| 1 |
| 2 |
| 3 |
k-nearest neighbour lookup routines for out-of-core octree data structure
| 4 |
| 5 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 6 |
(c) Lucerne University of Applied Sciences and Arts,
| 7 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 8 |
| 9 |
| 10 |
$Id: oocnn.h,v 1.14 2015/11/13 18:05:15 taschreg Exp taschreg $
| 11 |
| 12 |
| 13 |
| 14 |
| 15 |
#ifndef OOC_SEARCH_H
| 16 |
#define OOC_SEARCH_H
| 17 |
| 18 |
#include "oococt.h"
| 19 |
| 20 |
/* Priority queue node for octree lookups */
| 21 |
typedef struct {
| 22 |
float dist2; /* Record's *SQUARED* distance to query point */
| 23 |
unsigned idx; /* Record's index in queue buffer */
| 24 |
} OOC_SearchQueueNode;
| 25 |
| 26 |
| 27 |
/* Priority queue for octree lookups. Note that we explicitly store the
| 28 |
* NN candidates in a local in-core buffer nnRec for later retrieval
| 29 |
* without incurring additional disk I/O. */
| 30 |
typedef struct {
| 31 |
OOC_SearchQueueNode *node;
| 32 |
unsigned len, tail, recSize;
| 33 |
void *nnRec;
| 34 |
} OOC_SearchQueue;
| 35 |
| 36 |
| 37 |
/* Filter for k-NN search; records are accepted for which func(rec, data)
| 38 |
* returns nonzero */
| 39 |
typedef struct {
| 40 |
int (*func)(void *rec, void *data);
| 41 |
void *data;
| 42 |
} OOC_SearchFilter;
| 43 |
| 44 |
| 45 |
| 46 |
float OOC_FindNearest (OOC_Octree *oct, OOC_Node *node,
| 47 |
OOC_DataIdx dataIdx, const FVECT org, float size,
| 48 |
const FVECT key, const OOC_SearchFilter *filter,
| 49 |
OOC_SearchQueue *queue, float maxDist2);
| 50 |
/* Find k nearest neighbours (where k = queue -> len) within a maximum
| 51 |
* SQUARED distance of maxDist2 around key. Returns the corresponding
| 52 |
* data records with their SQUARED distances in the search queue
| 53 |
* (queue -> node [0] .. queue -> node [queue -> tail - 1]), with the
| 54 |
* furthest neighbour at the queue head and queue->tail <= queue->len.
| 55 |
| 56 |
* This is a recursive function requiring params for the current node:
| 57 |
* DataIdx is the data offset for records in the current node, which is
| 58 |
* necessary for implied addressing into the leaf file. Org and size are
| 59 |
* the origin and size of the current node's bounding box.
| 60 |
| 61 |
* An optional filter may be specified; if filter != NULL, filter->func()
| 62 |
* is called for each potential nearest neighbour along with additional
| 63 |
* data provided by the caller; see OOC_SearchFilter typedef above.
| 64 |
| 65 |
* Return value is the SQUARED distance to furthest neighbour on success,
| 66 |
* else -1 on failure. */
| 67 |
| 68 |
| 69 |
float OOC_Find1Nearest (OOC_Octree *oct, OOC_Node *node,
| 70 |
| 71 |
| 72 |
void *nnRec, float maxDist2);
| 73 |
/* Find single nearest neighbour within max SQUARED distance maxDist2
| 74 |
* around key and copy corresponding record in nnRec. This is an
| 75 |
* optimised version of OOC_FindNearest() without a search queue */
| 76 |
| 77 |
| 78 |
int OOC_InitNearest (OOC_SearchQueue *squeue,
| 79 |
unsigned len, unsigned recSize);
| 80 |
/* Initialise NN search queue of length len and local buffa for records
| 81 |
* of size recSize; precondition to calling OOC_FindNearest() */
| 82 |
| 83 |
| 84 |
void *OOC_GetNearest (const OOC_SearchQueue *queue, unsigned idx);
| 85 |
/* Return pointer to record at pos idx in search queue after calling
| 86 |
* OOC_FindNearest() */
| 87 |
#endif
