root/Development/ray/src/rt/ooccache.h
Revision: 2.1
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1
1 /*
2 =======================================================================
3 Cache for out-of-core octree.
4
5 Uses an LRU page replacement scheme. Page table nodes are stored in
6 order of reference in a doubly linked list, with the most recently used
7 (MRU) page at the head, and the least recently used (LRU) at the tail.
8
9 Nodes are referenced by the page's base address via a hashtable for
10 constant time access (in the absence of hash collisions). Hash
11 collisions can be limited by adjusting the hashtable load factor
12 OOC_CACHE_LOAD; this is the fraction of the number of pages that will
13 actually be cached.
14
15 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
16 (c) Lucerne University of Applied Sciences and Arts,
17 supported by the Swiss National Science Foundation (SNSF, #147053)
18 =======================================================================
19
20 $Id: ooccache.h,v 1.13 2015/11/16 13:33:08 taschreg Exp taschreg $
21 */
22
23
24 #ifndef OOC_CACHE_H
25 #define OOC_CACHE_H
26
27 #include <stdio.h>
28 #include <stdint.h>
29
30
31
32 /* Hashtable load factor to limit hash collisions */
33 #define OOC_CACHE_LOAD 0.75
34
35 /* Minimum number of cache pages */
36 #define OOC_CACHE_MINPAGES 8
37
38 /* Hashing function for key -> pagetable mapping (assumes n is prime) */
39 #define OOC_CACHE_PRIME 19603
40 #define OOC_CACHE_HASH(k,n) ((k) * OOC_CACHE_PRIME % (n))
41
42 /* Next index in pagetable probe sequence for collision resolution */
43 #define OOC_CACHE_NEXT(i,n) (((i) + 1) % (n))
44
45 /* Cache key and index types */
46 typedef uint32_t OOC_CacheKey;
47 typedef uint32_t OOC_CacheIdx;
48
49 /* Undefined value for cache index */
50 #define OOC_CACHEIDX_NULL UINT32_MAX
51
52
53
54 typedef struct {
55 OOC_CacheKey key; /* Key to resolve hashing collisions */
56 OOC_CacheIdx prev, next; /* Previous/next page in history */
57 void *data; /* Start of page data */
58 } OOC_CacheNode;
59
60 typedef struct {
61 unsigned recSize, /* Data record size in bytes */
62 recPerPage; /* Page size in number of records */
63 unsigned long pageSize; /* Page size in bytes (precomp) */
64 OOC_CacheIdx pageCnt, /* Num pages used */
65 numPages; /* Pagetable size */
66
67 /* NOTE: The hashtable load factor limits the number of pages actually
68 * used, such that pageCnt <= OOC_CACHE_LOAD * numPages */
69
70 OOC_CacheNode *pageTable; /* Pagetable with numPages nodes */
71 OOC_CacheIdx mru, lru; /* Most/least recently used page
72 == head/tail of page history */
73 OOC_CacheKey lastKey; /* Previous key to detect repeat lookups */
74 OOC_CacheNode *lastPage; /* Previous page for repeat lookups */
75
76 unsigned long numReads, /* Statistics counters */
77 numHits,
78 numColl,
79 numRept;
80 } OOC_Cache;
81
82
83
84 /* Initialise cache containing up to numPages pages; this is rounded up
85 * the next prime number to reduce hash clustering and collisions. The
86 * page size recPerPage is specified in units of records of size recSize
87 * bytes. Returns 0 on success, else -1. */
88 int OOC_CacheInit (OOC_Cache *cache, unsigned numPages,
89 unsigned recPerPage, unsigned recSize);
90
91 /* Return pointer to cached record with index recIdx, loading from file
92 * and possibly evicting the LRU page */
93 void *OOC_CacheData (OOC_Cache *cache, FILE *file, unsigned long recIdx);
94
95 /* Delete cache and free allocated pages */
96 void OOC_DeleteCache (OOC_Cache *cache);
97 #endif
