root/radiance/ray/src/rt/ooccache.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (8 months, 1 week ago) by greg
Changes since 2.1: +9 -2 lines
Error occurred while calculating annotation data.
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 =======================================================================
3 Cache for out-of-core octree.
4
5 Uses an LRU page replacement scheme. Page table nodes are stored in
6 order of reference in a doubly linked list, with the most recently used
7 (MRU) page at the head, and the least recently used (LRU) at the tail.
8
9 Nodes are referenced by the page's base address via a hashtable for
10 constant time access (in the absence of hash collisions). Hash
11 collisions can be limited by adjusting the hashtable load factor
12 OOC_CACHE_LOAD; this is the fraction of the number of pages that will
13 actually be cached.
14
15 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
16 (c) Lucerne University of Applied Sciences and Arts,
17 supported by the Swiss National Science Foundation (SNSF, #147053)
18 =======================================================================
19
20 $Id: ooccache.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
21 */
22
23
24 #ifndef OOC_CACHE_H
25 #define OOC_CACHE_H
26
27 #include <stdio.h>
28 #include <stdint.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif
33
34 /* Hashtable load factor to limit hash collisions */
35 #define OOC_CACHE_LOAD 0.75
36
37 /* Minimum number of cache pages */
38 #define OOC_CACHE_MINPAGES 8
39
40 /* Hashing function for key -> pagetable mapping (assumes n is prime) */
41 #define OOC_CACHE_PRIME 19603
42 #define OOC_CACHE_HASH(k,n) ((k) * OOC_CACHE_PRIME % (n))
43
44 /* Next index in pagetable probe sequence for collision resolution */
45 #define OOC_CACHE_NEXT(i,n) (((i) + 1) % (n))
46
47 /* Cache key and index types */
48 typedef uint32_t OOC_CacheKey;
49 typedef uint32_t OOC_CacheIdx;
50
51 /* Undefined value for cache index */
52 #define OOC_CACHEIDX_NULL UINT32_MAX
53
54
55
56 typedef struct {
57 OOC_CacheKey key; /* Key to resolve hashing collisions */
58 OOC_CacheIdx prev, next; /* Previous/next page in history */
59 void *data; /* Start of page data */
60 } OOC_CacheNode;
61
62 typedef struct {
63 unsigned recSize, /* Data record size in bytes */
64 recPerPage; /* Page size in number of records */
65 unsigned long pageSize; /* Page size in bytes (precomp) */
66 OOC_CacheIdx pageCnt, /* Num pages used */
67 numPages; /* Pagetable size */
68
69 /* NOTE: The hashtable load factor limits the number of pages actually
70 * used, such that pageCnt <= OOC_CACHE_LOAD * numPages */
71
72 OOC_CacheNode *pageTable; /* Pagetable with numPages nodes */
73 OOC_CacheIdx mru, lru; /* Most/least recently used page
74 == head/tail of page history */
75 OOC_CacheKey lastKey; /* Previous key to detect repeat lookups */
76 OOC_CacheNode *lastPage; /* Previous page for repeat lookups */
77
78 unsigned long numReads, /* Statistics counters */
79 numHits,
80 numColl,
81 numRept;
82 } OOC_Cache;
83
84
85
86 /* Initialise cache containing up to numPages pages; this is rounded up
87 * the next prime number to reduce hash clustering and collisions. The
88 * page size recPerPage is specified in units of records of size recSize
89 * bytes. Returns 0 on success, else -1. */
90 int OOC_CacheInit (OOC_Cache *cache, unsigned numPages,
91 unsigned recPerPage, unsigned recSize);
92
93 /* Return pointer to cached record with index recIdx, loading from file
94 * and possibly evicting the LRU page */
95 void *OOC_CacheData (OOC_Cache *cache, FILE *file, unsigned long recIdx);
96
97 /* Delete cache and free allocated pages */
98 void OOC_DeleteCache (OOC_Cache *cache);
99
100 #ifdef __cplusplus
101 }
102 #endif
103
104 #endif
