root/radiance/ray/src/rt/oocbuild.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (8 months, 1 week ago) by greg
Changes since 2.1: +10 -2 lines
Error occurred while calculating annotation data.
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 =======================================================================
3 Header for building out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 =======================================================================
9
10 $Id: oocbuild.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
11 */
12
13
14 #ifndef OOC_BUILD_H
15 #define OOC_BUILD_H
16
17 #ifdef __cplusplus
18 extern "C" {
19 #endif
20
21 /* Bottom-up construction of out-of-core octree in postorder traversal.
22 * The octree oct is assumed to be initialised with its origin (oct ->
23 * org), size (oct -> size), key callback (oct -> key), and its
24 * associated leaf file (oct -> leafFile).
25
26 * Records are read from the leafFile and assumed to be sorted in
27 * Z-order, which defines an octree leaf ordering. Leaves (terminal
28 * nodes) are constructed such that they contain <= leafMax records and
29 * have a maximum depth of maxDepth.
30
31 * Note that the following limits apply:
32 * leafMax <= OOC_OCTCNT_MAX (see oococt.h)
33 * maxDepth <= OOC_MORTON_BITS (see oocsort.h)
34
35 * The maxDepth limit arises from the fact that the Z-ordering has a
36 * limited resolution and will map node coordinates beyond a depth of
37 * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially
38 * read out of sequence and winding up in the wrong octree nodes.
39
40 * On success, the octree pointer oct is returned, with the constructed
41 * nodes in oct -> nodes, and the node count in oct -> numNodes. On
42 * failure, NULL is returned. */
43 OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax,
44 unsigned maxDepth);
45
46 #ifdef __cplusplus
47 }
48 #endif
49
50 #endif
