |
return NULL;
| 73 |
| 74 |
| 75 |
if (++oct -> numNodes > oct -> maxNodes) {
| 76 |
/* Need to allocate root or enlarge array */
| 77 |
oct -> maxNodes += OOC_BLKSIZE / sizeof(OOC_Node);
| 78 |
oct -> nodes = realloc(oct -> nodes,
| 79 |
oct -> maxNodes * sizeof(OOC_Node));
| 80 |
if (!oct -> nodes) {
| 81 |
perror("OOC_NewNode: couldn't realloc() nodes");
| 82 |
return NULL;
| 83 |
| 84 |
| 85 |
| 86 |
n = oct -> nodes + oct -> numNodes - 1;
| 87 |
n -> node.num = n -> node.kid = n -> node.branch = n -> node.type = 0;
| 88 |
| 89 |
return n;
| 90 |
| 91 |
| 92 |
| 93 |
| 94 |
int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec)
| 95 |
/* Reads indexed data record from leaf file and copies it to rec, else
| 96 |
* returns -1 on failure */
| 97 |
| 98 |
if (!oct || !rec)
| 99 |
return -1;
| 100 |
| 101 |
if (idx >= oct -> numData) {
| 102 |
fprintf(stderr, "OOC_GetData: invalid data record index %u\n", idx);
| 103 |
return -1;
| 104 |
| 105 |
| 106 |
if (oct -> cache) {
| 107 |
/* Retrieve record from leaf file via I/O cache */
| 108 |
void *cachedRec;
| 109 |
| 110 |
if (!(cachedRec = OOC_CacheData(oct -> cache, oct -> leafFile, idx)))
| 111 |
return -1;
| 112 |
| 113 |
/* It's safer to copy the record to the caller's local buffer as a
| 114 |
* returned pointer may be invalidated by subsequent calls if the
| 115 |
* page it points to is swapped out */
| 116 |
memcpy(rec, cachedRec, oct -> recSize);
| 117 |
| 118 |
else {
| 119 |
/* No I/O caching; do (SLOW!) per-record I/O from leaf file */
| 120 |
const unsigned long pos = (unsigned long)oct -> recSize * idx;
| 121 |
| 122 |
if (pread(fileno(oct -> leafFile), rec, oct -> recSize, pos) !=
| 123 |
oct -> recSize) {
| 124 |
perror("OOC_GetData: failed seek/read in leaf file");
| 125 |
return -1;
| 126 |
| 127 |
| 128 |
| 129 |
return 0;
| 130 |
| 131 |
| 132 |
| 133 |
| 134 |
int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
| 135 |
const FVECT key)
| 136 |
/* Check whether key lies within bounding box defined by org and size.
| 137 |
* Compares Morton codes rather than the coordinates directly to account
| 138 |
* for dicretisation error introduced by the former. */
| 139 |
| 140 |
const OOC_MortonIdx keyZ = OOC_KEY2MORTON(key, oct);
| 141 |
FVECT bbox = {size, size, size};
| 142 |
| 143 |
VADD(bbox, org, bbox);
| 144 |
return keyZ > OOC_KEY2MORTON(org, oct) &&
| 145 |
keyZ < OOC_KEY2MORTON(bbox, oct);
| 146 |
| 147 |
| 148 |
| 149 |
| 150 |
int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
| 151 |
const FVECT key, FVECT nuOrg)
| 152 |
/* Return index of octant containing key and corresponding origin if nuOrg
| 153 |
* != NULL, or -1 if key lies outside all octants. Size is already assumed
| 154 |
* to be halved, i.e. corresponding to the length of an octant axis.
| 155 |
| 156 |
| 157 |
| 158 |
int o;
| 159 |
FVECT octOrg;
| 160 |
| 161 |
for (o = 0; o < 8; o++) {
| 162 |
VCOPY(octOrg, org);
| 163 |
OOC_OCTORIGIN(octOrg, o, size);
| 164 |
| 165 |
if (OOC_InBBox(oct, octOrg, size, key)) {
| 166 |
if (nuOrg)
| 167 |
VCOPY(nuOrg, octOrg);
| 168 |
| 169 |
return o;
| 170 |
| 171 |
| 172 |
| 173 |
return -1;
| 174 |
| 175 |
| 176 |
| 177 |
| 178 |
int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
| 179 |
OOC_MortonIdx keyZ, FVECT nuOrg)
| 180 |
/* Optimised version of OOC_Branch() with precomputed key Morton code */
| 181 |
| 182 |
int o;
| 183 |
const FVECT cent = {size, size, size};
| 184 |
FVECT octOrg, bbox;
| 185 |
| 186 |
| 187 |
VCOPY(octOrg, org);
| 188 |
| 189 |
VADD(bbox, octOrg, cent);
| 190 |
| 191 |
if (keyZ > OOC_KEY2MORTON(octOrg, oct) &&
| 192 |
keyZ < OOC_KEY2MORTON(bbox, oct)) {
| 193 |
if (nuOrg)
| 194 |
| 195 |
| 196 |
return o;
| 197 |
| 198 |
| 199 |
| 200 |
return -1;
| 201 |
| 202 |
| 203 |
| 204 |
| 205 |
OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node, unsigned kid)
| 206 |
/* For a given octree node, return the sum of the data counters for kids
| 207 |
* [0..k-1]. On return, the node either points to the k'th kid, or
| 208 |
* NULL if the kid is nonexistent or the node is a leaf */
| 209 |
| 210 |
unsigned k;
| 211 |
OOC_Node *kidNode = OOC_KID1(oct, *node); /* NULL if leaf */
| 212 |
OOC_DataIdx dataIdx = 0;
| 213 |
| 214 |
for (k = 0; k < kid; k++) {
| 215 |
if (OOC_ISLEAF(*node))
| 216 |
/* Sum data counters of leaf octants */
| 217 |
dataIdx += (*node) -> leaf.num [k];
| 218 |
else
| 219 |
/* Sum data counter of inner node's nonempty kids and advance
| 220 |
* pointer to sibling */
| 221 |
if (OOC_ISBRANCH(*node, k)) {
| 222 |
dataIdx += OOC_DATACNT(kidNode);
| 223 |
kidNode++;
| 224 |
| 225 |
| 226 |
| 227 |
/* Update node pointer to selected kid (or NULL if nonexistent or node is
| 228 |
* a leaf) */
| 229 |
*node = OOC_ISBRANCH(*node, kid) ? kidNode : NULL;
| 230 |
return dataIdx;
| 231 |
| 232 |
| 233 |
| 234 |
| 235 |
#ifdef DEBUG_OOC
| 236 |
int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
| 237 |
FVECT org, RREAL size, OOC_DataIdx dataIdx)
| 238 |
/* Traverse tree & check for valid nodes; oct -> leafFile must be open;
| 239 |
* return 0 if ok, otherwise -1 */
| 240 |
| 241 |
unsigned k;
| 242 |
FVECT kidOrg;
| 243 |
const RREAL kidSize = size * 0.5;
| 244 |
| 245 |
if (!oct || !node)
| 246 |
return -1;
| 247 |
| 248 |
if (OOC_ISLEAF(node)) {
| 249 |
/* Node is a leaf; check records in each octant */
| 250 |
char rec [oct -> recSize]; /* Violates C89! */
| 251 |
OOC_OctCnt d;
| 252 |
RREAL *key;
| 253 |
| 254 |
for (k = 0; k < 8; k++) {
| 255 |
VCOPY(kidOrg, org);
| 256 |
OOC_OCTORIGIN(kidOrg, k, kidSize);
| 257 |
| 258 |
for (d = node -> leaf.num [k]; d; d--, dataIdx++) {
| 259 |
#ifdef DEBUG_OOC_CHECK
| 260 |
fprintf(stderr, "OOC_Check: checking record %lu\n",
| 261 |
(unsigned long)dataIdx);
| 262 |
#endif
| 263 |
if (OOC_GetData(oct, dataIdx, rec)) {
| 264 |
fprintf(stderr, "OOC_Check: failed getting record at %lu\n",
| 265 |
| 266 |
return -1;
| 267 |
| 268 |
| 269 |
key = oct -> key(rec);
| 270 |
if (!OOC_InBBox(oct, kidOrg, kidSize, key)) {
| 271 |
fprintf(stderr, "OOC_Check: key [%f, %f, %f] (zIdx %020lu) "
| 272 |
"outside bbox [[%f-%f], [%f-%f], [%f-%f]] "
| 273 |
"in octant %d (should be %d)\n",
| 274 |
key [0], key [1], key [2],
| 275 |
OOC_KEY2MORTON(key, oct),
| 276 |
kidOrg [0], kidOrg [0] + kidSize,
| 277 |
kidOrg [1], kidOrg [1] + kidSize,
| 278 |
kidOrg [2], kidOrg [2] + kidSize,
| 279 |
k, OOC_Branch(oct, org, kidSize, key, NULL));
| 280 |
/* return -1; */
| 281 |
| 282 |
| 283 |
| 284 |
| 285 |
else {
| 286 |
/* Internal node; recurse on all kids */
| 287 |
const OOC_Node *kid = OOC_KID1(oct, node);
| 288 |
OOC_DataIdx numData = 0;
| 289 |
| 290 |
if (node -> node.kid >= oct -> numNodes) {
| 291 |
fprintf(stderr, "OOC_Check: invalid node index %u\n",
| 292 |
node -> node.kid);
| 293 |
return -1;
| 294 |
| 295 |
| 296 |
if (!node -> node.num) {
| 297 |
fputs("OOC_Check: empty octree node\n", stderr);
| 298 |
return -1;
| 299 |
| 300 |
| 301 |
| 302 |
if (OOC_ISBRANCH(node, k)) {
| 303 |
VCOPY(kidOrg, org);
| 304 |
| 305 |
| 306 |
if (OOC_Check(oct, kid, kidOrg, kidSize, dataIdx))
| 307 |
return -1;
| 308 |
| 309 |
dataIdx += OOC_DATACNT(kid);
| 310 |
numData += OOC_DATACNT(kid);
| 311 |
kid++;
| 312 |
| 313 |
| 314 |
if (node -> node.num != numData) {
| 315 |
fprintf(stderr,
| 316 |
"Parent/kid data count mismatch; expected %u, found %u\n",
| 317 |
node -> node.num, numData);
| 318 |
return -1;
| 319 |
| 320 |
| 321 |
| 322 |
return 0;
| 323 |
| 324 |
#endif
| 325 |
| 326 |
| 327 |
| 328 |
int OOC_SaveOctree (const OOC_Octree *oct, FILE *out)
| 329 |
/* Appends octree nodes to specified file along with metadata. Uses
| 330 |
* RADIANCE's portable I/O routines. Returns 0 on success, else -1. Note
| 331 |
* the internal representation of the nodes is platform specific as they
| 332 |
* contain unions, therefore we use the portable I/O routines from the
| 333 |
* RADIANCE library */
| 334 |
| 335 |
int i;
| 336 |
OOC_NodeIdx nc;
| 337 |
OOC_Node *np = NULL;
| 338 |
| 339 |
if (!oct || !oct->nodes || !oct->numData || !oct->numNodes || !out) {
| 340 |
fputs("OOC_SaveOctree: empty octree\n", stderr);
| 341 |
return -1;
| 342 |
| 343 |
| 344 |
/* Write octree origin, size, data record size, number of records, and
| 345 |
* number of nodes */
| 346 |
for (i = 0; i < 3; i++)
| 347 |
putflt(oct -> org [i], out);
| 348 |
| 349 |
putflt(oct -> size, out);
| 350 |
putint(oct -> recSize, sizeof(oct -> recSize), out);
| 351 |
putint(oct -> numData, sizeof(oct -> numData), out);
| 352 |
putint(oct -> numNodes, sizeof(oct -> numNodes), out);
| 353 |
| 354 |
/* Write nodes to file */
| 355 |
for (nc = oct -> numNodes, np = oct -> nodes; nc; nc--, np++) {
| 356 |
if (OOC_ISLEAF(np)) {
| 357 |
/* Write leaf marker */
| 358 |
putint(-1, 1, out);
| 359 |
| 360 |
/* Write leaf octant counters */
| 361 |
for (i = 0; i < 8; i++)
| 362 |
putint(np -> leaf.num [i], sizeof(np -> leaf.num [i]), out);
| 363 |
| 364 |
else {
| 365 |
/* Write node marker */
| 366 |
putint(0, 1, out);
| 367 |
| 368 |
/* Write node, rounding field size up to nearest number of bytes */
| 369 |
putint(np -> node.kid, (OOC_NODEIDX_BITS + 7) >> 3, out);
| 370 |
putint(np -> node.num, (OOC_DATAIDX_BITS + 7) >> 3, out);
| 371 |
putint(np -> node.branch, 1, out);
| 372 |
| 373 |
| 374 |
if (ferror(out)) {
| 375 |
fputs("OOC_SaveOctree: failed writing to node file", stderr);
| 376 |
return -1;
| 377 |
| 378 |
| 379 |
| 380 |
fflush(out);
| 381 |
return 0;
| 382 |
| 383 |
| 384 |
| 385 |
| 386 |
int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
| 387 |
| 388 |
/* Load octree nodes and metadata from nodeFile and associate with records
| 389 |
* in leafFile. Uses RADIANCE's portable I/O routines. Returns 0 on
| 390 |
* success, else -1. */
| 391 |
| 392 |
int i;
| 393 |
OOC_NodeIdx nc;
| 394 |
| 395 |
| 396 |
if (!oct || !nodeFile)
| 397 |
return -1;
| 398 |
| 399 |
OOC_Null(oct);
| 400 |
| 401 |
/* Read octree origin, size, record size, #records and #nodes */
| 402 |
| 403 |
oct -> org [i] = getflt(nodeFile);
| 404 |
| 405 |
oct -> size = getflt(nodeFile);
| 406 |
oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = oct -> size;
| 407 |
VADD(oct -> bound, oct -> bound, oct -> org);
| 408 |
oct -> mortonScale = OOC_MORTON_MAX / oct -> size;
| 409 |
oct -> recSize = getint(sizeof(oct -> recSize), nodeFile);
| 410 |
oct -> numData = getint(sizeof(oct -> numData), nodeFile);
| 411 |
oct -> numNodes = getint(sizeof(oct -> numNodes), nodeFile);
| 412 |
oct -> key = key;
| 413 |
| 414 |
| 415 |
if (feof(nodeFile) || !oct -> numData || !oct -> numNodes) {
| 416 |
fputs("OOC_LoadOctree: empty octree\n", stderr);
| 417 |
return -1;
| 418 |
| 419 |
| 420 |
/* Allocate octree nodes */
| 421 |
if (!(oct -> nodes = calloc(oct -> numNodes, sizeof(OOC_Node)))) {
| 422 |
fputs("OOC_LoadOctree: failed octree allocation\n", stderr);
| 423 |
return -1;
| 424 |
| 425 |
| 426 |
/* Read nodes from file */
| 427 |
| 428 |
OOC_CLEARNODE(np);
| 429 |
| 430 |
/* Read node type marker */
| 431 |
if (getint(1, nodeFile)) {
| 432 |
/* Read leaf octant counters and set node type */
| 433 |
| 434 |
np -> leaf.num [i] = getint(sizeof(np -> leaf.num [i]),
| 435 |
nodeFile);
| 436 |
| 437 |
OOC_SETLEAF(np);
| 438 |
| 439 |
else {
| 440 |
/* Read node, rounding field size up to nearest number of bytes */
| 441 |
np -> node.kid = getint((OOC_NODEIDX_BITS + 7) >> 3, nodeFile);
| 442 |
np -> node.num = getint((OOC_DATAIDX_BITS + 7) >> 3, nodeFile);
| 443 |
np -> node.branch = getint(1, nodeFile);
| 444 |
| 445 |
| 446 |
if (ferror(nodeFile)) {
| 447 |
fputs("OOC_LoadOctree: failed reading from node file\n", stderr);
| 448 |
return -1;
| 449 |
| 450 |
| 451 |
| 452 |
return 0;
| 453 |
| 454 |
| 455 |
| 456 |
| 457 |
void OOC_Delete (OOC_Octree *oct)
| 458 |
/* Self-destruct */
| 459 |
| 460 |
free(oct -> nodes);
| 461 |
fclose(oct -> leafFile);
| 462 |
| 463 |
if (oct -> cache)
| 464 |
OOC_DeleteCache(oct -> cache);
| 465 |
| 466 |
| 467 |
#endif /* NIX / PMAP_OOC */
