1 |
2 |
3 |
Routines to generate and compare Morton Codes, i.e. indices on space |
4 |
filling Z-curves. |
5 |
6 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
7 |
(c) Lucerne University of Applied Sciences and Arts, |
8 |
supported by the Swiss National Science Foundation (SNSF, #147053) |
9 |
10 |
11 |
$Id: oocmorton.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $ |
12 |
13 |
14 |
#ifndef OOC_MORTON_H |
15 |
#define OOC_MORTON_H |
16 |
17 |
#include "fvect.h" |
18 |
#include <stdint.h> |
19 |
20 |
#ifdef __cplusplus |
21 |
extern "C" { |
22 |
#endif |
23 |
24 |
/* Type to represent Morton codes (Z-curve indices) as sort keys */ |
25 |
typedef uint64_t OOC_MortonIdx; |
26 |
27 |
28 |
/* Number of bits per dimension for Morton code (Z-curve index) used to |
29 |
* sort records. This corresponds to the maximum number of bounding box |
30 |
* subdivisions which can be resolved per axis; further subdivisions will |
31 |
* map to the same Morton code, thus invalidating the sort! */ |
32 |
#define OOC_MORTON_BITS 21 |
33 |
#define OOC_MORTON_MAX (((OOC_MortonIdx)1 << OOC_MORTON_BITS) - 1) |
34 |
35 |
36 |
/* Interleave lower OOC_MORTON_BITS bits of k with 00, resulting in |
37 |
* 3*OOC_MORTON_BITS bits. Optimised "bitmask hack" version. This code |
38 |
* taken from: |
39 |
* http://www.forceflow.be/2013/10/07/ |
40 |
* morton-encodingdecoding-through-bit-interleaving-implementations/ */ |
41 |
#define OOC_BitInterleave(k) \ |
42 |
((k) &= OOC_MORTON_MAX, \ |
43 |
(k) = ((k) | (k) << 32) & 0x001f00000000ffff, \ |
44 |
(k) = ((k) | (k) << 16) & 0x001f0000ff0000ff, \ |
45 |
(k) = ((k) | (k) << 8) & 0x100f00f00f00f00f, \ |
46 |
(k) = ((k) | (k) << 4) & 0x10c30c30c30c30c3, \ |
47 |
(k) = ((k) | (k) << 2) & 0x1249249249249249) |
48 |
49 |
50 |
/* Compute Morton code (Z-curve index) of length 3 * OOC_MORTON_BITS bits |
51 |
* for 3D key within bounding box defined by org and scaled to maximum |
52 |
* index with scale */ |
53 |
OOC_MortonIdx OOC_Key2Morton (const FVECT key, const FVECT org, |
54 |
RREAL scale); |
55 |
56 |
57 |
58 |
#endif |
59 |
60 |
#endif |
61 |
