root/radiance/ray/src/rt/oocnn.h
Revision: 2.1
Committed: Tue May 17 17:39:47 2016 UTC (9 years ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1
1 /*
2 =========================================================================
3 k-nearest neighbour lookup routines for out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 =========================================================================
9
10 $Id: oocnn.h,v 1.14 2015/11/13 18:05:15 taschreg Exp taschreg $
11 */
12
13
14
15 #ifndef OOC_SEARCH_H
16 #define OOC_SEARCH_H
17
18 #include "oococt.h"
19
20 /* Priority queue node for octree lookups */
21 typedef struct {
22 float dist2; /* Record's *SQUARED* distance to query point */
23 unsigned idx; /* Record's index in queue buffer */
24 } OOC_SearchQueueNode;
25
26
27 /* Priority queue for octree lookups. Note that we explicitly store the
28 * NN candidates in a local in-core buffer nnRec for later retrieval
29 * without incurring additional disk I/O. */
30 typedef struct {
31 OOC_SearchQueueNode *node;
32 unsigned len, tail, recSize;
33 void *nnRec;
34 } OOC_SearchQueue;
35
36
37 /* Filter for k-NN search; records are accepted for which func(rec, data)
38 * returns nonzero */
39 typedef struct {
40 int (*func)(void *rec, void *data);
41 void *data;
42 } OOC_SearchFilter;
43
44
45
46 float OOC_FindNearest (OOC_Octree *oct, OOC_Node *node,
47 OOC_DataIdx dataIdx, const FVECT org, float size,
48 const FVECT key, const OOC_SearchFilter *filter,
49 OOC_SearchQueue *queue, float maxDist2);
50 /* Find k nearest neighbours (where k = queue -> len) within a maximum
51 * SQUARED distance of maxDist2 around key. Returns the corresponding
52 * data records with their SQUARED distances in the search queue
53 * (queue -> node [0] .. queue -> node [queue -> tail - 1]), with the
54 * furthest neighbour at the queue head and queue->tail <= queue->len.
55 *
56 * This is a recursive function requiring params for the current node:
57 * DataIdx is the data offset for records in the current node, which is
58 * necessary for implied addressing into the leaf file. Org and size are
59 * the origin and size of the current node's bounding box.
60 *
61 * An optional filter may be specified; if filter != NULL, filter->func()
62 * is called for each potential nearest neighbour along with additional
63 * data provided by the caller; see OOC_SearchFilter typedef above.
64 *
65 * Return value is the SQUARED distance to furthest neighbour on success,
66 * else -1 on failure. */
67
68
69 float OOC_Find1Nearest (OOC_Octree *oct, OOC_Node *node,
70 OOC_DataIdx dataIdx, const FVECT org, float size,
71 const FVECT key, const OOC_SearchFilter *filter,
72 void *nnRec, float maxDist2);
73 /* Find single nearest neighbour within max SQUARED distance maxDist2
74 * around key and copy corresponding record in nnRec. This is an
75 * optimised version of OOC_FindNearest() without a search queue */
76
77
78 int OOC_InitNearest (OOC_SearchQueue *squeue,
79 unsigned len, unsigned recSize);
80 /* Initialise NN search queue of length len and local buffa for records
81 * of size recSize; precondition to calling OOC_FindNearest() */
82
83
84 void *OOC_GetNearest (const OOC_SearchQueue *queue, unsigned idx);
85 /* Return pointer to record at pos idx in search queue after calling
86 * OOC_FindNearest() */
87 #endif
