root/radiance/ray/src/rt/oocmorton.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (10 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.1: +11 -3 lines
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 ======================================================================
3 Routines to generate and compare Morton Codes, i.e. indices on space
4 filling Z-curves.
5
6 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
7 (c) Lucerne University of Applied Sciences and Arts,
8 supported by the Swiss National Science Foundation (SNSF, #147053)
9 ======================================================================
10
11 $Id: oocmorton.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
12 */
13
14 #ifndef OOC_MORTON_H
15 #define OOC_MORTON_H
16
17 #include "fvect.h"
18 #include <stdint.h>
19
20 #ifdef __cplusplus
21 extern "C" {
22 #endif
23
24 /* Type to represent Morton codes (Z-curve indices) as sort keys */
25 typedef uint64_t OOC_MortonIdx;
26
27
28 /* Number of bits per dimension for Morton code (Z-curve index) used to
29 * sort records. This corresponds to the maximum number of bounding box
30 * subdivisions which can be resolved per axis; further subdivisions will
31 * map to the same Morton code, thus invalidating the sort! */
32 #define OOC_MORTON_BITS 21
33 #define OOC_MORTON_MAX (((OOC_MortonIdx)1 << OOC_MORTON_BITS) - 1)
34
35
36 /* Interleave lower OOC_MORTON_BITS bits of k with 00, resulting in
37 * 3*OOC_MORTON_BITS bits. Optimised "bitmask hack" version. This code
38 * taken from:
39 * http://www.forceflow.be/2013/10/07/
40 * morton-encodingdecoding-through-bit-interleaving-implementations/ */
41 #define OOC_BitInterleave(k) \
42 ((k) &= OOC_MORTON_MAX, \
43 (k) = ((k) | (k) << 32) & 0x001f00000000ffff, \
44 (k) = ((k) | (k) << 16) & 0x001f0000ff0000ff, \
45 (k) = ((k) | (k) << 8) & 0x100f00f00f00f00f, \
46 (k) = ((k) | (k) << 4) & 0x10c30c30c30c30c3, \
47 (k) = ((k) | (k) << 2) & 0x1249249249249249)
48
49
50 /* Compute Morton code (Z-curve index) of length 3 * OOC_MORTON_BITS bits
51 * for 3D key within bounding box defined by org and scaled to maximum
52 * index with scale */
53 OOC_MortonIdx OOC_Key2Morton (const FVECT key, const FVECT org,
54 RREAL scale);
55
56 #ifdef __cplusplus
57 }
58 #endif
59
60 #endif
61
