root/radiance/ray/src/rt/ooccache.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (10 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.1: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
# User Rev Content
1 rschregle 2.1 /*
2     =======================================================================
3     Cache for out-of-core octree.
4
5     Uses an LRU page replacement scheme. Page table nodes are stored in
6     order of reference in a doubly linked list, with the most recently used
7     (MRU) page at the head, and the least recently used (LRU) at the tail.
8
9     Nodes are referenced by the page's base address via a hashtable for
10     constant time access (in the absence of hash collisions). Hash
11     collisions can be limited by adjusting the hashtable load factor
12     OOC_CACHE_LOAD; this is the fraction of the number of pages that will
13     actually be cached.
14
15     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
16     (c) Lucerne University of Applied Sciences and Arts,
17     supported by the Swiss National Science Foundation (SNSF, #147053)
18     =======================================================================
19
20 greg 2.2 $Id: ooccache.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
21 rschregle 2.1 */
22
23
24     #ifndef OOC_CACHE_H
25     #define OOC_CACHE_H
26
27     #include <stdio.h>
28     #include <stdint.h>
29
30 greg 2.2 #ifdef __cplusplus
31     extern "C" {
32     #endif
33 rschregle 2.1
34     /* Hashtable load factor to limit hash collisions */
35     #define OOC_CACHE_LOAD 0.75
36
37     /* Minimum number of cache pages */
38     #define OOC_CACHE_MINPAGES 8
39
40     /* Hashing function for key -> pagetable mapping (assumes n is prime) */
41     #define OOC_CACHE_PRIME 19603
42     #define OOC_CACHE_HASH(k,n) ((k) * OOC_CACHE_PRIME % (n))
43
44     /* Next index in pagetable probe sequence for collision resolution */
45     #define OOC_CACHE_NEXT(i,n) (((i) + 1) % (n))
46
47     /* Cache key and index types */
48     typedef uint32_t OOC_CacheKey;
49     typedef uint32_t OOC_CacheIdx;
50
51     /* Undefined value for cache index */
52     #define OOC_CACHEIDX_NULL UINT32_MAX
53
54
55
56     typedef struct {
57     OOC_CacheKey key; /* Key to resolve hashing collisions */
58     OOC_CacheIdx prev, next; /* Previous/next page in history */
59     void *data; /* Start of page data */
60     } OOC_CacheNode;
61
62     typedef struct {
63     unsigned recSize, /* Data record size in bytes */
64     recPerPage; /* Page size in number of records */
65     unsigned long pageSize; /* Page size in bytes (precomp) */
66     OOC_CacheIdx pageCnt, /* Num pages used */
67     numPages; /* Pagetable size */
68
69     /* NOTE: The hashtable load factor limits the number of pages actually
70     * used, such that pageCnt <= OOC_CACHE_LOAD * numPages */
71
72     OOC_CacheNode *pageTable; /* Pagetable with numPages nodes */
73     OOC_CacheIdx mru, lru; /* Most/least recently used page
74     == head/tail of page history */
75     OOC_CacheKey lastKey; /* Previous key to detect repeat lookups */
76     OOC_CacheNode *lastPage; /* Previous page for repeat lookups */
77
78     unsigned long numReads, /* Statistics counters */
79     numHits,
80     numColl,
81     numRept;
82     } OOC_Cache;
83
84
85
86     /* Initialise cache containing up to numPages pages; this is rounded up
87     * the next prime number to reduce hash clustering and collisions. The
88     * page size recPerPage is specified in units of records of size recSize
89     * bytes. Returns 0 on success, else -1. */
90     int OOC_CacheInit (OOC_Cache *cache, unsigned numPages,
91     unsigned recPerPage, unsigned recSize);
92
93     /* Return pointer to cached record with index recIdx, loading from file
94     * and possibly evicting the LRU page */
95     void *OOC_CacheData (OOC_Cache *cache, FILE *file, unsigned long recIdx);
96
97     /* Delete cache and free allocated pages */
98     void OOC_DeleteCache (OOC_Cache *cache);
99 greg 2.2
100     #ifdef __cplusplus
101     }
102     #endif
103
104 rschregle 2.1 #endif
