root/Development/ray/src/rt/oococt.c
Revision: 2.4
Committed: Mon Aug 14 21:12:10 2017 UTC (8 years, 4 months ago) by rschregle
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 2.3: +10 -22 lines
Updated photon map code for Windows; no multproc or ooC for now
# User Rev Content
1 rschregle 2.4 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4
5
6 greg 2.1 /*
7 rschregle 2.3 ======================================================================
8 greg 2.1 Out-of-core octree data structure
9
10     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
12     supported by the Swiss National Science Foundation (SNSF, #147053)
13     ======================================================================
14 greg 2.1
15 rschregle 2.4 $Id: oococt.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
16 greg 2.1 */
17
18
19 rschregle 2.4 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
20     /* No Windoze support for now */
21 rschregle 2.3
22     #include "oococt.h"
23     #include "rtio.h"
24 greg 2.1 #include <stdlib.h>
25 rschregle 2.3 #include <unistd.h>
26
27 greg 2.1
28
29 rschregle 2.3 void OOC_Null (OOC_Octree *oct)
30     /* Init empty octree */
31 greg 2.1 {
32 rschregle 2.3 oct -> maxNodes = oct -> numNodes = oct -> leafMax = oct -> maxDepth =
33     oct -> numData = oct -> size = oct -> recSize = oct -> mortonScale = 0;
34     oct -> org [0] = oct -> org [1] = oct -> org [2] =
35     oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = 0;
36     oct -> key = NULL;
37     oct -> nodes = NULL;
38     oct -> leafFile = NULL;
39     oct -> cache = NULL;
40 greg 2.1 }
41
42
43 rschregle 2.3
44     void OOC_Init (OOC_Octree *oct, unsigned recSize, FVECT org, RREAL size,
45     RREAL *(*key)(const void*), FILE *leafFile)
46 greg 2.1 {
47 rschregle 2.3 oct -> maxNodes = oct -> numNodes = oct -> leafMax =
48     oct -> maxDepth = oct -> numData = 0;
49     VCOPY(oct -> org, org);
50     oct -> size = oct -> bound[0] = oct -> bound[1] = oct -> bound[2] = size;
51     VADD(oct -> bound, oct -> bound, org);
52     oct -> mortonScale = size > 0 ? OOC_MORTON_MAX / size : 0;
53     oct -> recSize = recSize;
54     oct -> key = key;
55     oct -> nodes = NULL;
56     oct -> leafFile = leafFile;
57     oct -> cache = NULL; /* Cache currently initialised externally */
58 greg 2.1 }
59
60 rschregle 2.3
61
62     OOC_Node *NewNode (OOC_Octree *oct)
63 greg 2.1 /* Allocate new octree node, enlarge array if necessary.
64     Return pointer to new node or NULL if failed. */
65     {
66     OOC_Node *n = NULL;
67 rschregle 2.3
68     if (oct -> numNodes >= OOC_NODEIDX_MAX) {
69     /* Node index overflow */
70     fprintf(stderr, "OOC_NewNode: node index overflow (numNodes = %d)\n",
71     oct -> numNodes);
72     return NULL;
73     }
74
75 greg 2.1 if (++oct -> numNodes > oct -> maxNodes) {
76     /* Need to allocate root or enlarge array */
77     oct -> maxNodes += OOC_BLKSIZE / sizeof(OOC_Node);
78 rschregle 2.3 oct -> nodes = realloc(oct -> nodes,
79     oct -> maxNodes * sizeof(OOC_Node));
80     if (!oct -> nodes) {
81     perror("OOC_NewNode: couldn't realloc() nodes");
82 greg 2.1 return NULL;
83 rschregle 2.3 }
84 greg 2.1 }
85
86 rschregle 2.3 n = oct -> nodes + oct -> numNodes - 1;
87     n -> node.num = n -> node.kid = n -> node.branch = n -> node.type = 0;
88
89     return n;
90 greg 2.1 }
91
92 rschregle 2.3
93
94     int OOC_GetData (OOC_Octree *oct, OOC_DataIdx idx, void *rec)
95     /* Reads indexed data record from leaf file and copies it to rec, else
96     * returns -1 on failure */
97 greg 2.1 {
98 rschregle 2.3 if (!oct || !rec)
99     return -1;
100
101     if (idx >= oct -> numData) {
102     fprintf(stderr, "OOC_GetData: invalid data record index %u\n", idx);
103     return -1;
104     }
105
106     if (oct -> cache) {
107     /* Retrieve record from leaf file via I/O cache */
108     void *cachedRec;
109
110     if (!(cachedRec = OOC_CacheData(oct -> cache, oct -> leafFile, idx)))
111     return -1;
112
113     /* It's safer to copy the record to the caller's local buffer as a
114     * returned pointer may be invalidated by subsequent calls if the
115     * page it points to is swapped out */
116     memcpy(rec, cachedRec, oct -> recSize);
117     }
118     else {
119     /* No I/O caching; do (SLOW!) per-record I/O from leaf file */
120     const unsigned long pos = (unsigned long)oct -> recSize * idx;
121
122     if (pread(fileno(oct -> leafFile), rec, oct -> recSize, pos) !=
123     oct -> recSize) {
124     perror("OOC_GetData: failed seek/read in leaf file");
125     return -1;
126     }
127     }
128 greg 2.1
129 rschregle 2.3 return 0;
130 greg 2.1 }
131
132
133 rschregle 2.3
134     int OOC_InBBox (const OOC_Octree *oct, const FVECT org, RREAL size,
135     const FVECT key)
136     /* Check whether key lies within bounding box defined by org and size.
137     * Compares Morton codes rather than the coordinates directly to account
138     * for dicretisation error introduced by the former. */
139     {
140     const OOC_MortonIdx keyZ = OOC_KEY2MORTON(key, oct);
141     FVECT bbox = {size, size, size};
142
143     VADD(bbox, org, bbox);
144     return keyZ > OOC_KEY2MORTON(org, oct) &&
145     keyZ < OOC_KEY2MORTON(bbox, oct);
146     }
147
148
149
150     int OOC_Branch (const OOC_Octree *oct, const FVECT org, RREAL size,
151     const FVECT key, FVECT nuOrg)
152     /* Return index of octant containing key and corresponding origin if nuOrg
153     * != NULL, or -1 if key lies outside all octants. Size is already assumed
154     * to be halved, i.e. corresponding to the length of an octant axis.
155     * Compares Morton codes rather than the coordinates directly to account
156     * for dicretisation error introduced by the former. */
157 greg 2.1 {
158 rschregle 2.3 int o;
159     FVECT octOrg;
160 greg 2.1
161 rschregle 2.3 for (o = 0; o < 8; o++) {
162     VCOPY(octOrg, org);
163     OOC_OCTORIGIN(octOrg, o, size);
164
165     if (OOC_InBBox(oct, octOrg, size, key)) {
166     if (nuOrg)
167     VCOPY(nuOrg, octOrg);
168
169     return o;
170 greg 2.1 }
171     }
172
173 rschregle 2.3 return -1;
174 greg 2.1 }
175
176
177 rschregle 2.3
178     int OOC_BranchZ (const OOC_Octree *oct, const FVECT org, RREAL size,
179     OOC_MortonIdx keyZ, FVECT nuOrg)
180     /* Optimised version of OOC_Branch() with precomputed key Morton code */
181 greg 2.1 {
182 rschregle 2.3 int o;
183     const FVECT cent = {size, size, size};
184     FVECT octOrg, bbox;
185
186     for (o = 0; o < 8; o++) {
187     VCOPY(octOrg, org);
188     OOC_OCTORIGIN(octOrg, o, size);
189     VADD(bbox, octOrg, cent);
190
191     if (keyZ > OOC_KEY2MORTON(octOrg, oct) &&
192     keyZ < OOC_KEY2MORTON(bbox, oct)) {
193     if (nuOrg)
194     VCOPY(nuOrg, octOrg);
195
196     return o;
197     }
198     }
199 greg 2.1
200 rschregle 2.3 return -1;
201     }
202
203
204
205     OOC_DataIdx OOC_GetKid (const OOC_Octree *oct, OOC_Node **node, unsigned kid)
206     /* For a given octree node, return the sum of the data counters for kids
207     * [0..k-1]. On return, the node either points to the k'th kid, or
208     * NULL if the kid is nonexistent or the node is a leaf */
209     {
210     unsigned k;
211     OOC_Node *kidNode = OOC_KID1(oct, *node); /* NULL if leaf */
212     OOC_DataIdx dataIdx = 0;
213
214     for (k = 0; k < kid; k++) {
215     if (OOC_ISLEAF(*node))
216     /* Sum data counters of leaf octants */
217     dataIdx += (*node) -> leaf.num [k];
218     else
219     /* Sum data counter of inner node's nonempty kids and advance
220     * pointer to sibling */
221     if (OOC_ISBRANCH(*node, k)) {
222     dataIdx += OOC_DATACNT(kidNode);
223     kidNode++;
224     }
225     }
226
227     /* Update node pointer to selected kid (or NULL if nonexistent or node is
228     * a leaf) */
229     *node = OOC_ISBRANCH(*node, kid) ? kidNode : NULL;
230     return dataIdx;
231     }
232
233
234
235     #ifdef DEBUG_OOC
236     int OOC_Check (OOC_Octree *oct, const OOC_Node *node,
237     FVECT org, RREAL size, OOC_DataIdx dataIdx)
238     /* Traverse tree & check for valid nodes; oct -> leafFile must be open;
239     * return 0 if ok, otherwise -1 */
240     {
241     unsigned k;
242     FVECT kidOrg;
243     const RREAL kidSize = size * 0.5;
244
245     if (!oct || !node)
246 greg 2.1 return -1;
247 rschregle 2.3
248     if (OOC_ISLEAF(node)) {
249     /* Node is a leaf; check records in each octant */
250     char rec [oct -> recSize]; /* Violates C89! */
251     OOC_OctCnt d;
252     RREAL *key;
253
254     for (k = 0; k < 8; k++) {
255     VCOPY(kidOrg, org);
256     OOC_OCTORIGIN(kidOrg, k, kidSize);
257
258     for (d = node -> leaf.num [k]; d; d--, dataIdx++) {
259     #ifdef DEBUG_OOC_CHECK
260     fprintf(stderr, "OOC_Check: checking record %lu\n",
261     (unsigned long)dataIdx);
262     #endif
263     if (OOC_GetData(oct, dataIdx, rec)) {
264     fprintf(stderr, "OOC_Check: failed getting record at %lu\n",
265     (unsigned long)dataIdx);
266     return -1;
267     }
268
269     key = oct -> key(rec);
270     if (!OOC_InBBox(oct, kidOrg, kidSize, key)) {
271     fprintf(stderr, "OOC_Check: key [%f, %f, %f] (zIdx %020lu) "
272     "outside bbox [[%f-%f], [%f-%f], [%f-%f]] "
273     "in octant %d (should be %d)\n",
274     key [0], key [1], key [2],
275     OOC_KEY2MORTON(key, oct),
276     kidOrg [0], kidOrg [0] + kidSize,
277     kidOrg [1], kidOrg [1] + kidSize,
278     kidOrg [2], kidOrg [2] + kidSize,
279     k, OOC_Branch(oct, org, kidSize, key, NULL));
280     /* return -1; */
281     }
282     }
283     }
284     }
285     else {
286     /* Internal node; recurse on all kids */
287     const OOC_Node *kid = OOC_KID1(oct, node);
288     OOC_DataIdx numData = 0;
289
290     if (node -> node.kid >= oct -> numNodes) {
291     fprintf(stderr, "OOC_Check: invalid node index %u\n",
292     node -> node.kid);
293     return -1;
294     }
295
296     if (!node -> node.num) {
297     fputs("OOC_Check: empty octree node\n", stderr);
298     return -1;
299     }
300
301     for (k = 0; k < 8; k++)
302     if (OOC_ISBRANCH(node, k)) {
303     VCOPY(kidOrg, org);
304     OOC_OCTORIGIN(kidOrg, k, kidSize);
305
306     if (OOC_Check(oct, kid, kidOrg, kidSize, dataIdx))
307     return -1;
308
309     dataIdx += OOC_DATACNT(kid);
310     numData += OOC_DATACNT(kid);
311     kid++;
312     }
313
314     if (node -> node.num != numData) {
315     fprintf(stderr,
316     "Parent/kid data count mismatch; expected %u, found %u\n",
317     node -> node.num, numData);
318     return -1;
319     }
320     }
321 greg 2.1
322 rschregle 2.3 return 0;
323     }
324     #endif
325
326
327
328     int OOC_SaveOctree (const OOC_Octree *oct, FILE *out)
329     /* Appends octree nodes to specified file along with metadata. Uses
330     * RADIANCE's portable I/O routines. Returns 0 on success, else -1. Note
331     * the internal representation of the nodes is platform specific as they
332     * contain unions, therefore we use the portable I/O routines from the
333     * RADIANCE library */
334     {
335     int i;
336     OOC_NodeIdx nc;
337     OOC_Node *np = NULL;
338 greg 2.1
339 rschregle 2.3 if (!oct || !oct->nodes || !oct->numData || !oct->numNodes || !out) {
340     fputs("OOC_SaveOctree: empty octree\n", stderr);
341 greg 2.1 return -1;
342     }
343 rschregle 2.3
344     /* Write octree origin, size, data record size, number of records, and
345     * number of nodes */
346     for (i = 0; i < 3; i++)
347     putflt(oct -> org [i], out);
348
349     putflt(oct -> size, out);
350     putint(oct -> recSize, sizeof(oct -> recSize), out);
351     putint(oct -> numData, sizeof(oct -> numData), out);
352     putint(oct -> numNodes, sizeof(oct -> numNodes), out);
353
354     /* Write nodes to file */
355     for (nc = oct -> numNodes, np = oct -> nodes; nc; nc--, np++) {
356     if (OOC_ISLEAF(np)) {
357     /* Write leaf marker */
358     putint(-1, 1, out);
359
360     /* Write leaf octant counters */
361     for (i = 0; i < 8; i++)
362     putint(np -> leaf.num [i], sizeof(np -> leaf.num [i]), out);
363     }
364     else {
365     /* Write node marker */
366     putint(0, 1, out);
367
368     /* Write node, rounding field size up to nearest number of bytes */
369     putint(np -> node.kid, (OOC_NODEIDX_BITS + 7) >> 3, out);
370     putint(np -> node.num, (OOC_DATAIDX_BITS + 7) >> 3, out);
371     putint(np -> node.branch, 1, out);
372     }
373
374     if (ferror(out)) {
375     fputs("OOC_SaveOctree: failed writing to node file", stderr);
376     return -1;
377     }
378     }
379
380     fflush(out);
381     return 0;
382 greg 2.1 }
383
384
385 rschregle 2.3
386     int OOC_LoadOctree (OOC_Octree *oct, FILE *nodeFile,
387     RREAL *(*key)(const void*), FILE *leafFile)
388     /* Load octree nodes and metadata from nodeFile and associate with records
389     * in leafFile. Uses RADIANCE's portable I/O routines. Returns 0 on
390     * success, else -1. */
391     {
392     int i;
393     OOC_NodeIdx nc;
394     OOC_Node *np = NULL;
395
396     if (!oct || !nodeFile)
397     return -1;
398
399     OOC_Null(oct);
400
401     /* Read octree origin, size, record size, #records and #nodes */
402     for (i = 0; i < 3; i++)
403     oct -> org [i] = getflt(nodeFile);
404
405     oct -> size = getflt(nodeFile);
406     oct -> bound [0] = oct -> bound [1] = oct -> bound [2] = oct -> size;
407     VADD(oct -> bound, oct -> bound, oct -> org);
408     oct -> mortonScale = OOC_MORTON_MAX / oct -> size;
409     oct -> recSize = getint(sizeof(oct -> recSize), nodeFile);
410     oct -> numData = getint(sizeof(oct -> numData), nodeFile);
411     oct -> numNodes = getint(sizeof(oct -> numNodes), nodeFile);
412     oct -> key = key;
413     oct -> leafFile = leafFile;
414
415     if (feof(nodeFile) || !oct -> numData || !oct -> numNodes) {
416     fputs("OOC_LoadOctree: empty octree\n", stderr);
417     return -1;
418     }
419 greg 2.1
420 rschregle 2.3 /* Allocate octree nodes */
421     if (!(oct -> nodes = calloc(oct -> numNodes, sizeof(OOC_Node)))) {
422     fputs("OOC_LoadOctree: failed octree allocation\n", stderr);
423     return -1;
424     }
425
426     /* Read nodes from file */
427     for (nc = oct -> numNodes, np = oct -> nodes; nc; nc--, np++) {
428     OOC_CLEARNODE(np);
429
430     /* Read node type marker */
431     if (getint(1, nodeFile)) {
432     /* Read leaf octant counters and set node type */
433     for (i = 0; i < 8; i++)
434     np -> leaf.num [i] = getint(sizeof(np -> leaf.num [i]),
435     nodeFile);
436
437     OOC_SETLEAF(np);
438     }
439     else {
440     /* Read node, rounding field size up to nearest number of bytes */
441     np -> node.kid = getint((OOC_NODEIDX_BITS + 7) >> 3, nodeFile);
442     np -> node.num = getint((OOC_DATAIDX_BITS + 7) >> 3, nodeFile);
443     np -> node.branch = getint(1, nodeFile);
444     }
445
446     if (ferror(nodeFile)) {
447     fputs("OOC_LoadOctree: failed reading from node file\n", stderr);
448     return -1;
449 greg 2.1 }
450     }
451
452 rschregle 2.3 return 0;
453     }
454
455
456 greg 2.1
457 rschregle 2.3 void OOC_Delete (OOC_Octree *oct)
458     /* Self-destruct */
459 greg 2.1 {
460 rschregle 2.3 free(oct -> nodes);
461     fclose(oct -> leafFile);
462 greg 2.1
463 rschregle 2.3 if (oct -> cache)
464     OOC_DeleteCache(oct -> cache);
465     }
466 rschregle 2.4
467     #endif /* NIX / PMAP_OOC */
