root/radiance/ray/src/rt/oocmorton.h
Revision: 2.1
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 2 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1
1 /*
2 ======================================================================
3 Routines to generate and compare Morton Codes, i.e. indices on space
4 filling Z-curves.
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ======================================================================
10
11 $Id: oocmorton.h,v 1.2 2015/11/02 17:29:14 taschreg Exp taschreg $
12 */
13
14 #ifndef OOC_MORTON_H
15 #define OOC_MORTON_H
16
17 #include "fvect.h"
18 #include <stdint.h>
19
20
21 /* Type to represent Morton codes (Z-curve indices) as sort keys */
22 typedef uint64_t OOC_MortonIdx;
23
24
25 /* Number of bits per dimension for Morton code (Z-curve index) used to
26 * sort records. This corresponds to the maximum number of bounding box
27 * subdivisions which can be resolved per axis; further subdivisions will
28 * map to the same Morton code, thus invalidating the sort! */
29 #define OOC_MORTON_BITS 21
30 #define OOC_MORTON_MAX (((OOC_MortonIdx)1 << OOC_MORTON_BITS) - 1)
31
32
33 /* Interleave lower OOC_MORTON_BITS bits of k with 00, resulting in
34 * 3*OOC_MORTON_BITS bits. Optimised "bitmask hack" version. This code
35 * taken from:
36 * http://www.forceflow.be/2013/10/07/
37 * morton-encodingdecoding-through-bit-interleaving-implementations/ */
38 #define OOC_BitInterleave(k) \
39 ((k) &= OOC_MORTON_MAX, \
40 (k) = ((k) | (k) << 32) & 0x001f00000000ffff, \
41 (k) = ((k) | (k) << 16) & 0x001f0000ff0000ff, \
42 (k) = ((k) | (k) << 8) & 0x100f00f00f00f00f, \
43 (k) = ((k) | (k) << 4) & 0x10c30c30c30c30c3, \
44 (k) = ((k) | (k) << 2) & 0x1249249249249249)
45
46
47 /* Compute Morton code (Z-curve index) of length 3 * OOC_MORTON_BITS bits
48 * for 3D key within bounding box defined by org and scaled to maximum
49 * index with scale */
50 OOC_MortonIdx OOC_Key2Morton (const FVECT key, const FVECT org,
51 RREAL scale);
52 #endif
53
