root/Development/ray/src/rt/oocnn.c
Revision: 2.3
Committed: Tue Mar 23 00:16:38 2021 UTC (4 years, 9 months ago) by rschregle
CVS Tags: rad6R0, rad5R4, HEAD
fix(rtrace): Fixed ancient THT00PID bug that omitted an octant in
out-of-core pmap lookups! UUAARGH!
# User Rev Content
1 rschregle 2.2 #ifndef lint
2 rschregle 2.3 static const char RCSid[] = "$Id: oocnn.c,v 2.2 2017/08/14 21:12:10 rschregle Exp $";
3 rschregle 2.2 #endif
4
5
6 rschregle 2.1 /*
7     =========================================================================
8     k-nearest neighbour lookup routines for out-of-core octree data structure
9
10     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
11     (c) Lucerne University of Applied Sciences and Arts,
12     supported by the Swiss National Science Foundation (SNSF, #147053)
13     =========================================================================
14
15 rschregle 2.3 $Id: oocnn.c,v 2.2 2017/08/14 21:12:10 rschregle Exp $
16 rschregle 2.1 */
17
18
19 rschregle 2.2 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
20     /* No Windoze support for now */
21 rschregle 2.1
22     #include "oocnn.h"
23     #include "oocsort.h"
24     #include <stdlib.h>
25     #include <string.h>
26     #include <math.h>
27
28
29
30     #ifdef DEBUG_OOC_NN
31     static int OOC_SearchQueueCheck (OOC_SearchQueue *queue, const FVECT key,
32     RREAL *(*keyFunc)(const void*),
33     unsigned root)
34     /* Priority queue sanity check */
35     {
36     unsigned kid;
37     const OOC_SearchQueueNode *qn = queue -> node;
38     void *rec;
39     float d2;
40
41     if (root < queue -> tail) {
42     rec = OOC_GetNearest(queue, qn [root].idx);
43     d2 = dist2(keyFunc(rec), key);
44
45     if (qn [root].dist2 != d2)
46     return -1;
47
48     if ((kid = (root << 1) + 1) < queue -> tail) {
49     if (qn [kid].dist2 > qn [root].dist2)
50     return -1;
51     else return OOC_SearchQueueCheck(queue, key, keyFunc, kid);
52     }
53
54     if (++kid < queue -> tail) {
55     if (qn [kid].dist2 > qn [root].dist2)
56     return -1;
57     else return OOC_SearchQueueCheck(queue, key, keyFunc, kid);
58     }
59     }
60
61     return 0;
62     }
63     #endif
64
65
66
67     static float OOC_PutNearest (OOC_SearchQueue *queue, float d2, void *rec)
68     /* Insert data record with SQUARED distance to query point into search
69     * priority queue, maintaining the most distant record at the queue head.
70     * If the queue is full, the new record is only inserted if it is closer
71     * than the queue head.
72     * Returns the new maximum SQUARED distance at the head if the queue is
73     * full. Otherwise returns -1, indicating a maximum for the entire queue is
74     * as yet undefined
75     * The data record is copied into the queue's local record buffa for
76     * post-search retrieval to minimise redundant disk access. Note that it
77     * suffices to only rearrange the corresponding indices in the queue nodes
78     * when restoring the priority queue after every insertion, rather than
79     * moving the actual records. */
80     {
81     OOC_SearchQueueNode *qn = queue -> node;
82     unsigned root, kid, kid2, rootIdx;
83     float d2max = -1; /* Undefined max distance ^2 */
84
85     /* The queue is represented as a linearised binary tree with the root
86     * corresponding to the queue head, and the tail corresponding to the
87     * last leaf */
88     if (queue -> tail < queue -> len) {
89     /* Enlarge queue if not full, insert at tail and resort towards head */
90     kid = queue -> tail++;
91
92     while (kid) {
93     root = (kid - 1) >> 1;
94
95     /* Compare with parent and swap if necessary, else terminate */
96     if (d2 > qn [root].dist2) {
97     qn [kid].dist2 = qn [root].dist2;
98     qn [kid].idx = qn [root].idx;
99     kid = root;
100     }
101     else break;
102     }
103
104     /* Assign tail position as linear index into record buffa
105     * queue -> nnRec and append record */
106     qn [kid].dist2 = d2;
107     qn [kid].idx = queue -> tail - 1;
108     memcpy(OOC_GetNearest(queue, qn [kid].idx), rec, queue -> recSize);
109     }
110     else if (d2 < qn [0].dist2) {
111     /* Queue full and new record closer than maximum at head; replace head
112     * and resort towards tail */
113     root = 0;
114     rootIdx = qn [root].idx;
115
116     while ((kid = (root << 1) + 1) < queue -> tail) {
117     /* Compare with larger kid & swap if necessary, else terminate */
118     if ((kid2 = (kid + 1)) < queue -> tail &&
119     qn [kid2].dist2 > qn [kid].dist2)
120     kid = kid2;
121
122     if (d2 < qn [kid].dist2) {
123     qn [root].dist2 = qn [kid].dist2;
124     qn [root].idx = qn [kid].idx;
125     }
126     else break;
127
128     root = kid;
129     }
130
131     /* Reassign head's previous buffa index and overwrite corresponding
132     * record */
133     qn [root].dist2 = d2;
134     qn [root].idx = rootIdx;
135     memcpy(OOC_GetNearest(queue, qn [root].idx), rec, queue -> recSize);
136
137     /* Update SQUARED maximum distance from head node */
138     d2max = qn [0].dist2;
139     }
140
141     return d2max;
142     }
143
144
145
146     int OOC_InitNearest (OOC_SearchQueue *squeue,
147     unsigned len, unsigned recSize)
148     {
149     squeue -> len = len;
150     squeue -> recSize = recSize;
151     squeue -> node = calloc(len, sizeof(OOC_SearchQueueNode));
152     squeue -> nnRec = calloc(len, recSize);
153     if (!squeue -> node || !squeue -> nnRec) {
154     perror("OOC_InitNearest: failed search queue allocation");
155     return -1;
156     }
157
158     return 0;
159     }
160
161
162
163     void *OOC_GetNearest (const OOC_SearchQueue *squeue, unsigned idx)
164     {
165     return squeue -> nnRec + idx * squeue -> recSize;
166     }
167
168
169
170     static float OOC_BBoxDist2 (const FVECT bbOrg, RREAL bbSiz, const FVECT key)
171     /* Return minimum *SQUARED* distance between key and bounding box defined by
172     * bbOrg and bbSiz; a distance of 0 implies the key lies INSIDE the bbox */
173     {
174     /* Explicit comparison with bbox corners */
175     int i;
176     FVECT d;
177
178     for (i = 0; i < 3; i++) {
179     d [i] = key [i] - bbOrg [i];
180     d [i] = d [i] < 0 ? -d [i] : d [i] - bbSiz;
181
182     /* Set to 0 if inside bbox */
183     if (d [i] < 0)
184     d [i] = 0;
185     }
186
187     return DOT(d, d);
188     }
189
190
191
192     float OOC_FindNearest (OOC_Octree *oct, OOC_Node *node, OOC_DataIdx dataIdx,
193     const FVECT org, float size, const FVECT key,
194     const OOC_SearchFilter *filter,
195     OOC_SearchQueue *queue, float maxDist2)
196     {
197     const float kidSize = size * 0.5;
198     unsigned i, kid, kid0;
199     float d2;
200     char rec [oct -> recSize];
201     FVECT kidOrg;
202     OOC_DataIdx kidDataIdx, recIdx;
203     OOC_Node *kidNode;
204
205     /* Start with suboctant closest to key */
206     for (kid0 = 0, i = 0; i < 3; i++)
207     kid0 |= (key [i] > org [i] + kidSize) << i;
208
209 rschregle 2.3 for (i = 0; i < 8; i++) {
210 rschregle 2.1 kid = kid0 ^ i;
211     kidNode = node;
212     kidDataIdx = dataIdx + OOC_GetKid(oct, &kidNode, kid);
213
214     /* Prune empty suboctant */
215     if ((!kidNode && !OOC_ISLEAF(node)) ||
216     (OOC_ISLEAF(node) && !node -> leaf.num [kid]))
217     continue;
218
219     /* Set up suboctant */
220     VCOPY(kidOrg, org);
221     OOC_OCTORIGIN(kidOrg, kid, kidSize);
222
223     /* Prune suboctant if not overlapped by maxDist2 */
224     if (OOC_BBoxDist2(kidOrg, kidSize, key) > maxDist2)
225     continue;
226
227     if (kidNode) {
228     /* Internal node; recurse into non-empty suboctant */
229     maxDist2 = OOC_FindNearest(oct, kidNode, kidDataIdx, kidOrg,
230     kidSize, key, filter, queue, maxDist2);
231     if (maxDist2 < 0)
232     /* Bail out on error */
233     break;
234     }
235     else if (OOC_ISLEAF(node))
236     /* Leaf node; do linear check of all records in suboctant */
237     for (recIdx = kidDataIdx;
238     recIdx < kidDataIdx + node -> leaf.num [kid]; recIdx++) {
239     if (OOC_GetData(oct, recIdx, rec))
240     return -1;
241
242     if (!filter || filter -> func(rec, filter -> data))
243     /* Insert record in search queue SQUARED dist to key below
244     * maxDist2 and passes filter */
245     if ((d2 = dist2(key, oct -> key(rec))) < maxDist2) {
246     if ((d2 = OOC_PutNearest(queue, d2, rec)) >= 0)
247     /* Update maxDist2 if queue is full */
248     maxDist2 = d2;
249     #ifdef DEBUG_OOC_NN
250     if (OOC_SearchQueueCheck(queue, key, oct -> key, 0)) {
251     fprintf(stderr, "OOC_SearchPush: priority queue "
252     "inconsistency\n");
253     return -1;
254     }
255     #endif
256     }
257     }
258     }
259
260     return maxDist2;
261     }
262
263
264
265     float OOC_Find1Nearest (OOC_Octree *oct, OOC_Node *node, OOC_DataIdx dataIdx,
266     const FVECT org, float size, const FVECT key,
267     const OOC_SearchFilter *filter, void *nnRec,
268     float maxDist2)
269     {
270     const float kidSize = size * 0.5;
271     unsigned i, kid, kid0;
272     float d2;
273     char rec [oct -> recSize];
274     FVECT kidOrg;
275     OOC_DataIdx kidDataIdx, recIdx;
276     OOC_Node *kidNode;
277
278     /* Start with suboctant closest to key */
279     for (kid0 = 0, i = 0; i < 3; i++)
280     kid0 |= (key [i] > org [i] + kidSize) << i;
281
282 rschregle 2.3 for (i = 0; i < 8; i++) {
283 rschregle 2.1 kid = kid0 ^ i;
284     kidNode = node;
285     kidDataIdx = dataIdx + OOC_GetKid(oct, &kidNode, kid);
286
287     /* Prune empty suboctant */
288     if ((!kidNode && !OOC_ISLEAF(node)) ||
289     (OOC_ISLEAF(node) && !node -> leaf.num [kid]))
290     continue;
291
292     /* Set up suboctant */
293     VCOPY(kidOrg, org);
294     OOC_OCTORIGIN(kidOrg, kid, kidSize);
295
296     /* Prune suboctant if not overlapped by maxDist2 */
297     if (OOC_BBoxDist2(kidOrg, kidSize, key) > maxDist2)
298     continue;
299
300     if (kidNode) {
301     /* Internal node; recurse into non-empty suboctant */
302     maxDist2 = OOC_Find1Nearest(oct, kidNode, kidDataIdx, kidOrg,
303     kidSize, key, filter, nnRec, maxDist2);
304     if (maxDist2 < 0)
305     /* Bail out on error */
306     break;
307     }
308     else if (OOC_ISLEAF(node))
309     /* Leaf node; do linear check of all records in suboctant */
310     for (recIdx = kidDataIdx;
311     recIdx < kidDataIdx + node -> leaf.num [kid]; recIdx++) {
312     if (OOC_GetData(oct, recIdx, rec))
313     return -1;
314
315     if (!filter || filter -> func(rec, filter -> data))
316     /* Update closest record and max SQUARED dist to key if it
317     * passes filter */
318     if ((d2 = dist2(key, oct -> key(rec))) < maxDist2) {
319     memcpy(nnRec, rec, oct -> recSize);
320     maxDist2 = d2;
321     }
322     }
323     }
324
325     return maxDist2;
326     }
327
328 rschregle 2.2 #endif /* NIX / PMAP_OOC */
