root/radiance/ray/src/rt/oocbuild.c
Revision: 2.4
Committed: Mon Aug 14 21:12:10 2017 UTC (7 years, 11 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, HEAD
Changes since 2.3: +12 -2 lines
Updated photon map code for Windows; no multproc or ooC for now
# User Rev Content
1 rschregle 2.4 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4
5
6 greg 2.1 /*
7     =======================================================================
8     Routines for building out-of-core octree data structure
9
10     Adapted from: Kontkanen J., Tabellion E. and Overbeck R.S.,
11     "Coherent Out-of-Core Point-Based Global Illumination",
12     EGSR 2011.
13
14     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
15 rschregle 2.3 (c) Lucerne University of Applied Sciences and Arts,
16 rschregle 2.4 supported by the Swiss National Science Foundation (SNSF, #147053)
17 greg 2.1 =======================================================================
18
19 rschregle 2.4 $Id: oocbuild.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
20 greg 2.1 */
21
22
23 rschregle 2.4 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
24     /* No Windoze support for now */
25
26 greg 2.1 #include "oococt.h"
27     #include "oocsort.h"
28 rschregle 2.3 #include <stdlib.h>
29     #include <string.h>
30 greg 2.1
31
32     /* Test for empty/full input queue, return pointer to head/tail */
33     #define QueueFull(q) ((q) -> len == (q) -> cap)
34     #define QueueEmpty(q) (!(q) -> len)
35     #define QueueHead(q) ((q) -> data + (q) -> head * (q) -> recSize)
36     #define QueueTail(q) ((q) -> data + \
37 rschregle 2.3 ((q)->head + (q)->len-1) % (q)->cap * (q)->recSize)
38 greg 2.1
39
40 rschregle 2.3
41     /* Input queue for bottom-up octree construction */
42     typedef struct {
43     void *data;
44     unsigned head, len, cap, recSize; /* Queue head, length (from head),
45     capacity and record size */
46     FILE *in; /* Input file for data records */
47 greg 2.1 } OOC_BuildQueue;
48
49
50     static OOC_BuildQueue *QueueInit (OOC_BuildQueue *q, unsigned recSize,
51     unsigned capacity)
52     /* Initialise queue of #capacity records of size recSize each; returns queue
53     * pointer or NULL if failed. */
54     {
55     if (!(q && (q -> data = calloc(capacity, recSize))))
56     return NULL;
57
58     q -> cap = capacity;
59     q -> recSize = recSize;
60     q -> head = q -> len = 0;
61
62     return q;
63     }
64
65
66     static int QueuePush (OOC_BuildQueue *q, const void *rec)
67 rschregle 2.3 /* Append record to queue tail; return new queue length or -1 on failure */
68 greg 2.1 {
69 rschregle 2.3 if (!q || !rec || QueueFull(q))
70 greg 2.1 return -1;
71
72 rschregle 2.3 ++q->len;
73     memcpy(QueueTail(q), rec, q -> recSize);
74
75 greg 2.1 return q -> len;
76     }
77
78
79     static int QueuePop (OOC_BuildQueue *q, void *rec)
80 rschregle 2.3 /* Remove record from queue head and return in rec if not NULL; return new
81     * queue length or -1 on failure */
82 greg 2.1 {
83 rschregle 2.3 if (!q || QueueEmpty(q))
84 greg 2.1 return -1;
85
86 rschregle 2.3 /* Return head if rec != NULL */
87     if (rec)
88     memcpy(rec, QueueHead(q), q -> recSize);
89 greg 2.1
90     q -> head = (q -> head + 1) % q -> cap;
91
92     return --q -> len;
93     }
94
95
96 rschregle 2.3 static int QueueFill (OOC_BuildQueue *q)
97     /* Read records from q -> in until the queue is full; return queue
98     * length or -1 on failure */
99     {
100     static void *rec = NULL;
101
102     if (!rec && !(rec = malloc(q -> recSize)))
103     return -1;
104
105     while (!QueueFull(q) && !feof(q -> in) &&
106     fread(rec, q -> recSize, 1, q -> in))
107     QueuePush(q, rec);
108
109     return q -> len;
110     }
111
112
113
114     static OOC_DataIdx OOC_BuildRecurse (OOC_Octree *oct, OOC_Node* node,
115     FVECT org, RREAL size, unsigned depth,
116     OOC_BuildQueue *queue)
117 greg 2.1 /* Recursive part of OOC_Build(); insert records from input queue into
118 rschregle 2.3 * octree node and subdivide into kids if necessary. Returns number of
119     * records in subtree or OOC_DATAIDX_ERR if failed. */
120 greg 2.1 {
121 rschregle 2.3 int k;
122     const RREAL kidSize = size * 0.5;
123
124     if (!oct || !node)
125     return OOC_DATAIDX_ERR;
126
127     if (QueueEmpty(queue) ||
128     !OOC_InBBox(oct, org, size, oct -> key(QueueHead(queue))))
129 greg 2.1 /* Input exhausted or queue head outside node */
130     return 0;
131 rschregle 2.3
132     if (QueueFull(queue) && depth < oct -> maxDepth &&
133     OOC_InBBox(oct, org, size, oct -> key(QueueTail(queue)))) {
134     /*************************** SUBDIVIDE NODE *************************
135     * At least leafMax + 1 records (since the queue is full) lie inside
136     * the current node's bounding box, and maxDepth has not been reached
137     * ==> subdivide this node.
138     * (Note it suffices to only test the queue tail against the bounding
139     * box, as the records are in Z-order)
140     ********************************************************************/
141     OOC_Node kid [8];
142     OOC_DataIdx dataCnt;
143     FVECT kidOrg;
144
145     #ifdef DEBUG_OOC_BUILD
146     FVECT key;
147     unsigned k2 = 0;
148     #endif
149 greg 2.1
150 rschregle 2.3 /* We recurse on the nonempty kids first, then finalise their nodes so
151     * they are ordered consecutively, since the parent only indexes the 1st kid */
152     for (k = 0; k < 8; k++) {
153     /* Clear kid node and get its octant origin */
154     OOC_CLEARNODE(kid + k);
155
156     VCOPY(kidOrg, org);
157     OOC_OCTORIGIN(kidOrg, k, kidSize);
158
159     /* Recurse on kid and check for early bailout */
160     if (OOC_BuildRecurse(oct, kid + k, kidOrg, kidSize,
161     depth + 1, queue) == OOC_DATAIDX_ERR)
162     return OOC_DATAIDX_ERR;
163
164     #ifdef DEBUG_OOC_BUILD
165     if (!QueueEmpty(queue)) {
166     VCOPY(key, oct -> key(QueueHead(queue)));
167     k2 = OOC_Branch(oct, org, kidSize, key, NULL);
168     if (OOC_InBBox(oct, org, size, key) && k2 < k) {
169     fprintf(stderr,
170     "OOC_BuildRecurse, node subdiv: unsorted key [%f, %f, %f] with "
171     "octant %d (last %d with bbox [%f-%f, %f-%f, %f-%f])\n",
172     key [0], key [1], key [2], k2, k,
173     kidOrg [0], kidOrg [0] + kidSize, kidOrg [1], kidOrg [1] + kidSize,
174     kidOrg [2], kidOrg [2] + kidSize);
175     }}
176     #endif
177     }
178
179     /* Now finalise consecutive kid nodes, skipping empty ones */
180     for (k = 0; k < 8; k++)
181     if ((dataCnt = OOC_DATACNT(kid + k))) {
182     /* Nonzero kid ==> allocate and set node */
183     if (!NewNode(oct)) {
184     fputs("OOC_BuildRecurse: failed to allocate new node\n",
185     stderr);
186     return OOC_DATAIDX_ERR;
187     }
188     OOC_SETROOT(oct, kid + k);
189
190     /* Sum kid's data count to parent's and check for overflow */
191     if ((dataCnt += node -> node.num) <= OOC_DATAIDX_MAX)
192     node -> node.num = dataCnt;
193     else {
194     fputs("OOC_BuildRecurse: data count overflow in node\n",
195     stderr);
196     return OOC_DATAIDX_ERR;
197     }
198
199     /* Set kid index in parent (if first kid) and corresponding
200     * branch bit. The kid is the most recent node and thus at the
201     * end of the node array, which coincides with the current
202     * subtree root */
203     if (!node -> node.branch)
204     node -> node.kid = OOC_ROOTIDX(oct);
205
206     OOC_SETBRANCH(node, k);
207     }
208 greg 2.1 }
209     else {
210 rschregle 2.3 /****************************** MAKE LEAF ****************************
211     * Queue contains no more than leafMax records, queue tail lies
212     * outside node's bounding box, or maxDepth reached
213     * ==> make this node a leaf.
214     *********************************************************************/
215     RREAL *key;
216
217     #ifdef DEBUG_OOC_BUILD
218     OOC_MortonIdx zIdx, lastzIdx = 0;
219     FVECT /* key, */
220     lastKey, kidOrg;
221     unsigned lastk = 0;
222     #endif
223
224     /* Mark as leaf (note it's been cleared by the parent call) */
225     OOC_SETLEAF(node);
226
227     while (!QueueEmpty(queue) &&
228     OOC_InBBox(oct, org, size, (key = oct->key(QueueHead(queue))))) {
229     /* Record lies inside leaf; increment data counter for octant
230     * containing record. */
231
232     if ((k = OOC_Branch(oct, org, kidSize, key, NULL)) < 0) {
233     /* Shouldn't happen, as key tested within bbox above */
234     fprintf(stderr, "OOC_BuildRecurse: buggered Morton code, "
235     "disruption in space-time continuum?\n");
236     return OOC_DATAIDX_ERR;
237     }
238
239     if (node -> leaf.num [k] == OOC_OCTCNT_MAX) {
240     /* Currently we're buggered here; merge records instead? */
241     fprintf(stderr, "OOC_BuildRecurse: data count overflow in "
242     "leaf: depth = %d, count = %d\n",
243     depth, node -> leaf.num [k]);
244     return OOC_DATAIDX_ERR;
245     }
246
247     ++node -> leaf.num [k];
248
249     #ifdef DEBUG_OOC_BUILD
250     /* VCOPY(key, oct -> key(QueueHead(queue))); */
251     if ((zIdx = OOC_KEY2MORTON(key, oct)) < lastzIdx) {
252     fprintf(stderr, "OOC_BuildRecurse, make leaf: unsorted zIdx %020ld for "
253     "key [%f, %f, %f] (previous zIdx %020ld for "
254     "key [%f, %f, %f]\n", zIdx, key [0], key [1], key [2],
255     lastzIdx, lastKey [0], lastKey [1], lastKey [2]);
256     }
257
258     VCOPY(kidOrg, org);
259     OOC_OCTORIGIN(kidOrg, k, kidSize);
260     if (k < lastk || zIdx < lastzIdx) {
261     fprintf(stderr,
262     "OOC_BuildRecurse, make leaf: unsorted octant %d (last %d) with "
263     "bbox [%f-%f, %f-%f, %f-%f] for key [%f, %f, %f] with zIdx %020ld "
264     "(last [%f, %f, %f], zIdx %020ld)\n",
265     k, lastk, kidOrg [0], kidOrg [0] + kidSize,
266     kidOrg [1], kidOrg [1] + kidSize, kidOrg [2], kidOrg [2] + kidSize,
267     key [0], key [1], key [2], zIdx,
268     lastKey [0], lastKey [1], lastKey [2], lastzIdx);
269     }
270     lastk = k;
271     lastzIdx = zIdx;
272     VCOPY(lastKey, key);
273     #endif
274
275     /* Remove record from queue */
276     QueuePop(queue, NULL);
277     }
278
279     /* Refill queue for next node(s) */
280     if (QueueFill(queue) < 0) {
281     fputs("OOC_Build: failed input queue fill\n", stderr);
282     return OOC_DATAIDX_ERR;
283     }
284     }
285 greg 2.1
286 rschregle 2.3 return OOC_DATACNT(node);
287 greg 2.1 }
288 rschregle 2.3
289 greg 2.1
290
291 rschregle 2.3 OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax, unsigned maxDepth)
292     /* Bottom-up construction of out-of-core octree in postorder traversal. The
293     * octree oct is assumed to be initialised with its origin (oct -> org),
294     * size (oct -> size), key callback (oct -> key), and its associated leaf
295     * file (oct -> leafFile).
296
297     * Records are read from the leafFile and assumed to be sorted in Z-order,
298     * which defines an octree leaf ordering. Leaves (terminal nodes) are
299     * constructed such that they contain <= leafMax records and have a maximum
300     * depth of maxDepth.
301
302     * Note that the following limits apply:
303     * leafMax <= OOC_OCTCNT_MAX (see oococt.h)
304     * maxDepth <= OOC_MORTON_BITS (see oocsort.h)
305
306     * The maxDepth limit arises from the fact that the Z-ordering has a limited
307     * resolution and will map node coordinates beyond a depth of
308     * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially read
309     * out of sequence and winding up in the wrong octree nodes.
310
311     * On success, the octree pointer oct is returned, with the constructed
312     * nodes in oct -> nodes, and the node count in oct -> numNodes. On
313     * failure, NULL is returned. */
314 greg 2.1 {
315     OOC_BuildQueue queue;
316 rschregle 2.3 OOC_Node root;
317 greg 2.1
318 rschregle 2.3 if (!oct || !oct -> size) {
319     fputs("OOC_Build: octree not initialised", stderr);
320 greg 2.1 return NULL;
321     }
322 rschregle 2.3
323     if (!oct -> leafFile) {
324     fputs("OOC_Build: empty leaf file", stderr);
325 greg 2.1 return NULL;
326     }
327 rschregle 2.3
328     oct -> leafMax = leafMax;
329     oct -> maxDepth = maxDepth;
330     queue.in = oct -> leafFile;
331     rewind(queue.in);
332
333     /* Init queue and fill from leaf file */
334     if (!QueueInit(&queue, oct -> recSize, leafMax + 1) ||
335     QueueFill(&queue) < 0) {
336     fputs("OOC_Build: failed input queue init\n", stderr);
337 greg 2.1 return NULL;
338     }
339 rschregle 2.3
340     /* Clear octree root and recurse */
341     OOC_CLEARNODE(&root);
342     if (OOC_BuildRecurse(oct, &root, oct -> org, oct -> size, 0, &queue) ==
343     OOC_DATAIDX_ERR)
344 greg 2.1 return NULL;
345 rschregle 2.3
346     /* Finalise octree root */
347     if (!NewNode(oct)) {
348     fputs("OOC_Build: failed to allocate octree root\n", stderr);
349 greg 2.1 return NULL;
350 rschregle 2.3 }
351     OOC_SETROOT(oct, &root);
352     /* Passing OOC_ROOT(oct) avoids annoying compiler warnings about (&root)
353     * always evaluating to true when calling OOC_DATAIDX() */
354     oct -> numData = OOC_DATACNT(OOC_ROOT(oct));
355 greg 2.1
356     return oct;
357     }
358 rschregle 2.4
359     #endif /* NIX / PMAP_OOC */
